5.5. Video Input - Camera
5.5.1. Module Description
Camera Access Methods
  • X5 supports MIPI CSI video input or converting it to MIPI CSI signal access through a deserializer (deserial).
  • When using either method, the camera or deserializer must be bound and unbound to/from the VIN Node via attach and detach interfaces, to initialize and deinitialize the sensor.
    1. When accessing MIPI CSI directly, use hbn_camera_attach_to_vin and hbn_camera_detach_from_vin to bind and unbind the camera with the VIN Node.
    2. When using the deserializer access, use hbn_deserial_attach_to_vin and hbn_deserial_detach_from_vin to bind and unbind the deserializer with the VIN Node.
  • For more information about VIN Node, refer to Video Input - VIN.
5.5.1.1. Hardware block diagram
Main components
  • MIPI D-PHY (RX): As the physical layer of the MIPI protocol receiver, it supports high-speed serial data transmission.
  • MIPI HOST controller: implements the CSI-2 protocol on the host side and is responsible for receiving data from D-PHY and performing protocol analysis. X5 contains 4 independent HOST instances.
  • IPI (Image Pixel Interface): Image pixel interface. The effective image data parsed by the CSI HOST controller is output to the SIF (Sensor Interface) module through this parallel interface for subsequent processing.
  • IDI (Image Data Interface): Image data interface.
Key Features
  • The chip supports up to 4 independent MIPI HOSTs (CSI0~CSI3), each independently supports up to 2 Lanes
  • MIPI HOST and IPI distribution:
    • HOST0 /HOST2: Each can bind up to 4 IPIs.
    • HOST1 /HOST3: Each can bind up to 2 IPIs.
  • When the Lane splicing function is enabled through DMUX, HOST0 and HOST2 can be configured to use 4 Lanes respectively to obtain higher single-channel bandwidth. Note: Under this configuration, HOST1 and HOST3 will not be able to receive data.
  • The MIPI module connects data to the SIF through the 12-channel IPI interface. Each IPI channel can be bound to an independent virtual channel and used in combination with SerDes. In theory, up to 12 cameras can be connected.
5.5.1.2. MIPI Basic Specifications
  • Supports MIPI CSI video input:
    • Complies with MIPI Alliance interface specification v2.1
    • Supports up to 8 data lanes, each with a maximum data rate of 2.5 Gbps
    • Supports MIPI-HS and MIPI-LP modes
    • Hardware resources: 4 x 2-lane PHY + 4 x CSI-2 controllers
    • Supports up to 12 virtual channels
    • Supports maximum resolution of 5472 x 3076 pixels @30fps video input
    • Supports multiple video formats:
      • RAW 8-/10-/12-/14-/16-bit formats
      • YUV 422 format (8-/10-bit)
  • Supports video input-to-output pass-through mode:
    • Supports direct pass-through (back-to-back) mode from MIPI CSI RX to MIPI CSI TX
5.5.2. Reference Examples
  • Example code for camera accessing can be found in the sample_vin section.
5.5.3. API Reference
API Interface Interface Functionality
hbn_camera_create Creates a camera handle based on the configuration passed in camera_config_t.
hbn_camera_destroy Destroys the corresponding software resources based on the camera handle.
hbn_camera_attach_to_vin Binds the camera and VIN node within the VPF framework using their handles, and initializes the camera hardware.
hbn_camera_detach_from_vin Unbinds the camera from the VIN node and performs deinitialization.
hbn_camera_attach_to_deserial Binds the camera and deserializer using their handles, and initializes both deserializer and camera hardware.
hbn_camera_detach_from_deserial Unbinds the camera from the deserializer and performs deinitialization.
hbn_camera_start Configures camera registers to start streaming.
hbn_camera_stop Configures camera registers to stop streaming.
hbn_camera_reset Resets the camera by reinitializing the sensor.
hbn_camera_change_fps Dynamically switches the sensor frame rate.
