5.9. Region Processing - OSD
5.9.1. Module Description
The OSD (On-Screen Display) module is an important image processing tool that configures operation regions (Region) and overlays them onto images with operations such as color filling, drawing, and mosaic. Its main application scenarios include:
  • Video/image enhancement: overlay annotations or information display on real-time video or static images.
  • Privacy protection: Blur or cover specific areas by overlaying mosaics or occlusion areas to protect sensitive information.
Since OSD is an auxiliary function of VSE, it cannot be used independently. It must be attached to a VSE output channel by calling the hbn_rgn_attach_to_chn interface.
5.9.1.1. Basic Specifications
  • OSD supports color filling, point/line/text drawing, mosaic, and other functions.
  • Text drawing supports the 16x16 dot matrix HZK16 Chinese font library and the 16x8 dot matrix ASC16 English font library.
  • The width of overlaid Region in OSD must be a multiple of 32, height must be even, and minimum size is 32x2.
  • Supports overlay region data format VGA_8, with colormap supporting up to 16 colors.
  • Each OSD supports 8 histogram statistic regions with area size ranging from 2x2 to 256x256.
  • VSE hardware supports OSD functionality; all channels except channel 4 support hardware OSD with maximum of 4 regions per channel. Software OSD supports up to 255 regions.
  • When using OSD, it must be bound to a VSE output channel. The OSD support status for each VSE output channel is as follows:
VSE Output Channel ID Hardware OSD Overlay Function Software OSD Overlay Function
0 Supported Supported
1 Supported Supported
2 Supported Supported
3 Supported Supported
4 Not supported Supported
5 Supported Supported
Note: VSE channel 4 uses software implementation with NEON instruction set for OSD overlay functionality by default.
image-20241224-211604
  1. The input channel (Ichn0) of VSE receives data from two sources: one via VFLOW, and the other through recirculation.
  2. The region buffer is created via hbn_rgn_create, and then attached to a specified VSE channel using hbn_rgn_attach_to_chn.
  3. After binding the OSD to a specific VSE output channel (Ochnx), the OSD hardware automatically overlays the region buffer data onto the video frames processed by VSE.
  4. VSE output channel 4 (Ochn4) does not support hardware OSD and defaults to NEON-based software implementation for OSD overlay.
  5. When more than 4 regions are used on a VSE output channel, the extra regions beyond 4 are processed using software with NEON instructions.
5.9.1.2. Notes
Region Limitations: Each VSE channel supports up to 4 non-overlapping OSD regions in hardware (i.e., the 4 Regions must not overlap vertically). Below are example diagrams:
The left image shows supported OSD region overlay methods; the right image shows unsupported methods.
OSD_API_EN
OSD Supported Overlay Types:
  • OVERLAY: Overlay region, allows user-defined content filling within a rectangular area, such as writing text or drawing lines.
  • COVER: Covered area, solid color block, supports rectangles and polygons, but not circles.
  • MOSAIC: Mosaic region, applies mosaic effect to a rectangular area for obscuring.
5.9.2. Reference Examples
  • Refer to the sample_osd section for sample code related to OSD.
5.9.3. API Reference
API Interface Function Description
hbn_rgn_create Create region
hbn_rgn_destroy Destroy region
hbn_rgn_getattr Get region attributes
hbn_rgn_setattr Set region attributes
hbn_rgn_setbitmap Set region buffer
hbn_rgn_attach_to_chn Attach region to channel
hbn_rgn_detach_from_chn Detach region from channel
hbn_rgn_set_displayattr Set display attributes
hbn_rgn_get_displayattr Get display attributes
hbn_rgn_draw_word Write string into buffer
hbn_rgn_draw_line Draw line in buffer
hbn_rgn_set_colormap Set OSD color index mapping table
hbn_rgn_get_sta Get brightness statistic region
hbn_rgn_set_sta Set brightness statistic region
5.9.3.1. hbn_rgn_create()
【Function Declaration】
int32_t hbn_rgn_create(hbn_rgn_handle_t handle, const hbn_rgn_attr_t *region)
【Parameter Description】
  • [IN] hbn_rgn_handle_t handle: region handle, unique identifier for the region, maximum value cannot exceed 255.
  • [IN] hbn_rgn_attr_t region: region attribute.
【Return Value】
【Function Description】
Used to create a region.
