7.5.18 EtherCAT User Guide
1. Overview
This module is based on the open-source SOEM (Simple Open EtherCAT Master) library, ported and adapted for the embedded MCU platform (S100) running FreeRTOS. Main features:
This module is based on the open-source SOEM (Simple Open EtherCAT Master) library, ported and adapted for the embedded MCU platform (S600) running FreeRTOS. Main features:
| Feature | Description |
| EtherCAT master | Implements full EtherCAT MainDevice (master) functionality |
| Real-time scheduling | Periodic process data send/receive via FreeRTOS tasks |
| Hardware adaptation | Low-level Ethernet TX/RX through McalCdd/Ethernet (Eth.h) |
| Mailbox protocols | Supports CoE, FoE, EoE, SoE, and AoE mailbox protocols |
| Distributed clock | DC synchronization supported, with a PI controller for clock alignment |
| Slave diagnostics | Slave state detection, automatic recovery, and reconfiguration |
| Shell interface | Interactive command-line test entry points |
2. Software architecture
| Layer | Module / file | Description | Public interface |
| Application | ec_sample/src/ec_sample.c | Full EtherCAT sample: real-time task, check task, and startup flow | EtherCAT_Sample_Start() / Shell Ec_Sample_Test |
| Application | slaveinfo/src/slaveinfo.c | Slave scan, SDO read/write utilities | EtherCAT_SlaveInfo_Start() / Shell Ec_SlaveInfo, Ec_SlaveOP |
| SOEM core | core/src/ec_main.c | Master init, state machine, mailbox, EEPROM read/write | ecx_init / ecx_readstate / ecx_writestate, etc. |
| SOEM core | core/src/ec_config.c | Auto slave enumeration and PDO mapping | ecx_config_init / ecx_config_map_group |
| SOEM core | core/src/ec_coe.c | CoE (CANopen over EtherCAT) SDO read/write, object dictionary queries | ecx_SDOread / ecx_SDOwrite / ecx_readODlist |
| SOEM core | core/src/ec_dc.c | Distributed clock (DC) configuration and sync | ecx_configdc |
| SOEM core | core/src/ec_foe.c | FoE (File over EtherCAT) file transfer | ecx_FOEread / ecx_FOEwrite |
| SOEM core | core/src/ec_eoe.c | EoE (Ethernet over EtherCAT) Ethernet tunneling | ecx_EOEsend / ecx_EOErecv |
| SOEM core | core/src/ec_soe.c | SoE (Servo over EtherCAT) servo parameter access | ecx_SoEread / ecx_SoEwrite |
| SOEM core | core/src/ec_base.c | Low-level EtherCAT frame build/send/receive | ecx_send_processdata / ecx_receive_processdata |
| SOEM core | core/src/ec_print.c | Error/status codes to human-readable strings | ec_ALstatuscode2string / ecx_elist2string |
| OSAL | osal/src/osal.c | FreeRTOS adaptation for OS time, tasks, mutex | osal_usleep / osal_mutex_lock, etc. |
| OSHW / NIC | oshw/src/nicdrv.c | Network I/O: maps SOEM frame ops to McalCdd/Ethernet API | ecx_setupnic / ecx_outframe / ecx_inframe |
| OSHW / NIC | oshw/src/oshw.c | Byte order helpers (endian conversion) | oshw_htons / oshw_ntohs |
| Hardware | Ethernet controller 0 | Physical port, EtherCAT frames (EtherType 0x88A4) | McalCdd Eth_Transmit / Eth_Receive_ethercat |
3. Directory layout
McalCdd/EtherCAT/
├── SConscript # Top-level build script
├── README.md # Original notes
├── core/ # SOEM core sources
│ ├── SConscript
│ ├── src/
│ │ ├── ec_main.c # Main: init, state machine, mailbox
│ │ ├── ec_config.c # Auto slave config (PDO mapping)
│ │ ├── ec_coe.c # CoE (CANopen over EtherCAT) SDO ops
│ │ ├── ec_dc.c # Distributed clock (DC) config
│ │ ├── ec_eoe.c # EoE (Ethernet over EtherCAT)
│ │ ├── ec_foe.c # FoE (File over EtherCAT)
│ │ ├── ec_soe.c # SoE (Servo over EtherCAT)
│ │ ├── ec_base.c # Low-level frame operations
│ │ └── ec_print.c # Debug print helpers
│ └── inc/
│ ├── nicdrv.h # NIC driver interface
│ ├── osal.h # OSAL interface
│ ├── osal_defs.h # OSAL type definitions
│ ├── oshw.h # OS/HW utility interface
│ └── soem/
│ ├── soem.h # Umbrella header (include-all)
│ ├── ec_main.h # Data structures and main API
│ ├── ec_type.h # Basic types, enums, macros
│ ├── ec_options.h # Compile-time options
│ ├── ec_coe.h # CoE API declarations
│ ├── ec_config.h # Config API declarations
│ ├── ec_dc.h # DC API declarations
│ ├── ec_eoe.h # EoE API declarations
│ ├── ec_foe.h # FoE API declarations
│ ├── ec_soe.h # SoE API declarations
│ └── ec_print.h # Print helper declarations
├── osal/ # FreeRTOS OSAL implementation
│ ├── SConscript
│ └── src/osal.c
└── oshw/ # Hardware driver adaptation
├── SConscript
└── src/
├── nicdrv.c # McalCdd/Ethernet NIC driver
└── oshw.c # Byte-order utilities
samples/EtherCAT/
├── SConscript
├── ec_sample/
│ ├── SConscript
│ └── src/ec_sample.c # Basic run sample
└── slaveinfo/
├── SConscript
└── src/slaveinfo.c # Slave info scan sample
4. Key data structures
4.1 ecx_contextt — Master context
All SOEM APIs take a pointer to this structure as the first argument. The application should declare one static instance:
static ecx_contextt ctx;
Main members:
| Member | Type | Description |
port | ecx_portt | Network port (frame buffers, mutex) |
slavelist[] | ec_slavet[EC_MAXSLAVE] | Slave list; index 0 is the broadcast logical slave |
