4.8. Approved Vendor List
4.8.1. Introduction
This document lists approved vendors and their product information, aiming to provide reliable support options for relevant personnel.
4.8.2. DDR Support List
4.8.2.1. LPDDR4
| Type | Vendor | Part Number | Speed | Capacity | Temperature | HW ADC2 |
| LPDDR4 | GigaDevice | GDB5CBQN-ML | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mv |
| LPDDR4 | CXMT | CXDB5CCBM-MA-A | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mv |
| LPDDR4 | CXMT | CXDB4CBAM-ML-A | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | CXMT | CXDB6CCBM-MA-A | 4266 Mbps | 8GB | -25 ~ 85℃ | 1100mv |
| LPDDR4 | CXMT | CXDB5CBAM-MA-B | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mv |
| LPDDR4 | CXMT | CXDB4CBAM-MA-B | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | CXMT | CXDB4CBAM-MJ-A | 3200 Mbps | 2GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | FORESEE | FLXW2004G-P1 | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mv |
| LPDDR4 | FORESEE | FLXC2002G-N2 | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | SHICHUANGYI | DL4A64G32N4V-EC | 4266 Mbps | 8GB | -25 ~ 85℃ | 1100mv |
| LPDDR4 | SHICHUANGYI | DL4A16G32K1V-DC | 3733 Mbps | 2GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | GigaDevice | GDB5CCQN-ML | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mv |
| LPDDR4 | GigaDevice | GDB4CBQN-ML | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | Micron | MT53E2G32D4DE-046 WT:C | 4266 Mbps | 8GB | -25 ~ 85℃ | 1100mv |
| LPDDR4 | Micron | MT53E1G32D2FW-046 WT:B | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mv |
| LPDDR4 | Micron | MT53E768M32D4DT-053 WT E | 3733 Mbps | 3GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | Micron | MT53E512M32D1ZW-046 WT:B | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | Rayson | RS1G32LO4D2BDS-46BT | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mv |
| LPDDR4 | Rayson | RS512M32LO4D1BDS-46BT | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | Rayson | RS256M32LS4D1BNR-46BT | 4266 Mbps | 1GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | Samsung | K4FBE3D4HB-KHCL | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mv |
| LPDDR4 | Samsung | K4FBE3D4HB-MGCL | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mv |
| LPDDR4 | Samsung | K4F8E3S4HD-MGCL | 4266 Mbps | 1GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | SK hynix | H9HCNNNBKUMLXR-NEE | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | SK Hynix | H9HCNNNBKUMLHR-NME | 3733 Mbps | 2GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | NANYA | NT6AN256T32AV-J1 | 4266 Mbps | 1GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | BIWIN | BWCC2X32N2A-16G-X | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mv |
| LPDDR4 | Rayson | RS1G32LV4D2BDS-46BT | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mV |
| LPDDR4 | Rayson | RS512M32LO4D1BDS-53BT | 3733 Mbps | 2GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | Rayson | RS1536M32LB4D4BDT-46BT | 4266 Mbps | 6GB | -25 ~ 85℃ | 1100mV |
| LPDDR4 | KEYMOS | KL4X164CD-C7A | 3733 Mbps | 2GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | YMTC | MSP4C3D6I-032G | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mV |
| LPDDR4 | YMTC | MSP4M3B6I-032G | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mV |
| LPDDR4 | YMTC | MSP4C3F6I-064G | 4266 Mbps | 8GB | -25 ~ 85℃ | 1100mV |
| LPDDR4 | ISSI | IS43LQ32K01S2A-046BLI | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mV |
| LPDDR4 | Micron | MT53E768M32D2ZW-046 WT:C | 4266 Mbps | 3GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | BIWIN | BWCGBX32N2A-32G-X | 4266 Mbps | 4GB | -25 ~ 85℃ | 900mV |
| LPDDR4 | Rayson | RS384M32LZ4D2BNP-53BT | 3733 Mbps | 1.5GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | Leahkinn | LTHS0007JS4-ZRM1-AT | 4266 Mbps | 2GB | -25 ~ 85℃ | 100mV |
| LPDDR4 | Leahkinn | LTHS0077JS4-ZRN1-XT | 4266 Mbps | 4GB | -25 ~ 85℃ | 300mV |
| LPDDR4 | QCHP | QNLP4D512M32S-37I | 3733 Mbps | 2GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4 | KEYMOS | KL4X321CD-C7B | 3733 Mbps | 4GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
NOTE: ADC2 refers to the VIN2 pin voltage of the X5 ADC group. The system software will determine the DDR parameters based on the voltage detected on this pin. The customer must strictly ensure the correct correspondence between the DRAM and the ADC2 voltage in the BOM. For application details, please refer to section 2.1.11 of the X5 Hardware Design Guide.
