Version
3.2. sample_vin Instructions
3.2.1. get_vin_data
3.2.1.1. Function Overview
get_vin_data completes the initialization of the Camera Sensor, MIPI CSI, and SIF modules, enabling the retrieval of video frame data from the VIN module. It supports acquiring images in either Raw or YUV format from the VIN module.
  • Code location: app/samples/platform_samples/sample_vin/get_vin_data
  • Directory structure
sample_vin/
└── get_vin_data
    ├── get_vin_data.c
    └── Makefile
API Flow Description
3.2.1.2. Build and Deployment
Build
  • Enter the get_vin_data directory and run make to compile.
  • The output is the executable get_vin_data located in the source directory.
  • For detailed compilation methods, refer to the Build Methods section.
Program Deployment
After flashing the system software image, the executable file of this sample is located on the board at: /app/platform_samples/sample_vin/get_vin_data.
3.2.1.3. Run
How to Run the Program
  • Run ./get_vin_data -h to display help information.
  • Run ./get_vin_data -s 3 to start with sensor index 3 (sc230ai-30fps as example).
  • Run ./get_vin_data -s 3 -f 15 to specify the sensor index and configure a target FPS of 15.
  • After launch, the program enters interactive mode. See section 3.2.3.3 for execution results.
    Note: This sample implements frame skipping via SIF hardware (indirectly changing the sensor output frame rate) and supports configuring skip parameters both at init and at runtime:
    1. -f command-line option: configures skip parameters at initialization.
    2. s interactive command: configures skip parameters dynamically at runtime.
Program Option Descriptions
Usage: get_vin_data [OPTIONS]
  -s <sensor_index>      Specify sensor index
  -m <sensor_mode>       Specify sensor mode of camera_config_t, support 'm' and 's'
                m: Master
                s: Slave
                The default value is determined by the configuration in vp_sensor
  -e <extern_param>          Specify extension parameters through a JSON file
  -f <target_fps>        Specify target output FPS (0 = disable, sensor native)
index: 0  sensor_name: sc1330t                  config_file:linear_1280x960_raw10_30fps_1lane.c
index: 1  sensor_name: irs2875-tof              config_file:linear_208x1413_raw12_15fps_2lane.c
index: 2  sensor_name: sc230ai-10fps            config_file:linear_1920x1080_raw10_10fps_1lane.c
index: 3  sensor_name: sc230ai-30fps            config_file:linear_1920x1080_raw10_30fps_1lane.c
index: 4  sensor_name: sc230ai-dol2-30fps       config_file:dol2_1920x1080_raw10_30fps_2lane.c
index: 5  sensor_name: sc132gs-1280p            config_file:linear_1088x1280_raw10_60fps_1lane.c
index: 6  sensor_name: sc132gs-hdr-2lane        config_file:hdr_1088x1280_raw10_30fps_2lane.c
index: 7  sensor_name: sc035hgs                 config_file:linear_640x480_raw10_30fps_1lane.c
index: 8  sensor_name: sc035hgs_mono            config_file:linear_mono_640x480_raw10_30fps_1lane.c
index: 9  sensor_name: ov5640                   config_file:linear_1920x1080_raw10_30fps_2lane.c
index: 10  sensor_name: f37                     config_file:linear_1920x1080_raw10_30fps_1lane.c
index: 11  sensor_name: imx415-30fps-2lane      config_file:linear_3840x2160_raw10_30fps_2lane.c
index: 12  sensor_name: imx415-30fps-4lane      config_file:linear_3840x2160_raw10_30fps_4lane.c
