Pinctrl Debugging Guide
Pinctrl Usage
The S100 chip contains 3 sys modules with software-controllable pins. According to user requirements, pins can be configured for function multiplexing, attribute settings, and voltage domain settings.
The S600 chip contains 3 sys modules with software-controllable pins. According to user requirements, pins can be configured for function multiplexing, attribute settings, and voltage domain settings.
Pinmux Function
Pins in the SoC can be set to different functions. Through pinmux configuration, they can be assigned to corresponding functions as needed. Each pin has four multiplexing function options.
Pinconf Function
Pins in the SoC can be set to different states, including the following attributes:
  • Pull-up/pull-down setting
  • Drive strength setting
  • Voltage mode setting
  • Input enable setting
  • Schmitt trigger setting
  • Slew rate selection
io-domain Function
There are two voltage domains in the S100: 1.8v and 3.3v. Different pins need to operate in the appropriate voltage domain. The manual divides pins into power groups, where each power group controls a set of pins.
There are two voltage domains in the S600: 1.8v and 3.3v. Different pins need to operate in the appropriate voltage domain. The manual divides pins into power groups, where each power group controls a set of pins.
Source Code Description
The pinctrl-hobot.c file contains the main pinctrl logic code shared by S100/S600, registers the device with the pinctrl subsystem, and provides the initialization entry for SoC data downstream. The pinctrl-hobot-s100.c file contains the pin, pin group, function definitions, and device matching information for the S100.
/* Path */
hobot-drivers/pinctrl/pinctrl-hobot.c # pinctrl common main logic
hobot-drivers/pinctrl/pinctrl-hobot.h # pinctrl common header
hobot-drivers/pinctrl/pinctrl-hobot-s100.c # S100 driver data code
hobot-drivers/kernel-dts/drobot-s100-pinctrl.dtsi # S100 pinctrl device tree
The pinctrl-hobot.c file contains the main pinctrl logic code shared by S100/S600. The pinctrl-hobot-s600.c file contains the pin, pin group, function definitions, and device matching information for the S600 (compatible = "drobot,s600-pinctrl").
/* Path */
hobot-drivers/pinctrl/pinctrl-hobot-s600.c # S600 driver data code
hobot-drivers/kernel-dts/drobot-s600-pinctrl.dtsi # S600 pinctrl device tree
Pinctrl Driver Usage Guide
Pinmux and Pinconf Configuration
Pinmux and pinconf are typically configured in the device dts, as shown below:
&pinctrl_peri {
pinctrl_test_default: pinctrl_test_default {
/* pinmux configuration, multiplexing peri_i2c5_scl and peri_i2c5_sda pins to peri_i2c5 function */
pinmux {
function = "peri_i2c5";
pins = "peri_i2c5_scl", "peri_i2c5_sda";
/* pinconf configuration, setting drive current, pull-up/pull-down, input enable, voltage mode, slew rate, input Schmitt, and other electrical attributes for peri_i2c5_scl and peri_i2c5_sda pins */
pinconf {
/* two pins */
/* drive current configuration */
drive-strength = <7>;
/* configure as pull-down */
bias-pull-down;
/* disable input */
input-disable;
/* disable low voltage mode */
low-power-disable;
/* set slew rate to 1 */
slew-rate = <1>;
/* disable input Schmitt trigger */
input-schmitt-disable;
pinctrl_test_sleep: pinctrl_test_sleep {
pinmux {
pinconf {
drive-strength = <1>;
bias-pull-up;
input-enable;
low-power-enable;
slew-rate = <0>;
input-schmitt-enable;
Supported Pinconf Attributes and Corresponding Keywords in Device Tree
KeywordAttribute
bias-pull-upPull-up setting
bias-pull-downPull-down setting
bias-disableFloating setting
drive-strengthDrive strength
low-power-disableHigh voltage mode (3.3v)
low-power-enableLow voltage mode (1.8v)
input-disableInput disable
input-enableInput enable
input-schmitt-enableSchmitt trigger enable
input-schmitt-disableSchmitt trigger disable
Voltage Domain Setting
The io-domain setting of pins directly affects the normal operation of module functions. Incorrect voltage domain settings can even damage components and render the circuit board inoperable.
