Version
5.10.3. GDC Bin API
5.10.3.1. Module Description
  • The GDC bin API guides how to generate GDC bin files.
  • The GDC bin API generates GDC bin files via the hbn_gen_gdc_bin_json or hbn_gen_gdc_bin interfaces, and releases the GDC bin buffer using hbn_free_gdc_bin.
  • The GDC bin API is typically used in conjunction with the simulation tool GDC Tool. All transformation modes in GDC Tool can generate a layout.json file, which can then be used by the GDC Bin API to produce a GDC bin file.
For instructions on using GDC Tool, refer to GDC Tool Introduction.
Operation Flow
The general process for using the GDC Bin API:
  1. First, use GDC Tool to generate a JSON file, then use hbn_gen_gdc_bin_json to generate a GDC bin file. See example generate_bin.
  2. Load the generated GDC bin file into memory allocated by hbmem, then configure it to the GDC node via hbn_vnode_set_attr.
  3. Start the GDC node: begin image processing, and save the processed data to the file system using dump_2plane_yuv_to_file.
  4. After processing completes, release the buffer storing the GDC bin using hbn_free_gdc_bin.
For custom transformations, target images and calibration parameters must be generated in advance. Refer to the example custom-config to generate calibration parameters before continuing with the above steps.
5.10.3.2. Reference Examples
  • Example code for GDC can be found in the sample_gdc section.
5.10.3.3. API Reference
The following APIs are used for GDC BIN generation. For GDC module control APIs, see GDC API.
API Interface Functionality
hbn_gen_gdc_bin Configures and generates a gdc bin file using window parameters, storing it in cfg_buf; the size of this binary data is stored in cfg_size
hbn_gen_gdc_bin_json Reads a JSON configuration file, parses its content, generates a binary gdc bin file, and writes it to a specified file
hbn_free_gdc_bin Frees the buffer allocated by hbn_gen_gdc_bin() or hbn_gen_gdc_bin_json() for storing the gdc bin
hbn_gen_gdc_bin
【Function Declaration】
int32_t hbn_gen_gdc_bin(const param_t *gdc_param, const window_t *windows, uint32_t wnd_num, uint32_t **cfg_buf, uint64_t *cfg_size);
【Function Description】
Generates a gdc bin file using window configuration, stores it in cfg_buf, and writes the size of this binary data into cfg_size.
【Parameter Description】
  • [IN] param_t *gdc_parm: GDC-related parameters including resolution, format, etc.
  • [IN] window_t *wnds: Internal region parameters of GDC.
  • [IN] uint32_t wnd_num: Number of windows.
  • [OUT] uint32_t **cfg_buf: Generated gdc cfg bin, internally allocated.
  • [OUT] uint64_t *cfg_size: Size of the gdc cfg bin file.
【Return Value】
int32_t hbn_gen_gdc_bin_json(const char *layout_file, char *config_file, uint32_t **cfg_buf, uint64_t *config_size);
Reads a JSON configuration file, parses its content, generates a binary gdc bin file, and writes it to a specified file.
  • [IN] const char *layout_file: Path to the JSON file containing parameters for generating the gdc bin.
  • [IN] char *config_file: Specifies a file path where the generated gdc bin will be stored; can be NULL.
【Return Value】
【Compatibility】
Hardware: X5
hbn_free_gdc_bin
void hbn_free_gdc_bin(uint32_t *cfg_buf);
Frees the buffer allocated by hbn_gen_gdc_bin() or hbn_gen_gdc_bin_json() for storing the gdc bin.
  • [IN] uint32_t *cfg_buf: Buffer address of the gdc bin.
【Return Value】
  • None.
