2.6 First conversation
Workbench first conversation: after sending Hello, Moss replies in the chat area and waits for more input
After sign-in and device setup, send your first message to Moss from the workbench. You can brainstorm without a connected device; for on-board actions Moss will remind you to connect first.
Open the workbench​
Core → Workbench on the left is Moss’s primary entry. It combines chat with the project workspace; the right rail can surface status, history, diagnostics, changes, files, terminal, and more.
Finishing onboarding’s last step “Start using Moss” may auto-send an example prompt.
Pick work style and reply mode​
The composer exposes two switches. Defaults are fine for a first try:
SwitchOptionsMeaning
Work styleExecute / PlanExecute runs tasks directly; Plan lists steps and risks first
Reply modeFast / ReasoningFast for simple asks; reasoning for debugging, code, multi-step
If unsure, start with Execute + Reasoning so Moss inspects the current device thoroughly.
First prompts​
If a device is connected:
Check this device's system summary—tell me board model, OS version, disk, memory, and what you'd suggest next.
If not connected yet:
Introduce what RDK Studio and Moss can do for me, then give three example prompts I can try after I connect a device over SSH.
What success looks like​
A typical on-device task shows:
  • Device chip in the composer shows online/bound state.
  • Moss states what it will check.
  • Results or terminal output stream into the thread.
  • Workspace panels show diagnostics, files, terminal, changes, etc.
  • Risky actions prompt for confirmation.
If the device is offline, Moss can still answer and plan but will not pretend remote commands ran.
Prompts worth trying​
PromptWhat Moss does
Which ROS 2 nodes are running on this device?SSH to list ROS 2 nodes
Help me check recent errors under /var/logRemote commands or file reads for recent errors
What does this error mean: <paste error>Uses RDK context plus device state
Summarize Git changes in the current project directoryWorkspace changes or remote Git status
Give me a plan first—don't execute yetStays in or uses plan mode first
Next steps​
