5.8. Video Processing - VSE
5.8.1. Module Description
VSE (Video Scale Engine) is used for image scaling.
It supports 6 scaling channels with the following characteristics:
Maximum processing capability: 3840x2160@60fps
Supports input cropping, independent horizontal and vertical scaling, and separate processing of chroma and luma components
5 downscale channels
Maximum supported resolutions: 4K, 1080P, 1080P, 720P, 720P respectively
Minimum resolution: 64x64, supports arbitrary downscale factors
Supports frame rate control and OSD
1 upscale channel
Maximum supported resolution: 4K, maximum scaling factor: 4X (scaling factor range: 0–4)
| Output Channel ID | Type | Channel Function |
| 0 | offline | 4K Downscale |
| 1 | offline | 1080P Downscale |
| 2 | offline | 1080P Downscale |
| 3 | offline | 720P Downscale |
| 4 | offline | 720P Downscale |
| 5 | offline | 4K Upscale |
Input and output data formats:
Supported input data formats:
from DDR: YUV422sp(NV16), YUV422 interleave, YUV420sp(NV12)
from ISP: YUV420sp(NV12), YUV422sp(NV16)
Supported output data formats: YUV444, YUV422, YUV420, RGB888
Currently the software only supports the following combinations:
| Input Format | Output Format | Notes |
| NV12 | NV12 | - |
| NV16 | NV16 | - |
| NV16 | NV12 | When input is NV16, output channel 5 can only be configured as NV16 |
OSD features:
Each OSD supports up to 4 overlay regions (4 ROIs non-overlapping in vertical direction) and 8 histogram statistic regions
For more information about OSD, please refer to Region Processing - OSD
5.8.2. Reference Example
VSE code examples can be found in the sample_vse section
5.8.3. API Reference
hbn_vnode_open : Open vnode
hbn_vnode_close : Close vnode
hbn_vnode_set_attr : Set vnode attributes
hbn_vnode_set_ochn_attr : Set VSE vnode output channel attributes
hbn_vnode_get_ochn_attr : Get VSE vnode output channel attributes
hbn_vnode_set_ichn_attr : Set VSE vnode input channel attributes
hbn_vnode_get_ichn_attr : Get VSE vnode input channel attributes
hbn_vnode_set_ochn_buf_attr : Set VSE vnode output buffer attributes
hbn_vnode_start : Start vnode
hbn_vnode_stop : Stop vnode
hbn_vnode_getframe : Retrieve frame data from vnode
hbn_vnode_sendframe : Send frame data to vnode
hbn_vnode_releaseframe : Release frame data
5.8.4. Interface Descriptions
5.8.4.1. hbn_vnode_open
【Function Declaration】
【Function Description】
Initialize and open the vnode device node, returning the vnode handle for this module.
【Parameter Description】
[IN] hb_vnode_type vnode_type : vnode type; for VSE, use HB_VSE
[IN] uint32_t hw_id : Hardware ID of the module; for VSE, hw_id is 0
[IN] int32_t ctx_id : Context ID of the module, a software concept; can be specified or set to AUTO_ALLOC_ID for automatic allocation by the HBN framework
[OUT] hbn_vnode_handle_t *vnode_fd : Returns the vnode handle for the module
【Return Value】
Success: returns HBN_STATUS_SUCCESS 0
Failure: negative error code; see Return Value Description
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.2. hbn_vnode_close
Close the module’s device node.
[IN] hbn_vnode_handle_t vnode_fd: The vnode handle of the module;
【Return Value】
None
【Notes】
Must be used in pair with hbn_vnode_open.
【Compatibility】
Hardware: X5
5.8.4.3. hbn_vnode_set_attr
Set basic attributes of the module.
[IN] void *attr: Pointer to the attribute structure; for VSE, use vse_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.4. hbn_vnode_set_ochn_attr
Set output channel attributes of the module.
[IN] uint32_t ochn_id: Output channel ID; refer to VSE Channel Description;
[IN] void *attr: Pointer to the output channel attribute structure; for VSE, use vse_ochn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.5. hbn_vnode_get_ochn_attr
Get output channel attributes of the module.
[OUT] void *attr: Pointer to the output channel attribute structure; for VSE, use vse_ochn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.6. hbn_vnode_set_ichn_attr
Set input channel attributes of the module.
[IN] uint32_t ichn_id: Input channel ID; refer to VSE Channel Description;
[IN] void *attr: Pointer to the input channel attribute structure; for VSE, use vse_ichn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.7. hbn_vnode_get_ichn_attr
Get input channel attributes of the module.
[IN] uint32_t ichn_id: Input channel ID; for VSE, input channel is 0;
[OUT] void *attr: Pointer to the input channel attribute structure; for VSE, use vse_ichn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.8. hbn_vnode_set_ochn_buf_attr
Set output channel buffer attributes, including buffer count and whether buffer addresses are contiguous.