hbn_camera_read_register Reads the value of a camera register.
hbn_camera_get_handle Retrieves the corresponding camera handle via VIN node handle or camera port index.
hbn_camera_init_cfg Creates camera and deserializer handles and binds them based on the provided configuration.
hbn_deserial_create Creates a deserializer handle based on the provided configuration.
hbn_deserial_destroy Destroys the corresponding software resources based on the deserializer handle.
hbn_deserial_attach_to_vin Binds the deserializer to the VIN node.
hbn_deserial_detach_from_vin Unbinds the deserializer from the VIN node.
hbn_txser_create Creates a serializer handle (tx serial handle) based on the provided configuration.
hbn_txser_destroy Destroys the corresponding software resources based on the tx serial handle.
hbn_txser_attach_to_vin Binds the tx serial to the VIN node.
hbn_txser_detach_from_vin Unbinds the tx serial from the VIN node.
hbn_camera_switch_scence Dynamically switches the camera ISP tuning effect file.
5.5.3.1. hbn_camera_create
【Function Declaration】
int32_t hbn_camera_create(camera_config_t *cam_config, camera_handle_t *cam_fd)
【Parameter Description】
  • [IN] camera_config_t *cam_config: Pointer to the parameter structure for the camera to be configured;
  • [OUT] camera_handle_t *cam_fd: File descriptor returned based on configuration, used as the camera operation handle;
【Return Value】
  • Success: RET_OK 0
  • Failure: Negative error code
【Function Description】
【Notes】
  • The API checks the sensor library; if the sensor driver code does not comply with the HBN framework specification, an error will be reported.
  • The API checks cam_config; if the configuration exceeds hardware capabilities, an error will be reported.
5.5.3.2. hbn_camera_destroy
int32_t hbn_camera_destroy(camera_handle_t cam_fd)
  • [IN] camera_handle_t cam_fd: Camera operation handle created by hbn_camera_create;
【Return Value】
  • Success: RET_OK 0
【Notes】
  • hbn_camera_destroy must be used in pair with hbn_camera_create.
  • hbn_camera_destroy releases the sensor library; after execution, the sensor will no longer be accessible.
  • hbn_camera_destroy internally calls hbn_camera_detach_from_vin, which triggers a sensor stream stop. Therefore, hbn_camera_destroy must be called before hbn_vflow_destroy.
5.5.3.3. hbn_camera_attach_to_vin
int32_t hbn_camera_attach_to_vin(camera_handle_t cam_fd, vpf_handle_t vin_fd)
  • [IN] camera_handle_t cam_fd: Camera handle created by hbn_camera_create;
  • [IN] vpf_handle_t vin_fd: VIN node handle created by hbn_vnode_open.
【Return Value】
  • Success: RET_OK 0
【Notes】
  • The same camera must not call hbn_camera_attach_to_vin repeatedly; otherwise, an “attach error” will occur.
5.5.3.4. hbn_camera_detach_from_vin
int32_t hbn_camera_detach_from_vin(camera_handle_t cam_fd)
【Return Value】
  • Success: RET_OK 0
【Notes】
  • hbn_camera_detach_from_vin must be used in pair with hbn_camera_attach_to_vin.
  • hbn_camera_destroy internally calls hbn_camera_detach_from_vin, so after calling hbn_camera_destroy, there is no need to call hbn_camera_detach_from_vin again.
5.5.3.5. hbn_camera_attach_to_deserial
int32_t hbn_camera_attach_to_deserial(camera_handle_t cam_fd, deserial_handle_t des_fd, camera_des_link_t link)
  • [IN] deserial_handle_t des_fd: Deserializer handle created by hbn_deserial_create;
  • [IN] camera_des_link_t link: Link configuration between camera and deserializer, determined by which link the camera is connected to.
【Return Value】
  • Success: RET_OK 0
【Notes】
  • This interface is only needed when a deserializer is present in hardware.
