4.2 Python API
hbm_runtime is a Python binding built on pybind11 for accessing and operating the underlying libhbucp / libdnn C++ libraries, providing high-performance neural network model loading and inference.
This interface encapsulates low-level model runtime details so Python users can conveniently load single or multiple neural network models, query and manage model input/output metadata, and run inference flexibly. It supports multiple input data formats and, when necessary, automatically converts inputs to C-contiguous storage to ensure correct and efficient low-level access.
In addition, the new interface releases the Python GIL on the C++ side during inference, allowing multiple Python threads to call run() concurrently. For multi-model inference, the runtime automatically schedules each model’s inference task in parallel using multiple threads to improve throughput.
Use Cases
- Quickly integrate and call hbm_runtime capabilities in Python environments.
- Applications with high demands on inference efficiency and scheduling flexibility, such as robot vision and intelligent edge computing.
- Scenarios that need to load and manage multiple models simultaneously and configure task scheduling parameters (priority, core binding, device ID, etc.) per inference call as needed.
- Scenarios that need to query compile-time BPU information (for example, compile-time BPU core count) to assist runtime resource configuration and consistency checks.
Key Features
- Multi-model support
- Supports loading a single model or a group of multiple models; each model can independently expose input/output metadata and run inference.
run()supports one-shot inference over multi-model inputs and returns results keyed by model name (even for a single model, the nested structure{model_name: {...}}is returned).
- Flexible input formats
- Single input (
numpy.ndarray); - Single-model multi-input dict (
Dict[str, np.ndarray], keys are input tensor names); - Multi-model multi-input structure (
Dict[str, Dict[str, np.ndarray]], outer keys are model names, inner keys are input tensor names). - All inputs are automatically checked for C-contiguous memory layout and copied when necessary to ensure efficient and correct low-level access (non-contiguous inputs may incur extra copy overhead).
- Single input (
- Scheduling parameter configuration: default parameters + per-call overrides (run-local)
- Set model-level default scheduling parameters via
set_scheduling_params(...)(persisted inside the runtime and reusable across calls). - Optionally override scheduling on each
run()call; overrides take precedence over defaults for that call only and do not affect other threads or otherrun()invocations.
- Multi-threaded inference
- Concurrent
run()from multiple Python threads: the GIL is released inside C++ during inference so multiple Python threads can issue inference calls simultaneously. - Parallel multi-model inference: when the input is a multi-model structure, the runtime launches a thread per model to run inference in parallel (multi-threaded launch), which can improve throughput on multi-core BPU systems; a single-model case uses one inference thread.
- Concurrent
The hbm_runtime module is a high-performance inference runtime Python interface implemented in C++. It depends on pybind11 and Horizon’s underlying inference libraries (such as libdnn, libhbucp, etc.). It can be installed via system DEB packages (.deb).
System Dependencies
| Dependency | Minimum Version | Description |
| Python | ≥ 3.10 | Python 3.10 is recommended (tested on 3.10.12) |
| pip | ≥ 22.0 | Required for installing wheel packages |
| pybind11 | any | Used at build time; not required when installing the package |
| scikit-build-core | ≥ 0.7 | Used when building wheel packages (source builds only) |
| Horizon base libraries | platform-specific | e.g. libdnn.so, libucp.so, usually provided by the BSP |
| Python | ≥ 3.12 | Python 3.12 is recommended (tested on 3.12.3) |
Building Wheel Packages
There are three ways to build a wheel package, described below.
Build During DEB Installation
The hobot-dnn package install process includes building the hbm_runtime wheel. After the DEB install completes, the hbm-runtime whl package is generated.
