4.5.15. GPIO IRQ Test
4.5.15.1. Test Principle
The GPIO IRQ (interrupt) function allows the system to immediately trigger an interrupt handler when the state of a GPIO pin changes (e.g., level transition), enabling rapid response to external events. Typical application scenarios include:
  • Button input detection.
  • External signal triggering (e.g., rising/falling edge).
  • Peripheral status feedback detection (e.g., sensor triggers).
4.5.15.2. Test Preparation
  1. Confirm Hardware Connection
    • Refer to the schematic to locate the GPIO pin, as highlighted in the yellow box in the figure below:
    image-20240313201614942
  2. Device Tree Configuration
    • Add the gpio_keys_hobot node in the device tree and configure its properties:
     /dts-v1/;
     #include "x5.dtsi"
     #include "x5-memory.dtsi"
     #include "pinmux-func.dtsi"
     #include "pinmux-gpio.dtsi"
     #include <dt-bindings/input/linux-event-codes.h>
     #include <autoconf.h>
     	#address-cells = <2>;
     	#size-cells = <2>;
     	gpio-keys {
     		compatible = "gpio-keys";
     		autorepeat;
     		pinctrl-0 = <&aon_gpio_2>;
     		key-power {
     			debounce-interval = <100>;
     			gpios = <&aon_gpio_porta 2 GPIO_ACTIVE_LOW>;
     			label = "GPIO Key Power";
     			linux,code = <KEY_WAKEUP>;
     			wakeup-source;
     	gpio_keys_hobot {
     		compatible = "hobot,gpio_key";
     		debounce-interval = <200>;
     		gpios = <&ls_gpio0_porta 12 GPIO_ACTIVE_LOW>;
     	gua_audio_rpc_wrapper:audio-rpc-wrapper {
     		compatible = "gua,audio-rpc-wrapper";
     		rpmsg-enable;
  3. Debugging Tools Preparation
    • cat /proc/interrupts: View the number of interrupt triggers;
    • dmesg: Check driver logs and GPIO level changes;
    • Dupont wires: Used to short the GPIO pin to GND for interrupt triggering tests.
4.5.15.3. Test Method
Load the Driver
Upload the compiled gpio_key_drv.ko to the board’s /userdata directory. This module is used to test GPIO IRQ functionality. For detailed usage, refer to the IRQ usage section in the document: GPIO Debug Guide.
Load the module with the following command:
root@buildroot:/userdata/gpio_irq_test# insmod gpio_key_drv.ko
Expected normal output:
[64581.388130] gpio_key_init: init
[64581.391774] gpio_key_probe: probe start
Verify that the module has been loaded:
lsmod
The output should include:
gpio_key_drv           16384  0
Test with the Driver
Use a Dupont wire to connect the target GPIO pin to GND and observe the interrupt triggering.
Check whether the interrupt count changes:
watch -n 1 "cat /proc/interrupts | grep gpio_keys_hobot"
Example output:
Every 1.0s: cat /proc/interrupts | grep gpio_keys_hobot        buildroot: Thu Jan  1 18:34:38 1970
 77:        528          0          0          0          0          0          0          0  gpio-dwapb  12 Edge      gpio_keys_hobot
Check the level change logs:
dmesg | tail
Example output:
[  217.715873] gpio_key: IRQ GPIO 391 value=0
[  218.152797] gpio_key: IRQ GPIO 391 value=1
4.5.15.4. Test Metrics
After the driver is installed, monitor the GPIO interrupt triggering via /proc/interrupts and dmesg logs, ensuring the following requirements are met:
  • The driver runs stably for 48 hours without kernel crashes, deadlocks, or system reboots.
  • The interrupt count for the relevant entry in /proc/interrupts increases normally;
  • dmesg prints real-time logs of GPIO level changes;
  • No abnormal keywords such as fail, error, or timeout appear in the logs:
    dmesg | grep -iE 'error|fail|timeout'
4.5.15.5. Test Results
  • Check for abnormal keywords:
Empty output indicates normal operation with no errors.
  • Check interrupt count:
Example output:
 77:       28          0          0          0          0          0          0          0  gpio-dwapb  12 Edge      gpio_keys_hobot
The increasing count on interrupt number 77 indicates normal interrupt response.
  • Check GPIO level changes:
dmesg | tail
Partial output:
[  219.355553] gpio_key: IRQ GPIO 391 value=0
[  220.439865] gpio_key: IRQ GPIO 391 value=1
The continuous logging of level changes indicates timely and accurate interrupt triggering and response.