Therefore, based on previous bringup experience, the following practical guidelines for confirming consistency between hardware voltage values and software io-domain settings are provided:
  1. First, the software and hardware owners of each module should align to confirm the applicable io-domain range for the relevant pins in the module, ensuring requirement consistency, and output the reference values section in the "Pin io-domain Setting Manual" (document name is for reference only);
  2. Then, based on the information confirmed in the first step, perform the corresponding io-domain settings in the device tree;
  3. After completing the second step, capture the io-domain values of all pins on the prototype board, fill the obtained values into the actual values section of the "Pin io-domain Setting Manual," and identify any existing gaps;
  4. Since one power group in the S100 controls a set of pins, the setting of one pin may affect others in the same group. Therefore, hold alignment meetings to discuss and fix gaps identified in the third step until the gaps are eliminated.
Pinctrl Node Reference Configuration
The path of the pinctrl device tree file in the S100 acore is: hobot-drivers/kernel-dts/drobot-s100-pinctrl.dtsi.
In the pinctrl node, a group of pins is combined together, and the configuration of each node contains multiple child nodes.
The first child node "pinmux" contains pin multiplexing information, where "function" indicates the multiplexed function of the device pins, and "pins" indicates the pins required for that multiplexed function.
The second child node "pinconf" contains pin configuration information (the pinconf node can be omitted if default values are used), where "pins" indicates the pins to be configured, and "pinconf_*" indicates the configuration content, mainly including drive strength, pull-up/pull-down, voltage mode, etc.
&pinctrl_peri {
pinmux {
pinconf {
bias-pull-down;
input-disable;
low-power-disable;
slew-rate = <1>;
pinmux {
pinconf {
bias-pull-up;
input-enable;
low-power-enable;
slew-rate = <0>;
The path of the pinctrl device tree file in the S600 acore is: hobot-drivers/kernel-dts/drobot-s600-pinctrl.dtsi.
The S600 also uses pinmux and pinconf child nodes for configuration, but the node naming and function naming differ from the S100, typically organized by hsi/cam/peri domains.
&pinctrl_hsi {
hsi_spi3_mosi_spi3_mosi: hsi_spi3_mosi_spi3_mosi_func {
pinmux {
function = "hsi_spi3_mosi_spi3_mosi";
pins = "hsi_spi3_mosi";
pinconf {
Node Reference
Before a driver uses the pinctrl interface, it needs to configure the corresponding pinctrl node in the DTS. During driver probe, the default state is configured to the registers. Other states can be explicitly switched in the code.
pinctrl_test: pinctrl_test {
compatible = "horizon,s100-pinctrl-test";
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pinctrl_test_default>;
pinctrl-1 = <&pinctrl_test_sleep>;
#address-cells = <1>;
#size-cells = <0>;
compatible = "horizon,s600-pinctrl-test";
#size-cells = <0>;
To explicitly switch the pinctrl state, call the pinctrl_select_state interface.
* pinctrl_select_state() - select/activate/program a pinctrl state to HW
* @p: the pinctrl handle for the device that requests configuration
* @state: the state handle to select/activate/program
int pinctrl_select_state(struct pinctrl *p, struct pinctrl_state *state)
Pinctrl debugfs Usage Guide
info
Note: Non-root users need to add "sudo" before the command
Pin Information Query
The S100 and S600 maintain the same directory structure for pinctrl debugfs queries. Queries can be performed directly on the target device through the same nodes under /sys/kernel/debug/pinctrl/. The actual device name (e.g., <pinctrl_dev>) and output content are subject to the results on the device.
