7.5.6 PWM User Guide
Hardware Support
- Each channel is independent and supports IRQ request and DMA request.
- Supports configuration of two operating modes: general operating mode (PWM pulse output) and input capture mode.
- Each channel has its own independent clock divider register.
- All channels of each IP share one interrupt.
- When the target edge or pulse type arrives, an interrupt or DMA request is triggered.
- Supports DMA update of period and duty cycle.
- Supports setting the period edge alignment mode, which can be set to edge-aligned or center-aligned.
- Supports configuring the period and duty cycle for each PWM channel, subject to the following constraint:
- Period configuration granularity is clk_PWM, i.e., the PWM peripheral clock, with a maximum clock count value of 4294967295.
The IP configurations for S100 are as follows:
| Platform | Number of PWM IPs | Number of Channels per IP | Total Number of Channels |
| S100 | 1 | 12 Channels | 12 Channels |
The IP configurations for S600 are as follows:
| S600 | 3 | 12 Channels | 36 Channels |
Software Driver
- Supports CPU update of PWM channel period and duty cycle.
- Supports DMA update of PWM channel period and duty cycle.
- Supports enabling and disabling PWM interrupts, setting the interrupt function for PWM channels, and supporting interrupt types: rising edge, falling edge, both edges.
- Reads the internal state of the PWM output signal and returns it.
- Supports multi-channel synchronous output.
Code Path
Description of PWM Module Related Files
Config/McalCdd/gen_xxx/Pwm/src/Pwm_PBCfg.c: Pre-compiled configuration source file for PWM in normal mode, containing specific configuration parameters for channels and instances (such as period, duty cycle, polarity, etc.).Config/McalCdd/gen_xxx/Pwm/inc: Pre-compiled configuration header file, defining macro switches.McalCdd/Pwm/src/Pwm_Lld.c: Low-level driver implementation file, directly operating hardware registers and providing low-level interfaces.McalCdd/Pwm/src/Pwm.c: High-level driver logic implementation, encapsulating API interfaces and handling error detection, state management, and other control logic.McalCdd/Pwm/inc/Pwm_Lld.h: Low-level driver header file, declaring low-level function prototypes, structures, and enumeration types.McalCdd/Pwm/inc/Pwm_Types.h: Defining common data types, structures, and callback function pointer types for sharing between upper and lower layers.McalCdd/Pwm/inc/Pwm.h: Main header file, declaring high-level APIs and core structures.samples/Pwm/inc/Pwm_PBCfg.h: Header file for PWM test sample.samples/Pwm/src/Pwm_test.c: Source file for PWM test sample.
Important Configuration Instructions
The configuration source file in the PWM driver is Pwm_PBCfg.c, which supports individual configuration for each channel. The drivers and configurations for S600 and S100 are compatible. The following uses S600 as an example.
Pwm_HwChannelConfig_PBcontains the specific hardware configuration for PWM. Some configurations take effect immediately during PWM initialization.
static Pwm_Lld_ChannelConfigType Pwm_HwChannelConfig_PB[PWM_HW_CONF_MODS_PB][12] = {
/**< pwm hardware channel PwmHwChId4 */
.HwChannelId = PwmHwChId4,
/**< pwm hardware ip id 0 */
.HwIpId = 0,
/**< pwm clear mode */
.ClearMode = FALSE,
/**< pwm channel clock ratio*/
.ClockRatio = 0,
/**< pwm period*/
.Period = 9900000,
/**< pwm polarity*/
.Polarity = PWM_HIGH,
/**< pwm duty cycle*/
.DutyCycle = 4950000,
/**< pwm edge align mode */
.EdgeAlign = PWM_LLD_GEN_ALIGN_EDGE,
/**< pwm edge mode */
.EdgeMode = PWM_LLD_EDGEMODE_RISING,
/**< hardware triger mask */
.HwTrigMask = TRUE,
/**< pwm hardware triger width*/
.HwTrigWidth = 0,
/**< the switch of isr notification*/
.NotificationEnable = FALSE,
/**< the callback of isr notification */
.Notification = NULL_PTR,
/**< the switch of dma complete notification*/
.DmaCpltCallbackEnable = FALSE,
/**< the callback of dma complete notification */
.DmaCpltCallback = NULL_PTR,
- The
Pwm_Channels_PBstructure array defines the mapping between logical PWM channels and underlying hardware channels; thePwm_HwChannelConfig_PBstructure array defines the default hardware parameters for each PWM channel, such as period, duty cycle, polarity, interrupt enable, etc.
