4.4.6. ION System Debugging Guide
4.4.6.1. Overview
The ION system is a memory management subsystem in the Linux kernel designed for managing memory sharing between devices.
In the X5 BSP system, ION memory is primarily used in the following four scenarios:
BPU subsystem
HIFI subsystem (DSP)
Developers allocating ION memory via the hbmem interface
Multimedia system: including hardware acceleration units such as VIN, ISP, VSE, GDC, VPU, OSD, GPU, Display
ION Memory Regions
The ION memory management subsystem uses independent memory regions: reserved areas defined in the device tree, specifically allocated for the ION system. For details, see ION Region Adjustment Method.
General memory allocators in Linux cannot allocate memory from ION memory regions, such as kernel-space
kmalloc,vmalloc, or user-spacemalloc.The ION memory management subsystem assigns different names to each region:
carveout,chunk,cma_reserved,ion_cma,system,system_contig.In the X5 BSP, three main ION regions are used:
cma_reserved,carveout, andion_cma.cma_reservedmainly provides memory for the multimedia system.carveoutmainly provides memory for the BPU subsystem.ion_cmaserves as a fallback region; when the above two regions are exhausted, the ION management subsystem automatically allocates memory from theion_cmaregion.
Note: Explanation of ION region names:
An ION region is a dynamically allocated memory area. In software, such dynamic memory areas are commonly managed using a heap data structure. Therefore, each ION region in this document and in debug logs is also referred to as a heap region.
ION is an open-source memory management system implemented by Google in Android. For more information on ION region naming, refer to The Android ION memory allocator.
Characteristics of ION Memory
| Feature | Description |
| Memory Management | ION provides a generic memory management mechanism that supports memory allocation and release from ION regions in both user and kernel space. |
| Contiguous Physical Memory Allocation | Memory allocated by the ION memory management system is physically contiguous, enabling direct use by hardware accelerators (e.g., GPU, ISP, video decoders). |
| Inter-device Memory Sharing | ION allows memory sharing between different devices (e.g., GPU, ISP, video decoders) through kernel-level communication and data exchange. |
| Inter-process Memory Sharing | Supports sharing of the same ION memory region among multiple processes without memory copying. |
| Zero-copy | Multiple processes can directly access shared memory regions without explicit memory copying, improving memory efficiency and overall system performance. |
ION Region Allocation Rules
When allocating memory, the ION management subsystem must specify a specific ION region, which may result in:
Available free memory in the entire ION system, but allocation fails because the specified region is fully occupied.
Solution: The ION management subsystem supports automatic fallback allocation from other regions when the specified region is unavailable. The allocation logic is as follows:
When
cma_reservedis specified and exhausted: prefercarveout, thenion_cma.When
carveoutis specified and exhausted: prefercma_reserved, thenion_cma.When
ion_cmais specified and exhausted: choosecma_reserved.
Note: The purpose of the ion_cma region is to serve as a fallback option for other regions.
The software frameworks of the multimedia system and BPU internally specify preferred ION regions, as shown in the table below:
| Module | Preferred ION Region |
| Multimedia System | cma_reserved region |
| BPU System | carveout region |
Note:
The OSD module is special: although it belongs to the multimedia system’s hardware accelerators, it defaults to allocating memory from the
carveoutregion.Developers can specify the preferred ION region via the Flag parameter when allocating ION memory using the hbmem interface.
4.4.6.2. ION Usage Methods
ION Region Size Adjustment Method
ION regions are physical address spaces reserved in the device tree, located within DDR. When the DDR capacity varies, the reserved size of ION regions should also vary.
Therefore, the kernel device tree provides three default configurations based on DDR capacity:
Default ION region configuration for 1GB DDR
Default ION region configuration for 2GB DDR
Default ION region configuration for DDR ≥ 4GB
One of these configurations is selected and applied during boot. The process is as follows:
During miniboot startup, the current DDR capacity is detected and stored in registers.
During uboot startup, based on the value stored by miniboot, the current DDR capacity is known. Then, the kernel device tree file is parsed to obtain the default ION memory configuration corresponding to the DDR capacity.
The above describes the process for applying default ION region configurations. The X5 BSP also supports modifying ION region configurations via the uboot command line.
Note: The ION region configuration saved via the uboot command line has higher priority than that configured in the Linux device tree.
