3.7 System Flashing
Flashing wizard: choose the board type to flash
The Flashing page is used to install or reinstall the system on your board. Follow the prompts to select the board type, choose an image, pick the write target, then wait until it finishes.
2.2 Flash system image covers the fastest path to get started. The sections below go into detail by device and storage type.
Suggested order​
StepWhat to do
1Confirm the board type you are flashing
2Choose the officially recommended image, or upload an image provided by your team
3Select the write target—double‑check it is not your PC’s system disk
4After starting the flash, wait until it completes—do not unplug cables or let the PC sleep
5When flashing is done, boot the device and connect it to RDK Studio
Common choices are straightforward: RDK X3 / X5 usually start with TF‑card flashing; RDK X5 boards with eMMC can use eMMC flashing; RDK S100 uses the dedicated xburn tool.