【Notes】
None
5.9.3.2. hbn_rgn_destroy
int32_t hbn_rgn_destroy(hbn_rgn_handle_t handle)
【Return Value】
Used to destroy a region.
【Notes】
None
5.9.3.3. hbn_rgn_getattr
int32_t hbn_rgn_getattr(hbn_rgn_handle_t handle, hbn_rgn_attr_t *region)
  • [IN] hbn_rgn_attr_t *region: region attributes.
【Return Value】
After creating a region, this function retrieves its attributes.
【Notes】
None
5.9.3.4. hbn_rgn_setattr
int32_t hbn_rgn_setattr(hbn_rgn_handle_t handle, const hbn_rgn_attr_t *region)
【Return Value】
After creating a region, this function sets its attributes.
【Notes】
None
5.9.3.5. hbn_rgn_setbitmap
int32_t hbn_rgn_setbitmap(hbn_rgn_handle_t handle, const hbn_rgn_bitmap_t *bitmap_attr)
  • [IN] hbn_rgn_bitmap_t *bitmap_attr: buffer attributes for the region.
【Return Value】
After creating a region, users can allocate a buffer for drawing and set it as the buffer for this region.
【Notes】
None
5.9.3.6. hbn_rgn_attach_to_chn
int32_t hbn_rgn_attach_to_chn(hbn_rgn_handle_t handle, hbn_vnode_handle_t vnode_fd, int32_t chnid, const hbn_rgn_chn_attr_t *rgn_chn)
  • [IN] hbn_vnode_handle_t vnode_fd: target VSE handle to bind to, obtained via hbn_vflow_get_vnode_handle().
  • [IN] int32_t chnid: target VSE channel ID.
  • [IN] hbn_rgn_chn_attr_t *rgn_chn: display attributes of the region when overlaid on the channel.
【Return Value】
Used to attach a created region to a specific VSE channel.
【Notes】
VSE channel 4 lacks hardware OSD capability and uses software processing. Other channels support up to 4 hardware OSD regions, which must not overlap vertically. Any additional regions are handled by software.
5.9.3.7. hbn_rgn_detach_from_chn
int32_t hbn_rgn_detach_from_chn(hbn_rgn_handle_t handle, hbn_vnode_handle_t vnode_fd, int32_t chnid)
  • [IN] hbn_vnode_handle_t vnode_fd: VSE handle to detach from, obtained via hbn_vflow_get_vnode_handle().
  • [IN] int32_t chnid: VSE channel ID to detach from.
【Return Value】
Used to detach a created region from a specific VSE channel.
【Notes】
None
5.9.3.8. hbn_rgn_set_displayattr
int32_t hbn_rgn_set_displayattr(hbn_rgn_handle_t handle, hbn_vnode_handle_t vnode_fd, int32_t chnid, const hbn_rgn_chn_attr_t *rgn_chn)
  • [IN] hbn_vnode_handle_t vnode_fd: target VSE handle to operate on, obtained via hbn_vflow_get_vnode_handle().
【Return Value】
After binding a region to a channel, this function modifies the binding attributes.
【Notes】
None
5.9.3.9. hbn_rgn_get_displayattr
int32_t hbn_rgn_get_displayattr(hbn_rgn_handle_t handle, hbn_vnode_handle_t vnode_fd, int32_t chnid, const hbn_rgn_chn_attr_t *rgn_chn)
【Return Value】
After binding a region to a channel, this function retrieves the binding attributes.
【Notes】
None
5.9.3.10. hbn_rgn_draw_word
int32_t hbn_rgn_draw_word(const hbn_rgn_draw_word_t *draw_word)
  • [IN] hbn_rgn_draw_word_t *draw_word: attributes for drawing text.
【Return Value】
Draw text on a user-allocated buffer. Combined with the hbn_rgn_setbitmap() function, this buffer can be assigned to a specific region.
【Notes】
None
5.9.3.11. hbn_rgn_draw_line
int32_t hbn_rgn_draw_line(const hbn_rgn_draw_line_t *draw_line)
  • [IN] hbn_rgn_draw_line_t *draw_line: attributes for drawing lines.
【Return Value】
Draw lines on a user-allocated buffer. Combined with the hbn_rgn_setbitmap() function, this buffer can be assigned to a specific region.