4.8.2.2. LPDDR4X
| LPDDR4X | CXMT | CXDB5CCBM-MK-A | 3733 Mbps | 4GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4X | CXMT | CXDB5CBAM-MA-B | 4266 Mbps | 4GB | -25 ~ 85℃ | 1000mv |
| LPDDR4X | CXMT | CXDB5CCBM-MA-A | 4266 Mbps | 4GB | -25 ~ 85℃ | 400mv |
| LPDDR4X | CXMT | CXDB4CBAM-ML-A | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mv |
| LPDDR4X | Samsung | K4U6E3S4AB-MGCL | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mv |
| LPDDR4X | Samsung | K4UBE3D4AB-MGCL | 4266 Mbps | 4GB | -25 ~ 85℃ | 400mv |
| LPDDR4X | GigaDevice | GDB4CBQN-ML | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mv |
| LPDDR4X | GigaDevice | GDB5CCQN-ML | 4266 Mbps | 4GB | -25 ~ 85℃ | 400mv |
| LPDDR4X | GigaDevice | GDB5CBQN-ML | 4266 Mbps | 4GB | -25 ~ 85℃ | 1000mv |
| LPDDR4X | SK Hynix | H9HCNNNBKMMLXR-NEE | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mv |
| LPDDR4X | Micron | MT53E1G32D2FW-046 AAT:B | 4266 Mbps | 4GB | -25 ~ 85℃ | 400mv |
| LPDDR4X | Rayson | RS1G32LV4D2BDS-46BT | 4266 Mbps | 4GB | -25 ~ 85℃ | 1000mV |
| LPDDR4X | Micron | MT53E512M32D1ZW-046 WT:B | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mV |
| LPDDR4X | KEYMOS | KL4X321CD-D2B | 4266 Mbps | 4GB | -25 ~ 85℃ | 1000mV |
| LPDDR4X | Winbond | W66DP2RQQAHJ | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mV |
| LPDDR4X | Rayson | RS512M32LO4D1BDS-46BT | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mV |
| LPDDR4X | CXMT | CXDB4CBAM-MA-B | 4266 Mbps | 2GB | -25 ~ 85℃ | 200mV |
| LPDDR4X | NANYA | NT6AP1024F32BL-J1 | 4266 Mbps | 4GB | -25 ~ 85℃ | 400mV |
| LPDDR4X | SHICHUANGYI | DL4A32G32N2V-EC | 4266 Mbps | 4GB | -25 ~ 85℃ | 1000mV |
| LPDDR4X | Rayson | RS768M32LZ4D4ANQ-75BT | 3733 Mbps | 3GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
| LPDDR4X | FORESEE | FLXC4004G-W6 | 3733 Mbps | 4GB | -25 ~ 85℃ | Special configuration requires confirmation with the Field Application Engineer. |
4.8.3. eMMC Support List
| eMMC5.1 | SHICHUANGYI | E16GCYNB1ABE00 | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | SHICHUANGYI | E32GCYNB1ABE00 | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | SHICHUANGYI | E64GCM7T1ABE00 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | KOWIN | KAS04111 | HS200 | 4GB | -25 ~ 85℃ |
| eMMC5.1 | Kingston | EMMC8G-MV36 | HS200 | 8GB | -25 ~ 85℃ |
| eMMC5.1 | Kingston | EMMC16G-MW28 | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | Samsung | KLMBG2JETD-B041 | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | Samsung | KLM8G1GETF-B041 | HS200 | 8GB | -25 ~ 85℃ |
| eMMC5.1 | Samsung | KLMCG2UCTB-B041 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | Longsys | FEMDNN032G-A3A55 | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | Longsys | FEMDNN016G-C9A43 | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | SKYHIGH | S40FC008C3B1I00000 | HS200 | 8GB | -25 ~ 85℃ |
| eMMC5.1 | SKYHIGH | S40FC016C3B1I00000 | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | BIWIN | BWCMMQ511G08G | HS200 | 8GB | -25 ~ 85℃ |
| eMMC5.1 | BIWIN | BWCMAQD11G16G | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | BIWIN | BWCTARJ11X32G | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | BIWIN | BWCTH1311X32G | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | BIWIN | BWCTAKC11X64G | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | KIOXIA | THGAMVG7T13BAIL | HS200 | 16GB | -40 ~ 85℃ |
