4.7.3. perf
perf is an open-source performance analysis tool used for performance monitoring and analysis on Linux systems. It provides a variety of subcommands for different performance analysis scenarios, such as recording, analyzing, and statistical profiling.
4.7.3.1. Syntax Description
Below is the Usage output from executing perf --help:
usage: perf [--version] [--help] [OPTIONS] COMMAND [ARGS]
4.7.3.2. Parameter Options Description
perf supports multiple subcommands, each with its specific purpose. Below are some commonly used subcommands and their descriptions:
annotate
Purpose: Parse the perf.data file generated by perf record and display annotated code.
archive
Purpose: Package all sampled ELF files based on the build-id recorded in the data file. This archive can be used to analyze sampling data on any machine.
bench
Purpose: Built-in benchmark suite in perf, currently including two sets of benchmarks targeting the scheduler and memory management subsystems.
buildid-cache
Purpose: Manage perf's buildid cache. Each ELF file has a unique buildid, which perf uses to associate performance data with ELF files.
buildid-list
Purpose: List all buildids recorded in the data file.
diff
Purpose: Compare differences between two data files. It can show specific differences for each symbol (function) in hotspot analysis.
evlist
Purpose: List all performance events recorded in the perf.data file.
inject
Purpose: This tool reads the event stream recorded by perf record and redirects it to standard output. Additional events can be injected into the event stream at any point in the analyzed code.
kmem
Purpose: Tool for tracing and measuring the kernel memory (slab) subsystem.
kvm
Purpose: Used to trace and test Guest OS running on KVM virtual machines.
list
Purpose: List all performance events supported by the current system, including hardware performance events, software performance events, and tracepoints.
lock
Purpose: Analyze lock information in the kernel, including lock contention and waiting latency.
mem
Purpose: Memory access behavior.
record
Purpose: Collect sampling information and record it in a data file. The data file can later be analyzed using other tools.
report
Purpose: Read the data file created by perf record and provide hotspot analysis results.
sched
Purpose: Analysis tool for the scheduler subsystem.
script
Purpose: Execute Perl or Python extension scripts, generate script templates, read data from data files, etc.
stat
Purpose: Execute a command and collect performance statistics for a specific process, including CPI, cache miss rate, etc.
test
Purpose: Perform sanity testing of the current software and hardware platform. Use this tool to verify whether the current platform supports all perf features.
timechart
Purpose: Visualization tool for system behavior during testing.
top
Purpose: Similar to Linux's top command, provides real-time system performance analysis.
trace
Purpose: Tool related to system calls.
probe
Purpose: Used to define dynamic tracepoints.
Global Overview:
perf list
Purpose: View all performance events supported by the current system.
perf bench
Purpose: Benchmark system performance.
perf test
Purpose: Perform sanity testing on the system.
perf stat
Purpose: Statistically summarize overall system performance.
Global Details:
perf top
Purpose: Real-time view of function CPU usage across the system.
perf probe
Purpose: Define custom dynamic events.
Specific Function Analysis:
perf kmem
Purpose: Performance analysis of the slab subsystem.
perf kvm
Purpose: Analysis of KVM virtualization.
perf lock
Purpose: Analyze lock performance.
perf mem
Purpose: Analyze memory slab performance.
perf sched
Purpose: Analyze kernel scheduler performance.
perf trace
Purpose: Record system call traces.
Common Function: perf record
Can monitor system-wide, target a specific process, or even focus on a specific event within a process; can be macroscopic or highly microscopic.
perf record
Purpose: Record information into perf.data.
perf report
Purpose: Generate analysis reports.
perf diff
Purpose: Compare two recorded data files.
perf evlist
Purpose: List recorded performance events.
perf annotate
Purpose: Display function code from perf.data.
perf archive
Purpose: Package related symbols for convenient analysis on other machines.
Visualization Tool: perf timechart
perf timechart record
Purpose: Record system events.
perf timechart
Purpose: Generate output.svg file.
4.7.3.3. Command Options and Functional Descriptions
perf System Analysis
Command:
root@buildroot:~# perf top
Function:
Real-time display of functions or instructions consuming the most CPU cycles (useful for identifying hot functions).