Method to Adjust ION Regions in Linux Device Tree
The ION region configuration in the BSP source package file arch/arm64/boot/dts/hobot/x5-memory.dtsi is as follows:
reserved-memory {
/* UBoot will enable corresponding node when ddr size is confirmed */
ion_reserved_1g: ion_reserved_1g@A4100000 {
compatible = "ion-pool";
reg = <0x0 0xA4100000 0x0 0x07000000>; /* 112MiB */
status = "disabled";
ion_carveout_1g: ion_carveout_1g@AB100000 {
compatible = "ion-carveout";
ion_cma_1g: ion_cma_1g@B2100000 {
compatible = "ion-cma";
ion_reserved_2g: ion_reserved_2g@A4100000 {
ion_carveout_2g: ion_carveout_2g@C4100000 {
ion_cma_2g: ion_cma_2g@E4100000 {
ion_reserved_ge4g: ion_reserved_ge4g@A4100000 {
ion_carveout_ge4g: ion_carveout_ge4g@E4100000 {
ion_cma_ge4g: ion_cma_ge4g@124100000 {
Developers can modify the configuration according to their DDR size by referring to the following table:
| DDR Capacity | Device Tree Node for ION Region |
| 1GB | 1. cma_reserved region: ion_reserved_1g 2. carveout region: ion_carveout_1g 3. ion_cma region: ion_cma_1g |
| 2GB | 1. cma_reserved region: ion_reserved_2g 2. carveout region: ion_carveout_2g 3. ion_cma region: ion_cma_2g |
| ≥4GB | 1. cma_reserved region: ion_reserved_ge4g 2. carveout region: ion_carveout_ge4g 3. ion_cma region: ion_cma_ge4g |
Method to Adjust ION Regions in U-Boot
Refer to: U-Boot Dynamic Configuration of Kernel ION Reserved Memory Size Usage Guide.
ION Debugging Methods
The X5 BSP provides two perspectives for viewing ION debugging information:
From the ION region perspective (memory provider):
Describes information about each ION region.
For example, total size, used size, and detailed information about each allocated memory block.
From the client perspective (memory consumer):
A client represents an identity of a memory user, such as process ID, VPU, JPU, etc.
Shows the total memory usage of the client and detailed allocation information.
View Statistics of Each ION Region
Commands:
View statistics of individual ION regions:
cat /sys/kernel/debug/ion/heaps/ion_cma
cat /sys/kernel/debug/ion/heaps/cma_reserved
cat /sys/kernel/debug/ion/heaps/carveout
View statistics of all ION regions:
cat /sys/kernel/debug/ion/heaps/all_heap_info
Here, ion_cma, cma_reserved, and carveout correspond to the three ION regions used in the X5 BSP (other regions are unused).
Example using /sys/kernel/debug/ion/heaps/cma_reserved:
root@buildroot:~# cat /sys/kernel/debug/ion/heaps/cma_reserved
the heap id is 6
cma_reserved heap total size 536870912
heap name client pid size
cma_reserved udevd 294 1134592
cma_reserved udevd 307 3145728
allocations (info is from last known client):
udevd 294 gpu 4096 1
udevd 294 gpu 8192 1
udevd 294 gpu 1114112 1
udevd 307 vpu 3145728 1
total orphaned 0
total 4280320
Part 1:
heap idis the internal ID assigned by the ION subsystem to different ION region types. Seeenum ion_heap_typein the BSP source filekernel/include/uapi/ion.h.Part 2:
heap total sizeis the total reserved size of the current ION region in the system (Note: unit is bytes, decimal).Part 3: Column meanings are as labeled.
Note: When
clientisudevd, it indicates the user-space process at allocation time wasudevd, typically during driver initialization after automatic loading of.komodules.
Part 4: Details per allocation:
Column 1: process name
Column 2: PID (Note: PID may vary across boots; shown values are for reference only)
Column 3: X5 ION system’s custom module identifier, derived from the Flag passed by the client during allocation
Column 4: allocation size (Note: unit is bytes, decimal)
Column 5: number of kernel references to the allocated memory
Part 5: Summary data:
total orphaned: size of memory not used by any client but not yet freedtotal: total allocated memory size for the current heap (unit: bytes, decimal)
View Statistics of Clients Allocated ION Memory
The /sys/kernel/debug/ion/clients/ directory on X5 devices shows current clients that have allocated ION memory (excluding the BPU subsystem):
Note: The number of clients varies depending on module usage and is for reference only.
