3.18. sample_trustzone Usage Guide
3.18.1. Function Overview
sample_trustzone provides simple example code for both TA and CA. Users can learn how to create and use TA and CA for command interaction through sample_ta and sample_ca.
sample_ta implements three custom commands to handle integer and string data types:
Increment command
TA_SAMPLE_CMD_INC_VALUE: The TA increments the input value by 1 and returns it to the CA.Decrement command
TA_SAMPLE_CMD_DEC_VALUE: The TA decrements the input value by 1 and returns it to the CA.String echo command
TA_SAMPLE_CMD_ECHO_STR: The TA appends[TA]to the input string and echoes it back to the CA.
3.18.1.1. Software Architecture Description
3.18.1.2. Code Location and Directory Structure
Code location:
app/samples/platform_samples/sample_trustzoneDirectory structure
sample_trustzone
├── sample_ca
│ ├── Makefile
│ └── sample_ca.c
└── sample_ta
├── include
│ └── sample_ta.h
├── sample_ta.c
├── sub.mk
└── user_ta_header_defines.h
3.18.1.3. API Process Description
3.18.2. Compilation
The following sections describe the compilation methods for sample_ta and sample_ca respectively.
3.18.2.1. sample_ta Compilation
Copy sample_ta source code
Note: sample_ta is not compiled directly under the platform_samples directory. It needs to be copied to miniboot/optee/hobot_tee_devkit/ta/customer for compilation.
Use the following command:
cp app/samples/platform_samples/sample_trustzone/sample_ta miniboot/optee/hobot_tee_devkit/ta/customer/ -rf
Generate UUID
This step can be skipped if using the UUID provided in the example.
Multiple TAs can coexist in the system, each requiring a unique UUID.
UUIDs can be generated at: https://www.uuidgenerator.net/
As shown above, the generated UUID value is ed53d67d-4e58-4b9a-8514-0a61c3c94401.
Configure UUID
The UUID generated in the previous step must be inserted into the following source files.
File path: sample_ta/include/sample_ta.h
#define TA_SAMPLE_UUID \
{ 0xed53d67d, 0x4e58, 0x4b9a, \
{ 0x85, 0x14, 0x0a, 0x61, 0xc3, 0xc9, 0x44, 0x01} }
File path: sample_ta/Makefile
# The UUID for the Trusted Application
BINARY=ed53d67d-4e58-4b9a-8514-0a61c3c94401
Add sample_ta to build options
Modify miniboot/optee/hobot_tee_devkit/ta/customer/Makefile and append sample_ta to the variable CTA_DIRS:
CTA_DIRS := sample_ta
Compile
Run the command ./bd.sh miniboot at the SDK root directory to automatically compile sample_ta.
The compiled output will be located at miniboot/optee/hobot_tee_devkit/out/ta/sample_ta.
The TA executable follows the naming rule [UUID].ta. Based on the UUID configured earlier, the file will be named ed53d67d-4e58-4b9a-8514-0a61c3c94401.ta.
3.18.2.2. sample_ca Compilation
Configure UUID
The CA specifies the TA to invoke via UUID, so the TA’s UUID must be configured in the code.
// Match the TA UUID configured in the previous step
TEEC_UUID uuid = { 0xed53d67d, 0x4e58, 0x4b9a, \
{ 0x85, 0x14, 0x0a, 0x61, 0xc3, 0xc9, 0x44, 0x01} };
// ...(code omitted)...
// Pass the UUID when opening the session
res = TEEC_OpenSession(&ctx, &sess, &uuid,
TEEC_LOGIN_PUBLIC, NULL, NULL, &err_origin);
Compile
Run the make command in the sample_ca source directory to complete compilation:
cd /app/samples/platform_samples/sample_trustzone/sample_ca
make
For detailed compilation instructions, refer to the Compilation Method section.
3.18.3. Deployment
The following sections describe the deployment methods for sample_ta and sample_ca respectively.
3.18.3.1. sample_ta Deployment
Copy the compiled sample_ta binary from the previous step to the directory out/deploy/system/usr/lib/optee_armtz.
Run ./bd.sh system to package the sample_ta binary into the system partition.
After flashing the system image, the sample_ta file will be located on the device at: /usr/lib/optee_armtz.
3.18.3.2. sample_ca Deployment
After flashing the system image, the sample_ca executable will be located on the device at: /app/platform_samples/sample_trustzone/sample_ca.
3.18.4. Execution
3.18.4.1. Program Execution Method
Run the program directly with
./sample_ca -hto get help information:
3.18.4.2. Program Parameter Options
Usage: sample_ca [OPTIONS] [value]
-i <value> Increase value From TA
-d <value> Decrease value From TA
-c <string> Echo string From TA
-h Show this help message
i <value>: The TA increments the input value by 1 and returns it to the CA.d <value>: The TA decrements the input value by 1 and returns it to the CA.c <string>: The TA appends[TA]to the input string and echoes it back to the CA.h: Display help message.
3.18.4.3. Execution Results
Verify Increment Command
Run the command ./sample_ca -i 10 to pass 10 to sample_ta.
The printed log is as follows:
Establish Context with OP-TEE!
Establish Session with TA!
I/TC: RPMB: Using generated key
D/TA: TA_CreateEntryPoint:39 has been called
D/TA: TA_OpenSessionEntryPoint:68 has been called
D/TA: inc_value:105 has been called
I/TA: Got value: 10 from NW
I/TA: Increase value to: 11
TA incremented value to 11
Disconnect Session with TA!
D/TA: TA_DestroyEntryPoint:50 has been called
Disconnect Context with OP-TEE!
It can be seen that the TA processed and returned the value 11 to the CA.
Verify Decrement Command
Run the command ./sample_ca -d 10 to pass 10 to sample_ta.
D/TA: dec_value:125 has been called
I/TA: Decrease value to: 9
TA incremented value to 9
It can be seen that the TA processed and returned the value 9 to the CA.
Verify String Echo Command
Run the command ./sample_ca -c hello to pass the string to sample_ta.
D/TA: echo_str:146 has been called
I/TA: Got sting from NW: hello
TA Echo: hello[TA]
It can be seen that the TA processed and returned the string hello[TA] to the CA.
3.18.5. Common Issues
3.18.5.1. CA Program Fails to Call TA with “Verify key” Error
Solution:
TA loading depends on the user root key.
For instructions on burning the user root key, please refer to efuse
