Unlisted page
3.4.3 Paths you cannot edit
Some sensitive paths (e.g. /sys, /proc) block direct Files writes, reducing risk of accidental kernel or boot breakage.
Restricted paths​
PathWhy writes are risky
/sys/Kernel interface; writes can change behaviour or hurt hardware
/proc/Process/kernel state interface; writes can interfere with running processes
/dev/Device nodes — bad writes risk device malfunction
/boot/Boot assets — edits can brick boot
Reads are unrestricted. Blocks apply to write operations only.
When you truly need writes​
Two ways:
Option 1 — Terminal​
In 3.3 Terminal, run explicitly:
echo 1 > /sys/class/leds/red/brightness
Commands run on‑device shell. Verify command and paths before pressing Enter.
Option 2 — Explicit AI Dock authorization​
State authorization clearly in AI Dock, e.g.
“I authorize writes under /sys/class/leds. Turn on the red LED.”
Moss proceeds only after explicit approval when the destination is sensitive.
What you see when blocked​
When Files blocks a write:
This path is restricted and cannot be written via Files directly.
Use Terminal manually or give explicit authorization in AI Dock.
The UI surfaces the cause — not a silent apparent success.