Output:
PerfTop: 1109 irqs/sec kernel:58.4% exact: 0.0% lost: 0/0 drop: 0/0 [4000Hz cycles], (all, 8 CPUs)
7.52% perf [.] 0x00000000000d7930
5.45% libc.so.6 [.] strchr
5.23% [kernel] [k] format_decode
5.15% [kernel] [k] number
3.81% [kernel] [k] vsnprintf
3.43% [kernel] [k] kallsyms_expand_symbol.constprop.0
3.08% [kernel] [k] string
2.16% [kernel] [k] module_get_kallsym
2.03% libc.so.6 [.] __libc_calloc
1.60% perf [.] 0x00000000000e1974
Field Explanation:
1109 irqs/sec: Interrupt frequency, 1109 times per second.
kernel: Kernel-space CPU usage: 58.4%.
exact: Proportion of sampled events that precisely match hardware counters; 0.0% means all events were accurately recorded.
lost: Number of events lost during sampling (here 0).
drop: Number of events dropped by the kernel due to buffer overflow (here 0).
Each line contains four columns:
Overhead: Percentage of this symbol’s performance events among all samples.
Shared: Dynamic shared object (DSO) where the function or instruction resides, such as kernel, process name, shared library, or kernel module.
Object: Type of DSO.
[.]indicates user-space executable or shared library;[k]indicates kernel space.Symbol: Symbol name, i.e., function name. When unknown, shown as hexadecimal address.
perf Event Types
Command:
root@buildroot:~# perf list
Function:
Display all performance events supported by perf, which can be used for performance monitoring.
Output:
List of pre-defined events (to be used in -e or -M):
branch-instructions OR branches [Hardware event]
branch-misses [Hardware event]
bus-cycles [Hardware event]
cache-misses [Hardware event]
cache-references [Hardware event]
cpu-cycles OR cycles [Hardware event]
instructions [Hardware event]
stalled-cycles-backend OR idle-cycles-backend [Hardware event]
stalled-cycles-frontend OR idle-cycles-frontend [Hardware event]
alignment-faults [Software event]
bpf-output [Software event]
cgroup-switches [Software event]
context-switches OR cs [Software event]
cpu-clock [Software event]
cpu-migrations OR migrations [Software event]
dummy [Software event]
emulation-faults [Software event]
major-faults [Software event]
minor-faults [Software event]
page-faults OR faults [Software event]
task-clock [Software event]
duration_time [Tool event]
user_time [Tool event]
system_time [Tool event]
L1-dcache-load-misses [Hardware cache event]
L1-dcache-loads [Hardware cache event]
L1-icache-load-misses [Hardware cache event]
L1-icache-loads [Hardware cache event]
LLC-load-misses [Hardware cache event]
LLC-loads [Hardware cache event]
branch-load-misses [Hardware cache event]
branch-loads [Hardware cache event]
dTLB-load-misses [Hardware cache event]
dTLB-loads [Hardware cache event]
iTLB-load-misses [Hardware cache event]
iTLB-loads [Hardware cache event]
br_immed_retired OR armv8_pmuv3/br_immed_retired/ [Kernel PMU event]
br_mis_pred OR armv8_pmuv3/br_mis_pred/ [Kernel PMU event]
br_mis_pred_retired OR armv8_pmuv3/br_mis_pred_retired/ [Kernel PMU event]
br_pred OR armv8_pmuv3/br_pred/ [Kernel PMU event]
br_retired OR armv8_pmuv3/br_retired/ [Kernel PMU event]
br_return_retired OR armv8_pmuv3/br_return_retired/ [Kernel PMU event]
Field Explanation:
Hardware Events
Purpose: Directly use CPU hardware performance counters to measure low-level hardware behavior.
Key Events:
cpu-cycles: Number of CPU clock cycles (measures compute-intensive tasks).
instructions: Number of executed instructions (combined with cycles to compute IPC, instructions per cycle).
branch-misses: Number of branch prediction misses (key metric for optimizing branch logic).
cache-misses: Number of cache misses.
