Version
5.8. Video Processing - VSE
5.8.1. Module Description
VSE (Video Scale Engine) is used for image scaling.
It supports 6 scaling channels with the following characteristics:
  • Maximum processing capability: 3840x2160@60fps
  • Supports input cropping, independent horizontal and vertical scaling, and separate processing of chroma and luma components
  • 5 downscale channels
    • Maximum supported resolutions: 4K, 1080P, 1080P, 720P, 720P respectively
    • Minimum resolution: 64x64, supports arbitrary downscale factors
    • Supports frame rate control and OSD
  • 1 upscale channel
    • Maximum supported resolution: 4K, maximum scaling factor: 4X (scaling factor range: 0–4)
Output Channel ID Type Channel Function
0 offline 4K Downscale
1 offline 1080P Downscale
2 offline 1080P Downscale
3 offline 720P Downscale
4 offline 720P Downscale
5 offline 4K Upscale
Input and output data formats:
  • Supported input data formats:
    • from DDR: YUV422sp(NV16), YUV422 interleave, YUV420sp(NV12)
    • from ISP: YUV420sp(NV12), YUV422sp(NV16)
  • Supported output data formats: YUV444, YUV422, YUV420, RGB888
Note:
Currently the software only supports the following combinations:
Input Format Output Format Notes
NV12 NV12 -
NV16 NV16 -
NV16 NV12 When input is NV16, output channel 5 can only be configured as NV16
OSD features:
  • Each OSD supports up to 4 overlay regions (4 ROIs non-overlapping in vertical direction) and 8 histogram statistic regions
  • For more information about OSD, please refer to Region Processing - OSD
5.8.2. Reference Example
  • VSE code examples can be found in the sample_vse section
5.8.3. API Reference
5.8.4. Interface Descriptions
5.8.4.1. hbn_vnode_open
【Function Declaration】
【Function Description】
Initialize and open the vnode device node, returning the vnode handle for this module.
【Parameter Description】
  • [IN] hb_vnode_type vnode_type : vnode type; for VSE, use HB_VSE
  • [IN] uint32_t hw_id : Hardware ID of the module; for VSE, hw_id is 0
  • [IN] int32_t ctx_id : Context ID of the module, a software concept; can be specified or set to AUTO_ALLOC_ID for automatic allocation by the HBN framework
  • [OUT] hbn_vnode_handle_t *vnode_fd : Returns the vnode handle for the module
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.2. hbn_vnode_close
Close the module’s device node.
  • [IN] hbn_vnode_handle_t vnode_fd: The vnode handle of the module;
【Return Value】
None
【Notes】
Must be used in pair with hbn_vnode_open.
【Compatibility】
Hardware: X5
5.8.4.3. hbn_vnode_set_attr
Set basic attributes of the module.
  • [IN] void *attr: Pointer to the attribute structure; for VSE, use vse_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.4. hbn_vnode_set_ochn_attr
Set output channel attributes of the module.
  • [IN] uint32_t ochn_id: Output channel ID; refer to VSE Channel Description;
  • [IN] void *attr: Pointer to the output channel attribute structure; for VSE, use vse_ochn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.5. hbn_vnode_get_ochn_attr
Get output channel attributes of the module.
  • [OUT] void *attr: Pointer to the output channel attribute structure; for VSE, use vse_ochn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.6. hbn_vnode_set_ichn_attr
Set input channel attributes of the module.
  • [IN] uint32_t ichn_id: Input channel ID; refer to VSE Channel Description;
  • [IN] void *attr: Pointer to the input channel attribute structure; for VSE, use vse_ichn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.7. hbn_vnode_get_ichn_attr
Get input channel attributes of the module.
  • [IN] uint32_t ichn_id: Input channel ID; for VSE, input channel is 0;
  • [OUT] void *attr: Pointer to the input channel attribute structure; for VSE, use vse_ichn_attr_t;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.8. hbn_vnode_set_ochn_buf_attr
Set output channel buffer attributes, including buffer count and whether buffer addresses are contiguous.
  • [IN] hbn_buf_alloc_attr_t *alloc_attr: Buffer allocation attributes;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.9. hbn_vnode_start
Start the module.
