2.3.1 Type-C direct
RDK Type-C direct is for when the device is next to your PC but has no LAN IP yet. RDK Studio helps detect the Type-C NIC, set up the direct link, and add the device using default credentials.
When it applies​
ItemRequirement
DeviceRDK hardware with USB networking
CableFull-feature Type-C data cable; charge-only cables will not work
ClientRDK Studio desktop app
PermissionsAdmin rights may be needed the first time you configure the local NIC
After a successful direct link, the device appears in the device list like any SSH device. File manager, terminal, Moss, OpenClaw, and other features then work the same way.
Steps​
  1. Connect the board to your PC with a Type-C cable and wait for it to boot.
  2. Open Add device → RDK Type-C direct.
  3. In the NIC list, pick the interface that appears or goes online after you plug in.
  4. Click Connect. RDK Studio configures the local network and tries to reach the device.
  5. After success, enter or confirm the device alias and save to the list.
Typical addresses:
SideAddress
Device192.168.128.10
PCA local address on the same subnet as the device
The UI prefers online interfaces; you can switch to “show all” to debug offline or unrecognized NICs.
Common messages​
SymptomWhat to do
Type-C NIC not detectedConfirm the cable supports data; replug and refresh
NIC present but no IPConfirm you selected the RDK NIC, then start connect again
SSH timeoutWait for full boot and stable power, then retry
Auth failureDefaults are often root/root; if the image password was changed, use the SSH flow and enter credentials manually
PC loses internetUSB NIC may have changed route priority; follow the in-app hint to adjust network settings
Full troubleshooting: 5.3 Type-C direct failed.
Next steps​
Type-C direct suits first bring-up and bench debugging.
To use the device without the cable later, continue with 2.4 Configure network. After Wi-Fi is set up, add another SSH device entry using the Wi-Fi IP.