# Install from apt source
sudo apt-get install hobot-dnn
# Install from a local deb package (package names vary by build; use your actual filename)
dpkg -i hobot-dnn_4.0.4-20250909195426_arm64.deb
# After installation, find the wheel under /tmp on the board
ls /tmp
# Whl package names vary by version; xxx stands for the version
#hbm_runtime-x.x.x-cp310-cp310-manylinux_2_34_aarch64.whl
ls /tmp
#hbm_runtime-x.x.x-cp312-cp312-manylinux_2_34_aarch64.whl
Build During System Image Compilation
When building the system software image, the hobot-dnn deb is installed; during that install the hbm-runtime whl is built and copied to out/product/deb_packages.
sudo ./pack_image.sh
ls out/product/deb_packages
Build on Device
# Enter the hbm_runtime source tree
cd /usr/hobot/lib/hbm_runtime
# Run the build script
./build.sh
# List built wheel packages
ls dist/
./build.sh
ls dist/
Installation Methods
Using a Wheel Package
You can use either of the following wheel install methods.
Install from a local wheel package
- Locate the
.whlfile built in the Building Wheel Packages section.
# Example: install local whl with pip (package names vary by version; xxx stands for the version)
pip install hbm_runtime-x.x.x-cp310-cp310-manylinux_2_34_aarch64.whl# Example: install local whl with pip (package names vary by version; xxx stands for the version)
pip install hbm_runtime-x.x.x-cp312-cp312-manylinux_2_34_aarch64.whl - Locate the
Install from PyPI
Using a .deb Package
You can use either of the following deb install methods.
Install from a local DEB package
# Example: install DEB package (package names vary by build; use your actual filename)
sudo dpkg -i hobot-dnn_4.0.2-20250714201215_arm64.deb -
sudo apt-get install hobot-dnn -
FAQ
- If files are not updated after a
.debinstall, check whether other packages block the upgrade (for example, an olderhobot-spdev). - Use
dpkg -L hobot-dnnto verify deployed files.
Uninstallation
Uninstall pip-installed package:
pip uninstall hbm_runtime -
Uninstall deb-installed package:
sudo apt remove hobot-dnn
Quick Start
This section shows how to load models and run inference with hbm_runtime. A few lines of code are enough to run a model and obtain outputs.
Prerequisites
Ensure HBMRuntime is installed correctly (see Installation) and that you have an HBM model file.
Examples
Single-Threaded Inference
Single-Threaded, Single-Model, Single-Input Inference
For models with a single input tensor.
import numpy as np
from hbm_runtime import HB_HBMRuntime
# Load model
model = HB_HBMRuntime("/opt/hobot/model/s100/basic/lanenet256x512.hbm")
# Get model name and input name
model_name = model.model_names[0]
input_name = model.input_names[model_name][0] # Assume single input
# Get shape for this input
input_shape = model.input_shapes[model_name][input_name]
# Build numpy input
input_tensor = np.ones(input_shape, dtype=np.float32)
# Run inference
outputs = model.run(input_tensor)
# Get output
output_array = outputs[model_name]
print("Output:", output_array)
import numpy as np
# Load model (the S600 platform uses the ASR model as the single-input example)
model = HB_HBMRuntime("/opt/hobot/model/s600/basic/asr.hbm")
# Build numpy input
# Run inference
# Get output
Single-Threaded, Single-Model, Multi-Input Inference
For models with multiple input tensors.
import numpy as np
hb_dtype_map = {
"U8": np.uint8,
"S8": np.int8,
"F32": np.float32,
"F16": np.float16,
"U16": np.uint16,
"S16": np.int16,
"S32": np.int32,
"U32": np.uint32,
"BOOL8": np.bool_,
# Load model
model = HB_HBMRuntime("/opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm")
import numpy as np
hb_dtype_map = {
"U8": np.uint8,
"S8": np.int8,
"F32": np.float32,
"F16": np.float16,
"U16": np.uint16,
"S16": np.int16,
"S32": np.int32,
"U32": np.uint32,
"BOOL8": np.bool_,
# Load model
model = HB_HBMRuntime("/opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm")
# Get model name (assume one model loaded)
# Prepare input names and shapes
input_names = model.input_names[model_name]
input_shapes = model.input_shapes[model_name]
input_dtypes = model.input_dtypes[model_name]
# Build input dict
input_tensors = {}
for name in input_names:
shape = input_shapes[name]
np_dtype = hb_dtype_map.get(input_dtypes[name].name, np.float32) # fallback
input_tensors[name] = np.ones(shape, dtype=np_dtype)
# Optional: set inference priority and BPU device
priority = {model_name: 5}
bpu_cores = {model_name: [0]}
model.set_scheduling_params(
priority=priority,
bpu_cores=bpu_cores
# Run inference; optional per-call priority and BPU cores
results = model.run(input_tensors)
# Print outputs
for output_name, output_data in results[model_name].items():
print(f"Output: {output_name}, shape={output_data.shape}")
Single-Threaded, Multi-Model, Multi-Input Inference
For multiple models each with multiple inputs. “Multi-model” can mean several HBM files or several models inside one HBM file.