  • After calling hbn_camera_attach_to_deserial, hbn_camera_attach_to_vin should not be called; instead, the deserializer will be bound to the VIN node.
5.5.3.6. hbn_camera_detach_from_deserial
int32_t hbn_camera_detach_from_deserial(camera_handle_t cam_fd)
【Return Value】
  • Success: RET_OK 0
【Notes】
  • hbn_camera_detach_from_deserial must be used in pair with hbn_camera_attach_to_deserial.
5.5.3.7. hbn_camera_start
int32_t hbn_camera_start(camera_handle_t cam_fd)
【Return Value】
  • Success: RET_OK 0
【Notes】
After the camera handle is attached to vflow, this interface may not need to be called. If called, hbn_vflow_start must be called first, followed by hbn_camera_start.
5.5.3.8. hbn_camera_stop
int32_t hbn_camera_stop(camera_handle_t cam_fd)
【Return Value】
  • Success: RET_OK 0
【Notes】
  • Must be used in pair with hbn_camera_start.
5.5.3.9. hbn_camera_reset
int32_t hbn_camera_reset(camera_handle_t cam_fd)
【Return Value】
  • Success: RET_OK 0
【Notes】
  • If this interface is called before the camera is attached to VIN, it will initialize the sensor via camera_attach_to_vin to achieve reset. If called after attachment, it will stop and deinitialize the sensor, then reinitialize and restart it.
5.5.3.10. hbn_camera_change_fps
int32_t hbn_camera_change_fps(camera_handle_t cam_fd, int32_t fps)
  • [IN] int32_t fps: Sensor output frame rate;
【Return Value】
  • Success: RET_OK 0
【Notes】
  • This function requires the implementation of the callback function dynamic_switch_fps in the sensor library.
5.5.3.11. hbn_camera_read_register
int32_t hbn_camera_read_register(camera_handle_t cam_fd, camera_reg_type_t type, uint32_t reg_addr)
  • [IN] camera_reg_type_t type: Type of sensor register to read;
  • [IN] uint32_t reg_addr: Register address;
【Return Value】
  • Success: RET_OK 0
【Notes】
None
5.5.3.12. hbn_camera_get_handle
camera_handle_t hbn_camera_get_handle(vpf_handle_t vin_fd, int32_t camera_index)
  • [IN] vpf_handle_t vin_fd: File descriptor of the VIN node;
  • [IN] int32_t camera_index: Port index of the camera;
【Return Value】
  • Success: RET_OK 0
【Notes】
None
5.5.3.13. hbn_camera_init_cfg
int32_t hbn_camera_init_cfg(const char *cfg_file)
  • [IN] const char *cfg_file: Path to the camera configuration file (JSON);
【Return Value】
  • Success: RET_OK 0
【Notes】
  • This API creates the camera by parsing a JSON file, differing from non-JSON methods used in samples. For details, please consult FAE.
5.5.3.14. hbn_deserial_create
int32_t hbn_deserial_create(deserial_config_t *des_config, deserial_handle_t *des_fd)
  • [IN] deserial_config_t *des_config: Pointer to the deserializer configuration structure;
  • [OUT] deserial_handle_t *des_fd: Deserializer handle created based on configuration;
【Return Value】
  • Success: RET_OK 0
【Notes】
  • This interface validates the deserializer configuration; if out of range, an error will be reported.
  • This interface checks the deserializer library; if it does not comply with HBN architecture specifications, an error will be reported.
5.5.3.15. hbn_deserial_destroy
int32_t hbn_deserial_destroy(deserial_handle_t des_fd)
【Return Value】
  • Success: RET_OK 0
Destroy corresponding software resources based on the deserial handle.
【Notes】
  • hbn_deserial_destroy must be used in pair with hbn_deserial_create.