/sys/kernel/debug/pinctrl/pinctrl-devices
View which pinctrl devices are present in the system and whether the pinmux and pinconf modules are used.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/pinctrl-devices
name [pinmux] [pinconf]
peri yes yes
cam yes yes
video yes yes
/sys/kernel/debug/pinctrl/pinctrl-handles
View the pin configuration mappings that have been requested.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/pinctrl-handles
Requested pin control handlers their pinmux maps:
device: 39420000.i2c current state: default
state: default
type: MUX_GROUP controller cam group: cam_i2c0_scl (8) function: cam_i2c0 (6)
type: MUX_GROUP controller cam group: cam_i2c0_sda (9) function: cam_i2c0 (6)
type: CONFIGS_GROUP controller cam group cam_i2c0_scl (8)config 00000109
type: CONFIGS_GROUP controller cam group cam_i2c0_sda (9)config 00000109
device: 39430000.i2c current state: default
state: default
type: MUX_GROUP controller cam group: cam_i2c1_scl (10) function: cam_i2c1 (7)
type: MUX_GROUP controller cam group: cam_i2c1_sda (11) function: cam_i2c1 (7)
type: CONFIGS_GROUP controller cam group cam_i2c1_scl (10)config 00000109
type: CONFIGS_GROUP controller cam group cam_i2c1_sda (11)config 00000109
device: 39440000.i2c current state: default
state: default
type: MUX_GROUP controller cam group: cam_i2c2_scl (12) function: cam_i2c2 (8)
type: MUX_GROUP controller cam group: cam_i2c2_sda (13) function: cam_i2c2 (8)
type: CONFIGS_GROUP controller cam group cam_i2c2_scl (12)config 00000109
type: CONFIGS_GROUP controller cam group cam_i2c2_sda (13)config 00000109
device: 39450000.i2c current state: default
state: default
type: MUX_GROUP controller cam group: cam_i2c3_scl (14) function: cam_i2c3 (9)
type: MUX_GROUP controller cam group: cam_i2c3_sda (15) function: cam_i2c3 (9)
type: CONFIGS_GROUP controller cam group cam_i2c3_scl (14)config 00000109
type: CONFIGS_GROUP controller cam group cam_i2c3_sda (15)config 00000109
root@ubuntu:~#
/sys/kernel/debug/pinctrl/pinctrl-maps
View the used pin maps, including the controller for each used pin, which devices are using it, which pinctrl state it is in, which pin group it belongs to, and what function it is multiplexed to.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/pinctrl-maps
Pinctrl maps:
device 39420000.i2c
state default
type MUX_GROUP (2)
controlling device 370f3000.pinctrl
group cam_i2c0_scl
function cam_i2c0
device 39420000.i2c
state default
type MUX_GROUP (2)
group cam_i2c0_sda
function cam_i2c0
device 39420000.i2c
state default
type CONFIGS_GROUP (4)
group cam_i2c0_scl
config 00000109
root@ubuntu:~#
/sys/kernel/debug/pinctrl/<pinctrl_dev>/gpio-ranges
View the mapping between pin numbers in the pinctrl system and pins in the GPIO subsystem. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/gpio-ranges
GPIO ranges handled:
0: 394f0000.gpio GPIOS [480 - 511] PINS [2 - 33]
0: 39500000.gpio GPIOS [474 - 479] PINS [34 - 39]
root@ubuntu:~#
/sys/kernel/debug/pinctrl/<pinctrl_dev>/pinconf-pins
View information for each pin, including the register address and value for pinmux, the register address and value for pinconf, whether voltage conversion is supported, and the voltage value. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/pinconf-pins
