Unlisted page
3.7.1 Choose a flashing method
RDK Studio supports three flashing methods for different boards and scenarios. Scan the comparison below, then pick the one that fits.
Three entry points compared​
EntryTypical use
TF card flashingCommon install path for RDK X3 / X5
eMMC flashingUse only when both the device and image support the eMMC flow
RDK S100 flashingDedicated flow for RDK S100 / S100P
Recommendations​
Your board and goalPreferred medium
First-time setup on RDK X3 or RDK X5Start with TF card flashing
The page indicates eMMC support for the current deviceFollow the eMMC procedure
RDK S100 / S100PUse the S100 flashing flow
TF card tips​
Some TF cards are not suitable as a system drive. Follow the image page or the board’s official guidance, and prefer reliable, healthy cards from trusted sources. Low‑quality TF cards often show:
  • Fake capacity leading to failures mid‑flash
  • Slow writes stretching flash time significantly
  • Frequent read/write errors after some use
Before you flash​
Regardless of medium, beforehand you should:
  • Back up anything on the target medium (flashing wipes existing data)
  • Power off the board to avoid accidental boot during flashing
  • Keep the PC on stable power (laptop plugged in—avoid sleep during flashing)
