5.2. HBN Framework Description
5.2.1. Overview
The HBN framework is marked in red in the multimedia system software architecture diagram and covers most modules in the Camera Sensor capture pipeline, including VIN, ISP, VSE, GDC, and N2D.
The Camera API and OSD API (shown in green in the diagram) are not included within the HBN framework, but they can be attached to the HBN framework via corresponding attach functions.
In summary, the HBN framework encompasses all modules in the Camera Sensor capture pipeline and provides simple and flexible APIs.
Block Diagram
5.2.2. Software Abstraction
In the HBN framework, each module—VIN, ISP, VSE, GDC, and N2D—is abstracted as a vnode. Multiple vnodes are connected to form a vflow (similar to a pipeline).
Since Camera and OSD use independent APIs, the HBN framework provides attach interfaces to bind Camera with VIN and OSD with VSE.
  1. A vnode is an abstraction of a hardware acceleration unit. In the HBN framework, VIN, ISP, VSE, GDC, and N2D are all abstracted into the concept of vnode, which includes the following attributes:
  2. Multiple vnodes are connected to form one vflow. It supports creating multiple vflows simultaneously, and different vflows are completely independent. The process of connecting vnodes is as follows:
  3. For modules in HBN API that are not part of HBN Framework API, such as Camera and OSD, the attach interface is supported to bind them into a vflow
  4. For modules not in HBN API, such as BPU and Display, video frames can be retrieved from the vflow via the interface hbn_vnode_get_output_frame
The figure below shows examples of vflow in three scenarios (Recirculation in Scenario 1 means the data source comes from DDR):
Block Diagram
  1. Scenario 1: Single vflow (recirculation)
    • Scenario description: Video frames come from DDR (e.g., reading a video file into DDR), and VSE is used to scale the video frames
    • Data source: The data source is not included in the vflow; video frames from DDR must be actively fed into the vflow within a thread
    • The vflow must contain at least one vnode, and can contain multiple. When there is only one node, it does not need to be bound to the vflow. When multiple vnode nodes exist and need to be connected, they must be bound to the vflow
    • VSE, GDC, ISP, and N2D all support recirculation mode
  2. Scenario 2: Single vflow
    • Scenario description: One Camera is connected, passing through VIN, ISP, GDC, and VSE. Three output channels are generated at VSE, processed as follows:
      • Channel 0: Sent to CODEC for encoding
      • Channel 1: Sent to Display for rendering
      • Channel 2: Sent to BPU for inference
    • Data source: Camera Sensor connected via MIPI interface
    • The data source is included in the vflow. After the vflow is started, the HBN framework automatically schedules data flow transmission, requiring no developer intervention
    • After the vflow starts, video frames can be continuously retrieved from the end node and passed to acceleration units outside the HBN API, such as the devices in the dashed box in the figure (Codec, Display, BPU)
  3. Scenario 3: Multiple vflows
    • Scenario description: Two Cameras are connected, each passing through different processing pipelines
    • Data source: Each vflow connects one Camera
    • Two vflows are used to complete the capture of two video pipelines
    • The two vflows are completely independent
5.2.3. Vnode Connection Methods
vnodes are connected via input and output channels:
  • Each vnode has one input channel and multiple output channels
  • The output channel of an upstream vnode is connected to the input channel of a downstream vnode, linking multiple vnodes into one vflow
  • The output channel of the upstream vnode determines the connection method
The following describes three aspects: output channels, connection methods, and parameter configuration
5.2.3.1. Output Channels
  • The output channel determines the vnode connection method, supporting online and offline modes. See System Overview for details
  • Only VIN and ISP output channels support online mode; other modules support only offline mode
Module Output Channel ID Channel Function
VIN 0 Offline channel, outputs camera frames to DDR
1 Online channel, connects to ISP
3 Offline channel, outputs only emb data to DDR
ISP 0 Offline channel, outputs ISP-processed frames to DDR
1 Online channel, connects to VSE
VSE 0 Offline channel, 4K Downscale
1 Offline channel, 1080P0 Downscale
2 Offline channel, 1080P1 Downscale
3 Offline channel, 720P0 Downscale
4 Offline channel, 720P1 Downscale
5 Offline channel, 4K Upscale
GDC 0 Offline channel, outputs GDC-processed frames to DDR
5.2.3.2. Connection Methods
Only VIN and ISP output channels support online mode; other modules support only offline mode. Therefore, the combinations among VIN, ISP, and VSE are described as follows:
NOTE: When an HDR sensor is connected, the VIN-ISP connection must use online mode. Since online mode exclusively occupies the ISP resource, only 1 stream is supported.