Pin config settings per pin
Format: pin (name): configs
pin 0 (UFS_REF_CLK): type 2, pwr 0, funs:(0,20,20,20,), mux(39ff5060: 0), cfg(39ff6010: 31), pwr(39ff5040: 1)
pin 1 (UFS_RSTO): type 2, pwr 0, funs:(0,20,20,20,), mux(39ff5064: 0), cfg(39ff6014: 31), pwr(39ff5040: 1)
pin 2 (EMAC_MDC_HSI0): type 2, pwr 0, funs:(1,2,20,3,), mux(39ff5068: 0), cfg(39ff6018: 31), pwr(39ff5040: 1)
pin 3 (EMAC_MDIO_HSI0): type 3, pwr 0, funs:(1,20,20,3,), mux(39ff506c: 0), cfg(39ff601c: 32), pwr(39ff5040: 1)
pin 4 (SD_CLK): type 0, pwr 1, funs:(4,20,20,3,), mux(39ff5070: 0), cfg(39ff6020: 58), pwr(39ff5040: 1)
pin 5 (SD_CMD): type 0, pwr 1, funs:(4,20,20,3,), mux(39ff5074: 0), cfg(39ff6024: 58), pwr(39ff5040: 1)
pin 6 (SD_DATA0): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5078: 0), cfg(39ff6028: 58), pwr(39ff5040: 1)
pin 7 (SD_DATA1): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff507c: 0), cfg(39ff602c: 58), pwr(39ff5040: 1)
pin 8 (SD_DATA2): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5080: 0), cfg(39ff6030: 58), pwr(39ff5040: 1)
pin 9 (SD_DATA3): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5084: 0), cfg(39ff6034: 58), pwr(39ff5040: 1)
pin 10 (SD_DATA4): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5088: 0), cfg(39ff6038: 58), pwr(39ff5040: 1)
pin 11 (SD_DATA5): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff508c: 0), cfg(39ff603c: 58), pwr(39ff5040: 1)
pin 12 (SD_DATA6): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5090: 0), cfg(39ff6040: 58), pwr(39ff5040: 1)
pin 13 (SD_DATA7): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5094: 0), cfg(39ff6044: 58), pwr(39ff5040: 1)
pin 14 (SD_DATA_STRB): type 4, pwr 1, funs:(4,20,20,3,), mux(39ff5098: 0), cfg(39ff6048: 18), pwr(39ff5040: 1)
pin 15 (SD_DET_N): type 2, pwr 0, funs:(4,5,20,3,), mux(39ff509c: 3), cfg(39ff604c: 50), pwr(39ff5040: 1)
pin 16 (SD_WPROT): type 3, pwr 0, funs:(4,6,20,3,), mux(39ff50a0: 0), cfg(39ff6050: 50), pwr(39ff5040: 1)
pin 17 (I2C5_SCL): type 2, pwr 0, funs:(7,8,20,3,), mux(39ff50a4: 0), cfg(39ff6054: 31), pwr(39ff5040: 1)
pin 18 (I2C5_SDA): type 3, pwr 0, funs:(7,9,20,3,), mux(39ff50a8: 0), cfg(39ff6058: 32), pwr(39ff5040: 1)
pin 19 (SPI0_CSN0): type 2, pwr 0, funs:(10,20,20,3,), mux(39ff50ac: 0), cfg(39ff605c: 31), pwr(39ff5040: 1)
pin 20 (SPI0_CSN1): type 3, pwr 0, funs:(10,11,20,3,), mux(39ff50b0: 0), cfg(39ff6060: 32), pwr(39ff5040: 1)
pin 21 (SPI0_MOSI): type 3, pwr 0, funs:(10,20,20,3,), mux(39ff50b4: 0), cfg(39ff6064: 32), pwr(39ff5040: 1)
pin 22 (SPI0_MISO): type 3, pwr 0, funs:(10,20,20,3,), mux(39ff50b8: 0), cfg(39ff6068: 32), pwr(39ff5040: 1)
pin 23 (SPI0_SCLK): type 2, pwr 0, funs:(10,20,20,3,), mux(39ff50bc: 0), cfg(39ff606c: 31), pwr(39ff5040: 1)
pin 24 (SPI1_CSN0): type 3, pwr 0, funs:(12,20,20,3,), mux(39ff50c0: 0), cfg(39ff6070: 32), pwr(39ff5040: 1)
pin 25 (SPI1_CSN1): type 3, pwr 0, funs:(12,13,20,3,), mux(39ff50c4: 0), cfg(39ff6074: 32), pwr(39ff5040: 1)
pin 26 (SPI1_MOSI): type 3, pwr 0, funs:(12,20,20,3,), mux(39ff50c8: 0), cfg(39ff6078: 32), pwr(39ff5040: 1)
