Version
4.5.19. RTC Test
4.5.19.1. Test Principle
RTC (Real-Time Clock) keeps time after system power-off, powered by a coin cell battery through the PMIC VRTC pin. It records year/month/day/hour/minute/second and synchronizes hardware time to the Linux system clock at boot.
Time Synchronization Principle:
  • During power-off: The RTC is powered independently by PMIC VRTC, continuously maintaining the hardware time (year, month, day, hour, minute, second), independent of the main system power state.
  • At system boot: The kernel RTC driver reads the RTC hardware registers and writes the hardware time as the initial value to the Linux system clock (CLOCK_REALTIME), completing the initial RTC → system clock synchronization.
Alarm workflow:
  • Software sets the alarm via /sys/class/rtc/rtc0/wakealarm (relative time such as +10, or an absolute epoch value)
  • When the alarm expires, the PMIC sets ALARM_F internally and sends an interrupt to the CPU through the ALARM_N pin
  • The kernel driver clears wakealarm after handling the interrupt; userspace can verify the IRQ count change in /proc/interrupts
4.5.19.2. Preparation
Driver Verification
Ensure the HPU3501 RTC driver is loaded and the following messages appear in the kernel log:
# dmesg | grep rtc
[    0.589787] hpu3501 2-001c: Found hpu3501-rtc node, register rtc
[    0.593254] hpu3501-rtc hpu3501-rtc.1.auto: registered as rtc0
[    0.594082] hpu3501-rtc hpu3501-rtc.1.auto: setting system clock to 2026-06-10T11:34:32 UTC (1749555272)
Verify that the device node exists:
# ls /dev/rtc0
/dev/rtc0
Script Path
The test script is located on the board at:
/app/platform_samples/chip_base_test/15_rtc_test/rtc_test.sh
Script Usage
rtc_test.sh supports the -h option to display help information:
# ./rtc_test.sh --help
usage: ./rtc_test.sh <command>
commands:
  info                      show RTC hardware information
  read                      read hardware RTC time
  setsys <datetime>         set system time
                              example: ./rtc_test.sh setsys "2025-06-09 14:30:00"
  setrtc <datetime>         set RTC time (system time also updated)
                              example: ./rtc_test.sh setrtc "2025-06-09 14:30:00"
  alarm [-s seconds]        set RTC alarm and verify by interrupt count
                              default: 10s
examples:
  ./rtc_test.sh info
  ./rtc_test.sh read
  ./rtc_test.sh alarm -s 10
Parameter description:
Command Description
info Show RTC hardware information (device node, driver, current time, alarm IRQ, etc.)
read Read hardware RTC time
setsys <datetime> Set system time only (date -s), e.g. "2025-06-09 14:30:00"
setrtc <datetime> Set RTC time (date -s + hwclock -w; system time is updated as well)
alarm [-s seconds] Set RTC alarm and verify by IRQ count; default 10 seconds
-h / --help Show help
4.5.19.3. Test Steps
View RTC Information
# ./rtc_test.sh info
RTC Hardware Info
Device node : /dev/rtc0                                          # RTC device node
Sysfs path  : /sys/class/rtc/rtc0                                # sysfs interface path
Name        : hpu3501-rtc hpu3501-rtc.1.auto                     # device name
Date        : 2025-06-09                                         # RTC date (sysfs)
Time        : 14:30:00                                           # RTC time (sysfs)
Since epoch : 1749479400 sec                                     # seconds since Unix epoch
Wakealarm   :                                                    # alarm setting; empty if unset
Driver      : hpu3501-rtc                                        # kernel driver name
Hwclock     : Mon Jun  9 14:30:00 2025  0.000000 seconds         # hardware RTC time via hwclock
System date : Mon Jun  9 14:30:00 UTC 2025                     # current system time
Alarm IRQ   :  46:          0          0          0          0          0          0          0          0  gpio-dwapb   1 Edge      hpu3501_alarm_irq  # alarm IRQ line and count
Read RTC Time
# ./rtc_test.sh read
Hardware RTC: Mon Jun  9 14:30:05 2025  0.000000 seconds
Set System Time
Changes the system clock only; hardware RTC is not affected:
# ./rtc_test.sh setsys "2025-06-09 14:30:00"
Set datetime : 2025-06-09 14:30:00
System time  : Mon Jun  9 14:30:00 UTC 2025
PASS: system time set
Set RTC Time
Updates both system time and hardware RTC (retained after power-off):
# ./rtc_test.sh setrtc "2025-06-09 14:30:00"
Hardware RTC : Mon Jun  9 14:30:00 2025  0.000000 seconds
PASS: RTC time set
RTC Alarm Test
Set a relative alarm with -s 10 and verify that the interrupt count increases:
# ./rtc_test.sh alarm -s 10
RTC Alarm Test
Alarm delay : 10s
IRQ line    :  46:  0  0  0  0  0  0  0  0  gpio-dwapb  1 Edge  hpu3501_alarm_irq
IRQ before  : 0
Set at      : 2025-06-09 14:29:50
Waiting for alarm (delay 10s, max wait 15s) ...
  countdown:  1s left | IRQ +1
Trigger at  : 2025-06-09 14:30:00
Latency     : 10.052s (set -> trigger)
Error       : +0.052s
IRQ after   : 1
PASS: RTC alarm interrupt detected (+1), latency 10.052s
Output field description:
Field Description
Alarm delay Relative alarm interval in seconds (-s)
Waiting for alarm delay: expected time until alarm fires; max wait: script timeout (delay + 5s margin)
IRQ line RTC alarm interrupt line in /proc/interrupts
IRQ before / after IRQ count before and after the test; after > before means the alarm IRQ fired
Set at Time when the alarm was set (system time)
Trigger at Time when the alarm fired (system time)
Latency Actual time from set to trigger (seconds, millisecond precision)
Error Latency error = Latency − Alarm delay
countdown Seconds remaining until Alarm delay elapses (tracks delay, not max wait)
4.5.19.4. Test Criteria
Test Item Command Pass Criteria
Device detection info /dev/rtc0 exists, driver probe succeeds, IRQ line visible
Read time read Returns valid RTC time
Set system time setsys System time matches the set value
Set RTC time setrtc RTC and system time match the set value (±2 s settling delay allowed)
Alarm alarm IRQ count +1, wakealarm cleared, Latency ≈ Alarm delay (Error recommended ≤ ±1 s)
Pass rule: All mandatory items (info / read / setsys / setrtc / alarm) must PASS for the RTC function test to pass.
