2.3 Connect a device
Add-device flows use three entry points: SSH device, RDK Type-C direct, and local serial log.
Only SSH and Type-C save a device to the list; serial opens a local debug terminal only and is not stored as a device.
Add device dialog: SSH device, RDK Type-C direct, and local serial log—the three entry points
Compare the three​
EntryBest forSaved as device?What you get next
SSH deviceYou know Host / IP and remote login worksYesMoss, terminal, files, code editor, remote desktop, workspace
RDK Type-C directRDK X5 / S100 next to the PC, no LAN IPYesUSB NIC auto-config, then same as SSH
Local serial logBoot failure, no network, need boot logNoSerial terminal only—no files, Moss tools, or OpenClaw
SSH is the generic path for RDK, generic Linux, Jetson, Raspberry Pi, Rockchip, and more. RDK-only features show or hide based on detected board type.
How to choose​
Your situationRecommended entry
Device pingable or IP known2.3.2 Add device via SSH
RDK X5 / S100 plugged into the PC2.3.1 Type-C direct
Boot failure, no network, need logs2.3.3 Serial log
Non-RDK Linux host2.3.2 Add device via SSH
After a device is saved​
RDK Studio will:
  • Add it to the device list and allow it as the active workbench target.
  • Verify SSH reachability instead of trusting cache alone.
  • Classify the host (RDK, generic Linux, Jetson, Raspberry Pi, Rockchip, etc.).
  • Let Moss use the current device, project path, and workspace context.
  • Share the same connection across terminal, files, code editor, and remote desktop.
For RDK boards you can continue with Wi-Fi, OpenClaw deploy, RDK hardware context, and flashing features.
Wi-Fi step​
After device verification, a dialog may continue to Wi-Fi setup. It reuses the SSH session to scan and join wireless networks on the device.
Skip if the device is already online or you only need Ethernet/Type-C for now.
Details: 2.4 Configure network.
Ask Moss which entry to use​
You can describe your goal on the workbench:
  • “I know the IP is 192.168.1.23—which add flow should I use?”
  • “I plugged RDK X5 Type-C—what’s next?”
  • “Board won’t boot—how do I read serial logs?”
Moss will point you to the right UI. Enter Host / IP, username, and password in the add-device dialog—do not paste secrets into chat. Actions that need OS permission, device writes, or risky operations will ask for confirmation in the UI.