"""Multi-model inference quick start."""
import numpy as np
MODEL_PATHS = [
"/opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm",
"/opt/hobot/model/s100/basic/resnet18_224x224_nv12.hbm",
import numpy as np
MODEL_PATHS = [
"/opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm",
"/opt/hobot/model/s600/basic/resnet18_224x224_nv12.hbm",
DTYPE_MAP = {
"U8": np.uint8, "S8": np.int8,
"F16": np.float16, "F32": np.float32,
# Load models
rt = HB_HBMRuntime(MODEL_PATHS)
# Build inputs from model metadata
inputs = {
m: {
inp: np.random.rand(*rt.input_shapes[m][inp]).astype(
DTYPE_MAP.get(rt.input_dtypes[m][inp].name, np.float32)
for inp in rt.input_names[m]
for m in rt.model_names
# Optional: default scheduling params
rt.set_scheduling_params(
priority={m: 5 for m in rt.model_names},
bpu_cores={m: [0] for m in rt.model_names},
# Run inference (multi-model, parallel internally)
outputs = rt.run(inputs)
# Print results
for m, outs in outputs.items():
print(f"[{m}]")
for name, arr in outs.items():
print(f" {name}: {arr.shape}, {arr.dtype}")
Multi-Threaded Inference
Multi-Threaded, Single-Model, Single-Input Inference
import threading
import numpy as np
# Load model
model = HB_HBMRuntime("/opt/hobot/model/s100/basic/asr.hbm")
import threading
import numpy as np
# Load model
# Shared input (read-only)
def worker(core_id: int):
input_tensor,
model_name=model_name,
priority={model_name: 5},
bpu_cores={model_name: [core_id]},
custom_id={model_name: core_id}, # optional
# Print minimal info
outs = outputs[model_name]
first_name, first_arr = next(iter(outs.items()))
print(f"[T{core_id}] {first_name}: shape={first_arr.shape}, dtype={first_arr.dtype}")
threads = [threading.Thread(target=worker, args=(i,)) for i in range(4)]
for t in threads: t.start()
for t in threads: t.join()
Multi-Threaded, Single-Model, Multi-Input Inference
import threading
import numpy as np
hb_dtype_map = {
"U16": np.uint16, "S16": np.int16,
"U32": np.uint32, "S32": np.int32,
"BOOL8": np.bool_,
# Load single model
import threading
import numpy as np
hb_dtype_map = {
"BOOL8": np.bool_,
# Load single model
# Build input tensors (shared, read-only)
input_tensors = {
model.input_shapes[model_name][name],
dtype=hb_dtype_map.get(model.input_dtypes[model_name][name].name, np.float32)
for name in model.input_names[model_name]
input_tensors,
custom_id={model_name: core_id}, # optional, for tracing
out_name, out_arr = next(iter(results[model_name].items()))
print(f"[T{core_id}] {out_name}: {out_arr.shape}, {out_arr.dtype}")
# Launch 4 threads, bind to BPU cores 0~3
Multi-Threaded, Multi-Model, Multi-Input Inference
"""4-thread demo: each thread runs inference on a dedicated BPU core."""