[IN] hbn_buf_alloc_attr_t *alloc_attr: Buffer allocation attributes;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.9. hbn_vnode_start
Start the module.
【Return Value】
【Notes】
Module must be opened before starting.
【Compatibility】
Hardware: X5
5.8.4.10. hbn_vnode_stop
Stop the module.
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.11. hbn_vnode_getframe
hbn_vnode_image_t *out_img);
Retrieve image from the module’s output channel; this is a blocking interface.
[IN] uint32_t millisecondTimeout: Timeout duration in milliseconds;
[OUT] hbn_vnode_image_t *out_img: Address of the output image buffer structure;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.12. hbn_vnode_sendframe
hbn_vnode_image_t *img);
Send image to the module’s input channel, triggering processing. This is a blocking interface; waits for hardware processing to complete before returning. Default timeout is 1 second.
[IN] hbn_vnode_image_t *img: Address of the input image buffer;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.13. hbn_vnode_releaseframe
Release image buffer; the buffer is returned to the specified output channel.
[IN] hbn_vnode_image_t *img: Address of the image buffer structure;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.5. Data Structures
5.8.5.1. vse_cfg_t
| Name | Type | Min Value | Max Value | Default | Description |
| vse_attr | vse_attr_t | · | · | · | VSE basic attributes |
| ichn_attr | vse_ichn_attr_t | · | · | · | VSE input channel attributes |
| ochn_attr | vse_ochn_attr_t | · | · | · | VSE output channel attributes |
5.8.5.2. vse_attr_t
| fps | frame_fps_ctrl_t | · | · | 0 | Currently only supports setting fps of input image src; used for VSE frame rate control |
5.8.5.3. vse_ichn_attr_t
| tpg_en | cam_bool_e | 0 | 1 | 0 | Enable TPG function (currently not supported) |
| width | uint32_t | 0 | 5432 | 0 | Original width of input image |
| height | uint32_t | 0 | 3076 | 0 | Original height of input image |
| fmt | frame_format_e | FRM_FMT_NV12 | FRM_FMT_NV12 | 0 | FRM_FMT_NULL - Invalid, FRM_FMT_RAW - RAW format, FRM_FMT_NV12 - NV12 format, FRM_FMT_UYVY - UYVY format; currently only NV12 is supported |
| bit_width | uint32_t | 8 | 8 | 0 | Bit width of input image |
5.8.5.4. vse_ochn_attr_t
| chn_en | cam_bool_e | 0 | 1 | 0 | Enable channel |
| roi | common_rect_t | · | · | · | Crop region for output image; all zeros means crop disabled |
| target_w | uint32_t | 0 | Limited by channel capability | 0 | Output image width; 0 means scaling disabled |
| target_h | uint32_t | 0 | Limited by channel capability | 0 | Output image height; 0 means scaling disabled |
| y_stride | uint32_t | 0 | · | 0 | Y-plane stride of output image (currently not supported) |
| uv_stride | uint32_t | 0 | · | 0 | UV-plane stride of output image (currently not supported) |
| fps | frame_fps_ctrl_t | · | · | 0 | Currently only supports setting fps of output image dst; used for VSE frame rate control. When this value is 0, if input fps is 0, frame rate control is disabled; if input fps is non-zero, no data will be output |
5.8.6. Return Value Description
| Error Code | Macro Definition | Description | Common Causes and Solutions |
| 0 | HBN_STATUS_SUCCESS | Success | |
| 1 | HBN_STATUS_INVALID_NODE | Invalid vnode, corresponding vnode not found | |
| 2 | HBN_STATUS_INVALID_NODETYPE | Invalid vnode type, corresponding vnode not found | For VSE, vnode type should be HB_VSE |
| 3 | HBN_STATUS_INVALID_HWID | Invalid hardware module ID | For VSE, hw_id should be 0 |
| 4 | HBN_STATUS_INVALID_CTXID | Invalid context ID | Can be set to AUTO_ALLOC_ID for automatic allocation by HBN framework |
| 5 | HBN_STATUS_INVALID_OCHNID | Invalid output channel ID | VSE output channel range is [0,5] |
| 6 | HBN_STATUS_INVALID_ICHNID | Invalid input channel ID | VSE supports only one input channel |
