Instance Segmentation - Ultralytics YOLO11
This sample shows how to run the YOLOv11 instance segmentation model on BPU based on hbm_runtime. It supports image preprocessing, inference, and postprocessing (parsing outputs and overlaying colored segmentation masks). The sample code is located in /app/pydev_demo/03_instance_segmentation_sample/02_ultralytics_yolo11_seg/.
This sample shows how to run the YOLOv11 instance segmentation model on BPU based on hbm_runtime. It supports image preprocessing, inference, and postprocessing (parsing outputs and overlaying colored segmentation masks). The sample code is located in /app/pydev_demo/instance_segmentation_sample/ultralytics_yolo11_seg/.
Model Description
  • Introduction:
    Ultralytics YOLO11 is a lightweight object detection and instance segmentation model based on the YOLO series, combining anchor-free and anchor-based design ideas with distributional regression. This model is the instance segmentation variant, supporting simultaneous output of bounding boxes, class probabilities, and high-quality pixel-level masks. It is suitable for multi-object detection and segmentation tasks in real-time scenarios.
  • HBM model name: yolo11n_seg_nashe_640x640_nv12.hbm
  • HBM model name: yolo11n_seg_nashp_640x640_nv12.hbm
  • Input format: NV12 image (Y/UV separated), size 640x640
  • Output:
    • Object detection results (bounding box + class + score)
    • Instance segmentation masks (one mask per object)
  • Model download URL (automatically downloaded by the program):
    https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolo11n_seg_nashe_640x640_nv12.hbm
    https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolo11n_seg_nashp_640x640_nv12.hbm
Features
  • Model loading
    Use hbm_runtime to load the quantized Ultralytics YOLO11 instance segmentation model and parse runtime metadata such as input/output tensor names, shapes, and quantization parameters.
  • Input preprocessing
    Resize the input BGR image to 640×640 and convert it to NV12 format (Y and UV planes separated) to meet model input requirements.
  • Inference execution
    Trigger forward inference with the .run() method. Scheduling parameters (BPU core binding and priority) can be set through the interface. Inference outputs include multi-scale class scores, bounding box regression, mask coefficients, and global mask prototype tensors.
  • Output postprocessing
    • Filter detection candidates using thresholds and decode bounding boxes and mask coefficients;
    • Merge outputs from all scales and apply NMS to select final objects;
    • Reconstruct each object's mask from mask prototypes and coefficients;
    • Scale masks and bounding boxes back to the original image size;
    • Optional morphological opening to refine mask edges;
    • Final output includes bounding boxes, classes, scores, and pixel-level instance masks.
Environment Dependencies
This sample has no special environment requirements. You only need to ensure the dependencies in pydev are installed.
pip install -r ../../requirements.txt --break-system-packages
Directory Structure
├── ultralytics_yolo11_seg.py # Main inference script
└── README.md # Usage instructions
Parameter Description
ParameterDescriptionDefault Value
--model-pathModel file path (.hbm format)/opt/hobot/model/s100/basic/yolo11n_seg_nashe_640x640_nv12.hbm
--test-imgTest image path/app/res/assets/office_desk.jpg
--label-fileClassification label file/app/res/labels/coco_classes.names
--priorityModel priority (0~255)0
--bpu-coresBPU core IDs[0]
--nms-thresNMS IoU threshold0.7
--score-thresConfidence threshold0.25
--is-openWhether to apply morphological opening to segmentation resultsTrue
--is-pointWhether to draw contour points on mask edgesTrue
--model-pathModel file path (.hbm format)/opt/hobot/model/s600/basic/yolo11n_seg_nashp_640x640_nv12.hbm
Quick Start
  • Run the model
    • Use default parameters
      python ultralytics_yolo11_seg.py
    • Run with specified parameters
      python ultralytics_yolo11_seg.py \
      --model-path /opt/hobot/model/s100/basic/yolo11n_seg_nashe_640x640_nv12.hbm \
      --test-img /app/res/assets/office_desk.jpg \
      --img-save-path result.jpg \
      --priority 0 \
      --bpu-cores 0 \
      --nms-thres 0.7 \
      --score-thres 0.25 \
      --is-open True \
      --is-point True
      --model-path /opt/hobot/model/s600/basic/yolo11n_seg_nashp_640x640_nv12.hbm \
      --priority 0 \
      --bpu-cores 0 \
      --nms-thres 0.7 \
      --is-open True \
      --is-point True
  • View the result
    After successful execution, results will be drawn on the original image and saved to the path specified by --img-save-path.
    [Saved] Result saved to: result.jpg
Notes
  • If the specified model path does not exist, the program will attempt to download the model automatically.
License