index: 13  sensor_name: sc202cs-1600x1200       config_file:linear_1600x1200_raw10_30fps_1lane.c
index: 14  sensor_name: irs2381c-tof            config_file:linear_224x1903_raw12_5fps_2lane.c
index: 15  sensor_name: sc035hgs-vc0            config_file:linear_640x480_raw10_30fps_2lane_vc0.c
index: 16  sensor_name: sc035hgs-vc1            config_file:linear_640x480_raw10_30fps_2lane_vc1.c
index: 17  sensor_name: sc231ai-30fps           config_file:linear_1920x1080_raw10_30fps_2lane.c
index: 18  sensor_name: imx586-30fps-4lane      config_file:linear_3840x2160_raw10_30fps_4lane.c
index: 19  sensor_name: os08c10-30fps-2lane     config_file:linear_3840x2160_raw12_30fps_2lane.c
index: 20  sensor_name: ar0233-30fps            config_file:linear_1920x1080_raw12_30fps_2lane.c
index: 21  sensor_name: ar0820std-30fps         config_file:linear_3840x2160_yuv422_30fps_4lane.c
index: 22  sensor_name: sc1336                  config_file:linear_1280x720_raw10_15fps_2lane.c
index: 23  sensor_name: dummy                   config_file:dummy_sensor.c
index: 24  sensor_name: ar0233-30fps            config_file:ar0233_linear_1920x1080_raw12_30fps_2lane_vc0.c
index: 25  sensor_name: ar0233-30fps            config_file:ar0233_linear_1920x1080_raw12_30fps_2lane_vc1.c
index: 26  sensor_name: ov9782-200fps-2lane     config_file:linear_640x360_raw10_200fps_2lane.c
index: 27  sensor_name: ov9782-120fps-2lane     config_file:linear_1280x720_raw10_120fps_2lane.c
index: 28  sensor_name: imx219-640x480-30fps    config_file:linear_640x480_raw10_30fps_2lane.c
index: 29  sensor_name: imx219-1632x1232-30fps  config_file:linear_1632x1232_raw10_30fps_2lane.c
index: 30  sensor_name: imx219-1920x1080-30fps  config_file:linear_1920x1080_raw10_30fps_2lane.c
index: 31  sensor_name: imx219-3264x2464-15fps  config_file:linear_3264x2464_raw10_15fps_2lane.c
index: 32  sensor_name: imx219-3264x2464-21fps  config_file:linear_3264x2464_raw10_21fps_2lane.c
index: 33  sensor_name: ov5647-640x480-60fps    config_file:linear_640x480_raw10_60fps_2lane.c
index: 34  sensor_name: ov5647-1280x960-30fps   config_file:linear_1280x960_raw10_30fps_2lane.c
index: 35  sensor_name: ov5647-1920x1080-30fps  config_file:linear_1920x1080_raw10_30fps_2lane.c
index: 36  sensor_name: ov5647-2592x1944-15fps  config_file:linear_2592x1944_raw10_15fps_2lane.c
index: 37  sensor_name: imx678-30fps-4lane      config_file:linear_3840x2160_raw12_30fps_4lane.c
index: 38  sensor_name: imx678-30fps-4lane-dol2 config_file:dol2_3840x2160_raw12_30fps_4lane.c
index: 39  sensor_name: imx477-1280x960-120fps  config_file:linear_1280x960_raw10_120fps_2lane.c
index: 40  sensor_name: imx477-1920x1080-50fps  config_file:linear_1920x1080_raw12_50fps_2lane.c
index: 41  sensor_name: imx477-2016x1520-21fps  config_file:linear_2016x1520_raw12_21fps_2lane.c
index: 42  sensor_name: imx477-4000x3000-10fps  config_file:linear_4000x3000_raw12_10fps_2lane.c
index: 43  sensor_name: ov50h40-30fps-4lane     config_file:linear_4096x3072_raw10_30fps_4lane.c
index: 44  sensor_name: ox05b1s                 config_file:linear_2592x1944_raw10_30fps_4lane.c
index: 45  sensor_name: ox05b1s_2lane           config_file:linear_2592x1944_raw10_10fps_2lane.c
index: 46  sensor_name: imx415-60fps-4lane      config_file:linear_3840x2160_raw10_60fps_4lane.c