【Compatibility】
Hardware: X5
5.10.3.4. Data Structures
typedef struct param_t
Name Type Min Max Default Meaning Required
format frame_format_t - - - Image processing format Yes
in resolution_t - - - Actual input image dimensions Yes
out resolution_t - - - Actual output image dimensions Yes
x_offset int32_t 0 - 0 Pixel offset of input region along x-axis Yes
y_offset int32_t 0 - 0 Pixel offset of input region along y-axis Yes
diameter int32_t 0 Pixel diameter of the circular region within the rectangular input image that contains the actual fisheye image. For some cameras, this circular region's diameter may be larger or smaller than the rectangular canvas (sometimes cropped). Typically, diameter should match input.height Yes
fov double 0 Field of view defines the visible angle of the input image, affecting source grid curvature. Larger FOV results in greater perspective distortion Yes
typedef enum frame_format frame_format_t
FMT_UNKNOWN - - - - Unknown format -
FMT_LUMINANCE - - - - Not supported -
FMT_PLANAR_444 - - - - Not supported -
FMT_PLANAR_420 - - - - Not supported -
FMT_SEMIPLANAR_420 - - - - nv12 -
FMT_GDC_MAX - - - - - -
typedef struct resolution_s resolution_t
w uint32_t - - - Width (pixels) -
h uint32_t - - - Height (pixels) -
typedef struct window_t
out_r rect_t - - - Output data size information -
transform transformation_t 0 6 0 Transformation mode used -
input_roi_r rect_t ROI area
pan int32_t Horizontal target displacement centered on output image (in pixels)
tilt int32_t Vertical target displacement centered on output image (in pixels)
zoom double Target scaling factor
strength double 1.0 Non-negative transformation intensity in x-direction
strengthY double 1.0 Non-negative transformation intensity in y-direction
angle double 0 Rotation angle of the main projection axis around itself
elevation double 0 Angle specifying the main projection axis
azimuth double 0 Angle specifying the main projection axis, measured clockwise from north
keep_ratio int32_t 1 Maintain equal stretch intensity in horizontal and vertical directions
FOV_h double 90 Vertical dimension of output field of view in degrees
FOV_w double 90 Horizontal dimension of output field of view in degrees
cylindricity_y double 0 Cylindricity level of projection shape in vertical direction
cylindricity_x double 0 Cylindricity level of projection shape in horizontal direction
custom_file[128] char Custom transformation description file in custom mode
custom custom_tranformation_t Transformation information in custom mode
trapezoid_left_angle double 0 Left acute angle between trapezoid base and slanted side
trapezoid_right_angle double 0 Right acute angle between trapezoid base and slanted side
check_compute uint8_t Currently unused
typedef struct rect_s rect_t
x int32_t - - - Starting x-coordinate, must be even -
y int32_t - - - Starting y-coordinate, must be even -
w int32_t Width, must be even
h int32_t Height, must be even
typedef enum gdc_transformation transformation_t
PANORAMIC - - - - Panoramic transformation
CYLINDRICAL - - - - NA
STEREOGRAPHIC - - - - Same as distortion correction and panoramic transformation, but output image is a cylindrical panorama rather than a flat image
UNIVERSAL - - - - Equidistant transformation
CUSTOM - - - - User-defined transformation, allowing customization of transformation grid
AFFINE - - - - Linear transformation
DEWARP_KEYSTONE - - - - Compared to equidistant transformation, allows non-equidistant; equidistant is just a special case of this
typedef struct point_s point_t
x double - - - x-coordinate -
y double - - - y-coordinate -
typedef struct custom_tranformation_s custom_tranformation_t
full_tile_calc uint8_t - - - Whether to enable tile-based calculation; if enabled, libgdcbin performs additional min/max calculations per tile. More tiles mean higher precision and better results, but longer bin generation time -
tile_incr_x uint16_t - - - Tile increment in x direction -
tile_incr_y uint16_t - - - Tile increment in y direction -
w int32_t Number of points in horizontal direction of custom transformation grid
h int32_t Number of points in vertical direction of custom transformation grid
centerx double Center along x-axis, typically half the number of horizontal coordinate points
centery double Center along y-axis, typically half the number of vertical coordinate points
*points point_t Transformation sequence from config.txt, count = w*h