5.5.3.16. hbn_deserial_attach_to_vin
int32_t hbn_deserial_attach_to_vin(deserial_handle_t des_fd, camera_des_link_t link, vpf_handle_t vin_fd)
  • [IN] deserial_handle_t des_fd: deserial handle, created by hbn_deserial_create;
  • [IN] camera_des_link_t link: link index of the deserial;
  • [IN] vpf_handle_t vin_fd: vin node handle to be bound;
【Return Value】
  • Success: RET_OK 0
  • Failure: Error code is a negative value
Bind the deserial with the vin node.
【Notes】
  • If the hardware includes a deserializer, bind the camera with the deserial, and then bind the deserial with the vin node.
5.5.3.17. hbn_deserial_detach_from_vin
int32_t hbn_deserial_detach_from_vin(deserial_handle_t des_fd, camera_des_link_t link)
【Return Value】
  • Success: RET_OK 0
Unbind the deserial from the vin node.
【Notes】
  • hbn_deserial_detach_from_vin must be used in pair with hbn_deserial_attach_to_vin.
5.5.3.18. hbn_txser_create
int32_t hbn_txser_create(txser_config_t *txs_config, txser_handle_t *txs_fd)
  • [IN] txser_config_t *txs_config: pointer to the tx serial configuration structure;
  • [OUT] txser_handle_t *txs_fd: tx serial handle created according to the configuration;
【Return Value】
  • Success: RET_OK 0
Create a serializer handle (tx serial handle) based on the provided configuration.
【Notes】
  • This interface should only be called if the hardware includes a serializer.
  • This interface checks the txser configuration; an error will be reported if the configuration exceeds valid ranges.
  • This interface checks the txser library; an error will be reported if it does not comply with the HBN architecture specification.
5.5.3.19. hbn_txser_destroy
int32_t hbn_txser_destroy(txser_handle_t txs_fd)
  • [IN] txser_handle_t txs_fd: tx serial handle, created by hbn_txser_create;
【Return Value】
  • Success: RET_OK 0
Destroy corresponding software resources based on the tx serial handle.
【Notes】
  • hbn_txser_destroy must be used in pair with hbn_txser_create.
5.5.3.20. hbn_txser_attach_to_vin
int32_t hbn_txser_attach_to_vin(txser_handle_t txs_fd, camera_txs_csi_t csi, vpf_handle_t vin_fd)
  • [IN] camera_txs_csi_t csi: tx csi index;
【Return Value】
  • Success: RET_OK 0
Bind the tx serial with the vin node.
【Notes】
  • This interface initializes the txser hardware.
  • If the hardware includes a serializer, bind the camera with the txser, and then bind the txser with the vin node.
5.5.3.21. hbn_txser_detach_from_vin
int32_t hbn_txser_detach_from_vin(txser_handle_t txs_fd, camera_txs_csi_t csi)
【Return Value】
  • Success: RET_OK 0
Unbind the tx serial from the vin node.
【Notes】
  • hbn_txser_detach_from_vin must be used in pair with hbn_txser_attach_to_vin.
5.5.3.22. hbn_camera_switch_scence
int32_t hbn_camera_switch_scence(int64_t vflow_fd, int64_t isp_vnode_fd, const char *cname)
  • [IN] int64_t vflow_fd: camera flow handle, created by hbn_vflow_create;
  • [IN] int64_t isp_vnode_fd: isp node handle, obtained by hbn_vflow_get_vnode_handle;
  • [IN] const char *cname: ISP tuning JSON string. By default, the system looks for the specified tuning file in the /usr/hobot/lib/sensor directory. If the tuning file is not located there, specify the absolute path to the file;
【Return Value】
  • Success: RET_OK 0
Dynamically switch the camera ISP tuning effect file.
【Notes】
  • This API stops the vflow first, switches the ISP tuning file, and then restarts the vflow.