index: 47  sensor_name: sc850sl-30fps           config_file:linear_3840x2160_raw10_30fps_4lane.c
index: 48  sensor_name: shw3g-30fps             config_file:linear_2064x1552_raw12_30fps_4lane.c
index: 49  sensor_name: shw3g-30fps_vc1         config_file:linear_2064x1552_raw12_30fps_4lane_vc1.c
index: 50  sensor_name: sc235hai-30fps          config_file:linear_1920x1080_raw10_30fps_2lane.c
index: 51  sensor_name: cv4006-60fps-2lane      config_file:linear_1280x720_raw10_60fps_2lane.c
index: 52  sensor_name: ov50h40-30fps-4lane     config_file:linear_3840x2160_raw10_30fps_4lane.c
index: 53  sensor_name: ov50h40-30fps-4lane     config_file:linear_4096x3072_raw14_30fps_4lane.c
index: 54  sensor_name: sc132gs-slave-right     config_file:linear_1088x1280_raw10_30fps_slave_1lane_right.c
index: 55  sensor_name: sc132gs-slave-left      config_file:linear_1088x1280_raw10_30fps_slave_1lane_left.c
index: 56  sensor_name: sc132gsstd_vc0          config_file:linear_1088x1280_raw10_10fps_1lane_vc0.c
index: 57  sensor_name: sc132gsstd_vc1          config_file:linear_1088x1280_raw10_10fps_1lane_vc1.c
index: 58  sensor_name: sc132gsstd_vc2          config_file:linear_1088x1280_raw10_10fps_1lane_vc2.c
index: 59  sensor_name: sc132gsstd_vc3          config_file:linear_1088x1280_raw10_10fps_1lane_vc3.c
index: 60  sensor_name: imx415-30fps-4lane-dol2 config_file:dol2_3840x2160_raw10_30fps_4lane.c
index: 61  sensor_name: isx031-30fps-vc0        config_file:isx031_linear_1920x1536_yuv422_30fps_4lane_vc0.c
index: 62  sensor_name: isx031-30fps-vc1        config_file:isx031_linear_1920x1536_yuv422_30fps_4lane_vc1.c
index: 63  sensor_name: isx031-30fps-vc2        config_file:isx031_linear_1920x1536_yuv422_30fps_4lane_vc2.c
index: 64  sensor_name: isx031-30fps-vc3        config_file:isx031_linear_1920x1536_yuv422_30fps_4lane_vc3.c
  • s <sensor_index>: Specifies the camera sensor index to use. Can be specified multiple times (up to 4 sensors).
  • m <sensor_mode>: Specifies the sensor mode in the camera configuration.
  • e <extern_param>: Specifies a JSON format file used to quickly change parameters during the camera sensor power-up stage. For details, see the following files in the get_vin_data source directory: sensor_param_sample1.json, sensor_param_sample2.json, sensor_param_sample3.json.
  • f <target_fps>: Specifies the target output frame rate via SIF hardware. If not configured, the default frame rate is used. The configurable range is 1 to the default frame rate (e.g. for a 30fps sensor, the valid range is 1 to 30).
  • h: Displays help message.
List of currently supported sensors and their corresponding configuration files:
Index Sensor Name Configuration File
0 sc1330t linear_1280x960_raw10_30fps_1lane.c
1 irs2875-tof linear_208x1413_raw12_15fps_2lane.c
2 sc230ai-10fps linear_1920x1080_raw10_10fps_1lane.c
3 sc230ai-30fps linear_1920x1080_raw10_30fps_1lane.c
4 sc230ai-dol2-30fps dol2_1920x1080_raw10_30fps_2lane.c
5 sc132gs-1280p linear_1088x1280_raw10_60fps_1lane.c
6 sc132gs-hdr-2lane hdr_1088x1280_raw10_30fps_2lane.c
7 sc035hgs linear_640x480_raw10_30fps_1lane.c
8 sc035hgs_mono linear_mono_640x480_raw10_30fps_1lane.c
9 ov5640 linear_1920x1080_raw10_30fps_2lane.c
10 f37 linear_1920x1080_raw10_30fps_1lane.c
11 imx415-30fps-2lane linear_3840x2160_raw10_30fps_2lane.c
