4.7.6. hb_gpioinfo
hb_gpioinfo is a tool used to display GPIO pin information. It supports the following features:
Display basic information of GPIO pins (e.g., pin name, offset, direction, bias, drive mode, etc.).
Display the current state of pins (e.g., input/output, active-low, edge detection, etc.).
Display additional functional information of pins for specific platforms (e.g., pin function, pin number, etc.).
4.7.6.1. Syntax Description
Below is the command format for executing hb_gpioinfo:
hb_gpioinfo [OPTIONS] [line]...
4.7.6.2. Parameter Options Description
Below are the options supported by chip_log and their descriptions:
-c, --chip <chip>: Restrict scope to a specific GPIO chip.-h, --help: Display help information and exit.-s, --strict: Check all lines—do not assume pin names are unique.-v, --version: Display version information and exit.
4.7.6.3. Command Options and Their Function Descriptions
Display Help Information
Command:
hb_gpioinfo --help
Function:
Display usage help information for this command.
Usage: hb_gpioinfo [OPTIONS] [line]...
Print information about GPIO lines.
Lines are specified by name, or optionally by offset if the chip option is provided.
If no lines are specified then all lines are displayed.
-c, --chip <chip> restrict scope to a particular chip
-h, --help display this help and exit
-s, --strict check all lines - don't assume line names are unique
--unquoted don't quote line or consumer names
-v, --version output version information and exit
Display All GPIO Pin Information
Command:
root@buildroot:~# hb_gpioinfo
Function:
Display detailed information for all GPIO pins in the system.
Output:
[Number] [Mode] [Status] [GpioName] [PinName] [PinNum] [PinFunc]
line 0: unnamed input AON_GPIO_PIN0 498 aon_gpio_0
line 1: unnamed input AON_GPIO_PIN1 499 Default
line 2: unnamed input active-low GPIO Key Power AON_GPIO_PIN2 500 aon_gpio_2
line 3: unnamed input AON_GPIO_PIN3 501 Default
line 4: unnamed input AON_GPIO_PIN4 502 aon_gpio_4
line 5: unnamed input id AON_ENV_VDD 503 aon_gpio_5
line 6: unnamed input id AON_ENV_CNN0 504 aon_gpio_6
line 7: unnamed input AON_ENV_CNN1 505 aon_gpio_7
line 0: unnamed input HSIO_ENET_MDC 466 enetgrp
line 1: unnamed input HSIO_ENET_MDIO 467 enetgrp
line 2: unnamed input HSIO_ENET_TXD_0 468 enetgrp
line 3: unnamed input HSIO_ENET_TXD_1 469 enetgrp
line 4: unnamed input HSIO_ENET_TXD_2 470 enetgrp
line 5: unnamed input HSIO_ENET_TXD_3 471 enetgrp
line 6: unnamed input HSIO_ENET_TXEN 472 enetgrp
line 7: unnamed input HSIO_ENET_TX_CLK 473 enetgrp
line 8: unnamed input HSIO_ENET_RX_CLK 474 enetgrp
line 9: unnamed input HSIO_ENET_RXD_0 475 enetgrp
line 10: unnamed input HSIO_ENET_RXD_1 476 enetgrp
line 11: unnamed input HSIO_ENET_RXD_2 477 enetgrp
line 12: unnamed input HSIO_ENET_RXD_3 478 enetgrp
line 13: unnamed input HSIO_ENET_RXDV 479 enetgrp
line 14: unnamed input HSIO_ENET_PHY_CLK 480 enetgrp
line 15: unnamed input HSIO_SD_WP 481 sdgrp
line 16: unnamed input HSIO_SD_XLK 482 sdgrp
line 17: unnamed input HSIO_SD_CMD 483 sdgrp