| eMMC5.1 | KIOXIA | THGAMVG8T13BAIL | HS200 | 32GB | -40 ~ 85℃ |
| eMMC5.1 | Longsys | FEMDNN032G-C9A55 | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | Longsys | FEMDNN064G-C9A61 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | JIYI | JY064B-IE01 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | SanDisk | SDINBDG4-8G | HS200 | 8GB | -25 ~ 85℃ |
| eMMC5.1 | SanDisk | SDINBDG4-16G | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | Phison | PTE7A0YJ-32GE | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | Macronix | MX52LM08A11 | HS200 | 8GB | -25 ~ 85℃ |
| eMMC5.1 | Rayson | RS70B16G4Y06G | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | YEESTOR | SGM8205C-Y18BAG | HS200 | 16GB | -25 ~ 85℃ |
| eMMC5.1 | VMING | VMECGVY44C-B3A | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | KIOXIA | THGBMTG5D1LBAIL | HS200 | 4GB | -25 ~ 85℃ |
| eMMC5.1 | SanDisk | SDINBDV4-32G | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | Samsung | KLMBG1UCTC-B041 | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | SHICHUANGYI | E64GCYNE1ABE00 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | KIOXIA | THGAMSG9T15BAIL | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | SHICHUANGYI | E64GCMB41ABE00 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | YMTC | YMEC7C0TG1A2C3 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | Rayson | RS70B64G4M08G | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | SHICHUANGYI | E64GCSAG1ABE00 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | Macronix | MX52LM04A11VW | HS200 | 4GB | -25 ~ 85℃ |
| eMMC5.1 | Phison | PTE4A0YU-64GE | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | Phison | PTE4A0YU-32GE | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | SHICHUANGYI | E64GCDFH1ABE00 | HS200 | 64GB | -25 ~ 85℃ |
| eMMC5.1 | BIWIN | BWCTAQK11X32G | HS200 | 32GB | -25 ~ 85℃ |
| eMMC5.1 | JinTech | JTE5S0H7T3CA-064G | HS200 | 64GB | -25 ~ 85℃ |
4.8.4. NAND Flash Support List
| QSPI Nand | GigaDevice | GD5F1GQ5REYIGR | 100MHz | 1Gbits | -40 ~ 85℃ |
| QSPI Nand | XTX | XT26Q04DWSIGA | 100MHz | 4Gbits | -40 ~ 85℃ |
| QSPI Nand | ESMT | F50D4G41XB | 83MHz | 4Gbits | 0 ~ 70℃ |
| QSPI Nand | GigaDevice | GD5F4GM8REYIG | 100MHz | 4Gbits | -40 ~ 85℃ |
| QSPI Nand | GigaDevice | GD5F2GM7REYIG | 100MHz | 2Gbits | -40 ~ 85℃ |
| QSPI Nand | Winbond | W25N02GW (EOL) | 1Gbits | -40 ~ 85℃ | |
| QSPI Nand | WINBOND | W25N01JWZEIG | 1Gbits | -40 ~ 85℃ | |
| QSPI Nand | WINBOND | W25N01JWZEIT | 1Gbits | -40 ~ 85℃ | |
| QSPI Nand | MXIC | MX35UF1G24AD-Z4I | 1Gbits | -40 ~ 85℃ | |
| QSPI Nand | MXIC | MX35UF2G24AD-Z4I | 2Gbits | -40 ~ 85℃ | |
| QSPI Nand | MXIC | MX35UF4G24AD-Z4I | 4Gbits | -40 ~ 85℃ | |
| QSPI Nand | FORESEE | F35UQA001G-WWT | 1Gbit | -40 ~ 85℃ | |
| QSPI Nand | FORESEE | F35UQA512M-WWT | 512Mbit | -40 ~ 85℃ | |
| QSPI Nand | FORESEE | F35UQA002G-WWT | 2Gbit | -40 ~ 85℃ |
4.8.5. Camera Sensor Support List
NOTE:
Modules marked as “Available for sampling” have complete driver and tuning results.
