Version
4.5.13. 2D GPU Performance Test
4.5.13.1. Test Principle
The 2D GPU performance test primarily evaluates performance in common operations involving 2D graphics acceleration, including bit-block transfer, rectangle fill and clear, transparency blending, and other key metrics.
The test logic is as follows:
  1. Record the test start time
  2. Execute the 2D GPU processing function in a loop for 100 times
  3. Record the test end time
  4. Calculate the average execution time and frame rate of the 2D GPU processing function based on the start time, end time, and number of executions
4.5.13.2. Test Preparation
  1. The BSP image contains the executable test program by default. You can cd to the following path to check:
    cd /app/platform_samples/chip_base_test/10_gpu_2d_test/
    ls
    bin  performance_test.sh
  2. For custom images, you can copy the directory app/samples/platform_samples/chip_base_test/10_gpu_2d_test from the BSP source code directory to the device.
4.5.13.3. Test Method
  1. Run performance_test.sh
    ./performance_test.sh
  2. The following results will be printed:
root@buildroot:10_gpu_2d_test# ./performance_test.sh
[Case copy                          ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1142191   us] [AverageConsume 11421  us] [FPS    87.6]
[Case multi_source_alphablend       ] [Input 4*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 2046196   us] [AverageConsume 20461  us] [FPS    48.9]
[Case resize                        ] [Input 1*1920*1080] [Output 3840*2160] [TestTimes   100] [TotalConsume 1227924   us] [AverageConsume 12279  us] [FPS    81.4]
[Case resize                        ] [Input 1*1920*1080] [Output  960*540 ] [TestTimes   100] [TotalConsume 80673     us] [AverageConsume 806    us] [FPS  1239.6]
[Case stitch                        ] [Input 4*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1357203   us] [AverageConsume 13572  us] [FPS    73.7]
[Case stitch                        ] [Input 2*3840*2160] [Output 3840*1080] [TestTimes   100] [TotalConsume 688650    us] [AverageConsume 6886   us] [FPS   145.2]
[Case alphablend                    ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1146742   us] [AverageConsume 11467  us] [FPS    87.2]
[Case crop                          ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1141900   us] [AverageConsume 11419  us] [FPS    87.6]
[Case rectangle_fill                ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1143476   us] [AverageConsume 11434  us] [FPS    87.5]
4.5.13.4. Test Metrics
Analysis of the printed results in the Test Method section is as follows:
Test Case FPS Description
copy 87.2 Use 2D GPU to perform copy operation on an image with resolution 3840 * 2160
multi_source_alphablend 48.9 Fuse 4 input images of 3840 * 2160 into one 3840 * 2160 image
resize 81.4 Enlarge an input image of 1920*1080 by 4x to output an image of 3840 * 2160
resize (2nd) 1239.6 Shrink an input image of 1920 * 1080 by 4x to output an image of 960 * 540
stitch 73.7 Stitch 4 input images of 3840 * 2160 into one 3840 * 2160 image (each input image is first scaled down by 2x in both width and height before stitching)
stitch (2nd) 145.2 Stitch 2 input images of 3840 * 2160 into one 3840*1080 image (each input image is first scaled down by 2x in both width and height, then stitched horizontally)
alphablend 87.2 Blend two input images of 3840 * 2160 with different background colors using alpha blending, producing one 3840 * 2160 output image
crop 87.6 Crop a 3840 * 2160 region starting from coordinate (0,0) of one input image of 3840 * 2160, outputting a 3840 * 2160 image (using cropping to simulate image copy)
rectangle_fill 87.5 Fill a red rectangle of the same size as the input image onto a black 3840 * 2160 image, producing a 3840 * 2160 output image
Source code can be found in the BSP source directory: app/samples/platform_samples/sample_gpu_2d
4.5.13.5. Common Issues
  1. Small differences between results from multiple runs
  • Issue Description: As shown in the two execution logs below, the measured frame rates differ. First execution log:
    Second execution log:
    	[Case copy                          ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1160530   us] [AverageConsume 11605  us] [FPS    86.2]
      [Case multi_source_alphablend       ] [Input 4*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 2069446   us] [AverageConsume 20694  us] [FPS    48.3]
      [Case resize                        ] [Input 1*1920*1080] [Output 3840*2160] [TestTimes   100] [TotalConsume 1243849   us] [AverageConsume 12438  us] [FPS    80.4]
      [Case resize                        ] [Input 1*1920*1080] [Output  960*540 ] [TestTimes   100] [TotalConsume 80530     us] [AverageConsume 805    us] [FPS  1241.8]
      [Case stitch                        ] [Input 4*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1371815   us] [AverageConsume 13718  us] [FPS    72.9]
      [Case stitch                        ] [Input 2*3840*2160] [Output 3840*1080] [TestTimes   100] [TotalConsume 695384    us] [AverageConsume 6953   us] [FPS   143.8]
      [Case alphablend                    ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1160516   us] [AverageConsume 11605  us] [FPS    86.2]
      [Case crop                          ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1160381   us] [AverageConsume 11603  us] [FPS    86.2]
      [Case rectangle_fill                ] [Input 1*3840*2160] [Output 3840*2160] [TestTimes   100] [TotalConsume 1149800   us] [AverageConsume 11498  us] [FPS    87.0]
  • Issue Analysis: The performance test logic executes 100 iterations and calculates the average time, so deviations of around one frame are expected.
  • Solution: You can modify the number of execution iterations in the test script performance_test.sh (default is 100, set to quickly produce test results).
