5.17.3. OmniVision Sensor Bring-Up
  • This document uses os08c10 as an example to describe the complete process of adapting OmniVision series Camera Sensors on the X5 platform
  • The process includes driver implementation, App configuration, and program verification. For general concepts and DTS configuration, please first read the Camera Debugging Guide.
Source Code Location
  • Driver interface implementation: hbre/camsys/libcam/src/sensor/os08c10/os08c10_setting.c
  • Gain table and setting configuration: hbre/camsys/libcam/src/sensor/os08c10/inc/os08c10_setting.h (gain_lut, init/stream_on/stream_off register arrays)
5.17.3.1. DTS Configuration
5.17.3.2. Driver
sensor_module_t and File Naming
  • File name: os08c10_utility.c; structure/module name: os08c10; library name: libos08c10.so.1.0.0, deployed to /usr/hobot/lib/sensor/ on the board.
  • Required interfaces: init, deinit, start, stop, power_on, power_off, aexp_gain_control, aexp_line_control, userspace_control.
#ifdef CAMERA_FRAMEWORK_HBN
SENSOR_MODULE_F(os08c10, CAM_MODULE_FLAG_A16D8);
sensor_module_t os08c10 = {
        .module = SENSOR_MNAME(os08c10),
#else
        .module = "os08c10",
#endif
        .init = sensor_init,
        .start = sensor_start,
        .stop = sensor_stop,
        .deinit = sensor_deinit,
        .power_on = sensor_poweron,
        .power_off = sensor_poweroff,
power_on
  1. power_on controls sensor power-on via X5 GPIO, following the spec power-up timing.
  2. sensor_poweron is typically called in sensor_init and only needs to control XSHUTDOWN. Below is the power_on implementation for os08c10:
../../_images/screenshot-20260210-145220.png
int sensor_poweron(sensor_info_t *sensor_info)
        int gpio, ret = RET_OK;
                                usleep(100 * 1000);  // 100ms
                                if(ret < 0) {
        return ret;
power_off
  1. power_off controls sensor power-off via X5 GPIO, following the spec power-down timing.
  2. sensor_poweroff is typically called in sensor_deinit and only needs to control XSHUTDOWN. Below is the power_off implementation for os08c10:
../../_images/screenshot-20260210-145247.png
int sensor_poweroff(sensor_info_t *sensor_info)
                                if(ret < 0) {
                                        return -1;
        return ret;
init
  1. Writes the sensor initialization register list to the sensor via the I2C write function; different resolutions use different setting arrays
  2. os08c10_linear_data_init is used to populate turning_data information.
  3. sensor_init is called when hbn_camera_attach_to_vin is invoked
int sensor_init(sensor_info_t *sensor_info)
        int ret = RET_OK;
        int setting_size = 0;
        pr_debug("os08c10 sensor_init \n");
        if (ret < 0) {
                pr_err("%d : sensor reset %s fail\n", __LINE__, sensor_info->sensor_name);
                return ret;
        if (sensor_info->resolution == 2160) {
                pr_debug("os08c10 resolution is 2160 \n");
                setting_size = sizeof(os08c10_3840x2160_30fps_27MHz_linear_12bit_1701Mbps_2lane) / sizeof(uint32_t) / 2;
                                setting_size, os08c10_3840x2160_30fps_27MHz_linear_12bit_1701Mbps_2lane);
                if (ret < 0) {
                        pr_err("%d : init %s fail\n", __LINE__, sensor_info->sensor_name);
                        return ret;
        } else {
                pr_err("config mode is err\n");
                return -RET_ERROR;
        ret = os08c10_linear_data_init(sensor_info);
        if (ret < 0) {
                pr_err("%d : turning data init %s fail\n", __LINE__, sensor_info->sensor_name);
                return ret;
        return ret;
deinit
  1. deinit is typically called for sensor de-initialization; simply call power_off to power down.
  2. sensor_deinit is called when hbn_camera_destroy or hbn_camera_detach_from_vin is invoked.
int sensor_deinit(sensor_info_t *sensor_info)
        int ret = RET_OK;
        if (ret < 0) {
                pr_err("%d : deinit %s fail\n", __LINE__, sensor_info->sensor_name);
                return ret;
        return ret;
start
  1. start implements sending the stream-on register 0x0100 as 0x01 to make the sensor start streaming.
  2. sensor_start is called when the upper layer calls hbn_vflow_start.
../../_images/screenshot-20260210-205236.png
int sensor_start(sensor_info_t *sensor_info)
        int ret = RET_OK;
        pr_debug("os08c10 sensor start\n");
        setting_size = sizeof(os08c10_2lane_stream_on_setting) / sizeof(uint32_t) / 2;
                        setting_size, os08c10_2lane_stream_on_setting);
        if (ret < 0) {
                pr_err("start %s fail\n", sensor_info->sensor_name);
                return ret;
        return ret;
stop
  1. stop implements sending the stream-off register 0x0100 as 0x00 to make the sensor stop streaming.
