Object Detection - Ultralytics YOLOv5x
This example shows how to perform image object detection on the BPU using a quantized Ultralytics YOLOv5x model. It supports preprocessing, post-processing, NMS, bounding box drawing, and result saving. The sample code is located in /app/pydev_demo/02_detection_sample/01_ultralytics_yolov5x/.
This example shows how to perform image object detection on the BPU using a quantized Ultralytics YOLOv5x model. It supports preprocessing, post-processing, NMS, bounding box drawing, and result saving. The sample code is located in /app/pydev_demo/detection_sample/ultralytics_yolov5x/.
Model Description
Overview:
Ultralytics YOLOv5x is a high-performance object detection model. The name stands for "You Only Look Once," meaning a single forward pass can complete object localization and classification. YOLOv5x is the largest variant, with more network parameters and higher detection accuracy, making it suitable for scenarios that require high precision. The model maps the input image to multiple grids, with each grid predicting class labels and bounding boxes for multiple anchors. This model has been quantized into HBM format for BPU chips, with NV12 input at 672×672 resolution.
HBM model name: yolov5x_672x672_nv12.hbm
Input format: NV12, size 672x672 (Y and UV planes separated)
Output: N object boxes, each containing a tuple of (class index, probability, bounding box coordinates)
Features
Model loading
Loads the quantized Ultralytics YOLOv5x model through
hbm_runtime, parsing model name, input and output names, shapes, quantization parameters, and other information to prepare for subsequent inference. -
Input preprocessing
Resizes the input image to 672x672, converts it to NV12 format (Y and UV separated), and organizes the input as a nested dictionary to match the inference interface.
Inference execution
Runs inference using the
.run()method, with support for setting inference priority and BPU core binding (such as core0/core1). -
Post-processing
Dequantizes the output tensor;
Decodes YOLO outputs to obtain predicted boxes, confidence scores, and class indices;
Filters candidates based on the score threshold;
Applies NMS (non-maximum suppression) to remove redundant boxes;
Maps predicted box coordinates back to the original image size;
Overlays detection boxes and saves the result image.
Model download URL (automatically downloaded by the program):
https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolov5x_672x672_nv12.hbm
https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolov5x_672x672_nv12.hbm
Environment Dependencies
This sample has no special environment requirements. Just ensure that the dependencies in pydev are installed.
pip install -r ../../requirements.txt --break-system-packages
Directory Structure
├── ultralytics_yolov5x.py # Main inference script
└── README.md # Usage instructions
Parameters
--model-path | Model file path (.hbm format) | /opt/hobot/model/s100/basic/yolov5x_672x672_nv12.hbm |
--test-img | Test image path | /app/res/assets/kite.jpg |
--label-file | Class label path (one class per line) | /app/res/labels/coco_classes.names |
--img-save-path | Path to save the detection result image | result.jpg |
--priority | Model scheduling priority (0~255) | 0 |
--bpu-cores | List of BPU core IDs to use (e.g. --bpu-cores 0 1) | [0] |
--nms-thres | Non-maximum suppression (NMS) threshold | 0.45 |
--score-thres | Confidence threshold | 0.25 |
--model-path | Model file path (.hbm format) | /opt/hobot/model/s600/basic/yolov5x_672x672_nv12.hbm |
Quick Start
Run the model
With default parameters
python ultralytics_yolov5x.py -
Run with specified parameters
python ultralytics_yolov5x.py \
--test-img /app/res/assets/kite.jpg \
--img-save-path result.jpg \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25python ultralytics_yolov5x.py \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25
View results
After a successful run, detection boxes are drawn on the original image and saved to the path specified by
--img-save-path.[Saved] Result saved to: result.jpg
Notes
- If the specified model path does not exist, try looking in
/opt/hobot/model/s100/basic/.
/opt/hobot/model/s600/basic/.
License
