MIPI Camera YOLOv5x Inference
This is a real-time Ultralytics YOLOv5x inference sample based on hbm_runtime. It reads frames from a MIPI camera for object detection and visualizes the results in fullscreen. The sample code is located in /app/pydev_demo/10_mipi_camera_sample/.
This is a real-time Ultralytics YOLOv5x inference sample based on hbm_runtime. It reads frames from a MIPI camera for object detection and visualizes the results in fullscreen. The sample code is located in /app/pydev_demo/mipi_camera_sample/.
Features
  • Model loading
    Load .hbm models through hbm_runtime and initialize input/output information.
  • Camera capture
    Use srcampy.Camera() to initialize the VIO camera and capture 1920×1080 NV12 images.
  • HDMI display
    Use srcampy.Display() to bind the image output channel for real-time display.
  • Image preprocessing
    Split, scale, and convert NV12 images into the tensor format required by the BPU.
  • BPU inference
    Call the BPU to run inference tasks through the run() method.
  • Postprocessing
    Includes output decoding, confidence filtering, NMS suppression, and coordinate scaling.
  • Visualization
    Draw detection boxes and class labels on the overlay layer.
Model Description
See the Ultralytics YOLOv5x object detection sample section.
Environment Dependencies
  • Ensure the dependencies in pydev are installed
    pip install -r ../requirements.txt
    pip install -r ../requirements.txt --break-system-packages
Hardware Requirements
  • The MIPI camera interface uses auto-detection mode. Only one MIPI camera may be connected when running this sample (any MIPI port is supported). Connecting multiple cameras will cause errors.
  • This sample currently supports only MIPI sensors: IMX219 and SC230AI.
Directory Structure
├── 01_mipi_camera_yolov5x.py # Real-time camera object detection and display with YOLOv5x
├── 02_mipi_camera_dump.py # Save camera frames as YUV files (not related to model inference)
├── 03_mipi_camera_scale.py # Scale local YUV images to different resolutions (not related to model inference)
├── 04_mipi_camera_crop_scale.py # Crop and scale local YUV images (not related to model inference)
├── 05_mipi_camera_streamer.py # Stream camera images to HDMI in real time (streaming test; not related to model inference)
└── README.md # Script descriptions, parameters, and usage
Parameter Description
ParameterDescriptionDefault Value
--model-pathBPU quantized model path (.hbm)/opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm
--priorityInference priority (0~255, 255 is highest)0
--bpu-coresBPU core index list (for example, 0 1)[0]
--label-fileClass label file path/app/res/labels/coco_classes.names
--nms-thresIoU threshold for Non-Maximum Suppression (NMS)0.45
--score-thresDetection confidence threshold0.25
--model-pathBPU quantized model path (.hbm)/opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm
Quick Start
Note: This program must run in a desktop environment.
  • Run the model
    • Use default parameters
      python 01_mipi_camera_yolov5x.py
    • Run with specified parameters
      python 01_mipi_camera_yolov5x.py \
      --priority 0 \
      --bpu-cores 0 \
      --nms-thres 0.45 \
      --score-thres 0.25
      --priority 0 \
      --bpu-cores 0 \
      --nms-thres 0.45 \
      --score-thres 0.25
  • Exit
    Press Ctrl+C in the terminal.
  • View results
    After successful execution, object detection results are displayed on screen in real time.
Notes
  • This program must run in a desktop environment.
  • If the specified model path does not exist, try searching under /opt/hobot/model/s100/basic/.
  • If the specified model path does not exist, try searching under /opt/hobot/model/s600/basic/.
License
