3.8 Network configuration
Wi‑Fi dialog: choose a network, enter password, view connection status
Network configuration connects your device to Wi‑Fi. For first‑time setup, follow 2.4 Configure network for the shortest path.
After you are familiar, handle network switching, manually adding SSIDs, and edge cases below.
Suggested order​
StepWhat to do
1Add the device over SSH or Type‑C
2Open the Wi‑Fi configuration dialog
3Select or enter the SSID and password
4Click Connect and wait for the result
5Note the new Wi‑Fi IP; re-add SSH with the new address if needed
After a successful join, reboots normally reconnect without re-entering the password.
Common situations​
  • Network missing from scan: use Add SSID manually with details from your router or admin.
  • No automatic reconnect after reboot: check password, signal, whether the router allows new devices, and DHCP health.
  • Unstable Wi‑Fi: give 2.4 GHz and 5 GHz different SSIDs—pick whichever is stabler.
  • Long‑running devices: prefer Ethernet and fixed IPs when practical.