root@buildroot:~# ls /sys/kernel/debug/ion/clients/
1114-0 display-0 dsp0-0 galcore-0 jpu-0 vio_driver_ion-0 vpu-0 vsi_cam_drv_ion-0
Explanation of the listed clients:
| Filename | Client | Description |
| 1114-0 | Process ID | Process using ION, includes all module ION info used by the process |
| display-0 | Display subsystem | - |
| dsp0-0 | DSP | - |
| galcore-0 | GPU | ION memory used by 2DGPU and 3DGPU |
| jpu-0 | JPU | - |
| osd_driver_ion-0 | OSD | - |
| vio_driver_ion-0 | Camera-related hardware accelerators (except OSD) | Includes VIN, ISP, GDC, VSE |
| vpu-0 | Video subsystem | - |
| vsi_cam_drv_ion-0 | Camera subsystem background service | ION memory used by camera subsystem background service |
Specific usage per client can be viewed using cat /sys/kernel/debug/ion/clients/<client name>. Example for “galcore-0”:
root@buildroot:~# cat /sys/kernel/debug/ion/clients/galcore-0
heap_name: size_in_bytes : handle refcount : handle import : buffer ptr : buffer refcount : buffer share id : buffer share count
cma_reserved: 1000 : 1 : 1 : 4302dede : 2: 2 : 1
cma_reserved: 1000 : 1 : 1 : 417b1a04 : 2: 3 : 1
cma_reserved: 1000 : 1 : 1 : f8c13b57 : 2: 4 : 1
cma_reserved: 2000 : 1 : 1 : f2a1d186 : 2: 5 : 1
cma_reserved: 110000 : 1 : 1 : 3b5dd773 : 2: 6 : 1
total 115000
size in bytes: size of a single ION allocation (unit: bytes, hexadecimal)buffer ptr: physical address of the allocated ION memorytotal: total ION memory used by the current client (unit: bytes, hexadecimal)
ION Region Name Mapping Table
Correspondence between ION region names, device tree node names, and flags in the hbmem interface:
| ION Region Name | Device Tree Node Name | Flag in hbmem Interface |
| cma_reserved | ion_reserved_xg | HB_MEM_USAGE_PRIV_HEAP_2_RESERVERD HB_MEM_USAGE_PRIV_HEAP_2_RESERVED |
| carveout | ion_carveout_xg | HB_MEM_USAGE_PRIV_HEAP_RESERVERD HB_MEM_USAGE_PRIV_HEAP_RESERVED |
| ion_cma | ion_cma_xg | HB_MEM_USAGE_PRIV_HEAP_DMA |
In the table header,
xgdenotes the suffix of the ion reserved space node name in the Linux kernel device tree. Different definitions are made for different DDR capacities, soxgrepresents the capacity.For example,
ion_reserved_xgrefers to device tree nodes:ion_reserved_1g,ion_reserved_2g,ion_reserved_ge4g
4.4.6.3. Adjusting ION Region Size Based on Application Scenarios
The default ION region configuration in X5 BSP is set for general use cases. Customers can adjust ION region configurations based on their specific scenarios. Below are the adjustment methods:
Theoretical calculation of ION resource usage
Run actual programs and verify theoretical values using ION debugging tools
Configure ION regions based on theoretical values
Theoretical Calculation of ION Resource Usage
VPU
H.264 Encoding
| Function | Usage Size | Description |
| Custom SEI Information | 16384 * 5 | - |
| customMap | 262144 | - |
| vui | 16384 | - |
| Motion Vector Buffers | 4K_ALIGN((64_ALIGN(length) * 64_ALIGN(width) / 32) * 2) + 4096 | - |
| FBC Luma Table Buffer | 4K_ALIGN((256_ALIGN(length) * 64_ALIGN(width) / 32) * 2) + 4096 | - |
| FBC Chroma Table Buffer | 4K_ALIGN((256_ALIGN(length/2) * 64_ALIGN(width)/32) * 2) + 4096 | - |
| Sub-sampled Buffer for ME (Motion Estimation) | 4K_ALIGN((Align32(length/4) * Align4(width/4)) * 2) + 4096 | - |
| MediaCodec Output Buffer | 4K_ALIGN(length * width * bit_depth (NV12: 1.5)) * output_buffer_count | Example: 3112960 bytes for 1080P |
| MediaCodec Input Buffer | 4K_ALIGN(length * width * bit_depth (NV12: 1.5)) * input_buffer_count | Not needed in external memory mode |
| Task Buffer | Complex calculation; refer to table | - |
| Reconstructed and Reference Frames | Complex calculation; refer to table | - |
task bufferandreconstructed and reference frameshave complex logic, dependent only on image resolution. Refer to the following table. If resolution is not listed, estimate based on the table.
