5.10.2. GDC API
5.10.2.1. Module Description
The GDC (Geometrical Distortion Correction) module performs distortion correction, perspective transformation, and rotation at specified angles (0, 90, 180, 270) on input images.
Basic Specifications
Supported input image resolutions typically include: 3840*2160, 2688*1944, 1920*1080, 1280*720, 640*480, and 480*320.
Hardware features are as follows:
  • Maximum resolution: 4096x2160
  • Minimum resolution: 100x100 (odd number of rows or columns not supported)
  • Performance: 4096x2160@60fps
  • Input format: YUV420 semi-planar
  • Output format: YUV420 semi-planar
5.10.2.2. Reference Examples
  • Partial example code for GDC can be found in the sample_gdc section.
5.10.2.3. API Reference
API Interface Functionality
hbn_vnode_open Open vnode
hbn_vnode_close Close vnode
hbn_vnode_set_attr Set vnode attributes
hbn_vnode_set_ochn_attr Set GDC vnode output channel attributes
hbn_vnode_get_ochn_attr Get GDC vnode output channel attributes
hbn_vnode_set_ichn_attr Set GDC vnode input channel attributes
hbn_vnode_get_ichn_attr Get GDC vnode input channel attributes
hbn_vnode_set_ochn_buf_attr Set GDC vnode output buffer attributes
hbn_vnode_start Start vnode
hbn_vnode_stop Stop vnode
hbn_vnode_getframe Retrieve frame data from vnode
hbn_vnode_sendframe Send frame data to vnode
hbn_vnode_releaseframe Release frame data
5.10.2.4. Interface Descriptions
hbn_vnode_open
【Function Declaration】
【Functional Description】
Initialize the vnode, open the vnode device node, and return the vnode handle for this module.
【Parameter Description】
  • [IN] hb_vnode_type vnode_type: Vnode type; for GDC, use HB_GDC
  • [IN] uint32_t hw_id: Hardware ID of the module; for GDC, hw_id is 0
  • [IN] int32_t ctx_id: Context ID of the module; a software concept. Can be specified manually or set to AUTO_ALLOC_ID for automatic allocation by the HBN framework
  • [OUT] hbn_vnode_handle_t *vnode_fd: Returns the vnode handle of the module
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
hbn_vnode_close
Close the module’s device node.
  • [IN] hbn_vnode_handle_t vnode_fd: The vnode handle of the module
【Return Value】
None
【Notes】
Must be used in pair with hbn_vnode_open.
【Compatibility】
Hardware: X5
hbn_vnode_set_attr
Set basic attributes of the module.
  • [IN] void *attr: Pointer to the attribute structure of the module; for GDC, this is gdc_attr_t
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
Set output channel attributes of the module.
  • [IN] uint32_t ochn_id: Output channel ID of the module; for GDC, the output channel ID is 0
  • [IN] void *attr: Pointer to the output channel attribute structure; for GDC, this is gdc_ochn_attr_t
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
Get output channel attributes of the module.
  • [OUT] void *attr: Pointer to the output channel attribute structure; for GDC, this is gdc_ochn_attr_t
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
Set input channel attributes of the module.
  • [IN] uint32_t ichn_id: Input channel ID of the module; for GDC, the input channel ID is 0
  • [IN] void *attr: Pointer to the input channel attribute structure; for GDC, this is gdc_ichn_attr_t
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
Get input channel attributes of the module.
  • [OUT] void *attr: Pointer to the input channel attribute structure; for GDC, this is gdc_ichn_attr_t
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
Set output channel buffer attributes, including the number of buffers and whether buffer addresses are contiguous.
  • [IN] hbn_buf_alloc_attr_t *alloc_attr: Buffer allocation attributes
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
hbn_vnode_start
Start the module.
【Return Value】
【Notes】
The module must be opened before starting.
【Compatibility】
Hardware: X5
hbn_vnode_stop
Stop the module.
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
hbn_vnode_getframe
                hbn_vnode_image_t *out_img);
Retrieve image from the module’s output channel. This is a blocking interface.
  • [IN] uint32_t millisecondTimeout: Timeout duration in milliseconds
  • [OUT] hbn_vnode_image_t *out_img: Pointer to the output image buffer structure
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
hbn_vnode_sendframe
                 hbn_vnode_image_t *img);
Send an image to the module’s input channel, triggering processing. This is a blocking interface that waits for hardware processing to complete before returning, with a default timeout of 1 second.
  • [IN] hbn_vnode_image_t *img: Pointer to the input image buffer
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
Release the image buffer; the buffer will be returned to the specified output channel.