Software Events
Purpose: Abstract events simulated by the kernel, not dependent on hardware counters.
Key Events:
context-switches: Number of context switches.
page-faults: Number of page faults.
cpu-migrations: Number of process migrations between CPU cores.
Hardware Cache Events
Purpose: Measure behavior across CPU cache levels (L1/L2/L3).
Key Events:
L1-dcache-load-misses: L1 data cache load misses.
LLC-load-misses: Last-level cache (L3) load misses (high values suggest need for memory access optimization).
iTLB-load-misses: Instruction TLB load misses.
Kernel PMU Events
Purpose: Architecture-specific hardware events.
Key Events:
br_mis_pred_retired: Number of retired mispredicted branch instructions.
br_retired: Total number of retired branch instructions (used to calculate branch misprediction rate).
Tool Events
Purpose: Abstract events defined by perf itself for time distribution statistics.
Key Events:
duration_time: Total execution time.
user_time: Time spent in user-space code.
system_time: Time spent in kernel-space code.
Specifying Performance Events:
-e :u // userspace
-e :k // kernel
-e :h // hypervisor
-e :G // guest counting (in KVM guests)
-e :H // host counting (not in KVM guests)
Command:
root@buildroot:~# perf top -e cycles:k
Function:
Display functions consuming the most CPU cycles in kernel and modules.
Output:
PerfTop: 48 irqs/sec kernel:100.0% exact: 0.0% lost: 0/0 drop: 0/0 [4000Hz cycles:k], (all, 8 CPUs)
9.72% [kernel] [k] format_decode
8.56% [kernel] [k] number
7.23% [kernel] [k] kallsyms_expand_symbol.constprop.0
7.20% [kernel] [k] vsnprintf
4.84% [kernel] [k] string
4.33% [kernel] [k] module_get_kallsym
2.71% [kernel] [k] finish_task_switch.isra.0
2.62% [kernel] [k] mas_spanning_rebalance.isra.0
2.16% [kernel] [k] _raw_spin_unlock_irqrestore
1.82% [kernel] [k] memmove
1.26% [kernel] [k] pointer
1.23% [kernel] [k] mab_mas_cp
1.17% [kernel] [k] update_iter
1.09% [kernel] [k] strscpy
1.09% [kernel] [k] __slab_free.constprop.0
1.08% [kernel] [k] memset
1.07% [kernel] [k] mtree_range_walk
1.04% [kernel] [k] mas_descend_adopt
0.80% [kernel] [k] rcu_cblist_dequeue
0.80% [kernel] [k] kmem_cache_free
0.79% [kernel] [k] seq_read_iter
0.74% [kernel] [k] kmem_cache_alloc_bulk
0.72% [kernel] [k] do_raw_spin_unlock
0.65% [kernel] [k] s_next
0.65% [kernel] [k] mas_wr_walk_index.isra.0
0.62% [kernel] [k] __might_resched
0.62% [kernel] [k] perf_iterate_sb
0.51% libc.so.6 [.] __mprotect
0.50% [kernel] [k] perf_event_mmap
0.46% [kernel] [k] kmem_cache_free_bulk.part.0
perf Process Statistics
Used to analyze performance characteristics of a specified program. Input format:
perf stat [-e | --event=EVENT] [-a]
perf stat [-e | --event=EVENT] [-a] - []
Command:
root@buildroot:~# perf stat ls
Function:
Output includes execution time of ls and statistics for 10 performance events.
