3.11.1 SKILL.md File Structure
SKILL.md consists of two parts: YAML frontmatter (structured metadata) and Markdown body (detailed operational steps). Both parts are essential.
Full Template
description: A one-sentence summary of what it does
version: 1.0.0
trigger: keyword1,keyword2,keyword3
risk: low
permissions: device_exec
delegate_preference: board
requires_board: true
approval_level: none
cooldown_seconds: 0
scheduler_template: none
category: Custom
# Skill Title
## Applicable Scenarios
(When to use this skill)
## Execution Workflow
(Step 1 → Step 2 → ...)
## Tool Mapping
(Which Studio tools or board-side commands are used)
## Common Issues
(Known pitfalls and workarounds)
YAML frontmatter is a metadata block enclosed by --- at the top of a Markdown file. This format was originally introduced by static site generators like Jekyll and Hugo. Its key characteristics include structured fields, human readability, and machine readability.
Key Field Descriptions
| Field | Required | Description |
name | Yes | Unique skill ID (in slug format); used by AI to reference the skill |
description | Yes | One-sentence description—the most critical factor for AI when selecting a skill |
version | No | Skill version number, following semantic versioning (e.g., 1.0.0) |
trigger | Yes | List of trigger keywords (comma-separated); skills matching these keywords are prioritized for loading |
risk | Yes | Risk level: low / medium / high |
permissions | Yes | Required tool permissions (e.g., device_exec, network) |
delegate_preference | No | Preferred execution location: local (PC) / board (on-device) / hybrid |
approval_level | No | Whether approval is required before execution: none / prompt / always |
requires_board | No | Whether a board-side device is mandatory for using this skill |
category | No | Category tag used for grouping in the UI |
Impact of the risk Field
| Value | Agent Behavior |
low | Executes the skill automatically without interrupting the user |
medium | Prompts the developer in the conversation about what will be executed before proceeding |
high | Requires explicit developer confirmation (clicking Allow) before continuing |
When designing skills, never underestimate the risk level—err on the side of caution. Operations involving board-side system configuration changes, file deletion, service restarts, etc., should be set to medium or high.
Recommended Body Structure
Although the Markdown body allows flexible formatting, we recommend the following structure to enhance AI comprehension:
| Section | Content |
| Applicable Scenarios | When to use this skill (complements the description) |
| Execution Workflow | Step-by-step operational instructions (numbered list) |
| Tool Mapping | Studio tools and board-side commands used |
| Common Issues | Known pitfalls, error handling, and workarounds |
Avoid large blocks of prose. AI parsing is more reliable with structured, step-by-step lists.
