WebSocket YOLOv5x Inference
This sample demonstrates how to run Ultralytics YOLOv5x object detection on an embedded platform with HBM acceleration and a VIO camera module (such as RDK S100), and stream JPEG images and detection boxes to clients in real time over WebSocket. The sample code is located in /app/pydev_demo/11_web_display_camera_sample/.
This sample demonstrates how to run Ultralytics YOLOv5x object detection on an embedded platform with HBM acceleration and a VIO camera module (such as RDK S600), and stream JPEG images and detection boxes to clients in real time over WebSocket. The sample code is located in /app/pydev_demo/web_display_camera_sample/.
Features
Y
Model loading
Initialize
hbm_runtime, load the model, and obtain input/output names and dimensions. -
Preprocessing
Split raw NV12 images into Y/UV channels, scale them to the model input size, and build input tensors in the required format.
Inference
Call
.run()to execute BPU inference. -
Postprocessing
Decode inference results, filter low-confidence detections, apply NMS, and scale results back to the original image size.
Camera management (
CameraManager)Open the camera, obtain raw or model-sized images, and encode them as JPEG.
WebSocket server
Accept web client connections, continuously fetch camera frames, run detection, and return Protocol Buffer results to the web client.
Model Description
See the Ultralytics YOLOv5x object detection sample section.
Environment Dependencies
Ensure the dependencies in
pydevare installedpip install -r ../requirements.txt -
Install WebSocket packages
pip install websockets==15.0.1 protobuf==3.20.3pip install websockets==15.0.1 protobuf==3.20.3 --break-system-packages
Hardware Requirements
- The MIPI camera interface uses auto-detection mode. Only one MIPI camera may be connected when running this sample (any MIPI port is supported). Connecting multiple cameras will cause errors.
- This sample currently supports only MIPI sensors: IMX219 and SC230AI.
- For MIPI camera installation, refer to Camera Expansion Board - MIPI Camera Interface.
- For MIPI camera installation, refer to MIPI Camera Interface.
Directory Structure
├── mipi_camera_web_yolov5x.py # Main program
├── start_nginx.sh # nginx startup script
├── webservice/ # nginx + static front-end assets
├── x3_pb2.py # protobuf-generated message definitions
└── README.md # Usage instructions
Parameter Description
--model-path | BPU quantized model path (.hbm) | /opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm |
--priority | Inference priority (0~255, 255 is highest) | 0 |
--bpu-cores | BPU core index list (for example, 0 1) | [0] |
--label-file | Class label file path | /app/res/labels/coco_classes.names |
--nms-thres | IoU threshold for Non-Maximum Suppression (NMS) | 0.45 |
--score-thres | Detection confidence threshold | 0.25 |
--model-path | BPU quantized model path (.hbm) | /opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm |
Quick Start
Start the web service
# 1. Enter the webservice directory
cd webservice/
# 2. Start the service
sudo ./sbin/nginx -p . -
Run the model
Return to the sample directory
cd .. -
Use default parameters
python mipi_camera_web_yolov5x.py -
Run with specified parameters
python mipi_camera_web_yolov5x.py \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25python mipi_camera_web_yolov5x.py \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25
View results
After successful execution, open the web display at:
http://IPNote: Do not include a port number.
Exit
Press
Ctrl+Cin the terminal.
Notes
- If the specified model path does not exist, try searching under
/opt/hobot/model/s100/basic/.
/opt/hobot/model/s600/basic/.
License
