3.13.3 Configure AI models
The AI engine tells Moss which model handles complex work and which handles quick answers. Start by understanding reasoning vs fast defaults.
Settings center · AI engine: default models for reasoning and fast modes
Reasoning vs fast​
ModeUse forTypical choice
ReasoningMain chat, heavy tasks, device triage, code changesStronger cloud or team-hosted model
FastShort Q&A, summaries, file skimCheaper model or local Ollama
If fast mode points to local Ollama but the model is not running, AI Dock prompts you to open 3.12 Local LLMs.
Field reference​
FieldWhat to enter
Display nameA label you recognize, e.g. “Company model” or “Local fast”
ProviderMatch your platform or self-hosted stack
Model nameExactly as the provider documents (case-sensitive)
API keyUsually required for remote models; often empty for local Ollama. Enter in settings—do not paste keys into chat
Base URLFor self-hosted gateways; leave empty for vendor defaults
After saving, pick different models independently for reasoning and fast.
Wrong provider​
Provider must match the platform. “OpenAI-compatible” services use the matching compatible type; local Ollama uses Ollama. Wrong provider often shows failed tests, unknown model, or invalid key.
If unsure, share provider docs or internal field specs with Moss—redact keys in screenshots.
Relationship to local LLMs​
The local LLMs page installs, starts, downloads, and tests Ollama models; the AI engine assigns them to Moss. Recommended: on local LLMs click “set as fast model config”, then confirm in AI engine.
Relationship to OpenClaw​
On-device agents can follow Moss’s reasoning model, but some models cannot run on device. Local Ollama on the PC is not reachable from the board by default—the UI warns when that matters.
Connectivity test​
Click test before relying on a profile. If it fails, check:
  • Provider choice
  • Model name spelling
  • Full API key copied (no extra spaces)
  • Base URL if your team requires a custom endpoint
  • Local Ollama is running and the model is downloaded