12 imx415-30fps-4lane linear_3840x2160_raw10_30fps_4lane.c
13 sc202cs-1600x1200 linear_1600x1200_raw10_30fps_1lane.c
14 irs2381c-tof linear_224x1903_raw12_5fps_2lane.c
15 sc035hgs-vc0 linear_640x480_raw10_30fps_2lane_vc0.c
16 sc035hgs-vc1 linear_640x480_raw10_30fps_2lane_vc1.c
17 sc231ai-30fps linear_1920x1080_raw10_30fps_2lane.c
18 imx586-30fps-4lane linear_3840x2160_raw10_30fps_4lane.c
19 os08c10-30fps-2lane linear_3840x2160_raw12_30fps_2lane.c
20 ar0233-30fps linear_1920x1080_raw12_30fps_2lane.c
21 ar0820std-30fps linear_3840x2160_yuv422_30fps_4lane.c
22 sc1336 linear_1280x720_raw10_15fps_2lane.c
23 dummy dummy_sensor.c
24 ar0233-30fps ar0233_linear_1920x1080_raw12_30fps_2lane_vc0.c
25 ar0233-30fps ar0233_linear_1920x1080_raw12_30fps_2lane_vc1.c
26 ov9782-200fps-2lane linear_640x360_raw10_200fps_2lane.c
27 ov9782-120fps-2lane linear_1280x720_raw10_120fps_2lane.c
28 imx219-640x480-30fps linear_640x480_raw10_30fps_2lane.c
29 imx219-1632x1232-30fps linear_1632x1232_raw10_30fps_2lane.c
30 imx219-1920x1080-30fps linear_1920x1080_raw10_30fps_2lane.c
31 imx219-3264x2464-15fps linear_3264x2464_raw10_15fps_2lane.c
32 imx219-3264x2464-21fps linear_3264x2464_raw10_21fps_2lane.c
33 ov5647-640x480-60fps linear_640x480_raw10_60fps_2lane.c
34 ov5647-1280x960-30fps linear_1280x960_raw10_30fps_2lane.c
35 ov5647-1920x1080-30fps linear_1920x1080_raw10_30fps_2lane.c
36 ov5647-2592x1944-15fps linear_2592x1944_raw10_15fps_2lane.c
37 imx678-30fps-4lane linear_3840x2160_raw12_30fps_4lane.c
38 imx678-30fps-4lane-dol2 dol2_3840x2160_raw12_30fps_4lane.c
39 imx477-1280x960-120fps linear_1280x960_raw10_120fps_2lane.c
40 imx477-1920x1080-50fps linear_1920x1080_raw12_50fps_2lane.c
41 imx477-2016x1520-21fps linear_2016x1520_raw12_21fps_2lane.c
42 imx477-4000x3000-10fps linear_4000x3000_raw12_10fps_2lane.c
43 ov50h40-30fps-4lane linear_4096x3072_raw10_30fps_4lane.c
44 ox05b1s linear_2592x1944_raw10_30fps_4lane.c
45 ox05b1s_2lane linear_2592x1944_raw10_10fps_2lane.c
46 imx415-60fps-4lane linear_3840x2160_raw10_60fps_4lane.c
47 sc850sl-30fps linear_3840x2160_raw10_30fps_4lane.c
48 shw3g-30fps linear_2064x1552_raw12_30fps_4lane.c
49 shw3g-30fps_vc1 linear_2064x1552_raw12_30fps_4lane_vc1.c
50 sc235hai-30fps linear_1920x1080_raw10_30fps_2lane.c
51 cv4006-60fps-2lane linear_1280x720_raw10_60fps_2lane.c
52 ov50h40-30fps-4lane linear_3840x2160_raw10_30fps_4lane.c
53 ov50h40-30fps-4lane linear_4096x3072_raw14_30fps_4lane.c
54 sc132gs-slave-right linear_1088x1280_raw10_30fps_slave_1lane_right.c
55 sc132gs-slave-left linear_1088x1280_raw10_30fps_slave_1lane_left.c
56 sc132gsstd_vc0 linear_1088x1280_raw10_10fps_1lane_vc0.c
57 sc132gsstd_vc1 linear_1088x1280_raw10_10fps_1lane_vc1.c
58 sc132gsstd_vc2 linear_1088x1280_raw10_10fps_1lane_vc2.c
59 sc132gsstd_vc3 linear_1088x1280_raw10_10fps_1lane_vc3.c
60 imx415-30fps-4lane-dol2 dol2_3840x2160_raw10_30fps_4lane.c
61 isx031-30fps-vc0 isx031_linear_1920x1536_yuv422_30fps_4lane_vc0.c
62 isx031-30fps-vc1 isx031_linear_1920x1536_yuv422_30fps_4lane_vc1.c
63 isx031-30fps-vc2 isx031_linear_1920x1536_yuv422_30fps_4lane_vc2.c
64 isx031-30fps-vc3 isx031_linear_1920x1536_yuv422_30fps_4lane_vc3.c
Execution Results
Single Sensor Mode
  1. Based on the prompt, select the sensor name currently connected to the development board. Taking sc230ai-30fps as an example, run ./get_vin_data -s 3.
