3.11.5 Trigger Matching Mechanism
D-Moss Agent uses a trigger keyword matching mechanism to determine which skills are loaded into the current conversation context. This section describes how this mechanism works and how it differs from RAG (Retrieval-Augmented Generation).
Processing Workflow in D-Moss
When Studio starts up, the SkillManager inside D-Moss Agent performs the following initialization steps:
- Scans all files matching
skills/**/SKILL.md(recursive glob) - Parses the frontmatter of each SKILL.md file
- Builds an in-memory index using fields such as trigger, category, and risk
- Exposes the
/api/skillsendpoint for frontend skill listing - Provides an
inject()method for on-demand skill loading during conversations
Each time a user sends a message in AI Dock:
- SkillManager scans the trigger keywords of all installed skills
- Matches relevant skills (e.g., if the user says "USB camera black screen," it matches
rdk-x5-camera-debug) - Injects the body content of the matched SKILL.md file into the model's context
- The model follows the instructions in SKILL.md to make decisions and execute actions (possibly invoking tools like
device_exec,device_file_read, etc.) - The response to the user already includes a "targeted solution + specific commands"
Differences from RAG
The skill mechanism fundamentally differs from RAG (Retrieval-Augmented Generation):
| Dimension | RAG | Skill (Trigger Matching) |
| Trigger Method | Vector similarity matching | String keyword matching |
| Loading Timing | Attempts retrieval on every conversation turn | Loads only when a trigger is matched |
| Context Consumption | May inject numerous fragments | Injects only the full SKILL.md of matched skills |
| Interpretability | Opaque (vector similarity is hard to explain) | Transparent (clearly shows which trigger led to which skill being loaded) |
| Suitable Use Case | Semantic search across massive document collections | Structured operational playbook libraries |
The skill mechanism is better suited for scenarios where you want to "teach the AI a specific workflow or pattern." RAG is more appropriate for "finding answers within large volumes of documents." Both approaches can coexist—RDK Studio supports both mechanisms simultaneously (RAG for built-in documentation retrieval, and skills for operational strategies).
Matching Precision
Trigger matching performs exact string matching without semantic understanding. This means:
| Trigger Word(s) | User Message | Matched? |
USB camera | "What should I do if the USB camera screen is black?" | Matched (exact string match) |
USB camera | "The camera on my board is not displaying any image" | Not matched (semantically equivalent but textually different) |
USB camera, camera, cam | "The camera on my board is not displaying any image" | Matched (trigger includes "camera") |
To improve matching accuracy, we recommend the following when designing triggers:
- List common synonyms and variants (in Chinese, English, and abbreviations)
- Include distinctive strings from error messages (e.g.,
code -6,SIGABRT) - Incorporate colloquial expressions developers commonly use when describing issues
Verifying Skills Loaded in Current Session
Type /skills in AI Dock:
/skills
Example output:
Skills loaded in current session:
- rdk-device-ops (Core Device Operations)
- rdk-x5-camera-debug (X5 Camera Debugging)
- rdk-developer-docs (RDK Official Documentation Retrieval)
If you've installed a skill but it doesn't appear in the /skills output, it means its trigger didn't match the current conversation. Simply update the trigger field in the SKILL.md file and restart Studio to rebuild the index.