#define PWM_CONF_CHANNELS_PB 2
/** @brief Array of configured Pwm channels */
static Pwm_ChannelConfigType Pwm_Channels_PB[PWM_CONF_CHANNELS_PB] = {
/* @brief Pwm Channel id */
.ChannelId = 0,
/* @brief Pwm Channel Class */
.PwmChannelClass = PWM_VARIABLE_PERIOD,
/** @brief Pointer to channel pwm hw channel: pwm 0 - ch 4 */
.LldChannelCfg = &Pwm_HwChannelConfig_PB[0][0],
.ChannelId = 1,
/** @brief Pointer to channel pwm hw channel: pwm 0 - ch 5 */
.LldChannelCfg = &Pwm_HwChannelConfig_PB[0][1],
const Pwm_ConfigType Pwm_Config = {
/** @brief Number of configured Pwm ips */
.NumInstances = PWM_HW_CONF_MODS_PB,
/** @brief Number of configured Pwm channels */
.NumChannels = PWM_CONF_CHANNELS_PB,
.PwmChannelsConfig = Pwm_Channels_PB,
/** @brief Pointer to array of Pwm channels */
.PwmLldIpConfig = Pwm_Lld_IpConfig_PB,
Application Sample
Usage Example
The S100 development board provides access to PWM for user development and learning. The PIN positions and statuses of the accessible PWM channels are as follows:
| PWM Channel | Board | Pin Status/Multiplexing |
| pwm0 | MCU expansion board | Multiplexed with I2C9 SCL |
| pwm1 | MCU expansion board | NONE |
| pwm6 | Mainboard MCU expansion Header | NONE |
| pwm7 | Mainboard MCU expansion Header | NONE |
| pwm10 | MCU expansion board | Multiplexed with I2C8 SCL |
| pwm11 | MCU expansion board | Multiplexed with I2C8 SDA |
The pwmtest command is used to configure and control PWM (Pulse Width Modulation) channels. Below are the instructions and examples for using the pwmtest command.
- Usage
Set PWM duty cycle:
pwmtest <pwm_id> <pwm_channel> <period> <duty_cycle>
Stop PWM output:
pwmtest stop <pwm_id> <pwm_channel>
For example, to set the period of PWM channel 0 to 1000us and the duty cycle to 50%:
pwmtest 0 0 0x30d40 0x4000
- Parameter Description
<pwm_id>: PWM hardware IP instance ID (S100 has only 1 IP, fixed to 0).
<pwm_channel>: The PWM channel number to configure or stop (S100 exposed channels: 0, 1, 6, 7, 10, 11).
<period>: The period of the PWM signal.
<duty_cycle>: The duty cycle of the PWM signal, must be in the range of 0x0000 (0%) to 0x8000 (100%).
- Period Calculation
PWM period = clock source frequency / period register value.
Example: To output a wave with a period of 1000us, and the PWM clock source is 200Mhz by default, write 200000000/1000=200000 (0x30d40) into the register.