Module Combination Connection Method Description
VIN - ISP VIN online to ISP, ISP in PASSTHROUGH_MODE Hardware connection between VIN and ISP, bypassing DDR; supports up to one stream using this method
VIN online to ISP, ISP in MCM_MODE Supports up to four streams using this method. Reserved mode, currently not recommended
VIN offline to ISP, ISP in DDR_MODE Requires passing through DDR; supports up to six streams using this method
VIN - VSE VIN offline to VSE When Camera Sensor does not require ISP, bind VIN directly to VSE; supports only offline
ISP - VSE ISP online to VSE Hardware connection between ISP and VSE, bypassing DDR; supports up to four streams using this method
ISP offline to VSE Requires passing through DDR
5.2.3.3. Parameter Configuration
When binding two vnode nodes using the function hbn_vflow_bind_vnode, the connection method between modules is determined. However, the VIN and ISP nodes must be configured accordingly, as detailed below:
Module Combination Connection Method hbn_vflow_bind_vnode function vin_node_attr structure isp_node_attr structure
VIN - ISP Online (ISP in PASSTHROUGH_MODE) 1. src_out_channel =1
2. dst_input_channel =0
cim_isp_flyby =1 input_mode = 0
VIN - ISP Online (ISP in MCM_MODE) 1. src_out_channel =1
cim_isp_flyby =1 input_mode = 1
VIN - ISP Offline (ISP in DDR_MODE) 1. src_out_channel =0
1. ddr_en =1
2. cim_isp_flyby =0
input_mode = 2
VIN - VSE Offline 1. src_out_channel =0
ISP - VSE Online 1. src_out_channel =1
ISP - VSE Offline 1. src_out_channel =0
ddr_en =1 -
5.2.4. API List
API Interface Interface Function
hbn_vnode_open Open vnode
hbn_vnode_close Close vnode
hbn_vnode_set_attr Set vnode attributes
hbn_vnode_get_attr Get vnode attributes
hbn_vnode_set_attr_ex Set vnode extended attributes
hbn_vnode_get_attr_ex Get vnode extended attributes
hbn_vnode_set_ochn_attr Set output channel attributes of the module
hbn_vnode_get_ochn_attr Get output channel attributes of the module
hbn_vnode_set_ochn_attr_ex Set extended output channel attributes of the module, can be dynamically set during application runtime
hbn_vnode_set_ichn_attr Set input channel attributes of the module
hbn_vnode_get_ichn_attr Get input channel attributes of the module
hbn_vnode_set_ichn_attr_ex Set extended input channel attributes of the module, can be dynamically set during application runtime
hbn_vnode_set_ochn_buf_attr Set output channel buffer attributes
hbn_vnode_start Start vnode, module must be opened before starting
hbn_vnode_stop Stop vnode
hbn_vnode_getframe Get image from the module's output channel, blocking interface
hbn_vnode_releaseframe Release image buffer, buffer is returned to the specified output channel
hbn_vnode_sendframe Send image to the module's input channel, triggering module processing. Blocking interface, waits for hardware processing to complete before returning, default timeout is 1 second
hbn_vnode_sendframe_async Send image to the module's input channel, triggers module processing. Non-blocking interface
hbn_vnode_set_output_frame Set image buffer for the module's output channel, non-blocking interface, external buffer setting
hbn_vnode_get_output_frame Get processed image buffer from the module, used with hbn_vnode_set_output_frame, non-blocking interface
hbn_vflow_create Create a vflow, returns vflow handle
hbn_vflow_destroy Destroy a vflow based on vflow handle
hbn_vflow_add_vnode Add module to vflow, managed by vflow
hbn_vflow_bind_vnode Bind two modules together, after binding data frames from src_vnode_fd automatically flow to dst_vnode_fd
hbn_vflow_unbind_vnode Unbind src_vnode_fd and dst_vnode_fd modules
hbn_vflow_start Start a vflow, all vnodes in the vflow will start
hbn_vflow_stop Stop a vflow, all vnodes in the vflow will stop
hbn_vflow_get_vnode_handle Get vnode handle via module ID and context ID
hbn_vflow_create_cfg Create a vflow containing vnodes and their binding relationships from a configuration file
hbn_vflow_get_version Get version information of hbn API
5.2.5. API Call Flow
5.2.5.1. Creation Flow
API Creation Flow
5.2.5.2. Destruction Flow
The destruction flow is the reverse of the creation flow, but note the following:
API Destruction Flow
5.2.6. API Interface Description
5.2.6.1. hbn_vnode_open
【Function Declaration】
hobot_status hbn_vnode_open(hb_vnode_type vnode_type, uint32_t hw_id, int32_t ctx_id, hbn_vnode_handle_t *vnode_fd)
【Parameter Description】
  • [IN] hb_vnode_type vnode_type: vnode type, each hardware module corresponds to one vnode type. Values are HB_VIN, HB_ISP, HB_VSE, HB_GDC, HB_N2D;
  • [IN] uint32_t hw_id: hardware ID of the module. For the VIN module, hw_id values are [0, 3], corresponding to SIF0~SIF3 respectively; other modules use only 0;
  • [IN] uint32_t ctx_id: context ID of the module, a software concept. A specific ctx_id value can be specified, or set to AUTO_ALLOC_ID for automatic allocation by the HNB framework;
  • [OUT] hbn_vnode_handle_t *vnode_fd: returns the vnode handle of the module;
【Return Value】
【Function Description】
Initializes a module and returns its handle hbn_vnode_handle_t.
  1. Before using a module, hbn_vnode_open must be called first.
  2. The hbn_vnode_open function opens the module’s device node (e.g., /dev/vin0_cap).
  3. The hbn_vnode_open function returns a pointer to hbn_vnode_handle_t (vnode_fd), identifying a specific software instance of the module.
    For example, in the function hbn_vflow_bind_vnode, both parameters src_vnode_fd and dst_vnode_fd are hbn_vnode_handle_t pointers returned by hbn_vnode_open.
  4. The essence of hbn_vnode_handle_t is int64_t. The hbn_vnode_open function generates a system-unique integer value returned via *vnode_fd.
【Notes】
5.2.6.2. hbn_vnode_close
void hbn_vnode_close(hbn_vnode_handle_t vnode_fd)
  • [IN] hbn_vnode_handle_t vnode_fd: vnode handle of the module;
【Return Value】
None
Closes the module’s device node.
【Notes】
  • After calling hbn_vflow_destroy, there is no need to call hbn_vnode_close.
  • When a module is bound to a vflow: call hbn_vflow_destroy, no need to call hbn_vnode_close.
  • When a module is used independently (e.g., only ISP, VSE, GDC recirculation, not bound to a vflow): hbn_vnode_close must be called.
5.2.6.3. hbn_vnode_set_attr
hobot_status hbn_vnode_set_attr(hbn_vnode_handle_t vnode_fd, void *attr)
  • [IN] void *attr: pointer to the module’s basic attribute structure. The basic attribute structure can be vin_attr_t, isp_attr_t, vse_attr_t, etc., ending with module name +_attr_t;
【Return Value】
Sets the basic attributes of the module.
【Notes】
None
5.2.6.4. hbn_vnode_get_attr
hobot_status hbn_vnode_get_attr(hbn_vnode_handle_t vnode_fd, void *attr)
  • [OUT] void *attr: pointer to the module’s basic attribute structure. The basic attribute structure can be vin_attr_t, isp_attr_t, vse_attr_t, etc., ending with module name +_attr_t;
【Return Value】
Gets the basic attributes of the module.
【Notes】
None
5.2.6.5. hbn_vnode_set_attr_ex
hobot_status hbn_vnode_set_attr_ex(hbn_vnode_handle_t vnode_fd, void *attr)
  • [IN] void *attr: pointer to the module’s extended attribute structure. Extended attribute structures can be vin_attr_ex_t, etc., ending with module name +_attr_ex_t;
【Return Value】
Sets the extended attributes of the module, which can be dynamically set during application runtime.
【Notes】
None
5.2.6.6. hbn_vnode_get_attr_ex
hobot_status hbn_vnode_get_attr_ex(hbn_vnode_handle_t vnode_fd, void *attr)
  • [OUT] void *attr: pointer to the module’s extended attribute structure. Extended attribute structures can be vin_attr_ex_t, etc., ending with module name +_attr_ex_t;
【Return Value】
Gets the extended attributes of the module.
