3.3 Terminal
Terminal panel: prompts to add a device when disconnected; after connection you can create SSH or local serial sessions
The terminal is for logging into the device, running commands, and viewing output. It feels like typical SSH tooling, while sharing the UI with RDK Studio’s device list and Moss workspace.
First-time flow​
StepWhat to do
1Confirm the device was added successfully via SSH or Type-C
2Open the Terminal page and select the current device
3Create a new SSH tab and wait for the shell prompt
4Run a simple check such as pwd or uname -a
5Add a serial connection only when you need boot logs
When Moss runs commands for you, output also appears in the workspace so you can see what ran, whether it succeeded, and any errors.
Under brief network fluctuation the terminal tries to reconnect. Avoid spam-critical commands mid-reconnect; after repeated failures check power, network, host/IP, and SSH.
Next​