Debug Sample
- Usage
pwmdumpregs <pwm_id> <pwm_channel>
For example, dump the registers of PWM channel 0:
D-Robotics:/$ pwmdumpregs 0 0
[06915.231597 0]INFO: Pwm_RegDump pwm channel:0
[06915.231967 0]INFO: Pwm_RegDump channel 0
ch[0] PERIOD 22370000 60000 # period
ch[0] PERIOD 22370000 48000 # duty cycle
ch[0] CAP_TIME 22370004 0
ch[0] PWM_CTRL_REG.MODE_SEL 0
ch[0] PWM_CTRL_REG.GEN_ALIGN_SEL 0
ch[0] PWM_CTRL_REG.GEN_POLARITY 0
ch[0] PWM_CTRL_REG.INT_MASK 1
ch[0] PWM_CTRL_REG.DMA_MASK 0
ch[0] PWM_CTRL_REG.HW_TRIG_MASK 1
ch[0] PWM_CTRL_REG.GLITCH_FILTER_EN 0
ch[0] PWM_CTRL_REG.GLITCH_THRESHOLD 0
ch[0] PWM_CTRL_REG.HW_TRIG_WIDTH 0
ch[0] PWM_CTRL_REG.CLK_DIV_RATIO 0
ch[0] PWM_CTRL_REG.EDGE_SEL 0
ch[0] PWM_CTRL_REG.CPU_HALT_ENABLE 0
ch[0] PWM_CTRL_REG.TIMER_CLEAR_MODE 0
ch[0] PWM_CTRL_REG.RESERVED_BIT 0
ch[0] EN 2237000c 1
ch[0] COMPARE_STATE 22370010 0
ch[0] PIN_STATE 22370014 3
ch[0] CAP_CNT_THRESHOLD 22370018 1
ch[0] CAP_CNT 2237001c 1539
ch[0] EOI 22370024 0
ch[0] INT_ST 22370028 0
ch[0] CNT 2237002c 28991
pwm EOIS 22370300 0
pwm INT_ST 22370304 0
pwm RAW_INT_ST 22370308 1
pwm RESERVED 2237030c 0
pwm CAP_MISS 22370310 0
pwm CLEAR_MODE 22370314 33c
pwm SYNC_MODE 22370318 0
pwm CFG_LOCK_MODE 2237031c 0
[06915.263883 0]INFO: Pwm_RegDump end
The S600 development board provides access to PWM0 channel4 and PWM0 channel5 for user development and learning. The interface is located on the MCU daughter board.
Usage Example
- Usage
Set PWM duty cycle:
pwmtest <pwm_hwipid> <pwm_hwchid> <period> <duty_cycle>
Stop PWM output:
pwmtest stop <pwm_hwipid> <pwm_hwchid>
pwm_hwipid: PWM hardware IP instance ID, hardware range 0-2 (S600 has 3 PWM IPs in total)
pwm_hwchid: PWM hardware channel ID, hardware range 0-11 (12 channels per IP)
period: PWM signal period value, 32-bit value
duty_cycle: PWM signal duty cycle, must be in the range of 0x0000 (0%) to 0x8000 (100%)
For example, to set PWM0 channel4 with a period of 0x600000 and a duty cycle of 0x4000 (50%):
D-Robotics:/$ pwmtest 0x0 0x4 0x600000 0x4000
PWM0-CH4 pwm_period = 0x00600000 pwm_dutycycle = 0x4000
Set PWM pin function to PWM0-CH4
Stop the output of PWM0 channel4:
D-Robotics:/$ pwmtest stop 0x0 0x4
INFO: Stopping PWM0-Ch0004
Debug Sample
- Usage
pwmdumpregs <pwm_hwipid> <pwm_hwchid>
View the register configuration of PWM0 channel4:
D-Robotics:/$ pwmdumpregs 0 4
[064961.196947 0]INFO: #####Get Version for Pwm
[064961.197466 0]INFO: Pwm moduleID 121
[064961.197926 0]INFO: Pwm vendorID 196
[064961.198371 0]INFO: Pwm sw_major_version 1
[064961.198885 0]INFO: Pwm sw_minor_version 0
[064961.199395 0]INFO: Pwm sw_patch_version 0
[064961.199906 0]INFO: Pwm_RegDump instance 0 channel 4
[064961.200524 0]ch[4] PERIOD 234a00c0 0
[064961.201300 0]ch[4] PERIOD 234a00c0 0
[064961.202070 0]ch[4] CAP_TIME 234a00c4 0
[064961.202841 0]ch[4] CAP_TIME 234a00c4 0
[064961.203632 0]ch[4] PWM_CTRL_REG.MODE_SEL 0
[064961.204402 0]ch[4] PWM_CTRL_REG.GEN_ALIGN_SEL 0
[064961.205174 0]ch[4] PWM_CTRL_REG.GEN_POLARITY 0
[064961.205948 0]ch[4] PWM_CTRL_REG.INT_MASK 0
[064961.206718 0]ch[4] PWM_CTRL_REG.DMA_MASK 0
[064961.207491 0]ch[4] PWM_CTRL_REG.HW_TRIG_MASK 0
[064961.208274 0]ch[4] PWM_CTRL_REG.GLITCH_FILTER_EN 0
[064961.209049 0]ch[4] PWM_CTRL_REG.GLITCH_THRESHOLD 0
