Version
4.4.9.2. OTA API
This system provides a low-level flashing library libupdate.so, and implements a set of cross-platform APIs for writing OTA update packages.
Source code path: hbre/otaupdate/src/ota_apis/hobot_ota_hl.c
Header file: hobot_ota_hl.h
An ota_tool has been developed based on the OTA HighLevel API. This tool helps customers more easily reference and implement related functions when designing the OTA Service.
Source code path: hbre/otaupdate/src/ota_tool
Library: libupdate.so
Error Types Returned by Dynamic Library Interfaces
The dynamic library error values are defined as follows:
enum ota_err_e {
    OTA_SUCCESS = 0,
    OTAERR_IO,
    OTAERR_PLAT_UNSUPPORT,
    OTAERR_REPEAT,
    OTAERR_MUTEX_INIT_LOCK_ERR,
    OTAERR_NOTINIT,
    OTAERR_NULLPOINTER,
    OTAERR_SHORTBUF,
    OTAERR_THREAD_CREATE,
    OTAERR_RANGE,
    OTAERR_STAGE,
    OTAERR_IMAGE_WRITE,
    OTAERR_BOOT_FAILED,
    OTAERR_VEEPROM,
    OTAERR_FILE_TYPE,
    OTAERR_UNZIP,
    OTAERR_NO_EXISTS,
    OTAERR_MALLOC,
    OTAERR_VERIFY,
    OTAERR_IMG_SIZE,
    OTAERR_UPDATE_STATUS,
Interface List
Interface Prototype Description
int32_t otaInitLib(void); Dynamic library initialization
int32_t otaDeinitLib(void); Dynamic library deinitialization
int32_t otaGetLibVersion(char *version, int32_t len); Get dynamic library version
int32_t otaRequestStart(const char *image_name, enum ota_update_owner owner); Start upgrade thread
int32_t otaGetResult(void); Get upgrade status and result
int32_t otaGetProgress(void); Get upgrade progress
int32_t otaGetUpdatingImageName(char *image_name , int32_t len); Get currently upgrading package
int32_t otaGetSysVersion(char *version, int32_t len); Get current system version
int32_t otaGetPartition(uint8_t *partition); Get current boot AB partition
int32_t otaSetPartition(uint8_t partition); Set next boot AB partition
int32_t otaGetOwnerFlag(enum ota_update_owner *owner); Get OTA owner (after reboot)
int32_t otaMarkOTASuccessful(void); Mark OTA upgrade successful (after reboot)
int32_t otaCheckUpdate(void); Check if upgrade succeeded (after reboot)
int32_t otaPartitionSync(void); Synchronize AB and backup partitions
void otaClearFlags(void); End upgrade, clear OTA flags
otaInitLib
【Function Declaration】
【Parameter Description】
  • [OUT] N/A
  • [IN] N/A
【Return Value】
  • OTA_SUCCESS: Success
  • -OTAERR_REPEAT: Repeated initialization
【Function Description】
Initialize the dynamic library for board-side flashing interface, mainly initializing the global structure g_upgrade_info.
【Example Code】
#include <stdio.h>
#include <hobot_ota_hl.h>
int main(void) {
    int32_t ret;
    ret = otaInitLib();
    if (ret != 0) {
        printf("otaInitLib return: %d\n", ret);
        return ret;
    ret = otaDeinitLib();
    if (ret != 0) {
        printf("otaDeinitLib return: %d\n", ret);
        return ret;
otaDeinitLib
  • [OUT] N/A
  • [IN] N/A
【Return Value】
  • -OTAERR_NOTINIT: Not initialized, cannot call deinitialization
Deinitialization
【Example Code】
Refer to otaInitLib
otaGetLibVersion
  • [OUT] version: Buffer to store version information. Version is returned as a three-part string (e.g., 1.0.0)
  • [IN] len: Length of input buffer
【Return Value】
  • -OTAERR_NULLPOINTER: Null pointer for version
  • -OTAERR_SHORTBUF: Input buffer too small
  • -OTAERR_PLAT_UNSUPPORT: Getting version number is not supported
Get the version of this dynamic library
【Example Code】
#include <stdio.h>
int main(void) {
    int32_t ret;
    char version[128];
    if (ret = otaGetLibVersion(version, sizeof(version))) {
        return ret;
    printf("version: %s\n", version);
otaRequestStart
  • [OUT] N/A
  • [IN] image_name: Absolute path of the update package. Supports multiple package types passed simultaneously, separated by semicolons.
  • [IN] owner: Process initiating this update, defined by enum ota_update_owner
【Return Value】
  • -OTAERR_NULLPOINTER: Null pointer for image_name
  • -OTAERR_RANGE: Invalid owner setting, out of defined range
  • -OTAERR_NOTINIT: Dynamic library not initialized
  • -OTAERR_REPEAT: Another process is currently upgrading
  • -OTAERR_IO: IO failure
  • -OTAERR_THREAD_CREATE: Thread creation failed
Start the upgrade thread to perform update on the provided image_name, and set the current upgrade owner.