pin 27 (SPI1_MISO): type 3, pwr 0, funs:(12,20,20,3,), mux(39ff50cc: 0), cfg(39ff607c: 32), pwr(39ff5040: 1)
pin 28 (SPI1_SCLK): type 3, pwr 0, funs:(12,20,20,3,), mux(39ff50d0: 0), cfg(39ff6080: 32), pwr(39ff5040: 1)
pin 29 (UART0_TXD): type 3, pwr 0, funs:(14,20,20,3,), mux(39ff50d4: 0), cfg(39ff6084: 32), pwr(39ff5040: 1)
pin 30 (UART0_RXD): type 3, pwr 0, funs:(14,20,20,3,), mux(39ff50d8: 0), cfg(39ff6088: 32), pwr(39ff5040: 1)
pin 31 (UART0_RTSN): type 2, pwr 0, funs:(14,15,20,3,), mux(39ff50dc: 0), cfg(39ff608c: 31), pwr(39ff5040: 1)
pin 32 (UART0_CTSN): type 3, pwr 0, funs:(14,20,20,3,), mux(39ff50e0: 0), cfg(39ff6090: 32), pwr(39ff5040: 1)
pin 33 (UART1_TXD): type 3, pwr 0, funs:(16,17,20,3,), mux(39ff50e4: 0), cfg(39ff6094: 32), pwr(39ff5040: 1)
pin 34 (UART1_RXD): type 3, pwr 0, funs:(16,18,20,3,), mux(39ff50e8: 0), cfg(39ff6098: 32), pwr(39ff5040: 1)
pin 35 (PCM0_MCLK): type 2, pwr 0, funs:(19,20,20,3,), mux(39ff50ec: 3), cfg(39ff609c: 32), pwr(39ff5040: 1)
pin 36 (PCM0_BCLK): type 3, pwr 0, funs:(19,20,20,3,), mux(39ff50f0: 3), cfg(39ff60a0: 32), pwr(39ff5040: 1)
pin 37 (PCM0_FSYNC): type 3, pwr 0, funs:(19,20,20,3,), mux(39ff50f4: 3), cfg(39ff60a4: 32), pwr(39ff5040: 1)
pin 38 (PCM0_DATA0): type 3, pwr 0, funs:(19,20,20,3,), mux(39ff50f8: 3), cfg(39ff60a8: 32), pwr(39ff5040: 1)
pin 39 (PCM0_DATA1): type 2, pwr 0, funs:(19,20,20,3,), mux(39ff50fc: 3), cfg(39ff60ac: 32), pwr(39ff5040: 1)
/sys/kernel/debug/pinctrl/<pinctrl_dev>/pinconf-groups
View the electrical attribute configuration for each pin, such as pull-up/pull-down, input enable, Schmitt trigger, slew rate, etc. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/pinconf-groups
Pin config settings per pin group
Format: group (name): configs
0 (peri_ufs_ref_clk): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
1 (peri_ufs_rsto): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
2 (peri_emac_mdc_hsi0): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
3 (peri_emac_mdio_hsi0): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
4 (peri_sd_clk): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (0 mA), input enabled, input schmitt enabled, pin low power (1 mode), slew rate (0)
5 (peri_sd_cmd): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (0 mA), input enabled, input schmitt enabled, pin low power (1 mode), slew rate (0)
6 (peri_sd_data0): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
7 (peri_sd_data1): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
8 (peri_sd_data2): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
9 (peri_sd_data3): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
10 (peri_sd_data4): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
11 (peri_sd_data5): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
12 (peri_sd_data6): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
13 (peri_sd_data7): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
14 (peri_sd_data_strb): input bias disabled, input bias pull down (0 ohms), input bias pull up (0 ohms), input enabled, pin low power (1 mode)
15 (peri_sd_det_n): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), output drive strength (0 mA), input enabled, input schmitt enabled, slew rate (0)
