RTSP Stream Pull and YOLOv5x Inference
This sample demonstrates how to combine SP hardware modules (decoder, VIO, display) with the BPU on platforms such as RDK S100 to implement:
RTSP/H.264 video stream → hardware decode (NV12) → YOLOv5x inference → overlay detection boxes → real-time display. The sample code is located in /app/pydev_demo/12_rtsp_yolov5x_display_sample/.
This sample demonstrates how to combine SP hardware modules (decoder, VIO, display) with the BPU on platforms such as RDK S600 to implement:
RTSP/H.264 video stream → hardware decode (NV12) → YOLOv5x inference → overlay detection boxes → real-time display. The sample code is located in /app/pydev_demo/rtsp_yolov5x_display_sample/.
Features
Model loading
Load the YOLOv5x model with
hbm_runtime.HB_HBMRuntime(model_path), read input/output information, and configure BPU priority and core binding throughset_scheduling_params(). -
Preprocessing
Obtain NV12 frames from the decode thread, split Y/UV channels, resize to model input dimensions, and pack them into BPU input format.
Inference
Call
self.model.run()to perform forward inference and generate detection results. -
Postprocessing
Dequantize inference outputs, decode, filter, apply NMS, map coordinates to the display resolution, and output detection boxes and classes.
RTSP decoding
A child thread uses
cv2.VideoCaptureto pull H.264 streams and hardware-decodes them to NV12 frames throughsrcampy.Decoder. -
Resolution and display (VPS + Display)
Call
srcampy.Display()andsrcampy.Camera().open_vps()to build a VPS → HDMI display pipeline. -
Overlay drawing
Use
draw.draw_detections_on_disp()to draw detection boxes and class labels on the display layer. -
Signal handling
Catch
SIGINT(Ctrl+C), setis_stop=True, safely exit the main loop and child threads, and close VPS, display, and decoder in order. -
Threading and frame queue
DecodeRtspStreaminherits fromthreading.Threadand maintains a frame queue; the main thread obtains the latest frame throughget_frame(). -
Argument parsing
Provide parameters through
argparse: RTSP source, model path, BPU cores, priority, label file, NMS threshold, and confidence threshold. -
HDMI resolution detection
Call
/usr/bin/get_hdmi_resto obtain the current HDMI resolution; default to 1920×1080 if unavailable.
Model Description
See the Ultralytics YOLOv5x object detection sample section.
Environment Dependencies
This sample has no special environment requirements. You only need to ensure the dependencies in pydev are installed.
pip install -r ../requirements.txt
pip install -r ../requirements.txt --break-system-packages
Directory Structure
├── README.md # Usage instructions
└── rtsp_yolov5x_display.py # Main program
Parameter Description
--rtsp-urls / -u | RTSP stream URL(s); multiple streams can be separated by semicolons (for example: rtsp://192.168.1.10/stream1;rtsp://192.168.1.11/stream2) | rtsp://127.0.0.1/assets/1080P_test.h264 |
--model-path | BPU quantized model path (.hbm) | /opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm |
--priority | Inference priority (0~255, 255 is highest) | 0 |
--bpu-cores | BPU core index list (for example, 0 1) | [0] |
--label-file | Class label file path | /app/res/labels/coco_classes.names |
--nms-thres | IoU threshold for Non-Maximum Suppression (NMS) | 0.45 |
--score-thres | Detection confidence threshold | 0.25 |
--model-path | BPU quantized model path (.hbm) | /opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm |
Quick Start
Prepare RTSP stream
Use the built-in streaming service to prepare an RTSP stream as input. The service converts the
1080P_test.h264video file into an RTSP stream atrtsp://127.0.0.1/assets/1080P_test.h264. Start the streaming service with:cd /app/res
sudo chmod +x live555MediaServer
sudo ./live555MediaServer & -
Run the model
Use default parameters
python rtsp_yolov5x_display.py -
Run with specified parameters
python rtsp_yolov5x_display.py \
--rtsp-urls rtsp://127.0.0.1/assets/1080P_test.h264 \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25python rtsp_yolov5x_display.py \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25
Exit
Press
Ctrl+Cin the terminal. -
View results
After successful execution, object detection results are displayed on screen in real time.
Notes
This program must run in a desktop environment.
For more deployment options or supported models, refer to the official documentation or contact platform technical support.
License
