Object Detection - Ultralytics YOLO11
This example uses the Ultralytics YOLO11 model with the hbm_runtime interface to perform image object detection. It supports image preprocessing, inference, post-processing (including decoding, confidence filtering, and NMS), and result image saving. The sample code is located in /app/pydev_demo/02_detection_sample/02_ultralytics_yolo11/.
This example uses the Ultralytics YOLO11 model with the hbm_runtime interface to perform image object detection. It supports image preprocessing, inference, post-processing (including decoding, confidence filtering, and NMS), and result image saving. The sample code is located in /app/pydev_demo/detection_sample/ultralytics_yolo11/.
Model Description
Overview:
Ultralytics YOLO11 is a lightweight anchor-based object detection model that combines anchor-free and anchor-based ideas, offering fast inference and precise localization. During the regression stage, it uses discrete regression bins together with softmax classification and decoding mechanisms to improve localization accuracy. YOLO11 is suitable for deploying small models in real-time scenarios such as security monitoring and industrial inspection.
- HBM model name: yolo11n_detect_nashe_640x640_nv12.hbm
- HBM model name: yolo11n_detect_nashp_640x640_nv12.hbm
Input format: NV12, size 640x640 (Y and UV planes separated)
Output: Multi-scale feature maps, each containing class score tensors and discrete bounding box regression tensors; the final output includes object box locations, class IDs, and confidence scores
Model download URL (automatically downloaded by the program):
https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolo11n_detect_nashe_640x640_nv12.hbmhttps://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s600/ultralytics_YOLO/yolo11n_detect_nashp_640x640_nv12.hbm
Features
Model loading
Loads the quantized Ultralytics YOLO11 model using the
hbm_runtimeinterface and extracts model metadata such as input and output names, shapes, and quantization information for subsequent inference. -
Input preprocessing
Resizes the original BGR image to 640×640, converts it to NV12 format (Y and UV separated), and constructs a nested dictionary input tensor to meet the inference interface requirements.
Inference execution
Runs forward inference through the
.run()method, with optional scheduling parameters (inference priority and BPU core binding). The output includes classification and regression tensors from multiple scale branches. -
Post-processing
Dequantizes the quantized output to float32;
Filters classification scores at each scale branch and retains candidate boxes above the confidence threshold;
Decodes bounding boxes using a multi-bin regression algorithm;
Merges candidate boxes from all scales and applies NMS (non-maximum suppression) to remove redundant boxes;
Maps detection boxes from the model input coordinate system back to the original image size;
Optionally draws detection results and saves the output image.
Environment Dependencies
This sample has no special environment requirements. Just ensure that the dependencies in pydev are installed.
pip install -r ../../requirements.txt --break-system-packages
Directory Structure
├── ultralytics_yolo11.py # Main inference script
└── README.md # Usage instructions
Parameters
--model-path | Model file path (.hbm format) | /opt/hobot/model/s100/basic/yolo11n_detect_nashe_640x640_nv12.hbm |
--test-img | Input test image path | /app/res/assets/kite.jpg |
--label-file | Class label file path (one class name per line) | /app/res/labels/coco_classes.names |
--img-save-path | Path to save the detection result image | result.jpg |
--priority | Model scheduling priority (0~255; higher values mean higher priority) | 0 |
--bpu-cores | List of BPU core IDs to use (e.g. --bpu-cores 0 1) | [0] |
--nms-thres | IoU threshold for non-maximum suppression (NMS) | 0.45 |
--score-thres | Confidence filter threshold (objects below this value are discarded) | 0.25 |
--model-path | Model file path (.hbm format) | /opt/hobot/model/s600/basic/yolo11n_detect_nashp_640x640_nv12.hbm |
Quick Start
Run the model
With default parameters
python ultralytics_yolo11.py -
Run with specified parameters
python ultralytics_yolo11.py \
--model-path /opt/hobot/model/s100/basic/yolo11n_detect_nashe_640x640_nv12.hbm \
--test-img /app/res/assets/kite.jpg \
--img-save-path result.jpg \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25python ultralytics_yolo11.py \
--model-path /opt/hobot/model/s600/basic/yolo11n_detect_nashp_640x640_nv12.hbm \
--priority 0 \
--bpu-cores 0 \
--nms-thres 0.45 \
--score-thres 0.25
View results
After a successful run, detection boxes are drawn on the original image and saved to the path specified by
--img-save-path.[Saved] Result saved to: result.jpg
Notes
- If the specified model path does not exist, the program will attempt to download the model automatically.
License
