3.13 Configuration center
The settings center is at the bottom of the left sidebar. Defaults are fine for most users—open it when you hit connection, model, message channel, or account issues.
Settings center: categories on the left, current page on the right
StepWhat to do
1Confirm the signed-in account is correct
2If a device will not connect, open Device connection
3If Moss or the model misbehaves, open AI engine
4To use Feishu or WeChat, configure message channels
5To move machines or share with the team, use import/export
Areas​
AreaMain content
Account & securityCurrent account, sign out, local session and data cleanup
Device connectionSSH defaults, connectivity, networking, reconnect options
AppearanceDensity, fonts/zoom, desktop quick-window behavior
AI engineReasoning/fast models, provider, API key, base URL, connectivity test
Message channels · FeishuFeishu bot credentials, channel on/off, paired users
Message channels · WeChatWeChat QR bind, account list, channel restart
Apps & updatesUpdates, CLI, diagnostic bundles, maintenance
Installing local Ollama, downloads, and model files live under 3.12 Local LLMs.
The AI engine area only configures Moss fast/reasoning model presets.
When unsure what a setting does, leave the default. For problems, send page messages or redacted screenshots to Moss.
Next​