16 (peri_sd_wprot): input bias disabled, input bias pull down (1 ohms), input bias pull up (0 ohms), input enabled
17 (peri_i2c5_scl): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
18 (peri_i2c5_sda): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
19 (peri_spi0_csn0): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
20 (peri_spi0_csn1): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
21 (peri_spi0_mosi): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
22 (peri_spi0_miso): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
23 (peri_spi0_sclk): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
24 (peri_spi1_csn0): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
25 (peri_spi1_csn1): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
26 (peri_spi1_mosi): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
27 (peri_spi1_miso): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
28 (peri_spi1_sclk): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
29 (peri_uart0_txd): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
30 (peri_uart0_rxd): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
31 (peri_uart0_rtsn): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (1 mA), input enabled, input schmitt enabled, slew rate (0)
32 (peri_uart0_ctsn): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
33 (peri_uart1_txd): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
34 (peri_uart1_rxd): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
35 (peri_pcm0_mclk): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (2 mA), input enabled, input schmitt enabled, slew rate (0)
36 (peri_pcm0_bclk): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
37 (peri_pcm0_fsync): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
38 (peri_pcm0_data0): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), input enabled
39 (peri_pcm0_data1): input bias disabled, input bias pull down (0 ohms), input bias pull up (1 ohms), output drive strength (2 mA), input enabled, input schmitt enabled, slew rate (0)
/sys/kernel/debug/pinctrl/<pinctrl_dev>/pingroups
View the pin configuration within each pin group. In the S100, each pin is a group. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/pingroups
registered pin groups:
group: peri_ufs_ref_clk
pin 0 (UFS_REF_CLK)
group: peri_ufs_rsto
pin 1 (UFS_RSTO)
group: peri_emac_mdc_hsi0
group: peri_emac_mdio_hsi0
group: peri_sd_clk
pin 4 (SD_CLK)
group: peri_sd_cmd
pin 5 (SD_CMD)
group: peri_sd_data0
pin 6 (SD_DATA0)
group: peri_sd_data1
pin 7 (SD_DATA1)
group: peri_sd_data2
pin 8 (SD_DATA2)
group: peri_sd_data3
pin 9 (SD_DATA3)
group: peri_sd_data4
pin 10 (SD_DATA4)
group: peri_sd_data5
pin 11 (SD_DATA5)
group: peri_sd_data6
pin 12 (SD_DATA6)
group: peri_sd_data7
pin 13 (SD_DATA7)
group: peri_sd_data_strb
group: peri_sd_det_n
pin 15 (SD_DET_N)
group: peri_sd_wprot
pin 16 (SD_WPROT)
group: peri_i2c5_scl
pin 17 (I2C5_SCL)
group: peri_i2c5_sda
pin 18 (I2C5_SDA)
group: peri_spi0_csn0
pin 19 (SPI0_CSN0)
group: peri_spi0_csn1
pin 20 (SPI0_CSN1)
group: peri_spi0_mosi
pin 21 (SPI0_MOSI)
group: peri_spi0_miso
pin 22 (SPI0_MISO)
group: peri_spi0_sclk
pin 23 (SPI0_SCLK)
