USB Camera YOLOv5x Inference
This is a real-time Ultralytics YOLOv5x inference sample based on hbm_runtime. It reads frames from a USB camera for object detection and visualizes the results in fullscreen. The sample code is located in /app/pydev_demo/09_usb_camera_sample/.
This is a real-time Ultralytics YOLOv5x inference sample based on hbm_runtime. It reads frames from a USB camera for object detection and visualizes the results in fullscreen. The sample code is located in /app/pydev_demo/usb_camera_sample/.
Features
Model loading
Load the specified
.hbmmodel file throughhbm_runtimeand extract model name, input/output shapes, quantization information, and more. -
Camera capture
Automatically scan devices under
/dev/video*, open the first available USB camera, and configure MJPEG encoding, 1080p resolution, and 30 FPS. -
Image preprocessing
Resize BGR images to the model input resolution (letterbox or plain scaling) and convert them to NV12 format.
Inference execution
Submit input tensors through the
run()method to perform model forward inference on the BPU. -
Postprocessing
Includes quantized output decoding, candidate box filtering (by score threshold), NMS deduplication, and coordinate mapping back to the original image size.
Visualization
Draw detection boxes with class labels and confidence scores on the image, display them fullscreen in a window, and support real-time processing and exit control.
Model Description
See the Ultralytics YOLOv5x object detection sample section.
Environment Dependencies
Ensure the dependencies in
pydevare installedpip install -r ../requirements.txtpip install -r ../requirements.txt --break-system-packages
Directory Structure
├── usb_camera_yolov5x.py # Main program
├── usb_camera_snap.py # USB camera still capture (unrelated to object detection)
└── README.md # Usage instructions
Parameter Description
--model-path | BPU quantized model path (.hbm) | /opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm |
--priority | Inference priority (0~255, 255 is highest) | 0 |
--bpu-cores | BPU core index list (for example, 0 1) | [0] |
--label-file | Class label file path | /app/res/labels/coco_classes.names |
--nms-thres | IoU threshold for Non-Maximum Suppression (NMS) | 0.45 |
--score-thres | Detection confidence threshold | 0.25 |
--model-path | BPU quantized model path (.hbm) | /opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm |
Quick Start
Note: This program must run in a desktop environment.
Run the model
Use default parameters
python usb_camera_yolov5x.py -
Run with specified parameters
python usb_camera_yolov5x.py \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25python usb_camera_yolov5x.py \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25
Exit
Move the mouse over the display window and press
qto quit. -
View results
After successful execution, object detection results are displayed on screen in real time.
Notes
- This program must run in a desktop environment.
- If the specified model path does not exist, try searching under
/opt/hobot/model/s100/basic/.
/opt/hobot/model/s600/basic/.
License