slavecount | int | Number of slaves discovered |
grouplist[] | ec_groupt[EC_MAXGROUP] | Per-group slave information |
ecaterror | boolean | Whether an EtherCAT error is pending |
DCtime | int64 | Slave DC time (ns) |
ENI | ec_enit * | EtherCAT Network Information (optional) |
FOEhook | Function pointer | FoE data callback hook |
EOEhook | Function pointer | EoE data callback hook |
manualstatechange | int | 0 = automatic state transitions, 1 = manual |
overlappedMode | boolean | Overlapped mode (for TI ESC) |
packedMode | boolean | Compact PDO mapping mode |
4.2 ec_slavet — Slave information
| Member | Description |
state | Current slave state (ec_state enum) |
ALstatuscode | AL status code; gives the reason when in error |
configadr | Configured station address |
eep_man / eep_id / eep_rev | Vendor / product / revision from EEPROM |
Obytes / Ibytes | Output / input byte counts |
outputs / inputs | Pointers into the IOmap regions |
hasdc | Whether distributed clock is supported |
CoEdetails | CoE capability flags |
mbx_proto | Bitmask of supported mailbox protocols |
islost | Whether the slave is considered lost |
name | Human-readable slave name string |
4.3 ec_groupt — Slave group
Obytes / Ibytes | Total output / input bytes for the group |
outputsWKC / inputsWKC | Expected working counter values |
docheckstate | Flag to run state checking |
hasdc | Whether any slave in the group has DC |
5. Slave state machine
EtherCAT slaves follow this state machine (ESM):
INIT (0x01)
▼ I→P
PRE_OP (0x02)
▼ P→S
SAFE_OP (0x04)
▼ S→O
OPERATIONAL (0x08)
Enum values:
| Enum | Value | Description |
EC_STATE_NONE | 0x00 | Invalid |
EC_STATE_INIT | 0x01 | Init |
EC_STATE_PRE_OP | 0x02 | Pre-operational |
EC_STATE_BOOT | 0x03 | BOOT (firmware update) |
EC_STATE_SAFE_OP | 0x04 | Safe-op (input PDO only) |
EC_STATE_OPERATIONAL | 0x08 | Operational (full PDO) |
EC_STATE_ERROR | 0x10 | Error / ACK |
Write-state example:
/* Request all slaves to enter OPERATIONAL */
ctx.slavelist[0].state = EC_STATE_OPERATIONAL;
ecx_writestate(&ctx, 0);
/* Wait for acknowledgment (2 s timeout) */
ecx_statecheck(&ctx, 0, EC_STATE_OPERATIONAL, EC_TIMEOUTSTATE);
6. API reference
6.1 Init and shutdown
ecx_init
int ecx_init(ecx_contextt *context, const char *ifname);
Initializes the EtherCAT master and opens the low-level network interface.
| Parameter | Description |
context | Master context pointer |
ifname | Interface name (use NULL on this embedded platform; controller 0 is default) |
Return value: Non-zero on success, 0 on failure.
int rv = ecx_init(&ctx, NULL);
if (rv == 0) {
/* Initialization failed */
ecx_close
void ecx_close(ecx_contextt *context);
Shuts down the master and releases low-level network resources.
6.2 Slave configuration
ecx_config_init
int ecx_config_init(ecx_contextt *context);
Scans the bus, configures all slaves to PRE_OP, and fills ctx.slavelist[] and ctx.slavecount.
Return value: Number of slaves found.
int ecx_config_map_group(ecx_contextt *context, void *pIOmap, uint8 group);
Configures PDO mapping for all slaves in a group and maps inputs/outputs into pIOmap.
context | Master context |
pIOmap | IOmap buffer (4096 bytes recommended) |
group | Group index (0 = default group) |
Return value: Total mapped IO bytes on success.
static uint8 IOmap[4096];
int map_result = ecx_config_map_group(&ctx, IOmap, 0);
After mapping, compute the expected working counter:
ec_groupt *group = &ctx.grouplist[0];
int expectedWKC = (group->outputsWKC * 2) + group->inputsWKC;
ecx_reconfig_slave
int ecx_reconfig_slave(ecx_contextt *context, uint16 slave, int timeout);
Reconfigures one slave (fault recovery). Success returns a value greater than or equal to EC_STATE_PRE_OP.
ecx_recover_slave
int ecx_recover_slave(ecx_contextt *context, uint16 slave, int timeout);
Recovers a slave that was marked lost.
6.3 State management
ecx_readstate
int ecx_readstate(ecx_contextt *context);
Reads current state for all slaves and updates ctx.slavelist[i].state.
Return value: State of the lowest-priority slave.
ecx_writestate
int ecx_writestate(ecx_contextt *context, uint16 slave);
Writes the target state from ctx.slavelist[slave].state to the slave. slave == 0 broadcasts to all.
ecx_statecheck
uint16 ecx_statecheck(ecx_contextt *context, uint16 slave, uint16 reqstate, int timeout);
Polls until the slave reaches reqstate or times out.
slave | Slave index; 0 = all |
reqstate | Target state |
timeout | Timeout in microseconds; EC_TIMEOUTSTATE (2 s) is typical |
Return value: State actually reached.
6.4 Process data (PDO)
PDO traffic is the core of real-time EtherCAT exchange; call send/receive periodically from a dedicated real-time task.
int ecx_send_processdata(ecx_contextt *context);
Sends process-data frames for all groups (master outputs to slaves).
int ecx_receive_processdata(ecx_contextt *context, int timeout);
Receives process-data responses (slave inputs into the inputs regions).