  2. sensor_stop is called when the upper layer calls hbn_vflow_stop
int sensor_stop(sensor_info_t *sensor_info)
        int ret = RET_OK;
        printf("os08c10 sensor stop \n");
        setting_size = sizeof(os08c10_2lane_stream_off_setting) / sizeof(uint32_t) / 2;
                        setting_size, os08c10_2lane_stream_off_setting);
        if (ret < 0) {
                pr_err("stop %s fail\n", sensor_info->sensor_name);
                return ret;
        return ret;
ISP Configuration and linear_data_init
../../_images/screenshot-20260210-151059.png
In os08c10_linear_data_init, populate the tuning parameters:
  • Read VTS from sensor (registers 0x380e/0x380f), calculate lines_per_second;
  • exposure_time_max/min, analog_gain_max, digital_gain_max;
  • Populate bayer (sensor_data_bayer_fill, sensor_data_bits_fill);
  • Set stream_ctrl; copy again_lut from os08c10_setting.h (os08c10_gain_lut) to turning_data.normal.again_lut, then submit via ioctl.
Key parameter configuration:
  • exposure_time_max = vts (max VTS not found in documentation, configured as VTS)
  • analog_gain_max = 191 consistent with gain_lut maximum index, 63.5x corresponds to 191, refer to Gain index and gain ratio lookup table
  • digital_gain_max = 0 dgain unused, configure 0; if used, refer to analog_gain_max
  • exposure_time_min = 1
  • sensor_data_bayer_fill(..., 12, BAYER_START_B, BAYER_PATTERN_RGGB); sensor_data_bits_fill(..., 12), BAYER_START at position 0,0 is BAYER_START_B, BAYER_PATTERN is RGGB, raw12 format. sensor_data_bits_fill is only used for PWL mode; configure 12 here
aexp_line_control
The aexp_line_control function primarily implements exposure control, responsible for:
  1. Receiving the exposure line count calculated by the ISP 3A algorithm
  2. Converting the exposure line count to sensor register values
  3. Configuring and sending exposure registers to the sensor via I2C
  4. The exposure registers here are 0x3500, 0x3501, 0x3502.
../../_images/screenshot-20260210-130940.png
        const uint16_t EXP_LINE0 = 0x3500;
        const uint16_t EXP_LINE1 = 0x3501;
        const uint16_t EXP_LINE2 = 0x3502;
        if (mode == NORMAL_M) {
                uint32_t sline = line[0];
                if (sline > 2314) sline = 2314;
                if (sline < 8) sline = 8;
                temp0 = (sline >> 16) & 0xFF;
                vin_i2c_write8(info->bus_num, 16, info->sensor_addr, EXP_LINE0, temp0);
                temp1 = (sline >> 8) & 0x0F;
                vin_i2c_write8(info->bus_num, 16, info->sensor_addr, EXP_LINE1, temp1);
                temp2 = (sline) & 0xFF;
                vin_i2c_write8(info->bus_num, 16, info->sensor_addr, EXP_LINE2, temp2);
        } else {
aexp_gain_control:
The aexp_gain_control function primarily implements gain control, responsible for:
  1. Receiving the gain index value calculated by the ISP 3A algorithm
  2. Looking up the gain_lut table to find the sensor register value based on the gain index
  3. Configuring and sending gain registers to the sensor via I2C
  4. gain_lut generally needs to be configured according to the spec.
For OmniVision sensors, gain control generally uses an integer + fractional linear combination. Taking os08c10 as an example, you need to derive the register value calculation formula based on the gain ratio. The specific method is as follows:
Reference documentation and gain_table.xlsx:
../../_images/screenshot-20260116-103406.png
../../_images/screenshot-20260116-103426.png
../../_images/screenshot-20260116-103530.png
= "0x" & DEC2HEX(INT(B4)*256 + ROUND(MOD(B4,1)*128,0)*2, 4)
Formula explanation:
INT(B4): Get the integer part
MOD(B4,1): Get the fractional part (equivalent to B4-INT(B4))
*128: Convert to 1/128 units
ROUND(...,0): Round to integer
*2: Left shift by 1 bit (because it needs to be placed in the upper 7 bits)
*256: Shift integer part to high byte
DEC2HEX(...,4): Convert to 4-digit hexadecimal
        const uint16_t AGAIN_H = 0x3548;
        const uint16_t AGAIN_L = 0x3549;
        char again_reg_value_h = 0, again_reg_value_l = 0;
        int gain_index = 0;
                if (again[0] >= sizeof(os08c10_gain_lut)/sizeof(uint32_t))
                        gain_index = sizeof(os08c10_gain_lut)/sizeof(uint32_t) - 1;
                else
                        gain_index = again[0];
                again_reg_value_h = (os08c10_gain_lut[gain_index] >> 8) & 0x7F;
                again_reg_value_l = (os08c10_gain_lut[gain_index]) & 0xFE;
                vin_i2c_write8(info->bus_num, 16, info->sensor_addr, AGAIN_H, again_reg_value_h);
                vin_i2c_write8(info->bus_num, 16, info->sensor_addr, AGAIN_L, again_reg_value_l);
        } else {
userspace_control
  • sensor_userspace_control is used for Gain Control and Exposure Control switches.