| Resolution | Example Camera | Task Buffer | Reconstructed & Reference Frames |
| 3840*2160 | imx415 | 61501440 | 12443648 * 2 |
| 1920*1080 | sc230 | 16560128 | 3,112,960 * 2 |
| 1088*1280 | sc132 | 16494592 | 2088960 * 2 |
| 1600*1200 | sc202 | 16547840 | 2883584 * 2 |
| 640*480 | sc035 | 16396288 | 462848 * 2 |
H.265 Encoding
| vui | 16384 | - |
| 3840*2160 | imx415 | 60968960 | 12443648 * 2 |
| 1920*1080 | sc230 | 16461824 | 3112960 * 2 |
| 1088*1280 | sc132 | 16445440 | 2088960 * 2 |
| 1600*1200 | sc202 | 16457728 | 2883584 * 2 |
| 640*480 | sc035 | 16420864 | 462848 * 2 |
BPU
| Fixed Usage | 32768 * 2 | Occupied once if BPU module is used |
| Model File | 4K_ALIGN(Model File Size) + 4096 * 3 | Occupied once |
| Model Input Buffer Size | Determined by model input format, e.g., NV12: (4K_ALIGN([input_width] * [input_height]) + 4K_ALIGN([input_width] * [input_height] / 2)) |
Occupied upon calling hbSysAllocCachedMem |
| Model Output Buffer Size | Determined by model output dimensions, e.g., yolov5: 4K_ALIGN(output[0].AlignedByteSize) + 4K_ALIGN(output[1].AlignedByteSize) + 4K_ALIGN(output[2].AlignedByteSize) + |
Model Input Buffer Size: allocated via
hbSysAllocCachedMem, stores input imagesModel Output Buffer Size: allocated via
hbSysAllocCachedMem, stores model output resultsAlignedByteSize: member variablealignedByteSizein thehbDNNTensorPropertiesstructure of the BPU software framework
Note: BPU ION usage has some special cases; thus, more accurate measurement requires running a model-only program:
Case 1: In certain models, the BPU software framework may allocate an additional heap region at runtime, e.g., yolov5.
Case 2: Some model operators require additional ION memory, e.g., yolov5.
Validating Theoretical Values
After running the actual or test program, use ION Debugging Methods to check actual ION memory usage per module.
As known from View Statistics of Clients Allocated ION Memory, most modules correspond to one client node, and total ION usage can be viewed in the client node.
However, some modules are special, so we discuss three cases:
Camera modules (except OSD and background services) are grouped as one client; individual module usage cannot be viewed, requiring alternative methods.
BPU module: no corresponding client; requires other methods.
Other modules: VPU, GPU, OSD, etc., have corresponding client nodes.
Camera Modules
Camera modules (except OSD) are grouped as one client: vio_driver_ion-0, so only total usage is visible.
To view individual module usage:
Specify different Flags in the HBN software interface to show different names in
all_heap_info.View
all_heap_infoand filter by module names.
Example for VIN module (replace cimdma in command for other modules):
Each line’s 4th column shows VIN’s ION usage size (decimal, bytes):
root@buildroot:~# cat /sys/kernel/debug/ion/heaps/all_heap_info |grep cimdma
sunrise_camera 1070 cimdma 4096 1
sunrise_camera 1070 cimdma 4149248 0
| Module | Identifier | Description | Flag in HBN Software Interface |
| VIN | cimdma | - | HB_MEM_USAGE_HW_CIM |
| ISP | isp_yuv | - | HB_MEM_USAGE_HW_ISP |
| VSE | other(cma_reserved) | - | Not defined, uses default |
| GDC | gdc | - | HB_MEM_USAGE_HW_GDC_OUT |
| GDC BIN File | gdcfb | - | HB_MEM_USAGE_HW_GDC |
Flag in HBN Software Interface: see buffers_num member of hbn_buf_alloc_attr_t structure
BPU Module
Each line’s 4th column shows BPU’s ION usage (decimal, bytes). The sum of these values is the total BPU ION usage:
root@buildroot:~# cat /sys/kernel/debug/ion/heaps/all_heap_info |grep bpu
sunrise_camera 1070 bpu 32768 0
sunrise_camera 1070 bpu 9486336 0
sunrise_camera 1070 bpu 4259840 0
sunrise_camera 1070 bpu 7864320 0
sunrise_camera 1070 bpu 4096 0
sunrise_camera 1070 bpu 229376 0
sunrise_camera 1070 bpu 454656 0
sunrise_camera 1095 bpu 450560 0
sunrise_camera 1095 bpu 1802240 0
sunrise_camera 1095 bpu 7200768 0
Other Modules
Example for Display module:
Note: client node values are in hexadecimal. So total 5f0000 means Display uses 0x5f0000 bytes.
root@buildroot:~# cat /sys/kernel/debug/ion/clients/display-0 |grep "total"
total 5f0000
| Module | Client Filename |
| VPU | vpu-0 |
| JPG/MJPEG | jpu-0 |
| GPU | galcore-0 |
| Display | display-0 |
| OSD | osd_driver_ion-0 |
| DSP | dsp0-0 |
| Camera Background Service | vsi_cam_drv_ion-0 |
Modify and Apply ION Region Configuration
Quick debugging method: configure via uboot command line. Refer to Method to Adjust ION Regions in U-Boot
Formal method: modify device tree and recompile image. Refer to Method to Adjust ION Regions in Linux Device Tree
