3.9 Device management
Device connection settings: connection settings, saved devices, and add-device entry
Device management is where you work with multiple devices: online status, active device switching, adding/removing devices, notes and connection details. Terminal, Files, IDE, Remote Desktop, and AI Dock track the selected device after you switch.
Suggested order​
StepWhat to do
1Confirm the current device is online
2With multiple devices, make sure the active one is correct
3Add devices when onboarding new boards
4After reflash or password changes, update connection info
5Remove devices you no longer use from this machine’s list
After adding, Studio infers hardware type, online state, and available capabilities. If a device drops offline—check power, network, Host/IP, SSH—online state refreshes automatically when reachable again.