Return value: Working counter (WKC). Compare with expectedWKC to detect communication issues.
ecx_send_processdata_group / ecx_receive_processdata_group
Per-group variants:
int ecx_send_processdata_group(ecx_contextt *context, uint8 group);
int ecx_receive_processdata_group(ecx_contextt *context, uint8 group, int timeout);
Accessing PDO data
After mapping, use the pointers in ec_slavet:
ec_slavet *slave = &ctx.slavelist[1];
/* Write outputs (master → slave) */
memcpy(slave->outputs, &my_output, slave->Obytes);
/* Read inputs (slave → master) */
memcpy(&my_input, slave->inputs, slave->Ibytes);
6.5 Mailbox protocols (CoE / SDO)
SDO read
int ecx_SDOread(ecx_contextt *context,
uint16 slave, uint16 index, uint8 subindex,
boolean CA, int *psize, void *p, int timeout);
Reads one SDO object from a slave.
slave | Slave index (starts at 1) |
index | Object dictionary index |
subindex | Subindex |
CA | Complete Access |
psize | In: buffer size; out: bytes read |
p | Data buffer |
timeout | Timeout (µs); EC_TIMEOUTRXM (700 ms) is typical |
Return value: WKC (greater than 0 means success).
uint32_t vendor_id = 0;
int size = sizeof(vendor_id);
int wkc = ecx_SDOread(&ctx, 1, 0x1018, 0x01, FALSE, &size, &vendor_id, EC_TIMEOUTRXM);
SDO write
int ecx_SDOwrite(ecx_contextt *context,
uint16 Slave, uint16 Index, uint8 SubIndex,
boolean CA, int psize, const void *p, int Timeout);
Writes one SDO object to a slave.
uint16_t mode = 0x0008; /* e.g. set operation mode */
ecx_SDOwrite(&ctx, 1, 0x6060, 0x00, FALSE, sizeof(mode), &mode, EC_TIMEOUTRXM);
Mailbox handler task
For CoE-capable slaves, call the mailbox handler regularly from a loop:
ecx_mbxhandler(&ctx, 0, 4); /* Group 0, up to 4 messages */
Register a slave for cyclic mailbox handling:
ecx_slavembxcyclic(&ctx, slave_index);
CoE object dictionary listing
/* Read object dictionary list */
ec_ODlistt ODlist;
ecx_readODlist(&ctx, slave, &ODlist);
/* Read object description */
ecx_readODdescription(&ctx, item, &ODlist);
/* Read object entry information */
ec_OElistt OElist;
ecx_readOE(&ctx, item, &ODlist, &OElist);
6.6 Distributed clock (DC)
ecx_configdc
int ecx_configdc(ecx_contextt *context);
Configures DC for all DC-capable slaves, aligned to the first DC slave. Call after ecx_config_map_group.
DC time sync (PI controller)
Applications often align the local clock to DC time with a PI loop; see ec_sample.c:
static float pgain = 0.01f;
static float igain = 0.00002f;
static int64 syncoffset = 500000; /* 500 µs offset */
void ec_sync(int64 reftime, int64 cycletime, int64 *offsettime)
static int64 integral = 0;
int64 delta = (reftime - syncoffset) % cycletime;
if (delta > (cycletime / 2)) delta -= cycletime;
integral += -delta;
*offsettime = (int64)((-delta * pgain) + (integral * igain));
Use from the real-time task:
if (ctx.slavelist[0].hasdc && (wkc > 0))
ec_sync(ctx.DCtime, cycletime, &toff);
6.7 Error handling
Error stack
/* Check for pending errors */
boolean ecx_iserror(ecx_contextt *context);
/* Pop one error from the stack */
boolean ecx_poperror(ecx_contextt *context, ec_errort *Ec);
ec_errort members:
Time | Time of the error |
Slave | Slave index |
Index / SubIdx | CoE object index / subindex |
Etype | Error type (ec_err_type) |
AbortCode | SDO abort code (when CoE-related) |
Error type enum:
| Enum | Description |
EC_ERR_TYPE_SDO_ERROR | SDO error |
EC_ERR_TYPE_EMERGENCY | Emergency message |
EC_ERR_TYPE_PACKET_ERROR | Packet error |
EC_ERR_TYPE_FOE_ERROR | FoE error |
EC_ERR_TYPE_SOE_ERROR | SoE error |
EC_ERR_TYPE_MBX_ERROR | Mailbox error |
7. Quick start: ec_sample
samples/EtherCAT/ec_sample/src/ec_sample.c is a full EtherCAT master sample from init through run to shutdown.
7.1 Overall flow
EtherCAT_Sample_Start(cycle_time_us)
├─ xTaskCreate("ECAT_RT", ecatthread, ...) ← Highest priority
├─ xTaskCreate("ECAT_CHK", ecatcheck, ...) ← Low priority
└─ xTaskCreate("ECAT_BRINGUP", EtherCAT_Bringup_Task, ...)