import threading
import numpy as np
MODEL_PATHS = [
import threading
import numpy as np
MODEL_PATHS = [
DTYPE_MAP = {
# Build one shared input package (read-only in each thread)
inputs = {
m: {
# Per-run scheduling override: bind this run to a specific BPU core
outputs = rt.run(
inputs,
bpu_cores={m: [core_id] for m in rt.model_names},
custom_id={m: core_id for m in rt.model_names}, # optional, for tracing
# Print one line per model to keep it simple
first_out = next(iter(outs.values()))
print(f"[T{core_id}][{m}] first_out: {first_out.shape}, {first_out.dtype}")
FAQ
| Question | Answer |
| How do I get model names? | Use model.model_names to list loaded model names. |
| How do I confirm input dimensions and types? | Use model.input_shapes and model.input_dtypes. |
| How do I assign BPU cores? | Use the bpu_cores parameter with values such as [0, 1, 2, 3]; actual support depends on hardware. |
For advanced usage (multi-input models, reading quantization parameters, etc.), see the API Reference.
Module, Class, and Function Reference (API Reference)
The Python module hbm_runtime is a Horizon HBM model inference interface wrapped with PyBind11, implemented on libdnn and libhbucp. It provides unified model loading, input/output metadata queries, and inference execution, supporting multi-model loading, multi-input inference, per-model selection, BPU core binding, inference task priority, and more.
Enumerations
hbDNNDataType
Tensor data type enumeration:
- S4: 4-bit signed
- U4: 4-bit unsigned
- S8: 8-bit signed
- U8: 8-bit unsigned
- F16: 16-bit float
- S16: 16-bit signed
- U16: 16-bit unsigned
- F32: 32-bit float
- S32: 32-bit signed
- U32: 32-bit unsigned
- F64: 64-bit float
- S64: 64-bit signed
- U64: 64-bit unsigned
- BOOL8: 8-bit bool type
- MAX: maximum value (reserved)
Example
from hbm_runtime import hbDNNDataType
print(hbDNNDataType.F32) # Output: hbDNNDataType.F32
hbDNNQuantiType
Tensor quantization type enumeration:
- NONE: non-quantized type
- SCALE: linear scale quantization (scale + zero_point)
Example
from hbm_runtime import hbDNNQuantiType
print(hbDNNQuantiType.SCALE) # Output: hbDNNQuantiType.SCALE
Classes
HB_HBMRuntime
Model runtime class that loads one or more HBM model files and provides inference APIs.
Constructor
Function signature
HB_HBMRuntime(model_file: str)
HB_HBMRuntime(model_files: List[str]) -
Parameters
Parameter Type Description model_file str Path to an HBM model file model_files List[str] Paths to multiple HBM model files (multi-model) -
Return value
Class instance
Example
model = HB_HBMRuntime("model.hbm")
# Or load multiple models:
model = HB_HBMRuntime(["model1.hbm", "model2.hbm"])
Properties
All properties below are read-only.
version: str
- Description:
- Library version string.
- Structure:
- str: version string.
- Example:
print("Version:", HB_HBMRuntime.version)
- Description:
model_names: List[str]
- Description:
- List of loaded model names.
- Structure:
- List[str]: model name list
- Example:
print(model.model_names)
# Output: ['model_1', 'model_2']
- Description:
model_count: int
- Description:
- Number of loaded models.
- Structure:
- int: number of loaded models.
- Example:
print(model.model_count)
# Output: 2
- Description:
model_descs: Dict[str, str]
- Description:
- Per-model description (from embedded model notes).
- Structure:
- Dict[str, str]: keys are model names; values are overall model descriptions, usually from the compiler.
- Example:
# Print descriptions for all models
print(model.model_descs)
# Output: {'yolov5x_672x672_nv12': 'Image classification model based on ResNet-18.'}
- Description:
hbm_descs: Dict[str, str]
- Description:
- Notes embedded in each HBM file.
- Structure:
.hbmfile names (e.g."resnet18"); values are comment or metadata strings from the HBM file.