Output:
root@buildroot:/userdata# perf stat ls
all_in_one.signature all_in_one.zip gmsl log lost+found perf.data perf.txt perf.unfold startup.sh tee
Performance counter stats for 'ls':
6.04 msec task-clock # 0.742 CPUs utilized
0 context-switches # 0.000 /sec
0 cpu-migrations # 0.000 /sec
125 page-faults # 20.680 K/sec
3605684 cycles # 0.597 GHz
2112783 instructions # 0.59 insn per cycle
250653 branches # 41.468 M/sec
23909 branch-misses # 9.54% of all branches
0.008141958 seconds time elapsed
0.008350000 seconds user
0.000000000 seconds sys
Field Explanation:
task-clock:
Actual processor time consumed by the task, in milliseconds.
context-switches:
cpu-migrations:
Number of processor migrations. Linux migrates tasks between CPUs under certain conditions to maintain load balancing across processors.
page-faults:
Number of page faults. Triggered when the requested page is not established, not in memory, or when the mapping between physical and virtual addresses is not set up.
cycles:
Number of processor cycles consumed.
instructions:
Number of instructions executed.
branches:
Number of branch instructions encountered.
branch-misses:
Number of mispredicted branch instructions.
Common perf stat Options
-p: Stat events on existing process ID (comma-separated list).
Purpose: Analyze only the target process and its threads.
-a: System-wide collection from all CPUs.
Purpose: Collect performance data from all CPUs.
-r: Repeat command and print average + standard deviation (max: 100).
Purpose: Repeat command execution and compute average.
-C: Count only on the list of CPUs provided (comma-separated list).
Purpose: Collect performance data from specified CPUs.
-v: Be more verbose (show counter open errors, etc).
Purpose: Display more detailed performance data.
-n: Null run — don’t start any counters.
Purpose: Only show task execution time.
-x SEP: Specify separator for output columns.
-o file: Specify output file.
Command:
root@buildroot:~# perf stat -r 10 ls > /dev/null
Function:
Execute the program 10 times and report the ratio of standard deviation to mean.
Output:
Performance counter stats for 'ls' (10 runs):
3.21 msec task-clock # 0.696 CPUs utilized ( +- 7.72% )
121 page-faults # 35.452 K/sec ( +- 0.22% )
3842788 cycles # 1.126 GHz ( +- 1.15% )
2038097 instructions # 0.54 insn per cycle ( +- 0.35% )
239562 branches # 70.189 M/sec ( +- 0.29% )
22215 branch-misses # 9.44% of all branches ( +- 0.41% )
0.004613 +- 0.000344 seconds time elapsed ( +- 7.46% )
Field Explanation:
In the output of the performance testing tool perf stat, the ±x% in parentheses represents the standard deviation as a percentage of the mean, commonly known as the coefficient of variation (CV). It reflects the fluctuation range of the metric across multiple runs and is used to measure the stability and reliability of the data.
Command:
root@buildroot:~# perf stat -v ls > /dev/null
Function:
Display more detailed information.
Output:
Using CPUID 0x00000000410fd050
Control descriptor is not initialized
task-clock: 5669250 5669250 5669250
context-switches: 0 5669250 5669250
cpu-migrations: 0 5669250 5669250
page-faults: 120 5669250 5669250
cycles: 3390596 5666583 5666583
instructions: 2003447 5666583 5666583
branches: 237261 5666583 5666583
branch-misses: 22209 5666583 5666583
5.67 msec task-clock # 0.732 CPUs utilized
120 page-faults # 21.167 K/sec
3390596 cycles # 0.598 GHz
2003447 instructions # 0.59 insn per cycle
237261 branches # 41.851 M/sec
22209 branch-misses # 9.36% of all branches
0.007745041 seconds time elapsed
0.007955000 seconds user
Command:
root@buildroot:~# perf stat -n ls > /dev/null
Function:
Only display task execution time, without showing performance counters.
Output:
0.003568084 seconds time elapsed
0.003818000 seconds user
Command:
root@buildroot:~# perf stat -a -A ls > /dev/null
Function:
Display information for each individual CPU.
