4.7.9. hrut_ddr
hrut_ddr is a tool used to monitor DDR (Double Data Rate) bandwidth and performance. It reads data from specific device files (such as /dev/axi_mon or /dev/ddrmonitor) to display real-time information about DDR read/write bandwidth, latency, and more.
4.7.9.1. Syntax Description
Below is the Usage output from running hrut_ddr -h:
DDR MONITOR HELP INFORMATION
>>> -t/--type   sample type: cpu,bpu,vin,codec,gpu,sum,all
>>> -p/--period sample period: [1-1000] ms
>>> -r/--raw    print raw data
4.7.9.2. Option Descriptions
The following are the options supported by hrut_ddr and their descriptions:
  • -t/–type: Specifies the DDR port type to monitor.
    Function: Specifies the DDR port type to monitor.
    Parameters:
    • cpu: CPU port.
    • bpu: BPU0 (BPU, hardware acceleration unit) port.
    • vin: VIO (Video Input/Output) port.
    • codec: Codec port.
    • gpu: GPU (Graphics Processing Unit) port.
    • sum: Displays the sum of all ports.
    • all: Displays detailed information for all ports.
  • -p/–period:
    Function: Sets the sampling period.
    Parameter: Sampling period in milliseconds (ms), range [1–1000].
  • -r/–raw:
    Function: Displays detailed information in raw data format.
  • -h/–help:
    Function: Displays help information explaining how to use the command.
4.7.9.3. Command Options and Their Functionalities
Display Help Information
Command:
hrut_ddr -h
Function:
Output:
Monitor DDR Bandwidth Across All Ports
Command:
hrut_ddr -t all
Function:
Monitors read and write bandwidth information across all DDR ports.
Output:
root@buildroot:/userdata/gmsl_test# hrut_ddr -t all
port_type:ALL
DDR type is: LPDDR4
Set sample period:10ms, 100 samples per seconds
Time 3546.680s
MB/S   P0:CPU   P1:BPU  P2:VIN  P3:CODEC  P4:GPU      SUM
Read :     19        0        0       12        0       31
Write:      7        0        0        0        0        7
Time 3546.690s
Read :      1        0        0       11        0       12
Write:      0        0        0        0        0        0
Time 3546.700s
Read :      0        0        0       11        0       11
Write:      0        0        0        0        0        0
Time 3546.710s
Read :      3        0        0       12        0       15
Write:      1        0       37        0        0       38
Time 3546.720s
Read :      3        0        0       13        0       16
Write:      0        0       77        0        0       77
Time 3546.730s
Read :      0        0        0       13        0       13
Time 3546.740s
Read :     31        0      334       14        0      379
Write:     19        0      383        0        0      402
Time 3546.750s
Read :    342        0      563       14        0      919
Write:    323        0      607        0        0      930
Time 3546.760s
Read :     40        0        0      518        0      558
Write:     10        0        0      271        0      281
Result Explanation:
  • Time: Indicates the current sampling time.
  • Read and Write: Represent bandwidth information for DDR read and write operations, respectively.
  • P0:CPU, P1:BPU, etc.: Represent bandwidth values for different ports, in MB/s.
  • SUM: Represents the total bandwidth across all ports.
Monitor DDR Bandwidth on a Specific Port
Command:
hrut_ddr -t cpu
Function:
Monitors DDR bandwidth information only for the CPU port.
Output:
root@buildroot:/userdata/gmsl_test# hrut_ddr -t cpu
port_type:CPU
DDR type is: LPDDR4
Time 4521.998s       P0:CPU     SUM  MB/S
             Read :     20      638
             Write:     17      689
Time 4522.008s       P0:CPU     SUM  MB/S
             Read :    359      845
             Write:    331      747
Display Detailed Information in Raw Data Format
Command:
hrut_ddr -t all -r
Function:
Displays detailed information for all DDR ports in raw data format, including latency, command count, etc.
Output:
root@buildroot:/userdata/gmsl_test# hrut_ddr -t all -r
port_type:ALL
DDR type is: LPDDR4
Time 4651.868s
Read :
        CPU  (bw:    17 cmd_num:     0 max_lantency:  1679 min_lantency:    50 cmd_accomulative_latency:    253955 stop_ost:     2)
        BPU  (bw:     0 cmd_num:     0 max_lantency:     0 min_lantency:     0 cmd_accomulative_latency:         0 stop_ost:     0)
        VIN  (bw:     0 cmd_num:     0 max_lantency:     0 min_lantency:     0 cmd_accomulative_latency:         0 stop_ost:     0)
        CODEC(bw:    11 cmd_num:     0 max_lantency:  2147 min_lantency:    71 cmd_accomulative_latency:   2415530 stop_ost:     0)
        GPU  (bw:     0 cmd_num:     0 max_lantency:     0 min_lantency:     0 cmd_accomulative_latency:         0 stop_ost:     0)
Write:
        CPU  (bw:     6 cmd_num:     0 max_lantency:    86 min_lantency:     8 cmd_accomulative_latency:      9142 stop_ost:     0)
        CODEC(bw:     0 cmd_num:     0 max_lantency:     0 min_lantency:     0 cmd_accomulative_latency:         0 stop_ost:     0)
Time 4651.878s
Result Explanation:
  • bw: Indicates bandwidth value in MB/s.
  • cmd_num: Indicates total number of commands.
  • max_latency and min_latency: Represent maximum and minimum latency.
  • cmd_accomulative_latency: Represents cumulative latency.
  • stop_ost: Represents the number of clock cycles when stopped.
Set Sampling Period
Command:
hrut_ddr -t all -p 100
Function:
Sets the sampling period to 100 milliseconds and monitors bandwidth information for all DDR ports.
Output:
root@buildroot:/userdata/gmsl_test# hrut_ddr -t all -p 100
port_type:ALL
DDR type is: LPDDR4
Set sample period:100ms, 10 samples per seconds
Time 4942.393s
Read :     42        0       90       64        0      196
Write:     35        0      118       28        0      181
Time 4942.493s
Read :     39        0       90       64        0      193
Write:     33        0      118       28        0      179
Time 4942.593s
Read :     38        0       90       64        0      192
Write:     32        0      118       28        0      178