- Example:
# Print descriptions for all model files
print(model.hbm_descs)
# Output (S100): {'/opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm': 'xxx'}
# Output (S600): {'/opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm': 'xxx'}
- Description:
compile_bpu_core_num: Dict[str, int]
- Description:
- BPU core count specified at compile time for each model. Reflects the BPU core configuration used when the model was compiled into HBM; useful for runtime resource planning or consistency checks against runtime
bpu_coressettings.
- Structure:
- Dict[str, int]:
- key: model name
- value: compile-time BPU core count for that model
- Dict[str, int]:
- Example:
# Query compile-time BPU core count
print(model.compile_bpu_core_num)
# Example output
# {'model_1': 1, 'model_2': 2}
- Description:
input_counts: Dict[str, int]
- Description:
- Number of input tensors per model.
- Structure:
- Dict[str, int]: keys are model names; values are input tensor counts.
- Example:
print(model.input_counts)
# Output: {'yolov5x_672x672_nv12': 2}
- Description:
input_names: Dict[str, List[str]]
- Description:
- Input tensor name list per model.
- Structure:
- Outer Dict[str, ...]: keys are model names.
- Inner List[str]: input tensor names for that model.
- Example:
print(model.input_names)
# Output: {'yolov5x_672x672_nv12': ['data_y', 'data_uv']}
- Description:
input_descs: Dict[str, Dict[str, str]]
- Description:
- Description per input tensor.
- Structure:
- Outer Dict[str, ...]: model name.
- Inner Dict[str, str]: keys are input tensor names; values are descriptions.
- Example:
print(model.input_descs)
# Output: {'yolov5x_672x672_nv12': {'data_uv': 'xxx', 'data_y': 'xxx'}}
- Description:
input_shapes: Dict[str, Dict[str, List[int]]]
- Description:
- Shape of each input tensor.
- Structure:
- Inner Dict[str, List[int]]: keys are input names; values are tensor dimensions (shape).
- Example:
model.input_shapes
# Output: {'yolov5x_672x672_nv12': {'data_uv': [1, 336, 336, 2], 'data_y': [1, 672, 672, 1]}}
- Description:
input_dtypes: Dict[str, Dict[str, hbDNNDataType]]
- Description:
- Data type of each input tensor.
- Structure:
- Inner Dict[str, hbDNNDataType]: keys are input tensor names; values are data types (e.g. F32, U8).
- Example:
print(model.input_dtypes)
# Output: {'yolov5x_672x672_nv12': {'data_uv': <hbDNNDataType.U8: 3>, 'data_y': <hbDNNDataType.U8: 3>}}
- Description:
input_quants: Dict[str, Dict[str, QuantParams]]
- Description:
- Quantization parameters for all input tensors of each model. Used for pre-processing of quantized models or to inspect how tensors are quantized.
- Structure:
- Outer Dict[str, ...]: model name, e.g.
"resnet50"; - Inner Dict[str, QuantParams]: keys are input tensor names; values are
QuantParamsinstances; QuantParamsattributes:- scale: np.ndarray — scale factors, usually a float array;
- zero_point: np.ndarray — zero points for symmetric/asymmetric quantization;
- quant_type: hbDNNQuantiType — quantization type enum (e.g. SCALE, NONE);
- axis: int — for per-channel quantization, the axis along which quantization applies.
- Example:
quanti_info = model.input_quants
for model, inputs in quanti_info.items():
print(f"{model}:")
for name, info in inputs.items():
print(f" {name}:")
print(f" quant_type: {info.quant_type.name}")
print(f" quantize_axis: {info.axis}")
print(f" scale_data: {info.scale.tolist()}")
print(f" zero_point_data: {info.zero_point.tolist()}")
- Description:
input_strides: Dict[str, Dict[str, List[int]]]
- Description:
- Stride information per input tensor.
- Structure:
- Inner Dict[str, List[int]]: keys are input names; values are stride arrays.
- Example:
Note: For stride semantics, see the libdnn description in the OE documentation.
print(model.input_strides)
# Output: {'yolov5x_672x672_nv12': {'data_uv': [-1, -1, 2, 1], 'data_y': [-1, -1, 1, 1]}}
- Description:
output_counts: Dict[str, int]
- Description:
- Number of output tensors per model.
