7.5.11 I2C User Guide
The S100 MCU provides a standard I2C bus. The I2C bus controller transfers information between devices connected to the bus through the serial data line (SDA) and serial clock line (SCL). Each device has a unique address. The main function of the I2C subsystem is to implement serial communication between the microcontroller and peripherals. It can drive MIPI daughter cards, PMIC chips, and other common peripherals.
The S600 MCU provides a standard I2C bus. The I2C bus controller transfers information between devices connected to the bus through the serial data line (SDA) and serial clock line (SCL). Each device has a unique address. The main function of the I2C subsystem is to implement serial communication between the microcontroller and peripherals. It can drive MIPI daughter cards, PMIC chips, and other common peripherals.
I2C Controller​
The I2C controller supports the following features:
  • Three speed mode options (the driver currently does not support HIGH SPEED mode)
    • Standard Mode: 0~100 Kb/s
    • Fast Mode & Fast Mode Plus:
      • Fast Mode: 0~400 Kb/s
      • Fast Mode Plus: 0~1000 Kb/s
    • High-Speed Mode: 0~3.4 Mb/s
  • Master/slave mode configuration
  • 7-bit and 10-bit addressing modes
The S100 MCU provides 4 I2C controllers (I2C6~9) in total, with Fast Mode Plus as the default speed.
Code Paths​
  • McalCdd/Common/Register/inc/I2c_Register.h: Register definitions
  • McalCdd/I2c/src/I2c.c: Driver source code
  • McalCdd/I2c/src/I2c_Lld.c: Low-level driver source code
  • McalCdd/I2c/inc/I2c.h: Driver header file
  • McalCdd/I2c/inc/I2c_Lld.h: Low-level driver header file
  • Config/McalCdd/gen_s100_sip_B_mcu1/I2c/src/I2c_PBcfg.c: PB configuration file
  • Config/McalCdd/gen_s100_sip_B_mcu1/I2c/inc/I2c_PBcfg.h: PB configuration header file
  • Config/McalCdd/gen_s100_sip_B_mcu1/I2c/inc/I2c_Board.h: I2C board-level configuration file
  • samples/I2c/src/I2c_Cmd.c: I2C sample
Initialization and Scheduling​
General-purpose I/O pin initialization is outside the scope of the I2C driver. The PORT driver should initialize I/O first (Port_Init(NULL);), and then the I2C driver can be used. The I2C driver initialization function is I2c_Init(NULL).
I2C Usage​
S100 provides a set of MCU-side commands similar to the open-source i2c-tools for user debugging.
S600 provides a set of MCU-side commands similar to the open-source i2c-tools for user debugging.
The S100 MCU domain supports I2C6~I2C9.
The S600 MCU domain supports I2C10~I2C14.
Code path:
Currently supported commands: i2cdetect, i2cget, i2cset.
  • i2cdetect — Lists I2C buses and all devices on each bus
  • i2cget — Reads the value of a register on an I2C device
  • i2cset — Writes a value to a register on an I2C device
Test example:
D-Robotics:/$ i2cdetect 7
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- 12 -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
D-Robotics:/$ i2cdetect 13
10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- --
Application Programming Interface​
void I2c_Init ( const I2c_ConfigType * Config )​
Description: Subsystem driver initialization function.
Sync/Async: Synchronous
Parameters(in)
Config: Pointer to configuration structure
Parameters(inout)
None
Parameters(out)
None
Return value: None
void I2c_DeInit ( void )​
Description: De-initialize of i2c system to reset values.
Parameters(in)
None
Parameters(inout)
None
Parameters(out)
None
Return value: None
Std_ReturnType I2c_SyncDataTrans ( uint8 Channel, const I2c_RequestType* RequestPtr )​
Description: Sends or receives an I2C message blocking.
Parameters(in)
Channel: I2C Channel.
RequestPtr: I2C transmit request type
Parameters(inout)
None
Parameters(out)
None
Return value:
E_OK: command has been accepted
E_NOT_OK: command has not been accepted
Std_ReturnType I2c_SyncMultiDataTrans ( uint8 Channel, const I2c_RequestType* RequestPtr uint8 I2cRequestCnt)​
Parameters(in)
I2cRequestCnt: I2C transmit num
Parameters(inout)
None
Parameters(out)
None
Return value:
Std_ReturnType I2c_AsyncDataTrans ( uint8 Channel, const I2c_RequestType* RequestPtr )​
Description: This function performs Sends or receives an I2C message non-blocking
Sync/Async: Asynchronous
Parameters(in)
Parameters(inout)
None
Parameters(out)
None
Return value:
I2c_StatusType I2c_StatusGet ( uint8 Channel )​
Description: Gets the status of an I2C channel.
Parameters(in)
Parameters(inout)
None
Parameters(out)
None
Return value: status of an I2C channel
void I2c_GetVersionInfo ( Std_VersionInfoType* VersionInfo )​
Description: This function Gets the version information of this module
Parameters(in)
VersionInfo: version information of this module
Parameters(inout)
None
Parameters(out)
None
Return value: None