| 7 | HBN_STATUS_INVALID_FORMAT | Invalid format | |
| 8 | HBN_STATUS_INVALID_NULL_PTR | Null pointer | |
| 9 | HBN_STATUS_INVALID_PARAMETER | Invalid parameter, version check failed | |
| 10 | HBN_STATUS_ILLEGAL_ATTR | Invalid parameter | |
| 11 | HBN_STATUS_INVALID_FLOW | Invalid flow, corresponding flow not found | |
| 12 | HBN_STATUS_FLOW_EXIST | Flow already exists | |
| 13 | HBN_STATUS_FLOW_UNEXIST | Flow does not exist | |
| 14 | HBN_STATUS_NODE_EXIST | Node already exists | |
| 15 | HBN_STATUS_NODE_UNEXIST | Node does not exist | |
| 16 | HBN_STATUS_NOT_CONFIG | Reserved | |
| 17 | HBN_STATUS_CHN_NOT_ENABLED | Channel not enabled | |
| 18 | HBN_STATUS_CHN_ALREADY_ENABLED | Channel already enabled | |
| 19 | HBN_STATUS_ALREADY_BINDED | Node already bound | |
| 20 | HBN_STATUS_NOT_BINDED | Node not bound | |
| 21 | HBN_STATUS_TIMEOUT | Timeout | |
| 22 | HBN_STATUS_NOT_INITIALIZED | Not initialized | |
| 23 | HBN_STATUS_NOT_SUPPORT | Channel not supported or not activated | |
| 24 | HBN_STATUS_NOT_PERM | Operation not allowed | |
| 25 | HBN_STATUS_NOMEM | Insufficient memory | |
| 26 | HBN_STATUS_INVALID_VNODE_FD | Invalid node file descriptor | |
| 27 | HBN_STATUS_INVALID_ICHNID_FD | Invalid input channel file descriptor | |
| 28 | HBN_STATUS_INVALID_OCHNID_FD | Invalid output channel file descriptor | |
| 29 | HBN_STATUS_OPEN_OCHN_FAIL | Failed to open output channel | |
| 30 | HBN_STATUS_OPEN_ICHN_FAIL | Failed to open input channel | |
| 31 | HBN_STATUS_JSON_PARSE_FAIL | JSON parsing failed | |
| 32 | HBN_STATUS_REQ_BUF_FAIL | Failed to request buffer | |
| 33 | HBN_STATUS_QUERY_BUF_FAIL | Failed to query buffer information | |
| 34 | HBN_STATUS_SET_CONTROL_FAIL | Failed to set module control or adjustment parameters (e.g., ISP effect parameters) | |
| 35 | HBN_STATUS_GET_CONTROL_FAIL | Failed to get module control or adjustment parameters (e.g., ISP effect parameters) | |
| 36 | HBN_STATUS_NODE_START_FAIL | Failed to start node | |
| 37 | HBN_STATUS_NODE_STOP_FAIL | Failed to stop node | |
| 38 | HBN_STATUS_NODE_POLL_ERROR | Node channel poll error | |
| 39 | HBN_STATUS_NODE_POLL_TIMEOUT | Node channel poll timeout | |
| 40 | HBN_STATUS_NODE_POLL_FRAME_DROP | Frame drop occurred during node channel poll | |
| 41 | HBN_STATUS_NODE_POLL_HUP | File descriptor hung up during node channel poll | |
| 42 | HBN_STATUS_NODE_ILLEGAL_EVENT | Illegal event during node channel poll | |
| 43 | HBN_STATUS_NODE_DEQUE_ERROR | Node channel dequeue buffer error | |
| 44 | HBN_STATUS_ILLEGAL_BUF_INDEX | Invalid buffer index | |
| 45 | HBN_STATUS_NODE_QUE_ERROR | Node channel queue buffer error | |
| 46 | HBN_STATUS_FLUSH_FRAME_ERROR | Node channel frame flush error | |
| 47 | HBN_STATUS_INIT_BIND_ERROR | Error occurred during JSON parsing and binding | |
| 48 | HBN_STATUS_ADD_NODE_FAIL | Failed to add node to flow | |
| 49 | HBN_STATUS_WRONG_CONFIG_ID | System does not support the node ID | |
| 50 | HBN_STATUS_BIND_NODE_FAIL | Error occurred when binding node to flow | |
| 51 | HBN_STATUS_INVALID_VERSION | Version mismatch between lower driver and upper library | |
| 52 | HBN_STATUS_GET_VERSION_ERROR | Failed to get lower driver module version | |
| 53 | HBN_STATUS_MEM_INIT_FAIL | hbmem memory initialization failed | |
| 54 | HBN_STATUS_MEM_IMPORT_FAIL | hbmem memory import failed | |
| 55 | HBN_STATUS_MEM_FREE_FAIL | hbmem memory release failed | |
| 56 | HBN_STATUS_SYSFS_OPEN_FAIL | System file open failed | |
| 57 | HBN_STATUS_STRUCT_SIZE_NOT_MATCH | HAL layer structure size does not match kernel layer | |
| 58 | HBN_STATUS_RGN_UNEXIST | Cannot retrieve corresponding rgn data | |
| 59 | HBN_STATUS_RGN_INVALID_OPERATION | Invalid rgn operation | |
| 60 | HBN_STATUS_RGN_OPEN_FILE_FAIL | RGN module failed to open file | |
| 128 | HBN_STATUS_ERR_UNKNOW | Unknown error |