- Structure:
- Dict[str, int]: keys are model names; values are output tensor counts.
- Example:
print(model.output_counts)
# Output: {'yolov5x_672x672_nv12': 3}
- Description:
output_names: Dict[str, List[str]]
- Description:
- Output tensor name list per model.
- Structure:
- Inner List[str]: output tensor names for that model.
- Example:
print(model.output_names)
# Output: {'yolov5x_672x672_nv12': ['output', '1310', '1312']}
- Description:
output_descs: Dict[str, Dict[str, str]]
- Description:
- Description per output tensor.
- Structure:
- Inner Dict[str, str]: keys are output tensor names; values are descriptions.
- Example:
print(model.output_descs)
# Output: {'yolov5x_672x672_nv12': {'1310': 'xxx', '1312': 'xxx', 'output': 'xxx'}}
- Description:
output_shapes: Dict[str, Dict[str, List[int]]]
- Description:
- Shape of each output tensor.
- Structure:
- Inner Dict[str, List[int]]: keys are output names; values are tensor dimensions (shape).
- Example:
print(model.output_shapes)
# Output: {'yolov5x_672x672_nv12': {'1310': [1, 42, 42, 255], '1312': [1, 21, 21, 255], 'output': [1, 84, 84, 255]}}
- Description:
output_dtypes: Dict[str, Dict[str, List[int]]]
- Description:
- Data type of each output tensor.
- Structure:
- Inner Dict[str, hbDNNDataType]: keys are output tensor names; values are data types (e.g. F32, U8).
- Example:
print(model.output_dtypes)
# Output: {'yolov5x_672x672_nv12': {'1310': <hbDNNDataType.S32: 8>, '1312': <hbDNNDataType.S32: 8>, 'output': <hbDNNDataType.S32: 8>}}
- Description:
output_quants: Dict[str, Dict[str, QuantParams]]
- Description:
- Quantization parameters for all output tensors of each model. Used for post-processing of quantized models (e.g. dequantizing int8 to float32) or to inspect quantization (scale-based, etc.).
- Structure:
"resnet50"; - Inner Dict[str, QuantParams]: keys are output tensor names; values are
- axis: int — for per-channel quantization, the quantization axis.
- Example:
output_quanti = model.output_quants
for model, outputs in output_quanti.items():
print(f"{model}:")
for name, info in outputs.items():
print(f" {name}:")
print(f" scale_data: {info.scale}")
print(f" zero_point_data: {info.zero_point}")
- Description:
output_strides: Dict[str, Dict[str, List[int]]]
- Description:
- Stride information per output tensor.
- Structure:
- Inner Dict[str, List[int]]: keys are output names; values are stride arrays.
- Example:
print(model.output_strides)
# Output: {'yolov5x_672x672_nv12': {'1310': [1806336, 43008, 1024, 4], '1312': [451584, 21504, 1024, 4], 'output': [7225344, 86016, 1024, 4]}}
- Description:
sched_params: Dict[str, SchedParam]
- Description:
sched_paramsreturns the current scheduling parameters for all models, including per model:- priority
- custom ID (customId)
- assigned BPU cores (bpu_cores)
- device ID (deviceId) These parameters affect how models run on hardware, especially in multi-model or multi-core deployments.
- Structure:
- Inner SchedParam: instance with priority, customId, bpu_cores, and deviceId for that model;
"model_name": SchedParam(
priority: int,
customId: int,
bpu_cores: List[int],
deviceId: int
- Example:
Note:
params = model.sched_params
for name, sched in params.items():
print(f"Model: {name}")
print(f" priority: {sched.priority}")
print(f" customId: {sched.customId}")
print(f" bpu_cores: {sched.bpu_cores}")
print(f" deviceId: {sched.deviceId}")