  • [IN] hbn_vnode_image_t *img: Pointer to the image buffer structure
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.10.2.5. Data Structures
gdc_attr_t
Name Type Min Value Max Value Default Description Required
config_addr uint64_t - - - Address of the GDC configuration file Yes
config_size uint32_t - - - Size of the GDC configuration file Yes
div_width uint8_t 8 - 0 Reserved (not used) Yes
div_height uint8_t 0 - 0 Reserved (not used) No
total_planes uint32_t 0 - 0 Number of YUV planes Yes
binary_ion_id int32_t 0 - 0 Share ID of the physical address of the configuration file Yes
binary_offset uint64_t 0 - 0 Offset of the physical address where the configuration file resides Yes
gdc_ichn_attr_t
input_width uint32_t 0 4096 0 Width of input image Yes
input_height uint32_t 0 2160 0 Height of input image Yes
input_stride uint32_t 0 - 0 Stride of input image Yes
n_in_one uint32_t 0 - 0 Merge n frames into one Yes
gdc_ochn_attr_t
output_width uint32_t 0 - 0 Width of output image Yes
output_height uint32_t 0 - 0 Height of output image Yes
output_stride uint32_t 0 - 0 Stride of output image Yes
5.10.2.6. Return Value Description
Error Code Macro Definition Description Common Causes and Solutions
0 HBN_STATUS_SUCESS Success
1 HBN_STATUS_INVALID_NODE Invalid vnode, corresponding vnode not found
2 HBN_STATUS_INVALID_NODETYPE Invalid vnode type, corresponding vnode not found For GDC, the vnode type should be HB_GDC
3 HBN_STATUS_INVALID_HWID Invalid hardware module ID For GDC, hw_id should be 0
4 HBN_STATUS_INVALID_CTXID Invalid context ID Can be set to AUTO_ALLOC_ID, automatically assigned by the HBN framework
5 HBN_STATUS_INVALID_OCHNID Invalid output channel ID GDC output channel ID is 0
6 HBN_STATUS_INVALID_ICHNID Invalid input channel ID GDC supports only one input channel
7 HBN_STATUS_INVALID_FORMAT Invalid format
8 HBN_STATUS_INVALID_NULL_PTR Null pointer
9 HBN_STATUS_INVALID_PARAMETER Invalid parameter, version check failed
10 HBN_STATUS_ILLEGAL_ATTR Invalid parameter
11 HBN_STATUS_INVALID_FLOW Invalid flow, corresponding flow not found
12 HBN_STATUS_FLOW_EXIST Flow already exists
13 HBN_STATUS_FLOW_UNEXIST Flow does not exist
14 HBN_STATUS_NODE_EXIST Node already exists
15 HBN_STATUS_NODE_UNEXIST Node does not exist
16 HBN_STATUS_NOT_CONFIG Reserved
17 HBN_STATUS_CHN_NOT_ENABLED Channel not enabled
18 HBN_STATUS_CHN_ALREADY_ENABLED Channel already enabled
19 HBN_STATUS_ALREADY_BINDED Node already bound
20 HBN_STATUS_NOT_BINDED Node not bound
21 HBN_STATUS_TIMEOUT Timeout
22 HBN_STATUS_NOT_INITIALIZED Not initialized
23 HBN_STATUS_NOT_SUPPORT Channel not supported or not activated
24 HBN_STATUS_NOT_PERM Operation not allowed
25 HBN_STATUS_NOMEM Insufficient memory
26 HBN_STATUS_INVALID_VNODE_FD Invalid node file descriptor
27 HBN_STATUS_INVALID_ICHNID_FD Invalid input channel file descriptor
28 HBN_STATUS_INVALID_OCHNID_FD Invalid output channel file descriptor
29 HBN_STATUS_OPEN_OCHN_FAIL Failed to open output channel
30 HBN_STATUS_OPEN_ICHN_FAIL Failed to open input channel
31 HBN_STATUS_JSON_PARSE_FAIL JSON parsing failed
32 HBN_STATUS_REQ_BUF_FAIL Failed to request buffer
33 HBN_STATUS_QUERY_BUF_FAIL Failed to query buffer information
34 HBN_STATUS_SET_CONTROL_FAIL Failed to set module control or adjustment parameters (e.g., ISP effect parameters)
35 HBN_STATUS_GET_CONTROL_FAIL Failed to get module control or adjustment parameters (e.g., ISP effect parameters)
36 HBN_STATUS_NODE_START_FAIL Failed to start node
37 HBN_STATUS_NODE_STOP_FAIL Failed to stop node
38 HBN_STATUS_NODE_POLL_ERROR Node channel poll error
39 HBN_STATUS_NODE_POLL_TIMEOUT Node channel poll timeout
40 HBN_STATUS_NODE_POLL_FRAME_DROP Frame drop occurred during node channel poll
41 HBN_STATUS_NODE_POLL_HUP Descriptor hang-up during node channel poll
42 HBN_STATUS_NODE_ILLEGAL_EVENT Illegal event during node channel poll
43 HBN_STATUS_NODE_DEQUE_ERROR Node channel dequeue buffer error
44 HBN_STATUS_ILLEGAL_BUF_INDEX Invalid buffer index
45 HBN_STATUS_NODE_QUE_ERROR Node channel queue buffer error
46 HBN_STATUS_FLUSH_FRAME_ERROR Node channel frame flush error
47 HBN_STATUS_INIT_BIND_ERROR Error occurred during JSON parsing and binding
48 HBN_STATUS_ADD_NODE_FAIL Failed to add node to flow
49 HBN_STATUS_WRONG_CONFIG_ID Node ID not supported by system
50 HBN_STATUS_BIND_NODE_FAIL Error occurred when binding node to flow
51 HBN_STATUS_INVALID_VERSION Version mismatch between low-level driver module and upper-layer library
52 HBN_STATUS_GET_VERSION_ERROR Failed to get version number of low-level driver module
53 HBN_STATUS_MEM_INIT_FAIL hbmem memory initialization failed
54 HBN_STATUS_MEM_IMPORT_FAIL hbmem memory import failed
55 HBN_STATUS_MEM_FREE_FAIL hbmem memory release failed
56 HBN_STATUS_SYSFS_OPEN_FAIL Failed to open system file
57 HBN_STATUS_STRUCT_SIZE_NOT_MATCH Structure size in HAL layer does not match kernel layer
58 HBN_STATUS_RGN_UNEXIST Unable to retrieve corresponding rgn data
59 HBN_STATUS_RGN_INVALID_OPERATION Invalid rgn operation
60 HBN_STATUS_RGN_OPEN_FILE_FAIL Failed to open file in rgn module
128 HBN_STATUS_ERR_UNKNOW Unknown error
