7.5.12 Eth User Guide
Overview
Hardware Features
Maximum data transfer rate: 1000 Mbps
Supports full-duplex flow control (including IEEE 802.3x Pause packets and Priority flow control)
Supports network statistics
Supports Ethernet frame timestamps defined by IEEE 1588-2002/1588-2008
Supports PPS (pulse-per-second) output
Supports programmable Ethernet frame length, up to 16 KB
Assumptions and Limitations
- Up to 6 FIFOs are supported in each of the transmit and receive directions.
- Up to 8 FIFOs are supported in each of the transmit and receive directions.
Data larger than the available buffer size of the controller in use cannot be transmitted. Larger data must be transmitted using the Internet Protocol (IP) and Transmission Control Protocol (TCP).
The length of a single received frame (including the 14-byte Ethernet header and 4-byte FCS) must be less than or equal to the configured RX buffer length.
Module clock frequency is 250 MHz; PTP clock period is 20 ns.
Code Paths
McalCdd/Ethernet/inc— Header filesMcalCdd/Ethernet/src/Eth.c— Public API interfaceMcalCdd/Ethernet/src/Eth_Interrupt.c— Interrupt callback handler interfaceMcalCdd/Ethernet/src/Mac_Lld.c— Register control interface wrapper for API callsConfig/McalCdd/gen_s100_sip_B_mcu1/Ethernet/src/Eth_PBcfg.c— Eth post-build configuration for public API initializationConfig/McalCdd/gen_s100_sip_B_mcu1/Ethernet/src/Mac_Ip_PBcfg.c— MAC driver post-build configuration; static dependency ofEth_PBcfg.csamples/Eth/Eth_Test/Eth_test.c— Eth functional test sample
McalCdd/Ethernet/inc— Header filesMcalCdd/Ethernet/src/Eth.c— Public API interfaceMcalCdd/Ethernet/src/Eth_Interrupt.c— Interrupt callback handler interfaceMcalCdd/Ethernet/src/Mac_Lld.c— Register control interface wrapper for API callsConfig/McalCdd/gen_s600_md_mcu1/Ethernet/src/Eth_PBcfg.c— Eth post-build configuration for public API initializationConfig/McalCdd/gen_s600_md_mcu1/Ethernet/src/Mac_Ip_PBcfg.c— Eth post-build configuration for public API initializationsamples/Eth/Eth_Test/Eth_test.c— Eth functional test sample
Application Sample
The following uses samples/Eth/Eth_Test/Eth_test.c sending an ARP packet as an example:
Data Transmission
The Eth_test.c test program sends a constructed ARP packet. Use Wireshark on a PC to capture packets and verify that data is received correctly. IP addresses are fixed by default and cannot be modified dynamically.
0xd4, 0xfd, 0x9b, 0xae, 0x48, 0xf5, //Sender MAC address: d4:fd:9b:ae:48:f5 //MCU
0xC0, 0xA8, 0x01, 0x32, //Sender IP address: 192.168.1.50
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, //Target MAC address: 00:00:00:00:00:00 //PC
0xC0, 0xA8, 0x01, 0xf, //Target IP address: 192.168.1.15
- Pseudocode call flow
Eth_ProvideTxBuffer // Allocate buffer
Eth_Transmit // Send data
Eth_TxConfirmation // Release buffer
- Test procedure
After system startup, only Eth initialization is completed by default. Data transmission steps:
# Enable periodic EthTest_Mainfunc calls
setvar Eth_Test 1
# eth up
setvar eth_contrMode 1
setvar eth_testCase 3
# Send ARP packet
setvar eth_testCase 14
Data Reception
Print received packets through the serial port in EthIf_RxIndication. Reference:
if(eth_getIngressTsFlag)
eth_getIngressTsFlag = FALSE;
/* QT-S01-API-60105 QT-S01-API-60106 QT-S01-API-60107 QT-S01-API-60194 */
Eth_GetIngressTimeStamp(CtrlIdx,DataPtr,&Eth_TimeQual,&Eth_TimeStamp);
//LogSync("Ingress timestamp quality: %s\r\n", (Eth_TimeQual==ETH_VALID)?"ETH_VALID":"ETH_INVALID");
//LogSync("Ingress timestamp: %ds: %dns\r\n", ((uint32)(Eth_TimeStamp.secondsHi) << 16) + Eth_TimeStamp.seconds, Eth_TimeStamp.nanoseconds);
if(Eth_TimeStamp.secondsHi!=0 || Eth_TimeStamp.nanoseconds!=0)
eth_checkIngressTsFlg=TRUE;
if (count % 100 == 0) {
LogSync("Eth packet is received, FrameType: %x, IsBroadcast: %s\r\n", FrameType, (IsBroadcast==TRUE)?"TRUE":"FALSE");
LogSync("DstMac: %x-%x-%x-%x-%x-%x\r\n", *(DataPtr-14),*(DataPtr-13),*(DataPtr-12),*(DataPtr-11),*(DataPtr-10),*(DataPtr-9));
LogSync("SrcMac: %x-%x-%x-%x-%x-%x\r\n", PhysAddrPtr[0],PhysAddrPtr[1],PhysAddrPtr[2],PhysAddrPtr[3],PhysAddrPtr[4],PhysAddrPtr[5]);
count++;
if(FrameType==0x800)
LogSync("IP header checksum:%x,%x\r\n",DataPtr[10],DataPtr[11]);
if(DataPtr[9]==0x11)//UDP
LogSync("UDP checksum:%x,%x\r\n",DataPtr[26],DataPtr[27]);
eth_checkCksFlg=TRUE;
else if(DataPtr[9]==0x6)//tcp
LogSync("TCP checksum:%x,%x\r\n",DataPtr[36],DataPtr[37]);
Important Notes
- The default data transfer mode is polling. In polling mode, after transmitting with
Eth_Transmit, callEth_TxConfirmationto release the allocated buffer. - The PHY must be de-asserted from reset before
Eth_Initto ensure successful initialization. Pull the PHY reset pin high before Eth initialization.