【Example Code】
#include <stdio.h>
int main(void) {
    int32_t ret;
    int32_t result;
    int32_t progress;
    char imgname[256];
    ret = otaInitLib();
    if (ret != 0) {
        return ret;
    if (ret = otaRequestStart("/userdata/all_in_one.zip", OTA_TOOL)) {
        printf("otaRequestStart return: %d\n", ret);
        return ret;
    do {
        result = otaGetResult();
        if (ret = otaGetUpdatingImageName(imgname, sizeof(imgname))) {
            printf("otaGetUpdatingImageName return: %d\n", imgname);
        progress = otaGetProgress();
        printf("current image: %s, progress: %d\n", imgname, progress);
        sleep(1);
    } while(result != 0 && result != 3);
    ret = otaGetPartition(&cur_part);
    if (ret != 0) {
        printf("otaGetPartition returned with %d\n", ret);
    ret = otaSetPartition(1 - cur_part);
    if (ret != 0) {
        printf("otaSetPartition returned with %d\n", ret);
    /* Then reboot system */
otaGetResult
  • [OUT] N/A
  • [IN] N/A
【Return Value】
  • OTA_UPGRADE_NOT_START: Upgrade not started
  • OTA_UPGRADE_IN_PROGRESS: Upgrading
  • OTA_UPGRADE_SUCCESS: Upgrade completed successfully
  • OTA_UPGRADE_FAILED: Upgrade completed with failure
Get upgrade result
【Example Code】
Refer to otaRequestStart
otaGetProgress
  • [OUT] N/A
  • [IN] N/A
【Return Value】
  • 0 ~ 100: Current upgrade progress (%)
Get current upgrade progress
【Example Code】
  • [OUT] image_name: Buffer to store result. Possible values for image_name: “idle_state” – Upgrade not started “all_img_finish” – Upgrade completed “” – Failed before writing image Other package names ending with “.img”
  • [IN] len: Buffer length
【Return Value】
  • -OTAERR_SHORTBUF: Buffer length too short
Get the currently upgrading image
【Example Code】
otaGetSysVersion
  • [OUT] version: Buffer to store version information. Version stores system software version, starting with date (yyyymmdd)
【Return Value】
  • -OTAERR_IO: IO error, please retry
Get current system software version
【Example Code】
#include <stdio.h>
int main(void) {
    int32_t ret;
    char version[128];
    if (ret = otaGetSysVersion(version, sizeof(version))) {
        printf("otaGetSysVersion return: %d\n", ret);
        return -1;
    printf("current system version: %s\n", version);
otaGetPartition
  • [OUT] partition: Pointer to variable receiving current partition. *partition=0: currently on A partition, *partition=1: currently on B partition
  • [IN] N/A
【Return Value】
  • -OTAERR_NULLPOINTER: Null pointer for partition
【Example Code】
otaSetPartition
  • [OUT] N/A
  • [IN] partition: Next boot partition. 0: A partition, 1: B partition
【Return Value】
  • -OTAERR_RANGE: Invalid partition range, must be 0 or 1
  • -OTAERR_STAGE: Not supported in current upgrade stage. Not supported during or after failed upgrade
【Example Code】
otaGetOwnerFlag
  • [OUT] owner: Variable to receive current upgrade owner. See enum ota_update_owner
  • [IN] N/A
【Return Value】
Get current upgrade owner
【Example Code】
static int check_and_mark(void) {
    enum ota_update_owner owner;
    int32_t ret;
    ret = otaGetOwnerFlag(&owner);
    if (ret != 0) {
            printf("otaGetOwnerFlag returned with %d\n", ret);
            return -1;
    if (owner != OTA_TOOL) {
            printf("The OTA update is not launched by ota_tool, owner: %d\n", owner);
            return -1;
    ret = otaCheckUpdate();
    if (ret == -OTAERR_IMAGE_WRITE) {
            printf("ota_tool: OTA image write failed, is there a reboot during update?\n");
            goto clearFlags;
    if (ret == -OTAERR_BOOT_FAILED) {
            printf("ota_tool: The new package boot failed. Please check the packages\n");
            goto clearFlags;
    if (ret != 0) {
            printf("otaCheckUpdate returned with %d\n", ret);
            goto clearFlags;
    ret = otaMarkOTASuccessful();
    if (ret != 0) {
            printf("otaMarkOTASuccessful returned with %d\n", ret);
            goto clearFlags;
    ret = otaPartitionSync();
    if (ret != 0) {
            printf("otaPartitionSync returned with %d\n", ret);
            goto clearFlags;
clearFlags:
    otaClearFlags();
    return ret;
  • [OUT] N/A
  • [IN] N/A
【Return Value】
Mark this upgrade as successful
【Example Code】
Refer to otaGetOwnerFlag
otaCheckUpdate
【Parameter Description】- [OUT] N/A
  • [IN] N/A
【Return Value】
  • -OTAERR_STAGE: Upgrade not performed
  • -OTAERR_IMAGE_WRITE: Image write failed
  • -OTAERR_BOOT_FAILED: New image failed to boot or partition not switched
【Description】
Check whether the current upgrade was successful.
【Example Code】
otaClearFlags
  • [OUT] N/A
  • [IN] N/A
【Return Value】
  • N/A
【Description】
Clear OTA flags.
【Example Code】
otaPartitionSync
  • [OUT] N/A
  • [IN] N/A
【Return Value】
  • -OTAERR_REPEAT: Conflict with another upgrade process
【Description】
Synchronize AB partitions and backup partition.
【Example Code】