【Notes】
None
5.2.6.7. hbn_vnode_set_ochn_attr
hobot_status hbn_vnode_set_ochn_attr(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, void *attr)
  • [IN] uint32_t ochn_id: output channel ID of the module, channel IDs refer to: Module Channel Description;
  • [IN] void *attr: pointer to the module’s output channel attribute structure. Output channel attributes can be vin_ochn_attr_t, isp_ochn_attr_t, etc., ending with module name +_ochn_attr_t;
【Return Value】
Sets the output channel attributes of the module.
【Notes】
None
5.2.6.8. hbn_vnode_get_ochn_attr
hobot_status hbn_vnode_get_ochn_attr(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, void *attr)
  • [OUT] void *attr: pointer to the module’s output channel attribute structure. Output channel attributes can be vin_ochn_attr_t, isp_ochn_attr_t, etc., ending with module name +_ochn_attr_t;
【Return Value】
Gets the output channel attributes of the module.
【Notes】
None
5.2.6.9. hbn_vnode_set_ochn_attr_ex
hobot_status hbn_vnode_set_ochn_attr_ex(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, void *attr)
  • [IN] void *attr: pointer to the module’s extended output channel attribute structure. Extended output channel attributes can be vse_ochn_attr_ex_t, etc., ending with module name +_ochn_attr_ex_t;
【Return Value】
Sets the extended output channel attributes of the module, which can be dynamically set during application runtime.
【Notes】
None
5.2.6.10. hbn_vnode_set_ichn_attr
hobot_status hbn_vnode_set_ichn_attr(hbn_vnode_handle_t vnode_fd, uint32_t ichn_id, void *attr)
  • [IN] uint32_t ichn_id: input channel ID of the module, channel IDs refer to: Module Channel Description
  • [IN] void *attr: pointer to the module’s input channel attribute structure. Input channel attributes can be vin_ichn_attr_t, isp_ichn_attr_t, etc., ending with module name +_ichn_attr_t;
【Return Value】
Sets the input channel attributes of the module.
【Notes】
None
5.2.6.11. hbn_vnode_get_ichn_attr
hobot_status hbn_vnode_get_ichn_attr(hbn_vnode_handle_t vnode_fd, uint32_t ichn_id, void *attr)
  • [OUT] void *attr: pointer to the module’s input channel attribute structure. Input channel attributes can be vin_ichn_attr_t, isp_ichn_attr_t, etc., ending with module name +_ichn_attr_t;
【Return Value】
Gets the input channel attributes of the module.
【Notes】
NoneNone
5.2.6.12. hbn_vnode_set_ichn_attr_ex
hobot_status hbn_vnode_set_ichn_attr_ex(hbn_vnode_handle_t vnode_fd, uint32_t ichn_id, void *attr)
  • [IN] hbn_vnode_handle_t vnode_fd: The vnode handle of the module;
  • [IN] uint32_t ichn_id: Input channel ID of the module. See channel IDs in: Module Channel Description
  • [IN] void *attr: Pointer to the extended attribute structure for the input channel. Extended input channel attributes refer to structures ending with module name + _ichn_attr_ex_t;
【Return Value】
Set extended attributes for the module’s input channel, which can be dynamically configured during application runtime.
【Notes】
None
5.2.6.13. hbn_vnode_set_ochn_buf_attr
hobot_status hbn_vnode_set_ochn_buf_attr(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, hbn_buf_alloc_attr_t *alloc_attr)
  • [IN] uint32_t ochn_id: Output channel ID of the module. See channel IDs in: Module Channel Description
  • [IN] hbn_buf_alloc_attr_t *alloc_attr: Buffer allocation attributes;
【Return Value】
Set buffer attributes for the output channel.
【Notes】
5.2.6.14. hbn_vnode_start
hobot_status hbn_vnode_start(hbn_vnode_handle_t vnode_fd)
【Return Value】
Start the module.
【Notes】
The module must be opened before starting.
5.2.6.15. hbn_vnode_stop
hobot_status hbn_vnode_stop(hbn_vnode_handle_t vnode_fd)
【Return Value】
Stop the module.
【Notes】
None
5.2.6.16. hbn_vnode_getframe
hobot_status hbn_vnode_getframe(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, uint32_t millisecondTimeout, hbn_vnode_image_t *out_img)
  • [IN] uint32_t millisecondTimeout: Timeout waiting time;
  • [OUT] hbn_vnode_image_t *out_img: Address of the output image buffer structure;
【Return Value】
Retrieve image from the module’s output channel. This is a blocking interface.
【Notes】
None
5.2.6.17. hbn_vnode_releaseframe
hobot_status hbn_vnode_releaseframe(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, hbn_vnode_image_t *img)
  • [IN] hbn_vnode_image_t *img: Address of the image buffer structure;
【Return Value】
Release the image buffer; the buffer will be returned to the specified output channel.
【Notes】
None
5.2.6.18. hbn_vnode_sendframe
hobot_status hbn_vnode_sendframe(hbn_vnode_handle_t vnode_fd, uint32_t ichn_id, hbn_vnode_image_t *img)
  • [IN] hbn_vnode_image_t *img: Address of the input image buffer;
【Return Value】
Send an image to the module’s input channel, triggering the module to process it. This is a blocking interface that waits for hardware processing to complete before returning, with a default timeout of 1 second.
【Notes】
None
5.2.6.19. hbn_vnode_sendframe_async
hobot_status hbn_vnode_sendframe_async(hbn_vnode_handle_t vnode_fd, uint32_t ichn_id, hbn_vnode_image_t *img)
【Return Value】
Send an image to the module’s input channel, triggering the module to process it. This is a non-blocking interface.
【Notes】
None
5.2.6.20. hbn_vnode_set_output_frame
hobot_status hbn_vnode_set_output_frame(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, hbn_vnode_image_t *img)
  • [IN] hbn_vnode_image_t *img: Address of the output image buffer;
【Return Value】
Set the image buffer for the module’s output channel. This is a non-blocking interface. External setting of output buffer; usage refer to sample code.