# Output:
# Model: yolo12s_detect_nashe_640x640_nv12
# priority: 10
# customId: 0
# bpu_cores: [0]
# deviceId: 0
# Model: yolov5nu_detect_nashe_640x640_nv12
# priority: 66
# customId: 0
# bpu_cores: [-1]
# deviceId: 0bpu_coresreturning-1means the scheduler assigns cores automatically.
- Description:
Configuration Functions
- set_scheduling_params
Function signature
def set_scheduling_params(
priority: Optional[Dict[str, int]] = None,
bpu_cores: Optional[Dict[str, List[int]]] = None,
custom_id: Optional[Dict[str, int]] = None,
device_id: Optional[Dict[str, int]] = None
) -> None -
Sets default scheduling parameters per model (priority / bpu_cores / custom_id / device_id). Configures persistent, instance-level defaults on
HB_HBMRuntimefor subsequent inference calls.Relationship to
run()scheduling parameters:set_scheduling_params()sets model-level default scheduling parameters stored on the runtime instance.run()also accepts scheduling arguments for per-call temporary overrides (run-local).- Explicit scheduling arguments on
run()override defaults fromset_scheduling_params(). run()overrides apply only to that inference call and do not change stored defaults.- If a scheduling field is omitted on
run(), the default fromset_scheduling_params()is used.
Precedence:
run()arguments >set_scheduling_params()defaults > built-in initial defaults -
Parameters
Parameter Type Description priority optional dict (model name → int) Scheduling priority per model, typically 0–255; higher values mean higher priority bpu_cores optional dict (model name → List[int]) BPU core index list per model; default means auto-assignment; depends on hardware support custom_id optional dict (model name → int) Custom tie-breaker (e.g. timestamp, frame id); smaller values win when priority is equal. Precedence: priority > customId. device_id optional dict (model name → int) Device on which the model runs -
Return value
None
Example:
# Set model-level default scheduling parameters
priority={"model1": 200, "model2": 100},
bpu_cores={"model1": [0, 1], "model2": [0]}
# Verify defaults
print(params["model1"].priority) # Output: 200
print(params["model1"].bpu_cores) # Output: [0, 1]
# Per-call override in run() (does not change defaults)
inputs,
priority={"model1": 50} # Applies only to this call
# Defaults unchanged
print(model.sched_params["model1"].priority) # Still: 200
Inference Functions
run() accepts three input shapes (single input / single-model multi-input / multi-model multi-input). Each call can pass scheduling parameters: priority / bpu_cores / custom_id / device_id.
Multi-threading (important)
Multi-model parallelism: with
run(multi_input_tensors, ...), the runtime creates one C++ thread per model inmulti_input_tensorsand runs inference in parallel. -
Concurrent Python threads: you can combine “multiple Python threads calling
run()” with “parallel multi-model inference” for higher throughput (actual gain depends on BPU core count, model config, and system load). -
Per-call scheduling:
run()priority/bpu_cores/custom_id/device_id are temporary for that call; different threads or calls can use different values independently. -
run (single model · single input)
Function signature
run(
input_tensor: np.ndarray,
model_name: Optional[str] = None,
device_id: Optional[Dict[str, int]] = None,
) -> Dict[str, Dict[str, np.ndarray]] -
For single-model, single-input inference.
- When only one model is loaded,
model_namemay be omitted; with multiple models,model_nameis required (otherwise an error is raised). - If the selected model does not have exactly one input, an error is raised (this overload does not apply).
- Input dtype must match the model input type; shape must match the model input (dynamic dimensions marked
-1in the model are filled from the actual input). - Return structure:
{model_name: {output_name: np.ndarray}}
Parameters
Parameter Type Description input_tensor np.ndarray Single input tensor; only for single-model, single-input inference. Shape must match the model input. model_name str (optional) Target model name (optional if only one model is loaded; required otherwise) priority optional dict (model name → int) Inference priority for this call (temporary override) bpu_cores optional dict (model name → List[int]) BPU core indices for this call custom_id optional dict (model name → int) Custom priority for this call device_id optional dict (model name → int) Device ID for this call -
Return value
- Type: Dict[str, Dict[str, np.ndarray]]
- Outer key: model name
- Inner key: output tensor name
- Value: output numpy array (zero-copy wrapper over device buffer; released with the array lifetime)
Example: see Single-Threaded, Single-Model, Single-Input Inference in Quick Start.
run (single model · multi-input)
Function signature
run(
input_tensors: Dict[str, np.ndarray],
For single-model, multi-input inference.