group: peri_spi1_csn0
pin 24 (SPI1_CSN0)
group: peri_spi1_csn1
pin 25 (SPI1_CSN1)
group: peri_spi1_mosi
pin 26 (SPI1_MOSI)
group: peri_spi1_miso
pin 27 (SPI1_MISO)
group: peri_spi1_sclk
pin 28 (SPI1_SCLK)
group: peri_uart0_txd
pin 29 (UART0_TXD)
group: peri_uart0_rxd
pin 30 (UART0_RXD)
group: peri_uart0_rtsn
pin 31 (UART0_RTSN)
group: peri_uart0_ctsn
pin 32 (UART0_CTSN)
group: peri_uart1_txd
pin 33 (UART1_TXD)
group: peri_uart1_rxd
pin 34 (UART1_RXD)
group: peri_pcm0_mclk
pin 35 (PCM0_MCLK)
group: peri_pcm0_bclk
pin 36 (PCM0_BCLK)
group: peri_pcm0_fsync
pin 37 (PCM0_FSYNC)
group: peri_pcm0_data0
pin 38 (PCM0_DATA0)
group: peri_pcm0_data1
pin 39 (PCM0_DATA1)
root@ubuntu:~#
/sys/kernel/debug/pinctrl/<pinctrl_dev>/pinmux-functions
Pins are grouped by function. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/pinmux-functions
function 0: peri_ufs, groups = [ peri_ufs_ref_clk peri_ufs_rsto ]
function 1: peri_emac, groups = [ peri_emac_mdc_hsi0 peri_emac_mdio_hsi0 ]
function 2: peri_clkout, groups = [ peri_emac_mdc_hsi0 ]
function 3: peri_gpio, groups = [ peri_emac_mdc_hsi0 peri_emac_mdio_hsi0 peri_sd_clk peri_sd_cmd peri_sd_data0 peri_sd_data1 peri_sd_data2 peri_sd_data3 peri_sd_data4 peri_sd_data5 peri_sd_data6 peri_sd_data7 peri_sd_data_strb peri_sd_det_n peri_sd_wprot peri_i2c5_scl peri_i2c5_sda peri_spi0_csn0 peri_spi0_csn1 peri_spi0_mosi peri_spi0_miso peri_spi0_sclk peri_spi1_csn0 peri_spi1_csn1 peri_spi1_mosi peri_spi1_miso peri_spi1_sclk peri_uart0_txd peri_uart0_rxd peri_uart0_rtsn peri_uart0_ctsn peri_uart1_txd peri_uart1_rxd peri_pcm0_mclk peri_pcm0_bclk peri_pcm0_fsync peri_pcm0_data0 peri_pcm0_data1 ]
function 4: peri_sd, groups = [ peri_sd_clk peri_sd_cmd peri_sd_data0 peri_sd_data1 peri_sd_data2 peri_sd_data3 peri_sd_data4 peri_sd_data5 peri_sd_data6 peri_sd_data7 peri_sd_data_strb peri_sd_det_n peri_sd_wprot ]
function 5: peri_pcm1_bclk, groups = [ peri_sd_det_n ]
function 6: peri_pcm1_fsync, groups = [ peri_sd_wprot ]
function 7: peri_i2c5, groups = [ peri_i2c5_scl peri_i2c5_sda ]
function 8: peri_uart2_rxd, groups = [ peri_i2c5_scl ]
function 9: peri_uart2_txd, groups = [ peri_i2c5_sda ]
function 10: peri_spi0, groups = [ peri_spi0_csn0 peri_spi0_csn1 peri_spi0_mosi peri_spi0_miso peri_spi0_sclk ]
function 11: peri_uart3_rxd, groups = [ peri_spi0_csn1 ]
function 12: peri_spi1, groups = [ peri_spi1_csn0 peri_spi1_csn1 peri_spi1_mosi peri_spi1_miso peri_spi1_sclk ]
function 13: peri_uart3_txd, groups = [ peri_spi1_csn1 ]
function 14: peri_uart0, groups = [ peri_uart0_txd peri_uart0_rxd peri_uart0_rtsn peri_uart0_ctsn ]
function 15: peri_pcm1_mclk, groups = [ peri_uart0_rtsn ]
function 16: peri_uart1, groups = [ peri_uart1_txd peri_uart1_rxd ]
function 17: peri_pcm1_data1, groups = [ peri_uart1_txd ]
function 18: peri_pcm1_data0, groups = [ peri_uart1_rxd ]
function 19: peri_pcm0, groups = [ peri_pcm0_mclk peri_pcm0_bclk peri_pcm0_fsync peri_pcm0_data0 peri_pcm0_data1 ]
root@ubuntu:~#
/sys/kernel/debug/pinctrl/<pinctrl_dev>/pinmux-pins
View which pins are occupied, whether by MUX or GPIO. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/pinmux-pins
Pinmux settings per pin
Format: pin (name): mux_owner gpio_owner hog?