【Notes】
  • Only supports VSE, GDC, and GDC bound with VSE, for use in three scenarios with feedback mode
  • Requires control over allocation, release, and cache management of output buffers
  • Output buffer must satisfy: Y and UV address spaces must be contiguous, use ION space, and fill in necessary bufferindex and share_id
  • Does not support simultaneous internal buffer control operations, i.e., internal buffer allocation via hbn_vnode_set_ochn_buf_attr
5.2.6.21. hbn_vnode_get_output_frame
hobot_status hbn_vnode_get_output_frame(hbn_vnode_handle_t vnode_fd, uint32_t ochn_id, hbn_vnode_image_t *img)
【Return Value】
Retrieve the processed image buffer from the module. Used in conjunction with hbn_vnode_set_output_frame, this is a non-blocking interface; usage refer to sample code.
【Notes】
5.2.6.22. hbn_vflow_create
hobot_status hbn_vflow_create(hbn_vflow_handle_t *vflow_fd)
  • [OUT] hbn_vflow_handle_t *vflow_fd: vflow handle;
【Return Value】
Create a vflow and return the vflow handle.
【Notes】
None
5.2.6.23. hbn_vflow_destroy
void hbn_vflow_destroy(hbn_vflow_handle_t vflow_fd)
  • [IN] hbn_vflow_handle_t *vflow_fd: vflow handle;
【Return Value】
None
Destroy a vflow based on the provided vflow handle.
【Notes】
None
5.2.6.24. hbn_vflow_add_vnode
hobot_status hbn_vflow_add_vnode(hbn_vflow_handle_t vflow_fd, hbn_vnode_handle_t vnode_fd)
【Return Value】
Add a module to the vflow for management.
【Notes】
None
5.2.6.25. hbn_vflow_bind_vnode
hobot_status hbn_vflow_bind_vnode(hbn_vflow_handle_t vflow_fd, hbn_vnode_handle_t src_vnode_fd, uint32_t out_chn, hbn_vnode_handle_t dst_vnode_fd, uint32_t in_chn)
  • [IN] hbn_vnode_handle_t src_vnode_fd: Source module’s vnode handle;
  • [IN] uint32_t out_chn: Output channel ID of the source module. See channel IDs in: Module Channel Description
  • [IN] hbn_vnode_handle_t dst_vnode_fd: Destination module’s vnode handle;
  • [IN] uint32_t in_chn: Input channel ID of the destination module. See channel IDs in: Module Channel Description
【Return Value】
Bind two modules together. After binding, data frames from the src_vnode_fd module will automatically flow to the dst_vnode_fd module.
【Notes】
The flow must be created and the modules must be opened.
5.2.6.26. hbn_vflow_unbind_vnode
hobot_status hbn_vflow_unbind_vnode(hbn_vflow_handle_t vflow_fd, hbn_vnode_handle_t src_vnode_fd, uint32_t out_chn, hbn_vnode_handle_t dst_vnode_fd, uint32_t in_chn)
【Return Value】
Unbind the src_vnode_fd and dst_vnode_fd modules.
【Notes】
  • No need to call hbn_vflow_unbind_vnode after calling hbn_vflow_destroy
5.2.6.27. hbn_vflow_start
hobot_status hbn_vflow_start(hbn_vflow_handle_t vflow_fd)
  • [IN] hbn_vflow_handle_t vflow_fd: vflow handle;
【Return Value】
Start a vflow. All vnodes contained within the vflow will be started.
【Notes】
Module vnode needs to be added to vflow in advance.
5.2.6.28. hbn_vflow_stop
hobot_status hbn_vflow_stop(hbn_vflow_handle_t vflow_fd)
【Return Value】
Stop a vflow. All vnodes contained in the vflow will be stopped.
【Notes】
Should be used in pair with hbn_vflow_start.
5.2.6.29. hbn_vflow_get_vnode_handle
hbn_vnode_handle_t hbn_vflow_get_vnode_handle(hbn_vflow_handle_t vflow_fd, hb_vnode_type vnode_type, uint32_t index)
  • [IN] hb_vnode_type vnode_type: module ID;
  • [IN] uint32_t index: context ID, range [0, 7]
【Return Value】
Obtain vnode handle via module ID and context ID.
【Notes】
The module must be opened in advance.
5.2.6.30. hbn_vflow_create_cfg
hobot_status hbn_vflow_create_cfg(const char *cfg_file, hbn_vflow_handle_t *vflow_fd)
  • [IN] const char *cfg_file: configuration file path;
  • [OUT] hbn_vflow_handle_t *vflow_fd: pointer to vflow handle array, which may contain multiple vflows;
【Return Value】
Create a vflow containing vnodes and their binding relationships from a configuration file.
Operations inside the interface include: creating vflow, creating vnode, adding vnode to vflow, and binding vnodes.
【Notes】
None
5.2.6.31. hbn_vflow_get_version
hobot_status hbn_vflow_get_version(hbn_version_t *version)
  • [OUT] hbn_version_t *version: pointer to version information structure
【Return Value】
Obtain version information of hbn API.
【Notes】
Not supported yet.