└─ ecatbringup()
├─ ecx_init(&ctx, NULL)
├─ ecx_config_init(&ctx)
├─ ecx_config_map_group(&ctx, IOmap, 0)
├─ ecx_configdc(&ctx)
├─ ecx_slavembxcyclic() ← Register CoE slaves
├─ ecx_writestate() → OPERATIONAL
├─ [Run loop 500×20 ms]
└─ ecx_writestate() → SAFE_OP → INIT
7.2 Start function
* Start EtherCAT sample
* @param cycle_time_us Cycle time in microseconds; 0 uses default 1000 µs
* @return 0 on success
int EtherCAT_Sample_Start(int cycle_time_us);
7.3 Real-time task (ecatthread)
Runs at the highest FreeRTOS priority and executes periodically:
void ecatthread(void *pvParameters)
/* Wait until mapping completes */
while (!mappingdone) osal_usleep(100);
/* Initial time base */
osal_get_monotonic_time(&ts);
while (1)
/* Compute and wait for next cycle start */
add_time_ns(&ts, cycletime + toff);
osal_monotonic_sleep(&ts);
if (dorun > 0)
wkc = ecx_receive_processdata(&ctx, EC_TIMEOUTRET);
/* DC time sync */
/* Mailbox handling */
ecx_send_processdata(&ctx);
vTaskDelay(1);
7.4 Fault-check task (ecatcheck)
Runs at low priority (every 10 ms), monitors and recovers misbehaving slaves:
void ecatcheck(void *pvParameters)
while (1)
if (inOP && ((dowkccheck > 2) || ctx.grouplist[0].docheckstate))
ecx_readstate(&ctx);
for (int i = 1; i <= ctx.slavecount; i++)
if (slave->state == (EC_STATE_SAFE_OP + EC_STATE_ERROR))
/* Clear error ACK */
else if (slave->state == EC_STATE_SAFE_OP)
/* Push back to OPERATIONAL */
else if (slave->state > EC_STATE_NONE)
ecx_reconfig_slave(...); /* Reconfigure */
else if (slave->islost)
ecx_recover_slave(...); /* Recover */
vTaskDelay(pdMS_TO_TICKS(10));
7.5 FreeRTOS task parameters
| Task name | Function | Stack size | Priority |
ECAT_RT | ecatthread | configMINIMAL_STACK_SIZE × 8 | configMAX_PRIORITIES - 1 (highest) |
ECAT_CHK | ecatcheck | configMINIMAL_STACK_SIZE × 8 | tskIDLE_PRIORITY + 1 |
ECAT_BRINGUP | EtherCAT_Bringup_Task | configMINIMAL_STACK_SIZE × 10 | configMAX_PRIORITIES - 2 |
Note:
ecx_config_map_groupuses significant stack; the bring-up task uses a larger stack for that reason.
8. Slave info: slaveinfo
samples/EtherCAT/slaveinfo/src/slaveinfo.c scans the bus and prints detailed information for each slave.
8.1 Start function
* Start slave information scan
* @param sdo_flag Print SDO object dictionary
* @param map_flag Print PDO mapping
void EtherCAT_SlaveInfo_Start(boolean sdo_flag, boolean map_flag);
8.2 Printed content
After the scan, each slave prints:
- Slave index and name
- Vendor ID, product code, revision, serial
- Output / input byte counts
- Supported mailbox protocols (CoE / FoE / EoE / SoE / AoE)
- SM (sync manager) configuration
- FMMU configuration
- DC support and parameters
- PDO mapping details (
-map) - Object dictionary entries (
-sdo)
8.3 SDO shell command
* @param slave Slave index
* @param index Object index (hex)
* @param subindex Subindex
* @param value Write value (ignored for read)
* @param action 1 = read, 2 = write
int Ec_SlaveOP(uint16 slave, uint16 index, uint8 subindex, uint8 value, uint16 action);
9. Shell commands
Both samples register commands with SHELL_EXPORT_CMD:
Ec_Sample_Test
Ec_Sample_Test [ifname] [cyc_time_us]
Runs the EtherCAT sample (ifname is deprecated; cyc_time_us == 0 selects the default 1 ms cycle).
Examples:
Ec_Sample_Test "" 2000 # 2 ms cycle
Ec_Sample_Test "" 0 # Default 1 ms cycle
Ec_SlaveInfo
Ec_SlaveInfo [-sdo] [-map]
Scans and prints slave information. Options:
-sdo: include SDO object dictionary-map: include PDO mapping
Ec_SlaveOP
Ec_SlaveOP <slave> <index> <subindex> <value> <action>
Direct SDO read (action=1) or write (action=2).
10. Platform adaptation
10.1 OSAL
File: osal/src/osal.c
Abstracts OS services for SOEM; current port uses FreeRTOS.
| OSAL function | FreeRTOS implementation | Description |
osal_usleep(usec) | vTaskDelay(pdMS_TO_TICKS(...)) | Microsecond sleep |
osal_get_monotonic_time(ts) | xTaskGetTickCount() | Monotonic time |
osal_monotonic_sleep(ts) | vTaskDelay(target_ticks - now) | Absolute sleep |
osal_timer_start(t, us) | Computes deadline | Start timer |
osal_timer_is_expired(t) | Compare to now | Timeout check |
osal_mutex_create() | xSemaphoreCreateMutex() | Create mutex |
osal_mutex_lock(m) | xSemaphoreTake(portMAX_DELAY) | Lock |
osal_mutex_unlock(m) | xSemaphoreGive() | Unlock |
osal_thread_create(...) | xTaskCreate(..., tskIDLE_PRIORITY+1) | Normal thread |
osal_thread_create_rt(...) | xTaskCreate(..., MAX_PRIORITIES-1) | RT thread |
osal_malloc(size) | pvPortMalloc(size) | Allocate |
osal_free(ptr) | vPortFree(ptr) | Free |
10.2 OSHW / NIC
File: oshw/src/nicdrv.c
Maps SOEM NIC operations onto McalCdd/Ethernet (Eth.h).