Output:
Performance counter stats for 'system wide':
CPU0 4.24 msec cpu-clock # 1.042 CPUs utilized
CPU1 4.21 msec cpu-clock # 1.034 CPUs utilized
CPU2 4.19 msec cpu-clock # 1.029 CPUs utilized
CPU3 4.16 msec cpu-clock # 1.024 CPUs utilized
CPU4 4.15 msec cpu-clock # 1.020 CPUs utilized
CPU5 4.14 msec cpu-clock # 1.017 CPUs utilized
CPU6 4.13 msec cpu-clock # 1.016 CPUs utilized
CPU7 4.11 msec cpu-clock # 1.010 CPUs utilized
CPU0 3 context-switches # 708.159 /sec
CPU1 3 context-switches # 713.225 /sec
CPU2 3 context-switches # 716.625 /sec
CPU3 3 context-switches # 720.295 /sec
CPU4 3 context-switches # 723.117 /sec
CPU5 5 context-switches # 1.208 K/sec
CPU6 3 context-switches # 726.194 /sec
CPU7 5 context-switches # 1.217 K/sec
CPU0 1 cpu-migrations # 236.053 /sec
CPU1 1 cpu-migrations # 237.742 /sec
CPU2 1 cpu-migrations # 238.875 /sec
CPU3 1 cpu-migrations # 240.098 /sec
CPU4 1 cpu-migrations # 241.039 /sec
CPU5 1 cpu-migrations # 241.687 /sec
CPU6 1 cpu-migrations # 242.065 /sec
CPU7 1 cpu-migrations # 243.408 /sec
perf record - Collect Information
Collect sampling data and record it into a data file. The data file can later be analyzed using other tools (e.g., perf-report).
Common Options:
The perf record command has many available options. Below are commonly used ones. For the complete list, run perf record -h.
-a: Analyze system-wide performance
-A: Append output to the output file
-c: Sampling period for events
-C: Monitor only specified CPU(s)
-e: Select performance events, which can be hardware or software events
-f: Overwrite the output file
-g: Record function call chains
-o: Specify output file; default is perf.data
-p: Specify a process ID to collect data for a specific process
-t: Specify a thread ID to collect data for a specific thread
Command:
root@buildroot:~# perf record -a -F 1000 sleep 5
Function:
Sample events across all CPUs at a frequency of 1000 Hz during a 5-second sleep period.
Command:
root@buildroot:~# perf record -p xxx -g
Function:
Monitor the process with PID=xxx, record call chains, and save output to the default file perf.data.
root@buildroot:~# perf record -p xxx -g -o pidxxx.data
Function:
Monitor the process with PID=xxx, record call chains, and save output to pidxxx.data.
perf report - Analyze Results
perf report analyzes the data file generated by perf record.
Common Options:
The perf report command has many available options. Below are commonly used ones. For the complete list, run perf report -h.
-c: Specify sampling period
-C: Display information for specified CPU only
-d: Display symbols for specified DOS only
-g: Generate function call graph, equivalent to the
-goption inperf top-i: Input data file name; default is perf.data
-M: Display assembly instructions in specified syntax style
–sort: Sort statistics by criteria such as PID, COMM, CPU, etc.
-S: Consider only specified symbols
-U: Display only resolved symbols
-v: Show address for each symbol
Command:
root@buildroot:~# perf report -i perf.data
Function:
Analyze the data file generated by perf record.
Output:
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 505 of event 'cycles'
# Event count (approx.): 16387804
# Children Self Command Shared Object Symbol
[[31m 72.50%[[m 0.00% swapper [kernel.kallsyms] [k] cpu_startup_entry
---cpu_startup_entry
--[[31m71.81%[[m--do_idle
|--[[31m46.64%[[m--default_idle_call
| --[[31m46.21%[[m--arch_cpu_idle
| --[[31m14.86%[[m--el1h_64_irq
| el1h_64_irq_handler
| el1_interrupt
| irq_exit_rcu
| __irq_exit_rcu
| do_softirq_own_stack
| call_on_irq_stack
| ____do_softirq
| __softirqentry_text_start
| |--[[31m6.68%[[m--run_timer_softirq
| | --[[31m6.34%[[m--__run_timers.part.0
| | |--[[32m3.45%[[m--call_timer_fn.constprop.0
| | | |--[[32m1.72%[[m--process_timeout
| | | | wake_up_process
| | | | try_to_wake_up
| | | --[[32m0.86%[[m--tcp_orphan_update
| | --[[32m2.89%[[m--_raw_spin_unlock_irq
| |--[[32m4.39%[[m--run_rebalance_domains
| | |--[[32m2.50%[[m--rebalance_domains
| | | --[[32m2.10%[[m--load_balance
| | | --[[32m0.75%[[m--find_busiest_group
| | --[[32m1.89%[[m--update_blocked_averages
| --[[32m1.59%[[m--rcu_core_si
| |--[[32m0.90%[[m--file_free_rcu
| --[[32m0.57%[[m--rcu_core
|--[[31m10.88%[[m--schedule_idle
| __schedule
|--[[31m8.46%[[m--nohz_run_idle_balance
| |--[[31m7.71%[[m--_nohz_idle_balance.isra.0
| | --[[32m3.49%[[m--update_blocked_averages
| --[[32m0.52%[[m--_find_next_bit
--[[32m4.75%[[m--tick_nohz_idle_exit
Generate Flame Graph with perf
Step 1
In the xbuild compilation system, use the following command to help users configure kernel options. This command automatically uses the kernel configuration file set in the board configuration file. After configuration, it automatically runs savedefconfig and saves the configuration. Enter the command as follows:
./bd.sh boot menuconfig
Enable BPF_SYSCALL, save the configuration, and recompile and flash the kernel.