  2. Use -f <fps> to specify the target output frame rate, e.g. ./get_vin_data -s 3 -f 15 to output at 15fps.
  3. After executing the command, it automatically loads the sc230ai-30fps configuration file linear_1920x1080_raw10_30fps_1lane.c to initialize the Camera Sensor, MIPI CSI, and SIF modules.
  4. After initialization, the system enters interactive mode. The prompt displays each sensor’s short name and current output frame rate, e.g. Command [sc230ai:30fps]:.
Execution commands:
cd sample_vin/get_vin_data
chmod +x get_vin_data
./get_vin_data -s 3
Execution log:
  • g: Get one frame. Multiple ‘g’ inputs are supported for continuous image capture. For example, entering gggg will capture 4 images.
mipi mclk is configed.
INFO: Found sensor_name:sc230ai-30fps on mipi rx csi 0, i2c addr 0x30, config_file:linear_1920x1080_raw10_30fps_1lane.c
Not config sensor mode, so use default mode.
 g      -- get single frame
 l      -- get a set frames
 f      -- check frame rate and compare with configured fps
 s      -- set target FPS
 q      -- quit
 h      -- print help message
Command [sc230ai:30fps]: g
Dumping RAW data: handle 34661, resolution: 1920x1080 (stride: 3840), size: 4147200, frame id: 0, timestamp: 320230295485
Dump image to file(handle_34661_chn0_vc0_1920x1080_stride_3840_frameid_0_ts_320230295485.raw), size(4147200) succeeded
  • l: Continuously capture 12 frames, equivalent to entering 12 ‘g’ commands.
Command [sc230ai:30fps]: l
Dumping RAW data: handle 34661, resolution: 1920x1080 (stride: 3840), size: 4147200, frame id: 1, timestamp: 46024435294737
Dump image to file(handle_34661_chn0_vc0_1920x1080_stride_3840_frameid_1_ts_46024435294737.raw), size(4147200) succeeded
... (omitted, total of 12 frames dumped) ...
Dumping RAW data: handle 34661, resolution: 1920x1080 (stride: 3840), size: 4147200, frame id: 424, timestamp: 46038535296244
Dump image to file(handle_34661_chn0_vc0_1920x1080_stride_3840_frameid_424_ts_46038535296244.raw), size(4147200) succeeded
  • f: Calculate the actual frame rate and determine whether the configured frame rate is correct.
Command [sc230ai:30fps]: f
======================== Frame Rate Check =======================
Sensor sc230ai-30fps: Target FPS = 30fps
Statistics (timestamp): Average FPS = 30.25
First frame_id = 130, Last frame_id = 281, Frame count = 152
First timestamp = 116917846862208, Last timestamp = 116922871251586
Sensor sc230ai-30fps: Frame rate check: Success
=================== Frame Rate Check Complete ===================
  • s: Set the target output frame rate. Select the sensor index first, then enter the target FPS. Use f to verify afterward.
Command [sc230ai:12fps]: s
Enter sensor index (0..0): 0
Enter target FPS (0 = disable skip, restore native): 13
[FPS] Sensor[sc230ai] 30 -> 13 fps
Use 'f' to check frame rate
  • q: Quit the program.
Command [sc230ai:30fps]: q
quit
Multi-Sensor Mode
The -s option can be specified multiple times, up to 4 sensors simultaneously. -f applies to the most recent -s preceding it, allowing per-sensor FPS configuration. For example, ./get_vin_data -s 2 -f 5 -s 60 -f 15 sets sensor 2 to 5fps and sensor 60 to 15fps.