【Notes】
None
5.9.3.12. hbn_rgn_set_colormap
int32_t hbn_rgn_set_colormap(uint32_t color_map[16])
  • [IN] uint32_t color_map[16]: new color_map to set.
【Return Value】
Set a new global color_map. The color_map must follow this rule: R component in bits 16–23, G component in bits 8–15, B component in bits 0–7.
【Notes】
The newly set color_map remains effective until system reboot.
5.9.3.13. hbn_rgn_set_sta
int32_t hbn_rgn_set_sta(hbn_vnode_handle_t vnode_fd, int32_t chnid, uint8_t sta_level[3], hbn_rgn_sta_t sta_attr[8]);
  • [IN] hbn_vnode_handle_t vnode_fd: target VSE handle, obtained via hbn_vflow_get_vnode_handle().
  • [IN] uint8_t sta_level[3]: threshold values for statistics, must be configured in ascending order, range from 1 to 254.
  • [IN] hbn_rgn_sta_t sta_attr[8]: attributes of statistic regions, including positional information.
【Return Value】
Set 3 threshold values and position information for up to 8 statistic regions. These regions are independent of regular regions and should be used in conjunction with hbn_rgn_get_sta().
【Notes】
This function must be called each time before retrieving statistical data to reconfigure.
5.9.3.14. hbn_rgn_get_sta
int32_t hbn_rgn_get_sta(hbn_vnode_handle_t vnode_fd, int32_t chnid, uint16_t sta_value[8][4])
  • [OUT] uint16_t sta_value[8][4]: statistical data, retrieves pixel counts in 4 intervals based on brightness histogram and configured thresholds.
【Return Value】
Retrieve statistical data from up to 8 regions, output in the form of brightness histograms. With 3 configured thresholds, returns pixel counts in 4 intervals.
【Notes】
None.
5.9.4. Parameter Description
typedef enum hbn_rgn_type_e hbn_rgn_type_t
Name Type Min Max Default Meaning Required
OVERLAY_RGN - - - - Overlay type: overlays an image onto the channel -
COVER_RGN - - - - Covered type: covers the channel with a solid color -
MOSAIC_RGN - - - - Mosaic type: converts a region into mosaic (currently unsupported) -
RGN_TYPE_MAX - - - - Maximum number of supported types -
typedef enum hbn_rgn_font_size_e hbn_rgn_font_size_t
FONT_SIZE_SMALL - - - - Small font size -
FONT_SIZE_MEDIUM - - - - Medium font size -
FONT_SIZE_LARGE - - - - Large font size -
FONT_SIZE_EXTRA_LARGE - - - - Extra Large Font Size -
typedef enum hbn_rgn_font_color_e hbn_rgn_font_color_t
FONT_COLOR_WHITE - - - - White -
FONT_COLOR_BLACK - - - - Black -
FONT_COLOR_GREY - - - - Grey -
FONT_COLOR_BLUE - - - - Blue -
FONT_COLOR_GREEN - - - - Green -
FONT_COLOR_RED - - - - Red -
FONT_COLOR_CYAN - - - - Cyan -
FONT_COLOR_PURPLE - - - - Purple -
FONT_COLOR_YELLOW - - - - Yellow -
FONT_COLOR_ORANGE - - - - Orange -
FONT_COLOR_BROWN - - - - Brown -
FONT_COLOR_PINK - - - - Pink -
FONT_COLOR_DARKBLUE - - - - Dark Blue -
FONT_COLOR_DARKGREEN - - - - Dark Green -
FONT_COLOR_DARKRED - - - - Dark Red -
FONT_COLOR_DARKGRAY - - - - Dark Grey -
FONT_KEY_COLOR_NUM - - - - Number of Colors -
typedef enum hbn_rgn_pixel_format_e hbn_rgn_pixel_format_t
PIXEL_FORMAT_VGA_8 - - - - 8-bit color/alpha data format -
PIXEL_FORMAT_YUV420SP - - - - YUV420SP data format (not supported yet) -
typedef enum hbn_rgn_cover_type_e hbn_rgn_cover_type_t
COVER_RECT - - - - Rectangle -
COVER_POLYGON - - - - Polygon -
typedef struct hbn_rgn_size_s hbn_rgn_size_t
width uint32_t - - - Width -
height uint32_t - - - Height -
struct hbn_rgn_point_s hbn_rgn_point
x uint32_t - - - X coordinate -
y uint32_t - - - Y coordinate -