Platform hooks
| Function | Description |
ec_plat_init(ifname) | Init Eth controller (Eth_Init + Eth_SetControllerMode(ACTIVE)) |
ec_plat_close() | Shutdown (Eth_SetControllerMode(DOWN)) |
ec_plat_send(frame, len) | Transmit (Eth_ProvideTxBuffer + Eth_Transmit) |
ec_plat_recv(frame, maxlen) | Receive (Eth_Receive_ethercat, 10 ms timeout) |
Key macros
#define ETH_FRAME_TYPE_ECAT 0x88A4U /* EtherCAT EtherType */
#define ETH_CONTROLLER_IDX 0U /* Use controller 0 */
#define ETH_TX_PRIORITY 0U /* TX priority */
#define ETH_RX_BUFFER_SIZE 1536U /* RX buffer size */
SOEM NIC API (upper layer)
ecx_setupnic(port, ifname, secondary) | Init port, mutex, frame buffers |
ecx_closenic(port) | Close port |
ecx_outframe(port, idx, stacknumber) | Send frame at index |
ecx_inframe(port, idx, stacknumber) | Receive/parse frame at index |
ecx_waitinframe(port, idx, timeout) | Wait for frame with timeout |
ecx_srconfirm(port, idx, timeout) | Send with confirmation (retries) |
11. Configuration macros
Defined in core/inc/soem/ec_options.h:
| Macro | Default | Description |
EC_MAXSLAVE | 200 | Maximum slaves |
EC_MAXGROUP | 2 | Maximum groups |
EC_MAXBUF | 16 | Frame buffers per channel |
EC_MAXMBX | 1486 | Max mailbox size (bytes) |
EC_MBXPOOLSIZE | 32 | Mailbox pool size |
EC_MAXEEPDO | 0x200 | Max EEPROM PDO entries |
EC_MAXSM | 8 | Max sync managers per slave |
EC_MAXFMMU | 4 | Max FMMUs per slave |
EC_MAXNAME | 40 | Max readable name length |
EC_MAXODLIST | 1024 | Max OD list entries |
EC_MAXOELIST | 256 | Max OE list entries |
EC_MAX_MAPT | 1 | Concurrent mapping threads |
EC_LOGGROUPOFFSET | 16 | Group logical address offset (2^16) |
EC_MAXELIST | 64 | Max error list entries |
EC_MAXIOSEGMENTS | 64 | Max IO segments per group |
12. Timeout constants
From core/inc/soem/ec_options.h:
| Constant | Value (µs) | Typical use |
EC_TIMEOUTRET | 2,000 | Normal frame I/O |
EC_TIMEOUTRET3 | 6,000 | Triple-retry timeout |
EC_TIMEOUTSAFE | 20,000 | Safe transmission (wireless, etc.) |
EC_TIMEOUTEEP | 20,000 | EEPROM access |
EC_TIMEOUTTXM | 20,000 | Mailbox transmit |
EC_TIMEOUTRXM | 700,000 | Mailbox receive (SDO, etc.) |
EC_TIMEOUTSTATE | 2,000,000 | State transition |
13. FAQ and troubleshooting
Q1: ecx_init returns 0
Possible causes:
Eth_InitorEth_SetControllerModefailed- Controller 0 not configured or not powered
- MCU and slave Ethernet speeds do not match
Checks:
- Confirm McalCdd/Ethernet initialized (
Eth_Platform_Inited) - Check cabling and controller configuration
- Match MCU port speed to the slave
Q2: ecx_config_init returns 0 (no slaves)
Possible causes:
- Cable unplugged or slave off
- Wrong EtherType (must be
0x88A4) - RX filter blocking EtherCAT frames
- Speed mismatch
Checks:
- Verify physical link
- Confirm
ETH_FRAME_TYPE_ECATis0x88A4 - Confirm
Eth_Receive_ethercatreceives frames - Match port speeds
Q3: WKC does not match expectedWKC
Possible causes:
- Slave link lost / reset
- Cycle time too short
- IOmap inconsistent
Checks:
- Watch
ecatchecklogs forslave lost - Increase
cycletime(e.g. 1 ms → 2 ms) - Call
ecx_readstateand inspectstate/ALstatuscodeper slave
Q4: Stuck in SAFE_OP, cannot reach OPERATIONAL
Possible causes:
- PDO mapping error (
map_resultzero or wrong) ALstatuscodereports an error
Checks:
- Log
map_resultandexpectedWKC - After
ecx_readstate, print each slaveALstatuscode - Common codes:
0x001B: Invalid mailbox configuration0x001D: Invalid SM configuration0x001E: Invalid SM3 configuration (outputs)
Q5: Stack overflow
ecx_config_map_group walks slave EEPROM recursively and needs a large stack.
Mitigation:
- Give the bring-up task enough stack:
configMINIMAL_STACK_SIZE * 10or more - Use
uxTaskGetStackHighWaterMarkbefore/after tasks run
Q6: Reading/writing SDO at runtime
SDO calls may run from any task (not real-time safe—avoid inside ecatthread):
uint32_t value = 0;
int size = sizeof(value);
/* Read slave 1, object 0x1018 sub 0x02 (revision) */
int wkc = ecx_SDOread(&ctx, 1, 0x1018, 0x02, FALSE, &size, &value, EC_TIMEOUTRXM);
if (wkc > 0)
LOG_INFO("Revision: 0x%08X\n", value);
Q7: FoE firmware update
Move the slave to BOOT:
ctx.slavelist[slave].state = EC_STATE_BOOT;
ecx_writestate(&ctx, slave);
ecx_statecheck(&ctx, slave, EC_STATE_BOOT, EC_TIMEOUTSTATE); -
Call FoE write APIs (see
ec_foe.h) -
Return the slave through INIT → PRE_OP → SAFE_OP → OPERATIONAL
14. Test cases
This section covers the three Shell-registered commands under samples/EtherCAT/. All steps use the serial Shell; no code changes are required.