Application Programming Interface
void Eth_Init( const Eth_ConfigType* CfgPtr )
Description: Initializes the Ethernet Driver.
Sync/Async: Synchronous
Parameters(in)
CfgPtr: Points to the implementation specific structure
Parameters(inout)
None
Parameters(out)
None
Return value: None
Std_ReturnType Eth_SetControllerMode(uint8 CtrlIdx, Eth_ModeType CtrlMode)
Description: Enables / disables the indexed controller.
Sync/Async: Asynchronous
Parameters(in)
CtrlIdx: Index of the controller within the context of the Ethernet Driver
CtrlMode: ETH_MODE_DOWN: disable the controller; ETH_MODE_ACTIVE: enable the controller
Parameters(inout)
None
Parameters(out)
None
Return value: Std_ReturnType
E_OK: success
E_NOT_OK: controller mode could not be changed
Std_ReturnType Eth_GetControllerMode(uint8 CtrlIdx, Eth_ModeType* CtrlModePtr)
Parameters(in)
Parameters(inout)
CtrlModePtr: ETH_MODE_DOWN: disable the controller; ETH_MODE_ACTIVE: enable the controller
Parameters(out)
None
E_OK: success
E_NOT_OK: controller mode could not be obtained
void Eth_GetPhysAddr(uint8 CtrlIdx, uint8* PhysAddrPtr)
Description: Obtains the physical source address used by the indexed controller.
Parameters(in)
Parameters(inout)
PhysAddrPtr: Physical source address (MAC address) in network byte order
Parameters(out)
None
Return value: None
void Eth_SetPhysAddr(uint8 CtrlIdx, const uint8* PhysAddrPtr)
Description: Sets the physical source address used by the indexed controller.
Parameters(in)
PhysAddrPtr: Pointer to memory containing the physical source address (MAC address) in network byte order
Parameters(inout)
None
Parameters(out)
None
Return value: None
Std_ReturnType Eth_GetCurrentTime(uint8 CtrlIdx, Eth_TimeStampQualType* timeQualPtr, Eth_TimeStampType* timeStampPtr)
Eth_GetCurrentTime may be called within an exclusive area.
Description: Returns a time value out of the HW registers according to the capability of the HW. Is the HW resolution is lower than the Eth_TimeStampType resolution resp.range, than an the remaining bits will be filled with 0.
Parameters(in)
Parameters(inout)
None
Parameters(out)
timeQualPtr: Quality of HW time stamp, e.g. based on current drift
timeStampPtr: Current time stamp
E_OK: success
E_NOT_
BufReq_ReturnType Eth_ProvideTxBuffer(uint8 CtrlIdx, uint8 Priority, Eth_BufIdxType *BufIdxPtr, uint8 **BufPtr, uint16 *LenBytePtr)
Description: Provides access to a transmit buffer of the FIFO related to the specified priority.
Parameters(in)
Priority: Frame priority for transmit buffer FIFO selection
Parameters(inout)
LenBytePtr: In: desired length in bytes, out: granted length in bytes
Parameters(out)
BufIdxPtr: Index to the granted buffer resource. To be used for subsequent requests
BufPtr: Pointer to the granted buffer
Return value: BufReq_ReturnType
BUFREQ_OK: success
BUFREQ_E_NOT_OK: development error detected
BUFREQ_E_BUSY: all buffers in use
BUFREQ_E_OVFL: requested buffer too large
Std_ReturnType Eth_Transmit(uint8 CtrlIdx, Eth_BufIdxType BufIdx, Eth_FrameType FrameType, boolean TxConfirmation, uint16 LenByte, const uint8* PhysAddrPtr)
Description: Description: Triggers transmission of a previously filled transmit buffer.
Parameters(in)
BufIdx: Index of the buffer resource
FrameType: Ethernet frame type
TxConfirmation: Activates transmission confirmation
LenByte: Data length in byte
PhysAddrPtr: Physical target address (MAC address) in network byte order
Parameters(inout)
None
Parameters(out)
None
E_OK: success
E_NOT_OK: transmission failed
Void Eth_Receive(uint8 CtrlIdx, uint8 FifoIdx, Eth_RxStatusType* RxStatusPtr)
Description: Receive a frame from the related fifo.
Parameters(in)
FifoIdx: Specifies the related fifo
Parameters(inout)
None
Parameters(out)
RxStatusPtr: Indicates whether a frame has been received and if so, whether more frames are available for the related fifo.
Return value: None
void Eth_TxConfirmation(uint8 CtrlIdx)
Description: Triggers frame transmission confirmation.
Parameters(in)
Parameters(inout)
None
Parameters(out)
None
Return value: None
Std_ReturnType Eth_EnableSnapshot(uint8 CtrlIdx, GMAC_PPS_SOURCE PpsSource)
Description: Set snapshot source.
Parameters(in)
CtrlIdx: Index of the addresses ETH controller
PpsSource: Index of the PPS Source
Parameters(inout)
None
Parameters(out)
None
E_OK: success
E_NOT_OK: failed
Std_ReturnType Eth_GetSnapshotTime(uint8 CtrlIdx, Eth_TimeStampType * TimeStampPtr)
Description: Get snapshot time of PHC.
Parameters(in)
TimeStampPtr: Snapshot Time of PHC
Parameters(inout)
None
Parameters(out)
None
E_OK: success
E_NOT_OK: failed