5.2.7. Data Structures
5.2.7.1. Common Parameters
Name Type Min Max Default Description Required
flags int64_t - - - buffer flag, refer to hbmem module Yes
buffers_num uint32_t - - - number of buffers to allocate Yes
is_contig uint32_t - - - whether multi-layer buffers are allocated as a contiguous block Yes
hbn_frame_info_t
frame_id uint32_t - - - frame ID -
timestamps uint64_t - - - timestamp obtained from kernel at sif framestart -
sys_timestamps uint64_t - - - system timestamp obtained from kernel at sif framestart -
tv struct timeval - - - hardware timestamp obtained at sif framestart -
trig_tv struct timeval - - - hardware timestamp at sensor trigger exposure moment in trigger mode -
frame_done uint32_t - - - temporarily unused -
bufferindex int32_t - - - index of corresponding buffer
hbn_vnode_image_t
info hbn_frame_info_t - - - frame information -
buffer hb_mem_graphic_buf_t - - - buffer information -
*metadata void - - - metadata data -
hbn_version_t
major uint32_t - - - major version number -
minor uint32_t - - - minor version number -
5.2.7.2. MIPI Parameters
mipi_config_t
rx_enable uint32_t 0 1 0 RX device enable, enables corresponding MIPI RX port. Yes
rx_attr mipi_host_cfg_t - - - RX device attributes, sets properties of corresponding MIPI RX port. Yes
rx_ex_mask uint64_t - - - RX advanced attribute mask. No
rx_attr_ex mipi_host_param_t - - - RX advanced attribute configuration No
*bypass mipi_bypass_t - - - MIPI RX -> TX bypass enable, data received via MIPI RX is directly sent out via MIPI TX. No
mipi_host_cfg_t
phy uint16_t 0 1 0 0: represents dphy, X5 only supports this protocol. No
lane uint16_t 1 4 - number of mipi lanes; each MIPI RX currently supports 2 lanes by default; setting to 4 enables lane stitching. Yes
datatype uint16_t - - - input data format of mipi, must match sensor configuration. Yes
fps uint16_t 0 120 0 frame rate, used for calculating MIPI configuration. Yes
mclk uint16_t 0 65535 0 sensor mclk configuration: Yes
0: use external mclk
1: use chip-generated 24MHz mclk
2~24: invalid and dropped
25~636: invalid and error
637~ : configured frequency = mclk*10KHz → 6.37MHz~655.35MHz
mipiclk uint16_t 0 - 0 total MIPI transmission rate (all LANEs) Yes
width uint16_t 0 8192 - input image width (in pixels) Yes
height uint16_t 0 4096 - input image height (in pixels) Yes
linelenth uint16_t 0 - - total line length including hblank, used by RX for ipi parameter calculation, TX VPG mode can adjust frame rate Yes
framelenth uint16_t 0 - - total height including hblank, used by RX for ipi parameter calculation, TX VPG mode can adjust frame rate Yes
settle uint16_t 0 - - mipi settle time, phy settle time configuration, adjustable when phy error occurs Yes
ppi_pg uint16_t 0 - - mipi output test pattern, not functional, reserved for future use No
hsaTime uint16_t 0 - - ipi configuration, time of horizontal synchronism active No
hbpTime uint16_t 0 - - ipi configuration, time of horizontal back period No
hsdTime uint16_t 0 - - ipi configuration, time of horizontal sync porch delay period No
channel_num uint16_t 0 4 0 number of mipi virtual channels Yes
channel_sel[MIPIHOST_CHANNEL_NUM] uint16_t 0 1 0 ipi channel corresponding to mipi virtual channel Yes
5.2.7.3. SIF Parameters
vin_attr_t
vin_node_attr vin_node_attr_t - - - vin node attribute description Yes
vin_attr_ex vin_attr_ex_t - - - enhanced vin node attribute description Yes
vin_ochn_attr[] vin_ochn_attr_t - - - vin node output channel attribute description Yes
vin_ichn_attr vin_ichn_attr_t - - - vin node input channel attribute description Yes
vin_ochn_buff_attr[] vin_ochn_buff_attr_t - - - vin node output buffer attribute description Yes
vin_node_attr_t
cim_attr cim_attr_t - - - cim/sif attribute description Yes
lpwm_attr lpwm_attr_t - - - lpwm attribute description, used for multi-sensor synchronization No
vcon_attr vcon_attr_t - - - vcon attribute description No
flow_id uint32_t 0 - - pipeline ID, can be left unset No
cim_attr_t
mipi_en uint32_t 0 1 0 enable mipi, reserved, currently not required No
mipi_rx uint32_t 0 4 0 mipi rx port number Yes
vc_index uint32_t 0 4 0 mipi virtual index Yes
ipi_channel uint32_t 1 2 0 ipi channel number, Yes
1 for linear mode,
2 for hdr dol2 mode
tpg_input cim_input_tpg_t - - - reserved for future use No
func cim_func_desc_t - - - cim/sif advanced functions Yes
cim_func_desc_t
enable_frame_id uint32_t 0 1 0 enable frame ID No
set_init_frame_id uint32_t 0 - 0 initial value for frame ID No
time_stamp_en uint32_t - - - enable timestamp No
time_stamp_mode uint32_t 1 8 - sif/cim timestamp latching type, select one of the following: No
0x01: latch tv at frame start
0x02: latch trig_tv at sensor exposure trigger
0x03: latch both tv and trig_tv, recommended
Others: reserved
ts_src uint32_t 0 12 0 source that triggers SIF to latch timestamp No
0: trig_tv and tv timestamps not enabled
1: LPWM0_CHN0 triggers high-level moment for SIF to latch tv and trig_tv
2: LPWM0_CHN1 triggers high-level moment for SIF to latch tv and trig_tv
3: LPWM0_CHN2 triggers high-level moment for SIF to latch tv and trig_tv
4: LPWM0_CHN3 triggers high-level moment for SIF to latch tv and trig_tv
5: LPWM1_CHN0 triggers high-level moment for SIF to latch tv and trig_tv
6: LPWM1_CHN1 triggers high-level moment for SIF to latch tv and trig_tv
7: LPWM1_CHN2 triggers high-level moment for SIF to latch tv and trig_tv
8: LPWM1_CHN3 triggers high-level moment for SIF to latch tv and trig_tv
9: ENET_PTP reserved, not used
10: SW reserved, not used
11: MCU reserved, not used
12: GPS reserved, not used
pps_src uint32_t - - - reserved, not used No
enable_pattern uint32_t - - - reserved, not used No
skip_frame cim_skip_type_e 0 4 0 software skip frame mode, takes effect during pipeline initialization No
0 (CIM_DISABLE_SKIP): skip frame disabled
1 (CIM_IN_RATIO_SKIP): ratio-based skip frame, requires input_fps and output_fps
2 (CIM_FIRST_FRAMES_SKIP): discard the first N frames
3 (CIM_HW_SKIP): hardware skip frame
input_fps uint32_t 1 - 0 input frame rate, i.e. actual sensor frame rate. Required when skip_frame = 1 No
output_fps uint32_t 1 - 0 desired output frame rate, must be less than input_fps. Required when skip_frame = 1 No
Uses Bresenham algorithm to drop frames evenly in SIF DONE interrupt
Example: input_fps=30, output_fps=1 means keeping only 1 frame out of 30fps
skip_nums uint32_t - - - reserved, not used No
hw_extract_m uint32_t - - - reserved, not used No
hw_extract_n uint32_t - - - reserved, not used No
hdr_mode enum hdr_mode 0 2 0 value set as enum hdr_mode: Yes
0: no multi-frame synthesis required by SoC ISP
1: two-frame synthesis required by SoC
2: three-frame synthesis required (reserved, not supported by X5)
vin_attr_ex_t
Set VIN extended attributes via hbn_vnode_set_attr_ex, supporting both static configuration and runtime dynamic modification. Each call requires setting ex_attr_type to specify the operation type.