The following is the startup log for ./get_vin_data -s 2 -s 60, where each sensor independently completes CSI detection and initialization:
Using index:2  sensor_name:sc230ai-10fps  config_file:linear_1920x1080_raw10_10fps_1lane.c
INFO: Found sensor_name:sc230ai-10fps on mipi rx csi 2, i2c addr 0x30, config_file:linear_1920x1080_raw10_10fps_1lane.c
Using index:60  sensor_name:imx415-30fps-4lane-dol2  config_file:dol2_3840x2160_raw10_30fps_4lane.c
INFO: Found sensor_name:imx415-30fps-4lane-dol2 on mipi rx csi 0, i2c addr 0x1a, config_file:dol2_3840x2160_raw10_30fps_4lane.c
 s      -- set target FPS
 q      -- quit
Command [sc230ai:10fps, imx415:30fps]:
  • g: Get one frame from each sensor.
Command [sc230ai:10fps, imx415:30fps]: g
Dumping RAW data: handle 34661, resolution: 1920x1080 (stride: 3840), size: 4147200, frame id: 500, timestamp: 36387692251350
Dump image to file(handle_34661_chn0_vc0_1920x1080_stride_3840_frameid_500_ts_36387692251350.raw), size(4147200) succeeded
Dumping RAW data: handle 100197, resolution: 3840x2160 (stride: 7680), size: 16588800, frame id: 1631, timestamp: 36392514268144
Dump image to file(handle_100197_chn0_vc0_3840x2160_stride_7680_frameid_1631_ts_36392514268144.raw), size(16588800) succeeded
  • l: Continuously capture 12 frames from each sensor.
Command [sc230ai:10fps, imx415:30fps]: l
Dumping RAW data: handle 34661, resolution: 1920x1080 (stride: 3840), size: 4147200, frame id: 504, timestamp: 36388092014976
Dump image to file(handle_34661_chn0_vc0_1920x1080_stride_3840_frameid_504_ts_36388092014976.raw), size(4147200) succeeded
Dumping RAW data: handle 100197, resolution: 3840x2160 (stride: 7680), size: 16588800, frame id: 1633, timestamp: 36392580945394
Dump image to file(handle_100197_chn0_vc0_3840x2160_stride_7680_frameid_1633_ts_36392580945394.raw), size(16588800) succeeded
... (omitted, 12 frames dumped per sensor) ...
  • f: Check frame rate for each sensor, separated by ---.
Command [sc230ai:10fps, imx415:30fps]: f
Sensor sc230ai-10fps: Target FPS = 10fps
Statistics (timestamp): Average FPS = 10.20
First frame_id = 191, Last frame_id = 242, Frame count = 52
First timestamp = 117070885035740, Last timestamp = 117075982024326
Sensor sc230ai-10fps: Frame rate check: Success
Sensor imx415-30fps-4lane-dol2: Target FPS = 30fps
Statistics (timestamp): Average FPS = 30.20
First frame_id = 714, Last frame_id = 864, Frame count = 151
First timestamp = 117076018166701, Last timestamp = 117081018969245
Sensor imx415-30fps-4lane-dol2: Frame rate check: Success
  • s: In multi-sensor mode, select the sensor index first, then enter the target FPS.
Command [sc230ai:10fps, imx415:30fps]: s
Enter sensor index (0..1): 0
Enter target FPS (0 = disable skip, restore native): 7
[FPS] Sensor[sc230ai] 10 -> 7 fps
Command [sc230ai:7fps, imx415:30fps]: s
Enter sensor index (0..1): 1
Enter target FPS (0 = disable skip, restore native): 15
[FPS] Sensor[imx415] 30 -> 15 fps
Execution Result Explanation
After running the program, Raw images with filenames in the format like handle_34661_chn0_vc0_1920x1080_stride_3840_frameid_424_ts_46038535296244.raw will be obtained.