[064961.209819 0]ch[4] PWM_CTRL_REG.HW_TRIG_WIDTH 0
[064961.210589 0]ch[4] PWM_CTRL_REG.CLK_DIV_RATIO 0
[064961.211366 0]ch[4] PWM_CTRL_REG.EDGE_SEL 0
[064961.212136 0]ch[4] PWM_CTRL_REG.CPU_HALT_ENABLE 0
[064961.212927 0]ch[4] PWM_CTRL_REG.TIMER_CLEAR_MODE 0
[064961.213698 0]ch[4] PWM_CTRL_REG.RESERVED_BIT 0
[064961.214468 0]ch[4] EN 234a00cc 0
[064961.215240 0]ch[4] COMPARE_STATE 234a00d0 0
[064961.216014 0]ch[4] PIN_STATE 234a00d4 0
[064961.216784 0]ch[4] CAP_CNT_THRESHOLD 234a00d8 1
[064961.217557 0]ch[4] CAP_CNT 234a00dc 0
[064961.218340 0]ch[4] EOI 234a00e4 0
[064961.219114 0]ch[4] INT_ST 234a00e8 0
[064961.219885 0]ch[4] CNT 234a00ec 0
[064961.220659 0]pwm EOIS 234a0300 0
[064961.221432 0]pwm INT_ST 234a0304 0
[064961.222202 0]pwm RAW_INT_ST 234a0308 0
[064961.222993 0]pwm RESERVED 234a030c 0
[064961.223763 0]pwm CAP_MISS 234a0310 0
[064961.224534 0]pwm CLEAR_MODE 234a0314 fff
[064961.225328 0]pwm SYNC_MODE 234a0318 0
[064961.226101 0]pwm CFG_LOCK_MODE 234a031c 0
[064961.226872 0]INFO: Pwm_RegDump end
Application Interface
void Pwm_Init(const Pwm_ConfigType* ConfigPtr)
Description: Service for PWM initialization
Sync/Async: Synchronous
Parameters(in)
ConfigPtr: Pointer to configuration set
Parameters(inout)
None
Parameters(out)
None
Return value: None
void Pwm_DeInit(void)
Description: Service for PWM De-Initialization.
Parameters(in)
None
Parameters(inout)
None
Parameters(out)
None
Return value: None
void Pwm_SetDutyCycle(Pwm_ChannelType ChannelNumber, uint16 DutyCycle)
Description: Service sets the duty cycle of the PWM channel.
Sync/Async: Asynchronous
Parameters(in)
ChannelNumber: Numeric identifier of PWM
DutyCycle: Min=0x0000 Max=0x8000
Parameters(inout)
None
Parameters(out)
None
Return value: None
void Pwm_SetPeriodAndDuty(Pwm_ChannelType ChannelNumber, Pwm_PeriodType Period, uint16 DutyCycle)
Parameters(in)
Period: Period of the PWM signal
Parameters(inout)
None
Parameters(out)
None
Return value: None
void Pwm_SetOutputToIdle(Pwm_ChannelType ChannelNumber)
Description: Service sets the PWM output to the configured Idle state.
Parameters(in)
Parameters(inout)
None
Parameters(out)
None
Return value: None
Pwm_OutputStateType Pwm_GetOutputState(Pwm_ChannelType ChannelNumber)
Description: Service to read the internal state of the PWM output signal.
Parameters(in)
Parameters(inout)
None
Parameters(out)
None
Return value: Pwm_OutputStateType
PWM_HIGH: The PWM output state is high
PWM_LOW: The PWM output state is low
void Pwm_DisableNotification(Pwm_ChannelType ChannelNumber)
Description: Service to disable the PWM signal edge notification.
Parameters(in)
Parameters(inout)
None
Parameters(out)
None
Return value: None
void Pwm_EnableNotification(Pwm_ChannelType ChannelNumber, Pwm_EdgeNotificationType Notification)
Description: Service to enable the PWM signal edge notification.
Parameters(in)
Notification: Notification type to be enabled
Parameters(inout)
None
Parameters(out)
None
Return value: None
void Pwm_GetVersionInfo(Std_VersionInfoType* versioninfo)
Description: Service returns the version information of this module.
Parameters(in)
None
Parameters(inout)
None
Parameters(out)
versioninfo: Pointer to where to store the version information of this module.
Return value: None