ex_attr_type vin_attr_ex_type_e - - - extended attribute type, determines which field takes effect Yes
VIN_STATIC_CIM_ATTR (0): CIM static attributes
VIN_DYNAMIC_FPS_CTRL (2): runtime dynamic frame rate control
VIN_STATIC_MCLK_ATTR (7): MCLK frequency configuration
cim_static_attr cim_static_attr_t - - - CIM static attributes, effective when ex_attr_type = 0 No
fps_ctrl dynamic_fps_t - - - dynamic frame rate control, effective when ex_attr_type = 2 No
mclk_ex_attr mclk_attr_ex_t - - - MCLK extended attributes, effective when ex_attr_type = 7 No
vin_attr_ex_mask uint64_t - - 0 attribute mask during initialization, bit positions correspond to ex_attr_type enum values No
dynamic_fps_t
Runtime frame rate control structure, used with hbn_vnode_set_attr_ex and ex_attr_type = VIN_DYNAMIC_FPS_CTRL. Frame rate can be modified at any time while the pipeline is running, taking effect on the next frame immediately.
skip_mode cim_skip_type_e 0 4 0 skip frame mode Yes
0 (CIM_DISABLE_SKIP): skip frame disabled, restore original sensor frame rate
in_fps uint32_t 1 - 0 input frame rate (actual sensor frame rate), required when skip_mode = 1 Yes
out_fps uint32_t 1 - 0 desired output frame rate, must be less than in_fps, required when skip_mode = 1 Yes
Example: in_fps=30, out_fps=10 means output 10fps
Usage example (runtime dynamic frame rate modification):
vin_attr_ex_t vin_attr_ex = {0};
vin_attr_ex.ex_attr_type = VIN_DYNAMIC_FPS_CTRL;
vin_attr_ex.fps_ctrl.skip_mode = CIM_IN_RATIO_SKIP;  // ratio-based skip frame
vin_attr_ex.fps_ctrl.in_fps  = 30;   // actual sensor frame rate
vin_attr_ex.fps_ctrl.out_fps = 10;   // desired output 10fps
hbn_vnode_set_attr_ex(vin_node_handle, &vin_attr_ex);
// disable skip frame, restore original frame rate
vin_attr_ex.fps_ctrl.skip_mode = CIM_DISABLE_SKIP;
vin_attr_ex.fps_ctrl.in_fps  = 0;
vin_attr_ex.fps_ctrl.out_fps = 0;
vin_ochn_attr_t
ddr_en uint32_t 0 1 0 whether data is written to DDR Yes
roi_en uint32_t - - - reserved No
emb_en uint32_t - - - reserved, whether sensor embedded data is written to DDR No
ochn_attr_type vin_ochn_attr_type_e - - - vin ochn attribute
VIN_BASIC_ATTR, // default, basic vin attribute
VIN_EMB_ATTR, // sensor with emb output
Yes
vin_basic_attr vin_basic_attr_t - - - vin basic attribute, required when writing to DDR Yes
rawds_attr vin_rawds_attr_t - - - reserved No
roi_attr vpm_commn_roi_data_desc - - - reserved No
emb_attr vin_emb_attr_t - - - reserved, required when emb is enabled No
vin_basic_attr_t
pack_mode uint32_t - - - reserved No
wstride uint32_t 0 - - wide stride for cim/sif DDR output, 16-byte aligned. Yes
width for raw8, 2*width for raw10~raw16
vstride uint32_t - - - reserved No
format uint32_t - - - required when writing to DDR Yes
vin_pdaf_attr_t
pdaf_en uint32_t - - 0 whether PD info channel is enabled, 1: enabled, 0: disabled Yes
pd_ipi_channel uint32_t 0 3 - specify which IPI channel PD info uses.
RAW data uses IPI channel 0, PD info can use channel 1
Yes
pd_width uint32_t - - width of PD info Yes
pd_height uint32_t - - - height of PD info Yes
pd_format uint32_t - - - format of PD info Yes
vin_ichn_attr_t
format uint32_t - - - vin format, sensor output format Yes
width uint32_t 0 8192 0 sensor output resolution width in pixels Yes
height uint32_t 0 4096 0 sensor output resolution height in pixels Yes
buffers_num uint32_t 0 - 0 number of buffers for cim/sif DDR output, typically set to 6 Yes
flags int64_t - - - typically set in program as: No
hbn_buf_alloc_attr_t.flags = HB_MEM_USAGE_CPU_READ_OFTEN OR
HB_MEM_USAGE_CPU_WRITE_OFTEN OR
HB_MEM_USAGE_CACHED
lpwm_attr_t
enable uint32_t 0 - 0 whether to enable LPWM No
lpwm_chn_attr_t lpwm_chn_attr[LPWM_CHN_NUM] - - - - LPWM channel attribute configuration No
LPWM_CHN_NUM is 4
lpwm_chn_attr_t
Name Type Min Max Default Description Required Output 30Hz, high level 10us parameters
trigger_source uint32_t 0 10 0 trigger source selection No
0-3: pad_trigger_in, hardware IO input PPS
4: enet_ptp_pps, reserved
5: sw_trigger_in, software trigger
6: gps_trigger_in (TIME_SYNC2), hardware IO input PPS
7: mcu_trigger_in (TIME_SYNC1), hardware IO input PPS
8: time_sync2_in (TIME_SYNC3), hardware IO input PPS
9: time_sync3_in (TIME_SYNC4), hardware IO input PPS
10: camera_1sec_pulse_out, reserved
Note: refer to pinlist document for corresponding hardware IO pins.
trigger_mode uint32_t 0 1 0 trigger mechanism (1 - external hardware trigger, 0 - internal software trigger ) No
when trigger_mode is 0, automatically set to software trigger, trigger_source can be omitted
period uint32_t 2 us 1000000 us 0 period, actual effective period is (period + 1)us No 33332
offset uint32_t 0 (1000000/period) us 0 after LPWM is triggered by source, LPWM outputs square wave after offset(us). No 11
effective time: floor((1/24) * (offset * 24 + 3)) us
duty_time uint32_t 0 (4096/period) us 0 high-level active time, actual effective time is (duty_time + 1)us No 9
threshold uint32_t 0 65535 us 0 threshold for slow synchronization function No 0
adjust_step uint32_t 0 15 0 adjustment time per step: adjust_time = 2 ^ adjust_step No 0
5.2.7.4. ISP Parameters
isp_cfg_t
isp_attr isp_attr_t · · · ISP basic attributes Yes
ochn_attr isp_ochn_attr_t · · · ISP output channel attributes Yes
ichn_attr isp_ichn_attr_t · · · ISP input channel attributes Yes
isp_attr_t
input_mode uint32_t 0 2 0 upstream module input mode
0 - PASSTHROUGH_MODE
1 - MCM_MODE
2 - DDR_MODE
Note:
when input_mode is 0 or 1, sif must bind to isp using channel 1.
when input_mode is 2, sif DDR function must be enabled,
and sif binds to isp using channel 0.
