Version
4.5.18. Watchdog Test
4.5.18.1. Test Principle
The X5 integrates a hardware watchdog (watchdog@34250000, driver dw_wdt). After the WDT is started, its internal counter counts down continuously. A kick (keepalive) must be received before the timeout expires to reload the counter; otherwise an SoC system reset is triggered.
Typical behavior:
  • Kernel auto-feed (default): The kernel watchdogd thread kicks the WDT periodically. /sys/class/watchdog/watchdog0/state is inactive, and no userspace program is required.
  • Userspace takeover: After a process opens /dev/watchdog0 and writes to it, the kernel stops auto-feeding and that process must keep feeding the watchdog.
  • Disable watchdog: When nowayout=0, the watchdog can be stopped via Magic Close; a reboot is required to enable it again.
  Kernel / Userspace                DesignWare WDT     No kick before timeout
 ┌─────────────┐  Periodic kick    ┌──────────────┐                             ┌────────────┐
 │ Feed source │ ────────────────> │ Counter down │   ──────────────────────>   │  SoC reset │
4.5.18.2. Preparation
Script Usage
watchdog_test.sh supports the -h option to display help information:
# ./watchdog_test.sh --help
usage: ./watchdog_test.sh <command>
commands:
  info      show hardware watchdog information
  timeout   show configured watchdog timeout (seconds)
  feeder    show whether kernel or userspace is feeding
  timeleft  show remaining timeout (seconds)
  feed      feed watchdog N times: feed <count> [-i interval_sec]
  disable   stop watchdog (requires nowayout=0)
examples:
  ./watchdog_test.sh info
  ./watchdog_test.sh feeder
  ./watchdog_test.sh feed 1
  ./watchdog_test.sh feed 6 -i 2
Parameter description:
  • info: Show basic hardware watchdog information
  • timeout: Show the configured timeout (seconds)
  • feeder: Determine whether the kernel or userspace is feeding the watchdog
  • timeleft: Show the remaining timeout (seconds)
  • feed: Feed the watchdog <count> times [-i interval_sec]; default interval is 1 second
  • disable: Stop the watchdog; a reboot is required to enable it again
  • -h / --help: Show help
4.5.18.3. Test Steps
Check Default Timeout
# ./watchdog_test.sh timeout
Watchdog timeout: 10 sec
Check Feeding Source
# ./watchdog_test.sh  feeder
Watchdog Feeding Source
Sysfs state : inactive
Sampling timeleft (1s x 7, kernel feeds about every 5s):
  [1] timeleft=9s
  [2] timeleft=8s
  [3] timeleft=7s
  [4] timeleft=6s
  [5] timeleft=10s
  [6] timeleft=9s
  [7] timeleft=8s
Timeleft seq : 9 8 7 6 10 9 8
Feed source : kernel  # kernel is feeding the watchdog
Reason      : state=inactive, timeleft increased during sampling
              (kernel watchdog worker kicked the hardware WDT)
root@buildroot:/app/platform_samples/chip_base_test/14_watchdog_test
Check Remaining Timeout
# ./watchdog_test.sh timeleft
Watchdog timeleft: 9 sec (timeout=10 sec)
Feed Test
  • Feed once
# ./watchdog_test.sh  feed 1
Feeding watchdog on /dev/watchdog0: 1 time(s), interval=1s
  [1/1] keepalive ok, timeleft=10s
[  647.681517] watchdog: watchdog0: watchdog did not stop!
Feed done (1 times)
Note: userspace took over (state may become active);
      kernel auto-feed pauses until reboot or disable
  • Feed multiple times with a 5-second interval
# ./watchdog_test.sh feed 10  -i 5
Feeding watchdog on /dev/watchdog0: 10 time(s), interval=5s
  [1/10] keepalive ok, timeleft=10s
  [2/10] keepalive ok, timeleft=10s
  [3/10] keepalive ok, timeleft=10s
  [4/10] keepalive ok, timeleft=10s
  [5/10] keepalive ok, timeleft=10s
  [6/10] keepalive ok, timeleft=10s
  [7/10] keepalive ok, timeleft=10s
  [8/10] keepalive ok, timeleft=10s
  [9/10] keepalive ok, timeleft=10s
  [10/10] keepalive ok, timeleft=10s
[  329.019018] watchdog: watchdog0: watchdog did not stop!
Feed done (10 times)
Note: Once userspace feeds the watchdog, kernel auto-feed pauses. If you feed only N times and then exit without further feeding, the system will reset on timeout.
Disable Watchdog
# ./watchdog_test.sh disable
Stopping watchdog via magic close on /dev/watchdog0 ...
State after disable: inactive
Timeleft after disable: 0 sec
Watchdog disable command sent (magic close 'V')
Note: reboot or re-probe driver to re-enable if needed
Note: A reboot is required to enable the watchdog again after it is disabled.
4.5.18.4. Test Metrics
  • The watchdog is a Synopsys DesignWare hardware WDT with driver dw_wdt; the device node /dev/watchdog0 is available.
  • Under /sys/class/watchdog/watchdog0, attributes such as timeleft, timeout, identity, and state are present.