Step 2
Use the perf script tool to parse perf.data:
perf script -i perf.data &> perf.unfold
Step 3
Download the FlameGraph tool using git:
git clone https://github.com/brendangregg/FlameGraph.git
After downloading and extracting, the directory structure is as follows:
├── README.md
├── aix-perf.pl
├── demos
│ ├── README
│ ├── brkbytes-mysql.svg
│ ├── cpu-grep.svg
│ ├── cpu-illumos-ipdce.svg
│ ├── cpu-illumos-syscalls.svg
│ ├── cpu-illumos-tcpfuse.svg
│ ├── cpu-iozone.svg
│ ├── cpu-ipnet-diff.svg
│ ├── cpu-linux-tar.svg
│ ├── cpu-linux-tcpsend.svg
│ ├── cpu-mixedmode-flamegraph-java.svg
│ ├── cpu-mysql-filt.svg
│ ├── cpu-mysql.svg
│ ├── cpu-qemu-both.svg
│ ├── cpu-zoomable.html
│ ├── hotcold-kernelthread.svg
│ ├── io-gzip.svg
│ ├── io-mysql.svg
│ ├── mallocbytes-bash.svg
│ ├── off-bash.svg
│ ├── off-mysql-busy.svg
│ ├── off-mysql-idle.svg
│ ├── palette-example-broken.svg
│ └── palette-example-working.svg
├── dev
│ ├── README
│ ├── gatherhc-kern.d
│ ├── gatherthc-kern.d
│ ├── hcstackcollapse.pl
│ ├── hotcoldgraph.pl
│ └── thcstackcollapse.pl
├── difffolded.pl
├── docs
│ └── cddl1.txt
├── example-dtrace-stacks.txt
├── example-dtrace.svg
├── example-perf-stacks.txt.gz
├── example-perf.svg
├── files.pl
├── flamegraph.pl
├── jmaps
├── perf.folded
├── perf.svg
├── perf.unfold
├── pkgsplit-perf.pl
├── range-perf.pl
├── record-test.sh
├── stackcollapse-aix.pl
├── stackcollapse-bpftrace.pl
├── stackcollapse-chrome-tracing.py
├── stackcollapse-elfutils.pl
├── stackcollapse-faulthandler.pl
├── stackcollapse-gdb.pl
├── stackcollapse-go.pl
├── stackcollapse-ibmjava.pl
├── stackcollapse-instruments.pl
├── stackcollapse-java-exceptions.pl
├── stackcollapse-jstack.pl
├── stackcollapse-ljp.awk
├── stackcollapse-perf-sched.awk
├── stackcollapse-perf.pl
├── stackcollapse-pmc.pl
├── stackcollapse-recursive.pl
├── stackcollapse-sample.awk
├── stackcollapse-stap.pl
├── stackcollapse-vsprof.pl
├── stackcollapse-vtune-mc.pl
├── stackcollapse-vtune.pl
├── stackcollapse-wcp.pl
├── stackcollapse-xdebug.php
├── stackcollapse.pl
├── test
│ ├── perf-cycles-instructions-01.txt
│ ├── perf-dd-stacks-01.txt
│ ├── perf-funcab-cmd-01.txt
│ ├── perf-funcab-pid-01.txt
│ ├── perf-iperf-stacks-pidtid-01.txt
│ ├── perf-java-faults-01.txt
│ ├── perf-java-stacks-01.txt
│ ├── perf-java-stacks-02.txt
│ ├── perf-js-stacks-01.txt
│ ├── perf-mirageos-stacks-01.txt
│ ├── perf-numa-stacks-01.txt
│ ├── perf-rust-Yamakaky-dcpu.txt
│ ├── perf-vertx-stacks-01.txt
│ └── results
│ ├── perf-cycles-instructions-01-collapsed-addrs.txt
│ ├── perf-cycles-instructions-01-collapsed-all.txt
│ ├── perf-cycles-instructions-01-collapsed-jit.txt