【Return Value】
【Notes】
Module must be opened before starting.
【Compatibility】
Hardware: X5
5.8.4.10. hbn_vnode_stop
Stop the module.
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.11. hbn_vnode_getframe
				hbn_vnode_image_t *out_img);
Retrieve image from the module’s output channel; this is a blocking interface.
  • [IN] uint32_t millisecondTimeout: Timeout duration in milliseconds;
  • [OUT] hbn_vnode_image_t *out_img: Address of the output image buffer structure;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.12. hbn_vnode_sendframe
				 hbn_vnode_image_t *img);
Send image to the module’s input channel, triggering processing. This is a blocking interface; waits for hardware processing to complete before returning. Default timeout is 1 second.
  • [IN] hbn_vnode_image_t *img: Address of the input image buffer;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.4.13. hbn_vnode_releaseframe
Release image buffer; the buffer is returned to the specified output channel.
  • [IN] hbn_vnode_image_t *img: Address of the image buffer structure;
【Return Value】
【Notes】
None
【Compatibility】
Hardware: X5
5.8.5. Data Structures
5.8.5.1. vse_cfg_t
Name Type Min Value Max Value Default Description
vse_attr vse_attr_t · · · VSE basic attributes
ichn_attr vse_ichn_attr_t · · · VSE input channel attributes
ochn_attr vse_ochn_attr_t · · · VSE output channel attributes
5.8.5.2. vse_attr_t
fps frame_fps_ctrl_t · · 0 Currently only supports setting fps of input image src; used for VSE frame rate control
5.8.5.3. vse_ichn_attr_t
tpg_en cam_bool_e 0 1 0 Enable TPG function (currently not supported)
width uint32_t 0 5432 0 Original width of input image
height uint32_t 0 3076 0 Original height of input image
fmt frame_format_e FRM_FMT_NV12 FRM_FMT_NV12 0 FRM_FMT_NULL - Invalid, FRM_FMT_RAW - RAW format, FRM_FMT_NV12 - NV12 format, FRM_FMT_UYVY - UYVY format; currently only NV12 is supported
bit_width uint32_t 8 8 0 Bit width of input image
5.8.5.4. vse_ochn_attr_t
chn_en cam_bool_e 0 1 0 Enable channel
roi common_rect_t · · · Crop region for output image; all zeros means crop disabled
target_w uint32_t 0 Limited by channel capability 0 Output image width; 0 means scaling disabled
target_h uint32_t 0 Limited by channel capability 0 Output image height; 0 means scaling disabled
y_stride uint32_t 0 · 0 Y-plane stride of output image (currently not supported)
uv_stride uint32_t 0 · 0 UV-plane stride of output image (currently not supported)
fps frame_fps_ctrl_t · · 0 Currently only supports setting fps of output image dst; used for VSE frame rate control. When this value is 0, if input fps is 0, frame rate control is disabled; if input fps is non-zero, no data will be output
5.8.6. Return Value Description
Error Code Macro Definition Description Common Causes and Solutions
0 HBN_STATUS_SUCCESS Success
1 HBN_STATUS_INVALID_NODE Invalid vnode, corresponding vnode not found
2 HBN_STATUS_INVALID_NODETYPE Invalid vnode type, corresponding vnode not found For VSE, vnode type should be HB_VSE
3 HBN_STATUS_INVALID_HWID Invalid hardware module ID For VSE, hw_id should be 0
4 HBN_STATUS_INVALID_CTXID Invalid context ID Can be set to AUTO_ALLOC_ID for automatic allocation by HBN framework
5 HBN_STATUS_INVALID_OCHNID Invalid output channel ID VSE output channel range is [0,5]