typedef struct hbn_ren_overlay_s hbn_rgn_overlay_t
pixel_fmt hbn_rgn_pixel_format_t - - - Data format type Yes
size hbn_rgn_size_t - - - Size, width must be multiple of 32, Yes
height must be multiple of 2
struct hbn_rgn_polygon_s hbn_rgn_polygon
side_num hbn_rgn_pixel_format_t 0 POLYGON_MAX_SIDE - Number of polygon vertices Yes
vertex[POLYGON_MAX_SIDE] hbn_rgn_point_t - - - Coordinates of polygon vertices, inner polygons not supported Yes
struct hbn_rgn_cover_attr_s hbn_rgn_cover
cover_type hbn_rgn_cover_type_t - - - Cover type Yes
- union (size, polygon) - - - Size information for rectangle or coordinate data for polygon Yes
For rectangle: width must be multiple of 32, height must be multiple of 2 Yes
struct hbn_rgn_mosaic_attr_s hbn_rgn_mosaic
size hbn_rgn_size_t - - - Must satisfy width multiple of 16, height multiple of 2 Yes
pixel_block uint32_t - - - Currently unused No
struct hbn_rgn_attr_s hbn_rgn_attr
type hbn_rgn_type_t OVERLAY_RGN MOSAIC_RGN - Region type Yes
alpha uint32_t 0 15 - Alpha blending coefficient No
color hbn_rgn_font_color_t FONT_COLOR_WHITE FONT_COLOR_DARKGRAY - Color Yes
overlay_attr hbn_rgn_overlay_t - - - Overlay attribute Yes
cover_attr hbn_rgn_cover_t - - - Cover attribute Yes
mosaic_chn hbn_rgn_mosaic_t - - - Mosaic attribute No
struct hbn_rgn_chn_attr_s hbn_rgn_chn_attr
show bool - - - Whether to display Yes
invert_en bool - - - Whether to invert color (not supported yet) No
display_level uint32_t 0 3 0 Display level: must be 0 for hardware OSD, 1–3 for software; currently used to distinguish hardware/software, display level not supported yet Yes
point hbn_rgn_point_t - - - Coordinate information Yes
struct hbn_rgn_bitmap_attr_s hbn_rgn_bitmap
size hbn_rgn_size_t - - - Size information Yes
*paddr void - - - Input buffer address Yes
struct hbn_rgn_draw_word_param_s hbn_rgn_draw_word
*paddr void - - - Canvas buffer address Yes
size hbn_rgn_size_t - - - Canvas size Yes
*draw_string uint8_t - - - String address for drawing text, must end with "\0"; supports simplified Chinese and English characters; note that Chinese characters must be encoded in GBK Yes
font_color hbn_rgn_font_color_t 0 FONT_COLOR_DARKGRAY - Font color Yes
bg_color uint32_t 0 FONT_COLOR_DARKGRAY - Background color Yes
alpha uint32_t 0 15 - Alpha blending index: 0 = fully transparent, 15 = fully opaque; currently only hardware supports this Yes
font_size hbn_rgn_font_size_t - - - Font size Yes
flush_en bool - - - Whether to refresh canvas Yes
typedef struct hbn_rgn_draw_line_param_s hbn_rgn_draw_line_t
*paddr void - - - Buffer address for drawing line Yes
start_point hbn_rgn_point_t - - - Start coordinate of line Yes
end_point hbn_rgn_point_t - - - End coordinate of line Yes
thick uint32_t - - - Line thickness Yes
color hbn_rgn_font_color_t FONT_COLOR_WHITE FONT_COLOR_DARKGRAY - Line color Yes
bg_color uint32_t FONT_COLOR_WHITE FONT_COLOR_DARKGRAY - Background color Yes
alpha uint32_t 0 15 - Background transparency; line opacity is fixed at 15; hardware supports semi-transparent background, software currently only supports fully transparent background Yes
typedef struct hbn_rgn_sta_attr_s hbn_rgn_sta_t
sta_en uint8_t - - - Whether to enable this region Yes
start_x uint16_t - - - Starting X coordinate Yes
start_y uint16_t - - - Starting Y coordinate Yes
width uint16_t 2 255 - Width of statistics region Yes
height uint16_t 2 255 - Height of statistics region Yes
