3.4 Files
Files panel: switch to Files view from the workspace sidebar; read-only prompt when no device or remote folder is selected
The Files page is for browsing and managing files on the device. You can browse folders, upload, and download files like a local file explorer, or open small files for editing inline.
First-time workflow​
StepWhat to do
1Confirm the device is online and a remote folder is selected
2Open the Files page and review the folder tree on the left and list on the right
3To transfer files, drag and drop or use upload/download
4For one-off text edits, double-click a file to open and save
5If you lack permissions or hit a restricted path, confirm you really need to change it
Files and Moss see the same filesystem on the same device. Edits saved in Files can be read by Moss later; after Moss modifies files, refresh Files to see updates.
System and sensitive paths may block writes. If save fails due to permission or non-writable location, verify you really need that path, then share the UI message with Moss for troubleshooting.