│ ├── perf-cycles-instructions-01-collapsed-kernel.txt
│ ├── perf-cycles-instructions-01-collapsed-pid.txt
│ ├── perf-cycles-instructions-01-collapsed-tid.txt
│ ├── perf-dd-stacks-01-collapsed-addrs.txt
│ ├── perf-dd-stacks-01-collapsed-all.txt
│ ├── perf-dd-stacks-01-collapsed-jit.txt
│ ├── perf-dd-stacks-01-collapsed-kernel.txt
│ ├── perf-dd-stacks-01-collapsed-pid.txt
│ ├── perf-dd-stacks-01-collapsed-tid.txt
│ ├── perf-funcab-cmd-01-collapsed-addrs.txt
│ ├── perf-funcab-cmd-01-collapsed-all.txt
│ ├── perf-funcab-cmd-01-collapsed-jit.txt
│ ├── perf-funcab-cmd-01-collapsed-kernel.txt
│ ├── perf-funcab-cmd-01-collapsed-pid.txt
│ ├── perf-funcab-cmd-01-collapsed-tid.txt
│ ├── perf-funcab-pid-01-collapsed-addrs.txt
│ ├── perf-funcab-pid-01-collapsed-all.txt
│ ├── perf-funcab-pid-01-collapsed-jit.txt
│ ├── perf-funcab-pid-01-collapsed-kernel.txt
│ ├── perf-funcab-pid-01-collapsed-pid.txt
│ ├── perf-funcab-pid-01-collapsed-tid.txt
│ ├── perf-iperf-stacks-pidtid-01-collapsed-addrs.txt
│ ├── perf-iperf-stacks-pidtid-01-collapsed-all.txt
│ ├── perf-iperf-stacks-pidtid-01-collapsed-jit.txt
│ ├── perf-iperf-stacks-pidtid-01-collapsed-kernel.txt
│ ├── perf-iperf-stacks-pidtid-01-collapsed-pid.txt
│ ├── perf-iperf-stacks-pidtid-01-collapsed-tid.txt
│ ├── perf-java-faults-01-collapsed-addrs.txt
│ ├── perf-java-faults-01-collapsed-all.txt
│ ├── perf-java-faults-01-collapsed-jit.txt
│ ├── perf-java-faults-01-collapsed-kernel.txt
│ ├── perf-java-faults-01-collapsed-pid.txt
│ ├── perf-java-faults-01-collapsed-tid.txt
│ ├── perf-java-stacks-01-collapsed-addrs.txt
│ ├── perf-java-stacks-01-collapsed-all.txt
│ ├── perf-java-stacks-01-collapsed-jit.txt
│ ├── perf-java-stacks-01-collapsed-kernel.txt
│ ├── perf-java-stacks-01-collapsed-pid.txt
│ ├── perf-java-stacks-01-collapsed-tid.txt
│ ├── perf-java-stacks-02-collapsed-addrs.txt
│ ├── perf-java-stacks-02-collapsed-all.txt
│ ├── perf-java-stacks-02-collapsed-jit.txt
│ ├── perf-java-stacks-02-collapsed-kernel.txt
│ ├── perf-java-stacks-02-collapsed-pid.txt
│ ├── perf-java-stacks-02-collapsed-tid.txt
│ ├── perf-js-stacks-01-collapsed-addrs.txt
│ ├── perf-js-stacks-01-collapsed-all.txt
│ ├── perf-js-stacks-01-collapsed-jit.txt
│ ├── perf-js-stacks-01-collapsed-kernel.txt
│ ├── perf-js-stacks-01-collapsed-pid.txt
│ ├── perf-js-stacks-01-collapsed-tid.txt
│ ├── perf-mirageos-stacks-01-collapsed-addrs.txt
│ ├── perf-mirageos-stacks-01-collapsed-all.txt
│ ├── perf-mirageos-stacks-01-collapsed-jit.txt
│ ├── perf-mirageos-stacks-01-collapsed-kernel.txt
│ ├── perf-mirageos-stacks-01-collapsed-pid.txt
│ ├── perf-mirageos-stacks-01-collapsed-tid.txt
│ ├── perf-numa-stacks-01-collapsed-addrs.txt