5.5.4. Data Structures
Camera Parameters
typedef struct camera_config_s
Name Type Min Max Default Description Required
name[CAMERA_MODULE_NAME_LEN] char - CAMERA_MODULE_NAME_LEN(108) - Camera module name, must correspond to the sensor library name. For example, if the sensor driver name is libsc1330t.so, then the name should be sc1330t. Yes
addr uint32_t 0x00 0x7f 0x00 Sensor device address, typically the 7-bit I2C address. Yes
isp_addr uint32_t 0x00 0x7f 0x00 ISP device address (if exists), default is none. No
eeprom_addr uint32_t 0x00 0x7f 0x00 EEPROM device address (if exists), default is none. No
serial_addr uint32_t 0x00 0x7f 0x00 SerDes device address (if exists), default is none. No
sensor_mode uint32_t 1 6 1 Sensor operating mode, can use enum sensor_mode_e:
1: NORMAL_M, linear mode;
2: DOL2_M, HDR 2-frame merge;
3: DOL3_M, HDR 3-frame merge;
4: DOL4_M, HDR 4-frame merge;
5: PWL_M, HDR mode internal sensor merge;
6: SLAVE_M, slave mode, requires external trigger signal to output stream.
Yes
sensor_clk uint32_t - - 0x00 Clock configuration for sensor, currently not active, reserved. No
gpio_enable_bit uint32_t 0 0xFFFFFFFF 0 Whether to use X5 GPIO to control camera sensor pins to meet power sequence requirements.
e.g., control sensor XSHUTDN pin via GPIO.
Note: corresponding GPIO number must be configured in DTS.
0: do not use GPIO;
non-zero: use GPIO to control sensor, enable GPIO by bit. e.g., 0x07 enables [gpio_a, gpio_b, gpio_c].
Yes
gpio_level_bit uint32_t 0 1 0 If gpio_enable_bit is set, configure gpio_level_bit to control sensor pin high/low levels. The relationship between each GPIO bit and sensor pin level:
0: output low first, sleep 1s, then output high;
1: output high first, sleep 1s, then output low.
e.g., 0x05 = 101, from bit0 to bit2: gpio_a high→low, gpio_b low→high, gpio_c high→low. Customize according to sensor power-up sequence.
Yes
bus_select uint32_t 0 6 0 Sensor I2C number selection. Usually fixed by hardware, so recommended to configure in DTS, can be omitted here.
For binding sensor I2C in DTS, see: camera bring-up documentation.
No
bus_timeout uint32_t 0 - 0 I2C timeout configuration. Required only if bus_select is set. No
fps uint32_t 0 120 0 Sensor frame rate configuration. Yes
width uint32_t 0 8192 0 Sensor output image width (in pixels). Yes
height uint32_t 0 4096 0 Sensor output image height (in pixels). Yes
format uint32_t - - - Sensor data type, common values:
RAW8: 0x2A;
RAW10: 0x2B;
RAW12: 0x2C;
YUV422 8-bit: 0x1E.
Yes
flags uint32_t 0 - 0 Optional features: diagnostics, recovery, debug, etc. No
extra_mode uint32_t 0 - 0 Custom configuration inside each sensor library: often used to distinguish modules and function switches. Yes
config_index uint32_t 0 - 0 Custom configuration inside each sensor library: often used to distinguish modules and function switches. Yes
ts_compensate uint32_t 0 - 0 Reserved parameter, for future use. No
mipi_cfg mipi_config_t - - - MIPI configuration, set to NULL to automatically fetch from sensor driver (get_csi_attr). Yes
calib_lname char - - - Sensor tuning library path, default is /usr/hobot/lib/sensor, supports custom path, total length ≤ 100 bytes.
e.g., calib_lname="/userdata/test_tuning.json".
Current software version: if set to "disable", defaults to using sensor_name_tuning.json in code.