Refer to the Hobot Player Static Image section to view the images. The image parameter configuration is described as follows:
  • Viewing RAW Images
Configure the options as shown in the figure below. Pay attention to the settings in the file config, including pic_type, raw_type, pix_length, width, and height. For sc1330t, set to (PIC_RAW, UNPACKET_RAW, RAW_MIPI_BIT_10, 1920, 1080).
view_raw_tool_EN
3.2.1.4. Common Issues
1. “No Camera Sensor found” displayed
  • Cause Analysis:
    1. The actual camera model connected to the board does not match the camera specified by ./get_vin_data -s.
    2. Poor FPC cable contact or loose interface causes test abnormalities.
  • Solutions:
    1. Ensure the actual connected camera matches the camera specified by ./get_vin_data -s.
    2. Check the FPC cable connection and ensure the interface is securely connected.
3.2.2. time_synchronization
3.2.2.1. Function Overview
time_synchronization demonstrates the function of time synchronization between the camera and other peripherals.
  1. The camera’s timestamp is set through the SIF module, and the camera’s timestamp can be obtained via the hbn_frame_info_t structure.
  2. There are 4 timestamps in hbn_frame_info_t, described as follows:
Field Meaning Source Affected by NTP
timestamps Kernel timestamp at SIF frame start interrupt, counts from system boot ktime_get_raw_ns() No
sys_timestamps Wall clock time at SIF frame start interrupt (Unix nanoseconds) ktime_get_real_ns() Yes
tv Hardware timestamp latched by SIF at the SIF frame start moment SIF IPI_TS_VSYNC register No
trig_tv Hardware timestamp latched by SIF at the LPWM rising edge moment SIF IPI_TS_TRIG register No
The field parameters of the time-stamp configuration-related structure vin_node_attr.cim_attr.func are as follows:
Field Description
enable_frame_id Whether to enable frame_id; only after enabling can getframe obtain frame_id
time_stamp_en Whether to enable the SIF hardware timestamp; only after enabling do trig_tv/tv have values; does not affect timestamps/sys_timestamps
time_stamp_mode SIF latching type, bitmask combinable: 0x01=VSYNC (latch tv), 0x02=TRIGGER (latch trig_tv), 0x03=latch both (recommended)
ts_src Source that triggers SIF latching, 1-8 correspond to LPWM0/1 channels, must match the LPWM connected to hardware trigger exposure
Method for time synchronization with other sensors:
  1. Other sensors can use ktime_get_raw_ns or ktime_get_real_ns to obtain timestamps.
  2. The camera selects the timestamp with the same time base as the other sensor for computation.
Note: If the camera selects the LPWM-moment timestamp, the following computation is required
Use timestamps - (tv - trig_tv) to obtain the exposure-moment timestamp based on timestamps
Key points:
  • timestamps is raw monotonic counted from system boot, not affected by NTP frequency adjustment, suitable as a stable userspace synchronization baseline.
  • sys_timestamps is wall clock time, may jump due to NTP adjustment, not recommended as a synchronization baseline, only suitable for cross-device alignment scenarios such as logging/auditing.
  • trig_tv: latched at the moment the LPWM trigger pulse edge reaches SIF (the pulse is split into two paths simultaneously: one to the sensor to trigger exposure, one to SIF for timestamp latching; trig_tv marks the moment the latter reaches SIF, which is not equal to the moment the sensor actually starts exposure).
  • tv: latched at the moment the MIPI VSYNC (frame start signal) edge reaches SIF, read out from the register by the SIF frame start interrupt.
    • Both are latched into registers by the AON RTC (Always-On domain hardware counter, driven by the 24M crystal) at the signal edge; software reads the raw tick from the register in the frame start interrupt, then converts it to tv_sec/tv_usec (1 us precision) according to timestamp_clk and fills it into the buffer. Not affected by NTP.
    • tv - trig_tv is the inherent delay from “LPWM trigger pulse arrival” to “MIPI frame start signal arrival” (including sensor exposure + readout + MIPI transfer).
  • Code location: app/samples/platform_samples/sample_vin/time_synchronization
app/samples/platform_samples/sample_vin/time_synchronization/
└── time_synchronization
    ├── time_synchronization.c
time_synchronization is implemented based on the VIN pipeline, the main flow is as follows:
  1. Parse command line parameters, verify the sensor mode (-m selects master/slave; if not specified, the sensor config default mode is used).
  2. auto_fill_ts_src reads lpwm_chn from the device tree, sets ts_src/time_stamp_en/time_stamp_mode (SLAVE mode latches tv+trig_tv; non-SLAVE latches tv only).