- Keys in
input_tensorsmust be valid input names for the model (otherwise an error is raised). - When only one model is loaded,
model_namemay be omitted; with multiple models,model_nameis required. - Each input is checked for C-contiguous memory and copied if needed.
- Keys in
Parameters
Parameter Type Description input_tensors Dict[str, np.ndarray] Multi-input dict: input tensor name → NumPy array model_name str (optional) Target model name (optional if only one model is loaded; required otherwise) priority optional dict (model name → int) Inference priority for this call (temporary override) bpu_cores optional dict (model name → List[int]) BPU core indices for this call custom_id optional dict (model name → int) Custom priority for this call device_id optional dict (model name → int) Device ID for this call -
Return value
Same as above.
Example: see Single-Threaded, Single-Model, Multi-Input Inference in Quick Start.
run (multi-model · multi-input)
Function signature
run(
multi_input_tensors: Dict[str, Dict[str, np.ndarray]],
For simultaneous multi-model inference: outer keys are model names; inner dicts map input names to numpy arrays.
- If
model_nameis omitted: infer all models present inmulti_input_tensors. - If
model_nameis set: only that model’s inputs are kept and inferred (other models’ inputs are filtered out). - Parallel execution: one thread per model; GIL is released during inference so concurrent Python
run()calls can achieve higher throughput.
- If
Parameters
Parameter Type Description multi_input_tensors Dict[str, Dict[str, np.ndarray]] Multi-model inputs: model name → (input name → tensor). Supports multiple models, each with multiple inputs. model_name str (optional) If set, infer only this model; if omitted, infer all models with provided inputs priority optional dict (model name → int) Inference priority for this call (temporary override) bpu_cores optional dict (model name → List[int]) BPU core indices for this call custom_id optional dict (model name → int) Custom priority for this call device_id optional dict (model name → int) Device ID for this call -
Return value
Same as above.
Example: see Single-Threaded, Multi-Model, Multi-Input Inference in Quick Start.
Exceptions
ValueErrorif input tensor shape or dtype does not match the model.- Non-contiguous (non C-style) inputs are copied internally to a contiguous buffer.
- Input tensor shape must match
input_shapesbefore inference.
QuantParams Class
Tensor quantization parameter object.
Properties
- scale: numpy.ndarray, scale factor array
- zero_point: numpy.ndarray, zero-point array
- quant_type: hbDNNQuantiType, quantization mode
- axis: int, quantization axis (for per-channel quantization)
Example:
# Get quantization params for a model output
tensor_qparams = model.output_quants[model_name][output_name]
print("scale:", tensor_qparams.scale)
print("zero_point:", tensor_qparams.zero_point)
print("type:", tensor_qparams.quant_type)
print("axis:", tensor_qparams.axis)
SchedParam Class
Model scheduling parameter object describing default scheduling state for a single model (priority, core binding, etc.). Typically used to read current scheduling configuration rather than as the primary configuration API.
Properties
priority: Dict[str, int]
Inference task scheduling priority, range 0–255; higher values mean higher priority.
customId: Dict[str, int]
User-defined identifier (e.g. frame id, timestamp) passed to the low-level scheduler. Precedence: priority > customId.
bpu_cores: Dict[str, List[int]]
BPU core list bound to the model;
[-1]means ANY (scheduler auto-selects). S100 allows 1 core; S600 allows 0–3. -
deviceId: Dict[str, int]
Device ID for model deployment (multi-device scenarios).
Example:
runtime = HB_HBMRuntime("model.hbm")
sched_params = runtime.sched_params # Dict[str, SchedParam]
for model_name, sp in sched_params.items():
print(
model_name,
sp.priority,
sp.customId,
sp.bpu_cores,
sp.deviceId
Notes
- Dynamic inputs and outputs are untested; use with caution.