Yes
sensor_param char - - - Sensor custom data. No
iparam_mode uint32_t - - - Reserved parameter, for future use. No
end_flag uint32_t - - - Reserved parameter, for future use. No
typedef struct deserial_config_s
name char[CAMERA_MODULE_NAME_LEN] - - - Deserial name, e.g., max9296. Yes
addr uint32_t 0 - - Deserial device address. Yes
gpio_enable_bit uint32_t 0 - - GPIO operation enable bit, indexed from VCON. Yes
gpio_level_bit uint32_t 0 - - GPIO working state bit, indicating current GPIO status. Yes
gpio_mfp uint8_t[CAMERA_DES_GPIO_MAX] 0 CAMERA_DES_GPIO_MAX 0x0 MFP GPIO function selection, used to specify multi-function configuration. Yes
bus_select uint32_t 0 - - I2C bus selection, indexed from VCON. Yes
bus_timeout uint32_t 0 - - I2C timeout setting, in milliseconds. Yes
lane_mode uint32_t 0 - - PHY lane mode configuration selection. Yes
lane_speed uint32_t 0 - - PHY lane speed configuration. Yes
link_map uint32_t 0 - - Link to CSI/VC mapping configuration. Yes
link_desp char[CAMERA_DES_LINKMAX][CAMERA_DES_PORTDESP_LEN] - - - Configuration description for each link connected module, used for multi-process usage. Yes
reset_delay uint32_t 0 - - Delay time for reset operation, in milliseconds. Yes
flags uint32_t 0 - - Optional feature flags, e.g., diagnostics, debugging, etc. No
poc_cfg poc_config_t* - - NULL POC configuration pointer, NULL means no POC function. No
mipi_cfg mipi_config_t* - - NULL MIPI configuration pointer, NULL means auto-fetch configuration. No
deserial_param char* - - NULL Pointer to deserial custom data. No
end_flag uint32_t 0 0xFFFFFFFF - End flag for structure configuration, used for integrity check. Yes
typedef struct poc_config_s
name char[CAMERA_MODULE_NAME_LEN] - - - POC name, e.g., max20087. Yes
addr uint32_t 0 - - POC device address. Yes
poc_map uint32_t 0 - - Mapping between POC and Link. Yes
power_delay uint32_t 0 - - Delay time for POC on/off operation, in milliseconds. Yes
end_flag uint32_t 0 0xFFFFFFFF - End flag for structure configuration, used for integrity verification. Yes
5.5.5. Return Code Description
Error Code Macro Definition Description Common Causes and Solutions
0 HBN_STATUS_SUCCESS Success
1 HBN_STATUS_INVALID_NODE Invalid vnode, corresponding vnode not found
2 HBN_STATUS_INVALID_NODETYPE Invalid vnode type, corresponding vnode not found For VIN, vnode type is HB_VIN
3 HBN_STATUS_INVALID_HWID Invalid hardware module ID For VIN, hw_id value is 0
4 HBN_STATUS_INVALID_CTXID Invalid context ID Can be set to AUTO_ALLOC_ID, automatically assigned by HBN framework
5 HBN_STATUS_INVALID_OCHNID Invalid output channel ID VIN output channel is 0
6 HBN_STATUS_INVALID_ICHNID Invalid input channel ID VIN supports only one input channel
7 HBN_STATUS_INVALID_FORMAT Invalid format
8 HBN_STATUS_INVALID_NULL_PTR Null pointer
9 HBN_STATUS_INVALID_PARAMETER Invalid parameter, version check failed
10 HBN_STATUS_ILLEGAL_ATTR Invalid parameter
11 HBN_STATUS_INVALID_FLOW Invalid flow, corresponding flow not found