line 18: unnamed input HSIO_SD_CDN 484 sdgrp
line 19: unnamed input HSIO_SD_DATA0 485 sdgrp
line 20: unnamed input HSIO_SD_DATA1 486 sdgrp
line 21: unnamed input HSIO_SD_DATA2 487 sdgrp
line 22: unnamed input HSIO_SD_DATA3 488 sdgrp
line 23: unnamed input HSIO_SDIO_WP 489 sdiogrp
line 24: unnamed input HSIO_SDIO_XLK 490 sdiogrp
line 25: unnamed input HSIO_SDIO_CMD 491 sdiogrp
line 26: unnamed output power HSIO_SDIO_CDN 492 hsio_gpio0_26
line 27: unnamed input HSIO_SDIO_DATA0 493 sdiogrp
line 28: unnamed input HSIO_SDIO_DATA1 494 sdiogrp
line 29: unnamed input HSIO_SDIO_DATA2 495 sdiogrp
line 30: unnamed input HSIO_SDIO_DATA3 496 sdiogrp
Result Explanation:
Detailed information for each pin is displayed in the following format:
line <N>: <GpioName> <Mode> <Status> <PinName> <PinNum> <PinFunc>
line <N>: The pin number.<GpioName>: The name of the GPIO pin (displayed as “unnamed” if not named).<Mode>: The pin mode (e.g., input or output).<Status>: The pin status (e.g., active-low, bias=pull-up, drive=open-drain, etc.).<PinName>: The name of the pin.<PinNum>: The pin number.<PinFunc>: The multiplexing function of the pin.
Display Information for a Specific GPIO Chip
Command:
root@buildroot:~# hb_gpioinfo -c gpiochip4
Function:
Display pin information only for GPIO chip gpiochip4.
Output:
line 0: unnamed input LSIO_UART7_RX 379 lsio_gpio0_0
line 1: unnamed input LSIO_UART7_TX 380 lsio_gpio0_1
line 2: unnamed input LSIO_UART7_CTS 381 lsio_gpio0_2
line 3: unnamed input LSIO_UART7_RTS 382 lsio_gpio0_3
line 4: unnamed input LSIO_UART1_RX 383 lsio_gpio0_4
line 5: unnamed input LSIO_UART1_TX 384 lsio_gpio0_5
line 6: unnamed input LSIO_UART1_CTS 385 lsio_gpio0_6
line 7: unnamed input LSIO_UART1_RTS 386 lsio_gpio0_7
line 8: unnamed input LSIO_UART2_RX 387 uart2grp
line 9: unnamed input LSIO_UART2_TX 388 uart2grp
line 10: unnamed input scl LSIO_UART3_RX 389 i2c5grp
line 11: unnamed input sda LSIO_UART3_TX 390 i2c5grp
line 12: unnamed input LSIO_UART4_RX 391 lsio_gpio0_12
line 13: unnamed input LSIO_UART4_TX 392 lsio_gpio0_13
line 14: unnamed input LSIO_SPI0_SCLK 393 Default
line 15: unnamed input LSIO_SPI1_SSN_1 394 Default
line 16: unnamed input LSIO_SPI1_SCLK 395 Default
line 17: unnamed input LSIO_SPI1_SSN 396 Default
line 18: unnamed input LSIO_SPI1_MISO 397 Default
line 19: unnamed input LSIO_SPI1_MOSI 398 Default
line 20: unnamed input LSIO_SPI2_SCLK 399 spi2grp
line 21: unnamed input LSIO_SPI2_SSN 400 spi2grp
line 22: unnamed input LSIO_SPI2_MISO 401 spi2grp
line 23: unnamed input LSIO_SPI2_MOSI 402 spi2grp
line 24: unnamed input LSIO_SPI3_SCLK 403 lsio_gpio0_24
line 25: unnamed input LSIO_SPI3_SSN 404 pinctrl_lpwm1_1
line 26: unnamed input LSIO_SPI3_MISO 405 lsio_gpio0_26
line 27: unnamed input LSIO_SPI3_MOSI 406 lsio_gpio0_27
line 28: unnamed input LSIO_SPI4_SCLK 407 uart5grp
line 29: unnamed input LSIO_SPI4_SSN 408 uart5grp
line 30: unnamed input LSIO_SPI4_MISO 409 lsio_gpio0_30
line 31: unnamed output phyreset LSIO_SPI4_MOSI 410 lsio_gpio0_31