Modules not marked as “Available for sampling” have drivers and preliminary tuning results.
Note: When an HDR sensor is connected, the VIN-ISP connection must use online mode. Since online mode exclusively occupies the ISP resource, only 1 stream is supported.
| Type | Sensor Vendor | Model | Exp-Mode | SensorMode | Interface | Lanes | Available for sampling | Resolution@FPS |
| RGB | Cvsens | cv4006 | Rolling | Linear | MIPI | 2 | Yes | 1280 x 720@60fps |
| RGB | SmartSens | sc1336 | Rolling | Linear | MIPI | 2 | / | 1280 x 720@15fps |
| RGB | SmartSens | sc1330t | Rolling | Linear | MIPI | 1 | / | 1280 x 960@30fps |
| RGB | SmartSens | sc230ai | Rolling | Linear/HDR | MIPI/Serdes | 1/2 | Yes | 1920 x 1080@10fps 1920 x 1080@30fps |
| RGB | SmartSens | sc231ai | Rolling | Linear | MIPI | 2 | Yes | 1920 x 1080@30fps |
| RGB | Silicon | JX-F37 | Rolling | Linear | MIPI | 1 | / | 1920 x 1080@30fps |
| RGB | OmniVision | ov5640 | Rolling | Linear | MIPI | 2 | / | 1920 x 1080@30fps |
| RGB | Cvsens | cv2005 | Rolling | Linear | MIPI | / | / | 1920 x 1080@30fps |
| RGB | SmartSens | sc235HAL | Rolling | Linear | MIPI | 2 | Yes | 1920 x 1080@30fps |
| RGB | Sony | imx477 | Rolling | Linear | MIPI | 2 | / | 1280x960@120fps 1920 x 1080@50fps 2016x1520@21fps 4000x3000@10fps |
| RGBIR | OmniVision | ox02c1s | Rolling | Linear | MIPI | 2 | / | 1920 x 1280@30fps |
| RGB | SmartSens | sc202cs | Rolling | Linear | MIPI | 1 | / | 1600 x 1200@30fps |
| RGB | SmartSens | sc301iot | Rolling | Linear | MIPI | 2 | / | 1536 x 1536@30fps |
| RGB | Sony | imx415 | Rolling | Linear | MIPI | 2 / 4 | Yes | 3840 x 2160@30fps 3840 x 2160@60fps |
| RGB | Sony | imx586 | Rolling | Linear | MIPI | 4 | / | 3840 x 2160@30fps |
| RGB | OmniVision | os08c10 | Rolling | Linear | MIPI | 2 | / | 3840 x 2160@30fps |
| RGB | OmniVision | ov5647 | Rolling | Linear | MIPI | 2 | / | 640 x 480@60fps 1280 x 960@30fps 1920 x 1080@30fps 2592 x 1944@15fps |
| RGB | Sony | imx219 | Rolling | Linear | MIPI | 2 | / | 640 x 480@30fps 1632 x 1232@30fps 1920 x 1080@30fps 3264 x 2464@15fps 3264 x 2464@21fps |
| RGBIR | OmniVision | ox05b1s | Rolling | Linear | MIPI | 2/4 | / | 2592 x 1944@10fps 2592 x 1944@30fps |
| RGB | SmartSens | sc835SL | Rolling | Linear | MIPI | 4 | Yes | 3840 x 2160@30fps |
| RGB | Sony | imx678 | Rolling | Linear/HDR | MIPI | 4 | Yes | 3840 x 2160@30fps |
| RGB/Mono | OmniVision | ov50h40 | Rolling | Linear | MIPI | 4 | / | 3840 x 2160@30fps 4096 x 3072@30fps |