Common prerequisites (all tests):
- Board powered, serial Shell responsive
- At least one EtherCAT slave cabled to the board Ethernet port (controller 0)
- Firmware built with
USE_SHELL_CMDenabled
Shell command cheat sheet
| Command | Source file | Purpose |
Ec_SlaveInfo | slaveinfo/src/slaveinfo.c | Scan slaves; optional -sdo / -map |
Ec_SlaveOP | slaveinfo/src/slaveinfo.c | SDO upload / download |
Ec_Sample_Test | ec_sample/src/ec_sample.c | Full EtherCAT sample |
Ec_SlaveInfo: basic slave scan
Goal: Scan the bus and print basic hardware data for each slave.
Syntax:
Ec_SlaveInfo -sdo
Ec_SlaveInfo -map
Ec_SlaveInfo -sdo -map
Ec_SlaveInforequires at least one flag (-sdoor-map); with none, it prints usage and exits.
Flags:
| Flag | Meaning |
-sdo | Print CoE object dictionary (needs CoE) |
-map | Print PDO mapping (IO bit/byte layout) |
-sdo -map | Both |
Steps:
Basic info + PDO mapping only (faster, about 2–5 s):
Ec_SlaveInfo -map -
Object dictionary only (slower, about 10–60 s depending on slave):
Ec_SlaveInfo -sdo -
Full (
-map+-sdo):Ec_SlaveInfo -sdo -map
Expected log excerpt (-map example):
D-Robotics:/$ [0115.275660 0]INFO: Starting EtherCAT SDO write operation
[0115.275739 0]INFO: intmbxpool mbxp: mutex:
[0115.276190 0]INFO: ec_config_init
[0115.285230 0]INFO: ec_config_init wkc == 1
[0115.298250 0]INFO: ec_config_init context->slavecount == 1
[0115.434372 0]INFO: ec_config_map_group IOmap: group:216031240
[0115.435387 0]INFO: >Slave 1, configadr 1001, state 2
[0115.436381 0]INFO: getmbx item:0 mbx:0x0CC52480
[0115.437401 0]INFO: dropmbx item:0 mbx:
[0115.438394 0]INFO: getmbx item:1 mbx:0x0CC52A4F
[0115.439400 0]INFO: dropmbx item:1 mbx:
[0115.440385 0]INFO: getmbx item:2 mbx:0x0CC5301E
[0115.441400 0]INFO: dropmbx item:2 mbx:
[0115.442390 0]INFO: getmbx item:3 mbx:0x0CC535ED
[0115.443424 0]INFO: dropmbx item:3 mbx:
[0115.444389 0]INFO: getmbx item:4 mbx:0x0CC53BBC
[0115.445410 0]INFO: dropmbx item:4 mbx:
[0115.448400 0]INFO: getmbx item:5 mbx:0x0CC5418B
[0115.449417 0]INFO: dropmbx item:5 mbx:
[0115.450395 0]INFO: getmbx item:6 mbx:0x0CC5475A
[0115.451410 0]INFO: dropmbx item:6 mbx:
[0115.452393 0]INFO: getmbx item:7 mbx:0x0CC54D29
[0115.453435 0]INFO: dropmbx item:7 mbx:
[0115.454399 0]INFO: getmbx item:8 mbx:0x0CC552F8
[0115.455420 0]INFO: dropmbx item:8 mbx:
[0115.458410 0]INFO: getmbx item:9 mbx:0x0CC558C7
[0115.459427 0]INFO: dropmbx item:9 mbx:
[0115.460405 0]INFO: getmbx item:10 mbx:0x0CC55E96
[0115.461420 0]INFO: dropmbx item:10 mbx:
[0115.464405 0]INFO: getmbx item:11 mbx:0x0CC56465
[0115.465441 0]INFO: dropmbx item:11 mbx:
[0115.465507 0]INFO: CoE Osize:16 Isize:528
[0115.465757 0]INFO: SM programming
[0115.466404 0]INFO: SM2 Type:3 StartAddr:4x Flags:8x
[0115.467421 0]INFO: SM3 Type:4 StartAddr:4x Flags:8x
[0131.040524 0]INFO: UNSIGNED32 data16X 0x2X
[0131.040990 0]INFO: End slaveinfo, close socket
[0131.041543 0]INFO: Slaveinfo task completed
Pass criteria:
| Check | Pass if |
| Discovery | Log shows N slaves found and configured. (N ≥ 1) |
| Basics | Each slave prints Name, Output size, Input size, State |
PDO (-map) | SM2 outputs or SM3 inputs address/index/width lines appear |
SDO (-sdo) | CoE list includes at least 0x1000, 0x1018 |
| Clean exit | End slaveinfo, close socket appears |
Usage error (no arguments):
Input error, please check the entered characters!
Usage:
Ec_SlaveInfo <-sdo> <-map>
-sdo: print SDO info
-map: print mapping
Examples:
Ec_SlaveInfo -sdo -map - print SDO info and mapping
Ec_SlaveInfo -sdo - print SDO info
Ec_SlaveInfo -map - print mapping
Ec_SlaveOP upload: SDO read
Goal: Read the current value of one SDO via Shell.
Syntax:
Ec_SlaveOP upload <slave> <index> <subindex>
| Argument | Type | Description |
upload | Literal | Read (upload) |
<slave> | Integer (0-based) | Slave position; starts at 0 (internally +1 for EtherCAT address) |
<index> | Hex | Object index, e.g. 0x1018 |
<subindex> | Integer | Subindex, e.g. 1 |
Note:
slaveis 0-based; internally it maps to physical slave 1 when you pass0.