6 HBN_STATUS_INVALID_ICHNID Invalid input channel ID VSE supports only one input channel
7 HBN_STATUS_INVALID_FORMAT Invalid format
8 HBN_STATUS_INVALID_NULL_PTR Null pointer
9 HBN_STATUS_INVALID_PARAMETER Invalid parameter, version check failed
10 HBN_STATUS_ILLEGAL_ATTR Invalid parameter
11 HBN_STATUS_INVALID_FLOW Invalid flow, corresponding flow not found
12 HBN_STATUS_FLOW_EXIST Flow already exists
13 HBN_STATUS_FLOW_UNEXIST Flow does not exist
14 HBN_STATUS_NODE_EXIST Node already exists
15 HBN_STATUS_NODE_UNEXIST Node does not exist
16 HBN_STATUS_NOT_CONFIG Reserved
17 HBN_STATUS_CHN_NOT_ENABLED Channel not enabled
18 HBN_STATUS_CHN_ALREADY_ENABLED Channel already enabled
19 HBN_STATUS_ALREADY_BINDED Node already bound
20 HBN_STATUS_NOT_BINDED Node not bound
21 HBN_STATUS_TIMEOUT Timeout
22 HBN_STATUS_NOT_INITIALIZED Not initialized
23 HBN_STATUS_NOT_SUPPORT Channel not supported or not activated
24 HBN_STATUS_NOT_PERM Operation not allowed
25 HBN_STATUS_NOMEM Insufficient memory
26 HBN_STATUS_INVALID_VNODE_FD Invalid node file descriptor
27 HBN_STATUS_INVALID_ICHNID_FD Invalid input channel file descriptor
28 HBN_STATUS_INVALID_OCHNID_FD Invalid output channel file descriptor
29 HBN_STATUS_OPEN_OCHN_FAIL Failed to open output channel
30 HBN_STATUS_OPEN_ICHN_FAIL Failed to open input channel
31 HBN_STATUS_JSON_PARSE_FAIL JSON parsing failed
32 HBN_STATUS_REQ_BUF_FAIL Failed to request buffer
33 HBN_STATUS_QUERY_BUF_FAIL Failed to query buffer information
34 HBN_STATUS_SET_CONTROL_FAIL Failed to set module control or adjustment parameters (e.g., ISP effect parameters)
35 HBN_STATUS_GET_CONTROL_FAIL Failed to get module control or adjustment parameters (e.g., ISP effect parameters)
36 HBN_STATUS_NODE_START_FAIL Failed to start node
37 HBN_STATUS_NODE_STOP_FAIL Failed to stop node
38 HBN_STATUS_NODE_POLL_ERROR Node channel poll error
39 HBN_STATUS_NODE_POLL_TIMEOUT Node channel poll timeout
40 HBN_STATUS_NODE_POLL_FRAME_DROP Frame drop occurred during node channel poll
41 HBN_STATUS_NODE_POLL_HUP File descriptor hung up during node channel poll
42 HBN_STATUS_NODE_ILLEGAL_EVENT Illegal event during node channel poll
43 HBN_STATUS_NODE_DEQUE_ERROR Node channel dequeue buffer error
44 HBN_STATUS_ILLEGAL_BUF_INDEX Invalid buffer index
45 HBN_STATUS_NODE_QUE_ERROR Node channel queue buffer error
46 HBN_STATUS_FLUSH_FRAME_ERROR Node channel frame flush error
47 HBN_STATUS_INIT_BIND_ERROR Error occurred during JSON parsing and binding
48 HBN_STATUS_ADD_NODE_FAIL Failed to add node to flow
49 HBN_STATUS_WRONG_CONFIG_ID System does not support the node ID
50 HBN_STATUS_BIND_NODE_FAIL Error occurred when binding node to flow
51 HBN_STATUS_INVALID_VERSION Version mismatch between lower driver and upper library
52 HBN_STATUS_GET_VERSION_ERROR Failed to get lower driver module version
53 HBN_STATUS_MEM_INIT_FAIL hbmem memory initialization failed
54 HBN_STATUS_MEM_IMPORT_FAIL hbmem memory import failed
55 HBN_STATUS_MEM_FREE_FAIL hbmem memory release failed
56 HBN_STATUS_SYSFS_OPEN_FAIL System file open failed
57 HBN_STATUS_STRUCT_SIZE_NOT_MATCH HAL layer structure size does not match kernel layer
58 HBN_STATUS_RGN_UNEXIST Cannot retrieve corresponding rgn data
59 HBN_STATUS_RGN_INVALID_OPERATION Invalid rgn operation
60 HBN_STATUS_RGN_OPEN_FILE_FAIL RGN module failed to open file
128 HBN_STATUS_ERR_UNKNOW Unknown error