  3. Create the VIN pipeline (hbn_camera_create / hbn_vnode_* / hbn_vflow_*), enable LPWM in SLAVE mode.
  4. hbn_vnode_getframe() gets one frame, reads the four timestamps.
  5. Print the four timestamp values, clock domain description, and exposure-to-mipi delay (tv - trig_tv).
  6. hbn_vnode_releaseframe() releases the frame; release VIN resources on exit.
3.2.2.2. Build and Deployment
Build
  • Enter the time_synchronization directory and run make to compile
  • The output is time_synchronization in the source directory
Program Deployment
After flashing the system software image, the executable file of this sample is located on the board at: /app/platform_samples/sample_vin/time_synchronization.
The sensor index can be viewed via the -h parameter; select the sensor actually connected to the board, e.g., sc230ai-10fps corresponds to index 2.
3.2.2.3. Run
./time_synchronization -s 2 -m s
After starting, the program enters an interactive command menu: press g to grab a single frame, l to grab 12 consecutive frames, q to quit, h for help.
./time_synchronization [-s <index> -m <m|s>] [-h]
  • -s <index> (required): sensor index, view the list via -h
  • m <m|s> (optional): sensor mode
  • -h: show help
Interactive commands:
Command Description
g Grab one frame and print four timestamps
l Grab 12 consecutive frames and print timestamps
q Quit the program
h Show command help
Execution Results
Sensor index=2  name=sc230ai-10fps  config=linear_1920x1080_raw10_10fps_1lane.c
[INFO] RDK board_id is 0x0503, so skip csi test for index 1 and index 3
mipi mclk is not configed.
Searching camera sensor on device: /proc/device-tree/soc/cam/vcon@0 i2c bus: 6 mipi rx phy: 0
INFO: Found sensor_name:sc230ai-10fps on mipi rx csi 0, i2c addr 0x30, config_file:linear_1920x1080_raw10_10fps_1lane.c
Sensor mode: SLAVE_M
vcon@0: lpwm_chn=4 -> ts_src=5, time_stamp_en=1, mode=0x03
csi0: no mclk configured, skip mclk attr.
 g  -- grab one frame and print four timestamps
 l  -- grab 12 frames and print timestamps
 q  -- quit
 h  -- this help
Command: g
frame_id=0       1920x1080 stride=3840
  timestamps       = 336060994951 ns  (raw monotonic, ktime_get_raw_ns; NOT NTP-adjusted)
  sys_timestamps    = 946705156915582076 ns  (realtime, ktime_get_real_ns; wall clock, NTP-adjusted)
  trig_tv           = 342.216467 s  -> 342216467000 ns  (AON RTC, exposure trigger)
  tv                = 342.216618 s  -> 342216618000 ns  (AON RTC, frame start)
  exposure->mipi duration (tv - trig_tv)    = +151000 ns = +151.000 us
Field description:
  • timestamps: raw monotonic timestamp (ns) at the SIF frame start interrupt, counts from system boot, not affected by NTP adjustment
  • sys_timestamps: realtime timestamp (ns) at the SIF frame start interrupt, wall clock, may jump due to NTP adjustment
  • trig_tv: AON RTC hardware timestamp (ns) latched at the moment the LPWM trigger pulse reaches SIF
  • tv: AON RTC hardware timestamp (ns) latched at the moment the MIPI VSYNC (frame start signal) reaches SIF
  • exposure->mipi duration (tv - trig_tv): the inherent delay from “LPWM trigger pulse arrival” to “MIPI frame start signal arrival” (including sensor exposure + readout + MIPI transfer)
3.2.2.4. Common Issues
1. trig_tv is zero
  • Confirm time_stamp_en=1 and time_stamp_mode contains the corresponding bit (0x02 latches trig_tv, 0x01 latches tv, 0x03 latches both).
  • Confirm ts_src matches the LPWM channel used by hardware trigger exposure (this sample auto-derives from the device tree lpwm_chn; if it is 0, the device tree is not configured).
  • Confirm the sensor is in SLAVE mode (master mode has no LPWM trigger, trig_tv is always 0).