PASSTHROUGH_MODE supports single stream only,
MCM_MODE supports up to four streams.
Yes
sched_mode uint32_t 0 2 0 image processing priority policy, currently not supported
0 - ROUND_ROBIN
1 - FIXED_SEQUENCE
2 - FIFO
No
tile_mode uint32_t 0 1 0 whether to enable tile_mode, must be enabled when input size exceeds 4096 No
sensor_mode isp_sensor_mode_e 0 2 0 corresponding sensor mode
0 - ISP_NORMAL_M
1 - ISP_DOL2_M
2 - ISP_PWL_M
Yes
crop common_rect_t · · · crop region for input image No
isp_ichn_attr_t
tpg_en cam_bool_e 0 1 0 enable tpg function, currently not supported No
width uint32_t 0 5472 0 input image width Yes
height uint32_t 0 3076 0 input image height Yes
fmt frame_format_e FRM_FMT_RAW FRM_FMT_RAW 0 FRM_FMT_NULL - invalid, FRM_FMT_RAW - RAW format, FRM_FMT_NV12 - NV12 format, FRM_FMT_UYVY - UYVY format, currently only RAW format is supported Yes
bit_width uint32_t 8 12 0 bit width of input image data Yes
isp_ochn_attr_t
ddr_en cam_bool_e 0 1 0 output image to DDR Yes
out common_rect_t · · · output image size, post-crop not supported yet, so setting has no effect No
fmt frame_format_e FRM_FMT_NV12 FRM_FMT_NV12 0 FRM_FMT_NULL - invalid, FRM_FMT_RAW - RAW format, FRM_FMT_NV12 - NV12 format, FRM_FMT_UYVY - UYVY format, currently only NV12 format is supported Yes
bit_width uint32_t 8 8 8 bit width of output image data, currently only NV12 format, 8bit Yes
5.2.7.5. VSE Parameters
vse_ochn_type_e
VSE_DOWN_SCALE_4K - - - - downscale output channel, maximum 4K -
VSE_DOWN_SCALE_1080P0 - - - - downscale output channel, maximum 1080p-0 -
VSE_DOWN_SCALE_1080P1 - - - - downscale output channel, maximum 1080p-1 -
VSE_DOWN_SCALE_720P0 - - - - downscale output channel, maximum 720p-0 -
VSE_DOWN_SCALE_720P1 - - - - downscale output channel, maximum 720p-1 -
VSE_UP_SCALE_4K - - - - upscale output channel, up to 4x scaling, maximum output size 4096x3076 -
Note: 4x of cropped size; width and height scaling ratios can be adjusted freely, total scaling factor up to 4
VSE_OCHN_MAX
vse_cfg_t
vse_attr vse_attr_t - - - vse basic attributes Yes
ochn_attr[VSE_OCHN_MAX] vse_ochn_attr_t - - - vse output channel attributes Yes
ichn_attr vse_ichn_attr_t - - - vse input channel attributes Yes
vse_attr_t
fps frame_fps_ctrl_t - - 0 configure fps of input image src, used for frame rate control No
vse_ichn_attr_t
width uint32_t 0 5432 0 original input image width Yes
height uint32_t 0 3076 0 original input image height Yes
fmt frame_format_e FRM_FMT_NV12 FRM_FMT_NV12 0 image format, currently only NV12 format supported Yes
bit_width uint32_t 8 8 0 input image bit width Yes
vse_ochn_attr_t
chn_en cam_bool_e 0 1 0 enable channel Yes
roi common_rect_t - - - crop region for output image, all zeros means disabled No
target_w uint32_t 0 limited by channel capability 0 output image width, 0 means scale disabled Yes
target_h uint32_t 0 limited by channel capability 0 output image height, 0 means scale disabled Yes
y_stride uint32_t 0 - 0 y-plane stride of output image, currently not supported No
uv_stride uint32_t 0 - 0 uv-plane stride of output image, currently not supported No
fmt frame_format_e FRM_FMT_NV12 FRM_FMT_NV12 0 output image format, currently only NV12 format supported Yes
bit_width uint32_t 8 8 0 output image bit width Yes
fps frame_fps_ctrl_t - - 0 configure fps of output image dst, used for frame rate control No
Notes:
  • Fields such as width, height, format, etc., must comply with hardware capability limitations.
  • A default value of 0 may disable the corresponding function.
5.2.7.6. GDC Parameters
gdc_attr_t
config_addr uint64_t - - - Address of the GDC configuration file Yes
config_size uint32_t - - - Size of the GDC configuration file Yes
div_width uint8_t 8 - 0 Reserved (not used for now) Yes
div_height uint8_t 0 - 0 Reserved (not used for now) No
total_planes uint32_t 0 - 0 Number of YUV layers Yes
binary_ion_id int32_t 0 - 0 Share ID of the physical address of the configuration file Yes
binary_offset uint64_t 0 - 0 Offset of the physical address where the configuration file resides Yes