  • When debugging with hbplayer to troubleshoot flicker or image abnormalities, you can enable/disable HAL_GAIN_CONTROL / HAL_LINE_CONTROL to confirm the issue.
Driver Deployment
  1. Compile with ./bd.sh hbre camsys/libcam.
  2. Copy out/deploy/hbre/lib/sensor/libos08c10.so.1.0.0 to /usr/hobot/lib/sensor/ on the board.
5.17.3.3. App Configuration
  • In the path app/samples/platform_samples/vp_sensors/os08c10/, add configuration for os08c10.
  • Configure mipi (lane, datatype, mipiclk, linelength, framelength, settle), camera (name, addr, sensor_mode, gpio, fps, width, height, format), vin_node_attr (mipi_rx, cim_isp_flyby, etc.), vin_ichn_attr, vin_ochn_attr (wstride, etc.), isp_attr, isp_ichn_attr, isp_ochn_attr.
  • HTS/VTS can be read from registers 0x380c/0x380d and 0x380e/0x380f, or obtained from the sensor FAE, or measured with an oscilloscope. For measurement methods, refer to MIPI parameter determination
  • mipiclk can generally be obtained from the sensor FAE. For calculation methods, refer to MIPI CLK
  • Other configurations are generic; refer to the Data Structures documentation for configuration.
vp_sensor configuration file: linear_3840x2160_raw10_30fps_2lane.c
  • Configuration file path: os08c10/linear_3840x2160_raw10_30fps_2lane.c.
  • Configuration structure name: os08c10_linear_3480x2160_raw12_30fps_2lane (must be registered in vp_sensor_config_list).
  • The current example uses RAW12 output; datatype/format is configured as 0x2C. Main parameters are as follows:
Configuration Item Parameter Name / Location Value Description
Top-level config_file "linear_3840x2160_raw12_30fps_2lane.c"
sensor_name "os08c10-30fps-2lane"
chip_id_reg / chip_id 0x300A / 0x53
sensor_i2c_addr_list {0x21}
MIPI lane 2
datatype RAW12 (0x2C)
fps 30
mipiclk 1701 (Mbps)
width / height 3840 / 2160
linelength / framelength 4860 / 2314 (refer to sensor HTS/VTS)
settle 0 (adjust 0-120 if MIPI errors occur)
channel_num 1
Camera name / addr "os08c10" / 0x21
sensor_mode 1 (NORMAL_M)
format RAW12
calib_lname "disable"
VIN mipi_rx 0
cim_isp_flyby 0 (offline)
hdr_mode NOT_HDR
mclk_freq (vin_attr_ex) 27000000 (27MHz)
VIN Output wstride SENSOR_WIDTH * 2 (RAW12 is x2)
ISP Input input_mode DDR_MODE
sensor_mode ISP_NORMAL_M
crop x=0, y=0, w=3840, h=2160
input_fmt FRM_FMT_RAW
input_bit_width 12
ISP Output output_fmt FRM_FMT_NV12
output_bit_width 8
ddr_en 1
5.17.3.4. Program Verification
  1. sample_vin: Run get_vin_data to confirm raw image has no severe color cast and frame rate is normal; calculate and print the actual frame rate to verify the configured frame rate is correct.
  2. sample_isp: Copy a tuning.json with the same resolution as os08c10_tuning.json and change sensor_name to os08c10. Run get_isp_data to confirm YUV is normal.
  3. hbplayer: Connect to the board to preview YUV, see hbplayer and tuning_tool Usage Guide.
  4. tuning_tool: After connecting to hbplayer using tuning_tool, enter command e, configure Manual AE, set aGain and integrationTime. Check driver printout to verify registers 0x3508/0x3509 and 0x3500~0x3502 match the spec. ISP gain limits can be configured in os08c10_tuning.json for self-testing.
For common issues, see Camera Sensor FAQ.
