Unlisted page
3.9.2 Automatic device detection
On first connect Studio captures hardware and OS metadata and stores it so Moss knows what kind of board it is talking to.
What gets detected​
InfoWhy it matters
Board type (X3 / X5 / S100)Gates board-specific features
System image detailsGrounds environment-aware answers
ROS / TROS stackBetter ROS command guidance
OpenClaw statusWhether the on-board agent is available
BPU typeWarns if model artifacts match the board
Network addressesQuick lookup in lists and Workbench
Detection runs when you add a device—no manual trigger needed. After a full reflash, follow device detail prompts to refresh.
How Moss uses it​
Moss leans on this context for practical answers instead of generic templates.
Examples:
You askMoss tends to
“Check BPU usage”Pick checks appropriate to the board
“Install a ROS 2 package”Suggest commands aligned with the installed distro
“Why does hbm load fail?”Relate errors to BPU/model compatibility
“Knowing the active device” is one of the biggest differences from a plain chat client.
Incomplete detection​
Custom images may omit standard fields—then:
  • Studio marks missing items as “unknown” without blocking the rest.
  • You can set board type and image version manually on the device page.
  • Moss can still use those manual fields.
If answers stay wrong after manual fixes, post on RDK developer community.