| RGB | SmartSens | sc035hgs | Global | Linear | MIPI | 1 / 2 | / | 640 x 480@30fps |
| RGB/Mono | OmniVision | ov9782 | Global | Linear | MIPI | 2 | / | 640 x 360@200fps 1280 x 720@120fps |
| Mono | OmniVision | ov9281 | Global | Linear | MIPI | 2 | / | 640 x 400@24fps |
| RGB | SmartSens | sc132gs | Global | Linear/HDR | MIPI/serdes | 1 / 2 | Yes | 1088 x 1280@30fps 1088 x 1280@60fps |
| RGB | SmartSens | sc233HGS | Global | Linear | MIPI | 4 | / | 1920 x 1080@120fps |
| RGB | Sony | IMX900 | Global | Linear | Serdes | 4 | / | 2064 x 1552@30fps |
| TOF | Infineon | irs2875 | / | / | MIPI | 2 | / | 208 x 1413@15fps |
| TOF | Infineon | irs2381c | / | / | MIPI | 2 | / | 224 x 1903@5fps |
4.8.6. Wi-Fi/Bluetooth Support List
| Vendor | Model | Interface Wi-Fi | Interface Bluetooth |
| Realtek | rtl8852bs | SDIO | UART |
| Realtek | rtl8733bs | SDIO | UART |
| Realtek | rtl8723du | USB 2.0 | USB 2.0 |
| Realtek | rtl8189ftv | SDIO | - |
| Quectel | FCS960K | SDIO | UART |
| Xiwai | SWT6652 | SDIO | UART |
| Unisoc | uwe5622 | SDIO | SDIO |
4.8.7. PHY Support List
| Vendor | Model | Interface |
| YT Microelectronics | YT8512 | GMAC |
| Realtek | rtl8211f-cg | GMAC 1000M |
4.8.8. BT1120 To HDMI List
| Vendor | Model | Interface | Specifications |
| Lontium | LT8618SXB(QFN64) | BT1120 | 4K@30fps |
| Lontium | Sil9022ACNU | BT1120 | 1080P@60fps |
4.8.9. Audio Codec Support List
| Texas Instruments | tlv320adc3140 | I2S, I2C |
| Awinic | AW88298 | I2S, I2C |
| Evergreen | ES8326 | I2S, I2C |
| Evergreen | ES8311 | I2S, I2C |
| Evergreen | ES7210 | I2S, I2C |
| Evergreen | ES8156 | I2S, I2C |
4.8.10. IMU Support List
| BMI | BMI088 | SPI |
| BMI | BMI088 | I2C/SPI |
| InvenSense | inv-icm42652 | I2C/SPI |
4.8.11. MIPI DSI Support List
| Vendor | TP | LCM | Interface Display | Resolution |
| waveshare | gt911 | waveshare,2.8inch-panel | MIPI DSI/I2C | 2.8inch DSI LCD |
| waveshare | gt911 | waveshare,3.4inch-panel | MIPI DSI/I2C | 3.4inch DSI LCD (C) |
| waveshare | ft5406 | waveshare,4.3inch-panel | MIPI DSI/I2C | 4.3inch DSI LCD |
| waveshare | gt911 | waveshare,7.0inch-panel | MIPI DSI/I2C | 7inch DSI LCD (C) |
| waveshare | gt911 | waveshare,7.9inch-panel | MIPI DSI/I2C | 7.9inch DSI LCD |
| waveshare | gt911 | waveshare,8.0inch-panel | MIPI DSI/I2C | 8inch DSI LCD (C) |
| waveshare | gt911 | waveshare,10.1inch-panel | MIPI DSI/I2C | 10.1inch DSI LCD (C) |
| Jingchuang | gt911 | JC050HD134-ZC-A | MIPI DSI/I2C | 720x1280 |
4.8.12. 4G Support List
| Quectel | EC25 | USB 2.0 | 4G |