Example: Read led8 value on the first slave (0x7010:08):
Ec_SlaveOP upload 0 0x7010 8
Expected log:
D-Robotics:/$ Ec_SlaveOP upload 0 0x7010 8
D-Robotics:/$ [0238.504638 0]INFO: Starting EtherCAT SDO write operation
[0238.504717 0]INFO: intmbxpool mbxp: mutex:
[0238.505168 0]INFO: ec_config_init
[0238.514190 0]INFO: ec_config_init wkc == 1
[0238.527181 0]INFO: ec_config_init context->slavecount == 1
[0238.663320 0]INFO: ec_config_map_group IOmap: group:216031240
[0238.664339 0]INFO: >Slave 1, configadr 1001, state 2
[0238.665328 0]INFO: getmbx item:0 mbx:0x0CC52480
[0238.666330 0]INFO: dropmbx item:0 mbx:
[0238.667326 0]INFO: getmbx item:1 mbx:0x0CC52A4F
[0238.668340 0]INFO: dropmbx item:1 mbx:
[0238.669348 0]INFO: getmbx item:2 mbx:0x0CC5301E
[0238.670335 0]INFO: dropmbx item:2 mbx:
[0238.671330 0]INFO: getmbx item:3 mbx:0x0CC535ED
[0238.672344 0]INFO: dropmbx item:3 mbx:
[0238.673333 0]INFO: getmbx item:4 mbx:0x0CC53BBC
[0238.674367 0]INFO: dropmbx item:4 mbx:
[0238.675334 0]INFO: getmbx item:5 mbx:0x0CC5418B
[0238.676349 0]INFO: dropmbx item:5 mbx:
[0238.677340 0]INFO: getmbx item:6 mbx:0x0CC5475A
[0238.678343 0]INFO: dropmbx item:6 mbx:
[0238.679361 0]INFO: getmbx item:7 mbx:0x0CC54D29
[0238.680353 0]INFO: dropmbx item:7 mbx:
[0238.708362 0]INFO: getmbx item:13 mbx:0x0CC57003
[0238.709399 0]INFO: dropmbx item:13 mbx:
[0238.709463 0]INFO: value == 0x0
[0238.709583 0]INFO: SDO read operation successful
[0238.710159 0]INFO: EtherCAT SDO write task completed
Pass criteria:
| Check | Pass if |
| Discovery | N slaves found and configured. (N ≥ 1) |
| Read OK | value == 0xXXXXXXXX and SDO read operation successful |
| No faults | No SDO read operation failed or timeout |
Usage error (bad args):
Usage:
Ec_SlaveCtl <download/upload> <slave> <index> <subindex> <value>
download/upload: spi bus id
slave: slave number
index: index to write
subindex: subindex to write or read
value: the data written or the value obtained.
Examples:
Ec_SlaveCtl download 0 0x7010 0x8 1 - Set subindex 0x8 of 0x7010 to 1.
Ec_SlaveOP download: SDO write
Goal: Write a new SDO value and verify by reading back.
Syntax:
Ec_SlaveOP download <slave> <index> <subindex> <value>
download | Literal | Write (download) |
<slave> | Integer (0-based) | Slave position, starts at 0 |
<index> | Hex | Object index |
<subindex> | Integer | Subindex |
<value> | Integer | Value in decimal or hex |
Note: The write path moves the slave to SAFE_OP first; when finished the stack calls
ecx_close.
Example 1: Set output control for slave 1 (0x7010:08) to 1:
Ec_SlaveOP download 0 0x7010 8 1
Verify:
Expected log (write path):
D-Robotics:/$ Ec_SlaveOP download 0 0x7010 8 1
D-Robotics:/$ [0317.724882 0]INFO: Starting EtherCAT SDO write operation
[0317.724962 0]INFO: intmbxpool mbxp: mutex:
[0317.725415 0]INFO: ec_config_init
[0317.734450 0]INFO: ec_config_init wkc == 1
[0317.747428 0]INFO: ec_config_init context->slavecount == 1
[0317.883567 0]INFO: ec_config_map_group IOmap: group:216031240
[0317.884597 0]INFO: >Slave 1, configadr 1001, state 2
[0317.885574 0]INFO: getmbx item:0 mbx:0x0CC52480
[0317.886577 0]INFO: dropmbx item:0 mbx:
[0317.887568 0]INFO: getmbx item:1 mbx:0x0CC52A4F
[0317.888587 0]INFO: dropmbx item:1 mbx:
[0317.889595 0]INFO: getmbx item:2 mbx:0x0CC5301E
[0317.890581 0]INFO: dropmbx item:2 mbx:
[0317.891578 0]INFO: getmbx item:3 mbx:0x0CC535ED
[0317.892590 0]INFO: dropmbx item:3 mbx:
[0317.893584 0]INFO: getmbx item:4 mbx:0x0CC53BBC
[0317.894613 0]INFO: dropmbx item:4 mbx:
[0317.895580 0]INFO: getmbx item:5 mbx:0x0CC5418B
[0317.896592 0]INFO: dropmbx item:5 mbx:
[0317.897587 0]INFO: getmbx item:6 mbx:0x0CC5475A
[0317.898589 0]INFO: dropmbx item:6 mbx:
[0317.899601 0]INFO: getmbx item:7 mbx:0x0CC54D29
[0317.900599 0]INFO: dropmbx item:7 mbx:
[0317.901592 0]INFO: getmbx item:8 mbx:0x0CC552F8
[0317.902593 0]INFO: dropmbx item:8 mbx:
[0317.903589 0]INFO: getmbx item:9 mbx:0x0CC558C7
[0317.904633 0]INFO: dropmbx item:9 mbx:
[0317.905590 0]INFO: getmbx item:10 mbx:0x0CC55E96
[0317.906597 0]INFO: dropmbx item:10 mbx:
[0317.907593 0]INFO: getmbx item:11 mbx:0x0CC56465
[0317.908609 0]INFO: dropmbx item:11 mbx:
[0317.908675 0]INFO: CoE Osize:16 Isize:48
[0317.908915 0]INFO: SM programming
[0317.909615 0]INFO: SM2 Type:3 StartAddr:4x Flags:8x
[0317.910587 0]INFO: SM3 Type:4 StartAddr:4x Flags:8x
