4.7.14. hrut_somstatus
hrut_somstatus is used to monitor and output system hardware status information in real time. It retrieves data such as temperature, CPU frequency, BPU frequency, DDR frequency, and GPU frequency by reading system device files, and displays the information in a specified format.
4.7.14.1. Syntax Description
Below is the Usage output from executing hrut_somstatus -h:
hrut_somstatus -h
Usage: /usr/hobot/bin/hrut_somstatus [-n count] [-d second]
4.7.14.2. Option Arguments Description
The following are the options supported by hrut_somstatus and their descriptions:
-n count: Specifies the number of times the script executes (default is 1).-d second: Sets the sleep duration between each output (default is 1 second).-h: Displays help information.
4.7.14.3. Command Options and Functional Descriptions
Default Usage
Command:
root@buildroot:~# hrut_somstatus
Output:
temperature-->
DDR : 53.0 (C)
BPU : 52.2 (C)
CPU : 52.3 (C)
cpu frequency-->
min(M) cur(M) max(M)
cpu0: 300 1500 1500
cpu1: 300 1200 1500
cpu2: 300 1500 1500
cpu3: 300 1200 1500
cpu4: 300 1200 1500
cpu5: 300 1200 1500
cpu6: 300 1500 1500
cpu7: 300 1200 1500
bpu status information---->
min(M) cur(M) max(M) ratio
bpu0: 500 1000 1000 0
ddr: 266 4266 4266
gc8000: 200 1000 1000
Functionality:
By default, this command displays temperature, CPU frequency, BPU frequency, DDR frequency, and GPU frequency information once in the specified format.
Result Interpretation:
temperature
DDR: Indicates DDR temperature, currently at 53.0°C.
BPU: Indicates BPU temperature, currently at 52.2°C.
CPU: Indicates CPU temperature, currently at 52.3°C.
cpu frequency
min: The minimum frequency at which the CPU can operate.
cur: The current operating frequency of the CPU.
max: The maximum frequency at which the CPU can operate.
min: The minimum frequency at which the BPU can operate.
cur: The current operating frequency of the BPU.
max: The maximum frequency at which the BPU can operate.
ratio: The load ratio during BPU operation.
ddr frequency information
min: The minimum frequency at which DDR can operate.
cur: The current operating frequency of DDR.
max: The maximum frequency at which DDR can operate.
GPU gc8000 frequency information
min: The minimum frequency at which the GPU can operate.
cur: The current operating frequency of the GPU.
max: The maximum frequency at which the GPU can operate.
Display Multiple Status Readings
Command:
root@buildroot:~# hrut_somstatus -n 5
Functionality:
This command prints temperature, CPU frequency, BPU frequency, DDR frequency, and GPU frequency information five times consecutively, formatted as specified.
=====================5=====================
temperature-->
DDR : 53.1 (C)
BPU : 52.5 (C)
CPU : 52.6 (C)
cpu frequency-->
cpu0: 300 1500 1500
cpu1: 300 1200 1500
cpu2: 300 1200 1500
cpu3: 300 1500 1500
cpu4: 300 1200 1500
cpu5: 300 1200 1500
cpu6: 300 1500 1500
cpu7: 300 1200 1500
ddr: 266 4266 4266
Set Interval Time Between Outputs
Command:
hrut_somstatus -n 5 -d 2
Functionality:
This command prints temperature, CPU frequency, BPU frequency, DDR frequency, and GPU frequency information five times consecutively, with a 2-second delay between each output.