gdc_ichn_attr_t
input_width uint32_t 0 4096 0 Width of input image Yes
input_height uint32_t 0 2160 0 Height of input image Yes
input_stride uint32_t 0 - 0 Stride of input image Yes
n_in_one uint32_t 0 - 0 Feed n frames to compose 1 frame Yes
gdc_ochn_attr_t
output_width uint32_t 0 - 0 Width of output image Yes
output_height uint32_t 0 - 0 Height of output image Yes
output_stride uint32_t 0 - 0 Stride of output image Yes
Notes
  1. The input and output width and height of GDC must be even numbers.
  2. Input and output strides must be multiples of 16.
5.2.7.7. N2D Parameters
n2d_command_t
scale - - - - Indicates that scale (resizing) operation will be performed Yes
overlay - - - - Indicates that overlay (layering) operation will be performed Yes
stitch - - - - Indicates that stitch (image stitching) operation will be performed Yes
csc - - - - Indicates that csc (color space conversion) operation will be performed Yes
n2d_config_t
ninputs uint32_t 0 4 - Number of input channels Yes
input_width[N2D_IN_MAX] uint32_t 0 4096 - Width of N2D input channels Yes
input_height[N2D_IN_MAX] uint32_t 0 2160 - Height of N2D input channels Yes
input_stride[N2D_IN_MAX] uint32_t - - - Row stride of N2D input channels Yes
output_width uint32_t 0 4096 - Width of N2D output channel Yes
output_height uint32_t 0 2160 - Height of N2D output channel Yes
output_stride uint32_t - - - Row stride of N2D output channel Yes
output_format uint32_t - - - Format of N2D output channel Yes
in_buffer_addr[N2D_IN_MAX][HBN_VIO_BUFFER_MAX_PLANES] uint64_t - - - Data address of N2D input channels Yes
out_buffer_addr[HBN_VIO_BUFFER_MAX_PLANES] uint64_t - - - Data address of N2D output channel Yes
command n2d_command_t - - - Operation to be performed by this configuration Yes
5.2.8. Return Value Description
Error Code Macro Definition Description Common Causes and Solutions
0 HBN_STATUS_SUCESS Success
1 HBN_STATUS_INVALID_NODE Invalid vnode, corresponding vnode not found
2 HBN_STATUS_INVALID_NODETYPE Invalid vnode type, corresponding vnode not found For VSE, vnode type should be HB_VSE
3 HBN_STATUS_INVALID_HWID Invalid hardware module ID For VSE, hw_id should be 0
4 HBN_STATUS_INVALID_CTXID Invalid context ID Can be set to AUTO_ALLOC_ID, automatically assigned by HNB framework
5 HBN_STATUS_INVALID_OCHNID Invalid output channel ID VSE output channel range is [0,5]
6 HBN_STATUS_INVALID_ICHNID Invalid input channel ID VSE supports only 1 input channel
7 HBN_STATUS_INVALID_FORMAT Invalid format
8 HBN_STATUS_INVALID_NULL_PTR Null pointer
9 HBN_STATUS_INVALID_PARAMETER Invalid parameter, version check failed
10 HBN_STATUS_ILLEGAL_ATTR Invalid parameter
11 HBN_STATUS_INVALID_FLOW Invalid flow, corresponding flow not found
12 HBN_STATUS_FLOW_EXIST Flow already exists
13 HBN_STATUS_FLOW_UNEXIST Flow does not exist
14 HBN_STATUS_NODE_EXIST Node already exists
15 HBN_STATUS_NODE_UNEXIST Node does not exist
16 HBN_STATUS_NOT_CONFIG Reserved
17 HBN_STATUS_CHN_NOT_ENABLED Channel not enabled
18 HBN_STATUS_CHN_ALREADY_ENABLED Channel already enabled
19 HBN_STATUS_ALREADY_BINDED Node already bound
20 HBN_STATUS_NOT_BINDED Node not bound
21 HBN_STATUS_TIMEOUT Timeout
22 HBN_STATUS_NOT_INITIALIZED Not initialized
23 HBN_STATUS_NOT_SUPPORT Channel not supported or not activated
24 HBN_STATUS_NOT_PERM Operation not allowed
25 HBN_STATUS_NOMEM Insufficient memory
26 HBN_STATUS_INVALID_VNODE_FD Invalid node file descriptor
27 HBN_STATUS_INVALID_ICHNID_FD Invalid input channel file descriptor
28 HBN_STATUS_INVALID_OCHNID_FD Invalid output channel file descriptor
29 HBN_STATUS_OPEN_OCHN_FAIL Failed to open output channel
30 HBN_STATUS_OPEN_ICHN_FAIL Failed to open input channel
31 HBN_STATUS_JSON_PARSE_FAIL JSON parsing failed
32 HBN_STATUS_REQ_BUF_FAIL Failed to request buffer
33 HBN_STATUS_QUERY_BUF_FAIL Failed to query buffer information
34 HBN_STATUS_SET_CONTROL_FAIL Failed to set module control or adjustment parameters (e.g., ISP effect parameters)
35 HBN_STATUS_GET_CONTROL_FAIL Failed to get module control or adjustment parameters (e.g., ISP effect parameters)
36 HBN_STATUS_NODE_START_FAIL Failed to start node
37 HBN_STATUS_NODE_STOP_FAIL Failed to stop node
38 HBN_STATUS_NODE_POLL_ERROR Node channel poll error
39 HBN_STATUS_NODE_POLL_TIMEOUT Node channel poll timeout
40 HBN_STATUS_NODE_POLL_FRAME_DROP Frame drop occurred during node channel poll
41 HBN_STATUS_NODE_POLL_HUP Descriptor hang-up during node channel poll
42 HBN_STATUS_NODE_ILLEGAL_EVENT Illegal event during node channel poll
43 HBN_STATUS_NODE_DEQUE_ERROR Node channel dequeue buffer error
44 HBN_STATUS_ILLEGAL_BUF_INDEX Invalid buffer index
45 HBN_STATUS_NODE_QUE_ERROR Node channel queue buffer error
46 HBN_STATUS_FLUSH_FRAME_ERROR Node channel frame flush error
47 HBN_STATUS_INIT_BIND_ERROR Error occurred during JSON parsing and binding
48 HBN_STATUS_ADD_NODE_FAIL Failed to add node to flow
49 HBN_STATUS_WRONG_CONFIG_ID Node ID not supported by system
50 HBN_STATUS_BIND_NODE_FAIL Error occurred when binding node to flow
51 HBN_STATUS_INVALID_VERSION Mismatch between lower-level driver module and upper-layer library version
52 HBN_STATUS_GET_VERSION_ERROR Failed to get lower-level driver module version
53 HBN_STATUS_MEM_INIT_FAIL hbmem memory initialization failed
54 HBN_STATUS_MEM_IMPORT_FAIL hbmem memory import failed
55 HBN_STATUS_MEM_FREE_FAIL hbmem memory release failed
56 HBN_STATUS_SYSFS_OPEN_FAIL Failed to open system file
57 HBN_STATUS_STRUCT_SIZE_NOT_MATCH HAL layer structure size does not match kernel layer
58 HBN_STATUS_RGN_UNEXIST Unable to retrieve corresponding rgn data
59 HBN_STATUS_RGN_INVALID_OPERATION Invalid rgn operation
60 HBN_STATUS_RGN_OPEN_FILE_FAIL Failed to open file in rgn module
128 HBN_STATUS_ERR_UNKNOW Unknown error