[0317.910665 0]INFO: OUTPUT MAPPING
[0317.911040 0]INFO: FMMU 0
[0317.911398 0]INFO: SM2
[0317.912590 0]INFO: slave 1 Outputs startbit 216031240
[0317.912669 0]INFO: =Slave 1, INPUT MAPPING
[0317.913121 0]INFO: FMMU 1
[0317.913504 0]INFO: SM3
[0317.914616 0]INFO: Inputs startbit 216031242
[0317.914686 0]INFO: =Slave 1, MBXSTATUS MAPPING
[0317.916593 0]INFO: IOmapSize 9
[0317.926610 0]INFO: getmbx item:12 mbx:0x0CC56A34
[0317.927624 0]INFO: dropmbx item:12 mbx:
[0317.928608 0]INFO: getmbx item:13 mbx:0x0CC57003
[0317.929650 0]INFO: dropmbx item:13 mbx:
[0317.929714 0]INFO: SDO write operation successful
[0317.930041 0]INFO: EtherCAT SDO write task completed
Expected log (read-back):
[0338.976953 0]INFO: Inputs startbit 216031242
[0338.977023 0]INFO: =Slave 1, MBXSTATUS MAPPING
[0338.978932 0]INFO: IOmapSize 9
[0338.988949 0]INFO: getmbx item:12 mbx:0x0CC56A34
[0338.989947 0]INFO: dropmbx item:12 mbx:
[0338.990947 0]INFO: getmbx item:13 mbx:0x0CC57003
[0338.991977 0]INFO: dropmbx item:13 mbx:
[0338.992041 0]INFO: value == 0x1
[0338.992161 0]INFO: SDO read operation successful
[0338.992737 0]INFO: EtherCAT SDO write task completed
Pass criteria:
| Check | Pass if |
| Write OK | SDO write operation successful |
| Read-back | upload returns the same value as download |
| No faults | No SDO write operation failed or Failed to reach SAFE_OP |
Common failures:
| Symptom | Cause | Action |
Failed to reach SAFE_OP state for SDO write | No slave / init failed | Cable and power |
SDO write operation failed | Read-only object or out-of-range value | Inspect with -sdo |
No slaves found for SDO write | Empty bus | Physical link |
Ec_Sample_Test: default cycle
Goal: Exercise full master flow—init, PDO exchange, auto shutdown—at the default 1 ms cycle.
Syntax:
Ec_Sample_Test <ifname> <cyc_time_us>
<ifname> | String | Deprecated; pass ""; driver uses controller 0 |
<cyc_time_us> | Integer (µs) | PDO period; 0 = default 1000 µs (1 ms) |
Steps — default 1 ms:
Ec_Sample_Test "" 0
Runtime behavior:
- Command returns immediately after creating three FreeRTOS tasks
ECAT_BRINGUPruns initialization and reaches OPERATIONALECAT_RTruns PDO I/O each 1 ms at highest priorityECAT_CHKpolls slave health every 10 ms- After ~10 s in OP (500 × 20 ms), the sample drops to INIT and cleans up
Full-flow log example:
D-Robotics:/$ Ec_Sample_Test
[065.290630 0]INFO: SOEM (Simple Open EtherCAT Master) ec_sample
[065.290708 0]INFO: Starting EtherCAT sample with cycle time: 1000000 us
[065.292044 0]INFO: Starting EtherCAT bringup task with stack size: 720
[065.292440 0]INFO: Initial stack high water mark: 836
[065.292895 0]INFO: EtherCAT Startup
[065.293313 0]INFO: intmbxpool mbxp: mutex:
[065.293834 0]INFO: ec_config_init
D-Robotics:/$ [065.302668 0]INFO: ec_config_init wkc == 1
[065.315680 0]INFO: ec_config_init context->slavecount == 1
[065.451817 0]INFO: Calling ecx_config_map_group (this may cause stack overflow)
[065.452062 0]INFO: ec_config_map_group IOmap: group:214037844
[065.453824 0]INFO: >Slave 1, configadr 1001, state 2
[065.454827 0]INFO: getmbx item:0 mbx:0x0CC81198
[065.455835 0]INFO: dropmbx item:0 mbx:
[065.456826 0]INFO: getmbx item:1 mbx:0x0CC81767
[065.457846 0]INFO: dropmbx item:1 mbx:
[065.458837 0]INFO: getmbx item:2 mbx:0x0CC81D36
[065.459839 0]INFO: dropmbx item:2 mbx:
[065.460830 0]INFO: getmbx item:3 mbx:0x0CC82305
[065.461849 0]INFO: dropmbx item:3 mbx:
[065.462835 0]INFO: getmbx item:4 mbx:0x0CC828D4
[065.463846 0]INFO: dropmbx item:4 mbx:
[065.464834 0]INFO: getmbx item:5 mbx:0x0CC82EA3
[065.465855 0]INFO: dropmbx item:5 mbx:
[078.509090 0]INFO: EtherCAT operational loop completed
[078.509159 0]INFO: EtherCAT to SAFE_OP
[078.512061 0]INFO: EtherCAT to INIT
[078.514184 0]INFO: Final stack high water mark: 702
[078.514252 0]INFO: EtherCAT bringup completed
Log field meanings:
| Field | Meaning |
cycle | PDO cycle counter (one line every 100 cycles) |
Wck | WKC for the PDO frame; should track expectedWKC |
DCtime | DC reference time (ns) |
dt | Local vs DC clock error (ns); PI loop drives this toward 0 |
Pass criteria:
| Check | Pass if |
| OP | EtherCAT OP appears |
| WKC | Wck stable and non-zero |
| DC | dt shrinks over cycles when DC is present |
| Shutdown | EtherCAT to SAFE_OP → EtherCAT to INIT → EtherCAT bringup completed |
