Unlisted page
3.2.5 Slash commands
Slash commands start with / in the AI Dock. They manage the current session, list skills, or temporarily switch models. They are not sent to the model and do not use tokens.
Command list​
CommandEffect
/helpLists available slash commands and what they do
/clearClears the current session’s reference context and restarts “empty” (history kept)
/sessionsLists past sessions; pick one to continue
/skillsLists skill IDs loaded in this session with short descriptions
/modelTemporarily switches the model for this session only
/resetResets Moss: clears context, reloads capabilities, re-probes devices
Typical uses​
/clear vs new chat​
/clear drops reference context but keeps the session record—good for “new topic, same thread.” New chat is better for a fully new task. Pick what fits.
/skills to verify loading​
If a skill seems absent (installed but unused), run /skills to see what is active.
Skills load on demand: only when your message matches a trigger keyword.
If wording and triggers disagree, adjust triggers in 3.11 Skill Workshop.
/model for a one-off stronger model​
For heavy code generation, temporarily switch:
/model claude-sonnet-4-20250514
Takes effect immediately for this session only; does not change global defaults. New sessions revert to defaults.
/reset when Moss misbehaves​
If Moss loops a failed step or drifts off-topic, /reset clears context, reloads tools, and re-probes the device—stronger than /clear.