│ ├── perf-numa-stacks-01-collapsed-all.txt
│ ├── perf-numa-stacks-01-collapsed-jit.txt
│ ├── perf-numa-stacks-01-collapsed-kernel.txt
│ ├── perf-numa-stacks-01-collapsed-pid.txt
│ ├── perf-numa-stacks-01-collapsed-tid.txt
│ ├── perf-rust-Yamakaky-dcpu-collapsed-addrs.txt
│ ├── perf-rust-Yamakaky-dcpu-collapsed-all.txt
│ ├── perf-rust-Yamakaky-dcpu-collapsed-jit.txt
│ ├── perf-rust-Yamakaky-dcpu-collapsed-kernel.txt
│ ├── perf-rust-Yamakaky-dcpu-collapsed-pid.txt
│ ├── perf-rust-Yamakaky-dcpu-collapsed-tid.txt
│ ├── perf-vertx-stacks-01-collapsed-addrs.txt
│ ├── perf-vertx-stacks-01-collapsed-all.txt
│ ├── perf-vertx-stacks-01-collapsed-jit.txt
│ ├── perf-vertx-stacks-01-collapsed-kernel.txt
│ ├── perf-vertx-stacks-01-collapsed-pid.txt
│ └── perf-vertx-stacks-01-collapsed-tid.txt
└── test.sh
Place the perf.unfold file you wish to analyze into the extracted FlameGraph directory. Use the stackcollapse-perf.pl script to fold the symbols in perf.unfold.
./stackcollapse-perf.pl perf.unfold &> perf.folded
Step 4
Use the flamegraph.pl script to generate an SVG image.
./flamegraph.pl perf.folded > perf.svg
Open the resulting SVG file in Chrome or an image viewer. The generated flame graph looks like this:
Flame Graph Interpretation
Core Structure of Flame Graph
X-axis (horizontal)
- Represents CPU time distribution. Wider blocks indicate functions or code paths that consume a higher proportion of CPU time, potentially indicating performance bottlenecks.
- All call stacks at the same level are displayed side by side; they do not represent chronological order.
Y-axis (vertical)
- Represents call stack depth. Functions are shown from bottom to top, illustrating the call hierarchy.
- The bottom layer is the program entry point (e.g., main function), and upper layers represent currently executing functions.
Colors and Blocks
- Colors are typically used only to differentiate functions and have no fixed meaning.
- Tall and wide "flat-topped" flames (where the same function appears multiple times at the top of the stack) are key targets for performance optimization.
Steps for Flame Graph Analysis
Identify CPU Hotspots
- Open the SVG flame graph and horizontally scan for the widest blocks to quickly identify functions consuming the most CPU time.
Analyze Call Chains
- Trace the call path from bottom to top through each layer to understand how hot functions are invoked.
Correlate with iperf Operation Mode
- Server-side flame graph: Focus on CPU overhead in receiving logic such as accept, recv.
- Client-side flame graph: Focus on performance cost in sending logic such as connect, send.