12 HBN_STATUS_FLOW_EXIST Flow already exists
13 HBN_STATUS_FLOW_UNEXIST Flow does not exist
14 HBN_STATUS_NODE_EXIST Node already exists
15 HBN_STATUS_NODE_UNEXIST Node does not exist
16 HBN_STATUS_NOT_CONFIG Reserved
17 HBN_STATUS_CHN_NOT_ENABLED Channel not enabled
18 HBN_STATUS_CHN_ALREADY_ENABLED Channel already enabled
19 HBN_STATUS_ALREADY_BINDED Node already bound
20 HBN_STATUS_NOT_BINDED Node not bound
21 HBN_STATUS_TIMEOUT Timeout
22 HBN_STATUS_NOT_INITIALIZED Not initialized
23 HBN_STATUS_NOT_SUPPORT Channel not supported or not activated
24 HBN_STATUS_NOT_PERM Operation not allowed
25 HBN_STATUS_NOMEM Insufficient memory
26 HBN_STATUS_INVALID_VNODE_FD Invalid node file descriptor
27 HBN_STATUS_INVALID_ICHNID_FD Invalid input channel file descriptor
28 HBN_STATUS_INVALID_OCHNID_FD Invalid output channel file descriptor
29 HBN_STATUS_OPEN_OCHN_FAIL Failed to open output channel
30 HBN_STATUS_OPEN_ICHN_FAIL Failed to open input channel
31 HBN_STATUS_JSON_PARSE_FAIL JSON parsing failed
32 HBN_STATUS_REQ_BUF_FAIL Failed to request buffer
33 HBN_STATUS_QUERY_BUF_FAIL Failed to query buffer information
34 HBN_STATUS_SET_CONTROL_FAIL Module control or tuning parameter (e.g., ISP effect parameter) setting failed
35 HBN_STATUS_GET_CONTROL_FAIL Module control or tuning parameter (e.g., ISP effect parameter) getting failed
36 HBN_STATUS_NODE_START_FAIL Failed to start node
37 HBN_STATUS_NODE_STOP_FAIL Failed to stop node
38 HBN_STATUS_NODE_POLL_ERROR Node channel poll error
39 HBN_STATUS_NODE_POLL_TIMEOUT Node channel poll timeout
40 HBN_STATUS_NODE_POLL_FRAME_DROP Frame drop during node channel poll
41 HBN_STATUS_NODE_POLL_HUP Node channel descriptor hang-up during poll
42 HBN_STATUS_NODE_ILLEGAL_EVENT Illegal event during node channel poll
43 HBN_STATUS_NODE_DEQUE_ERROR Node channel dequeue buffer error
44 HBN_STATUS_ILLEGAL_BUF_INDEX Invalid buffer index
45 HBN_STATUS_NODE_QUE_ERROR Node channel queue buffer error
46 HBN_STATUS_FLUSH_FRAME_ERROR Node channel frame flush error
47 HBN_STATUS_INIT_BIND_ERROR Error occurred during JSON parsing and binding
48 HBN_STATUS_ADD_NODE_FAIL Failed to add node to flow
49 HBN_STATUS_WRONG_CONFIG_ID System does not support the node ID
50 HBN_STATUS_BIND_NODE_FAIL Error occurred when binding node to flow
51 HBN_STATUS_INVALID_VERSION Version mismatch between low-level driver and upper-layer library
52 HBN_STATUS_GET_VERSION_ERROR Failed to get low-level driver module version
53 HBN_STATUS_MEM_INIT_FAIL hbmem memory initialization failed
54 HBN_STATUS_MEM_IMPORT_FAIL hbmem memory import failed
55 HBN_STATUS_MEM_FREE_FAIL hbmem memory release failed
56 HBN_STATUS_SYSFS_OPEN_FAIL Failed to open system file
57 HBN_STATUS_STRUCT_SIZE_NOT_MATCH Structure size mismatch between HAL layer and kernel layer
58 HBN_STATUS_RGN_UNEXIST Unable to retrieve corresponding rgn data
59 HBN_STATUS_RGN_INVALID_OPERATION Invalid rgn operation
60 HBN_STATUS_RGN_OPEN_FILE_FAIL Failed to open file in rgn module
128 HBN_STATUS_ERR_UNKNOW Unknown error