pin 0 (UFS_REF_CLK): 39410000.ufs (GPIO UNCLAIMED) function peri_ufs group peri_ufs_ref_clk
pin 1 (UFS_RSTO): 39410000.ufs (GPIO UNCLAIMED) function peri_ufs group peri_ufs_rsto
pin 2 (EMAC_MDC_HSI0): 330f0000.ethernet (GPIO UNCLAIMED) function peri_emac group peri_emac_mdc_hsi0
pin 3 (EMAC_MDIO_HSI0): 330f0000.ethernet (GPIO UNCLAIMED) function peri_emac group peri_emac_mdio_hsi0
pin 4 (SD_CLK): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 5 (SD_CMD): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 6 (SD_DATA0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 7 (SD_DATA1): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 8 (SD_DATA2): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 9 (SD_DATA3): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 10 (SD_DATA4): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 11 (SD_DATA5): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 12 (SD_DATA6): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 13 (SD_DATA7): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 14 (SD_DATA_STRB): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 15 (SD_DET_N): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 16 (SD_WPROT): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 17 (I2C5_SCL): 39470000.i2c (GPIO UNCLAIMED) function peri_i2c5 group peri_i2c5_scl
pin 18 (I2C5_SDA): 39470000.i2c (GPIO UNCLAIMED) function peri_i2c5 group peri_i2c5_sda
pin 19 (SPI0_CSN0): 39800000.spi (GPIO UNCLAIMED) function peri_spi0 group peri_spi0_csn0
pin 20 (SPI0_CSN1): 39800000.spi (GPIO UNCLAIMED) function peri_spi0 group peri_spi0_csn1
pin 21 (SPI0_MOSI): 39800000.spi (GPIO UNCLAIMED) function peri_spi0 group peri_spi0_mosi
pin 22 (SPI0_MISO): 39800000.spi (GPIO UNCLAIMED) function peri_spi0 group peri_spi0_miso
pin 23 (SPI0_SCLK): 39800000.spi (GPIO UNCLAIMED) function peri_spi0 group peri_spi0_sclk
pin 24 (SPI1_CSN0): 39810000.spi (GPIO UNCLAIMED) function peri_spi1 group peri_spi1_csn0
pin 25 (SPI1_CSN1): 39810000.spi 394f0000.gpio:503 function peri_spi1 group peri_spi1_csn1
pin 26 (SPI1_MOSI): 39810000.spi (GPIO UNCLAIMED) function peri_spi1 group peri_spi1_mosi
pin 27 (SPI1_MISO): 39810000.spi (GPIO UNCLAIMED) function peri_spi1 group peri_spi1_miso
pin 28 (SPI1_SCLK): 39810000.spi (GPIO UNCLAIMED) function peri_spi1 group peri_spi1_sclk
pin 29 (UART0_TXD): 394a0000.uart (GPIO UNCLAIMED) function peri_uart0 group peri_uart0_txd
pin 30 (UART0_RXD): 394a0000.uart (GPIO UNCLAIMED) function peri_uart0 group peri_uart0_rxd
pin 31 (UART0_RTSN): 394a0000.uart (GPIO UNCLAIMED) function peri_uart0 group peri_uart0_rtsn
pin 32 (UART0_CTSN): 394a0000.uart (GPIO UNCLAIMED) function peri_uart0 group peri_uart0_ctsn
pin 33 (UART1_TXD): 394b0000.uart0 (GPIO UNCLAIMED) function peri_uart1 group peri_uart1_txd
pin 34 (UART1_RXD): 394b0000.uart0 (GPIO UNCLAIMED) function peri_uart1 group peri_uart1_rxd
pin 35 (PCM0_MCLK): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 36 (PCM0_BCLK): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 37 (PCM0_FSYNC): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 38 (PCM0_DATA0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 39 (PCM0_DATA1): (MUX UNCLAIMED) (GPIO UNCLAIMED)
/sys/kernel/debug/<pinctrl_dev>/pinmux-select
You can query the group and function for each pin through the pinmux-functions node, and set the pinmux through the pinmux-select node with parameters group name and func name. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
cd /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/
echo "peri_spi0_csn0 peri_gpio" > pinmux-select
echo "peri_i2c5_scl peri_i2c5" > pinmux-select
echo "peri_i2c5_sda peri_i2c5" > pinmux-select
/sys/kernel/debug/<pinctrl_dev>/pins
View information for each pin, including the pin name and the corresponding GPIO pin. The following command uses <pinctrl_dev> as 39ff5000.pinctrl-peri as an example.
root@ubuntu:~# cat /sys/kernel/debug/pinctrl/39ff5000.pinctrl-peri/pins
registered pins: 40
pin 0 (UFS_REF_CLK) 0:?
pin 1 (UFS_RSTO) 0:?
pin 2 (EMAC_MDC_HSI0) 0:394f0000.gpio
pin 3 (EMAC_MDIO_HSI0) 1:394f0000.gpio
pin 4 (SD_CLK) 2:394f0000.gpio
pin 5 (SD_CMD) 3:394f0000.gpio
pin 6 (SD_DATA0) 4:394f0000.gpio
pin 7 (SD_DATA1) 5:394f0000.gpio
pin 8 (SD_DATA2) 6:394f0000.gpio
pin 9 (SD_DATA3) 7:394f0000.gpio
pin 10 (SD_DATA4) 8:394f0000.gpio
pin 11 (SD_DATA5) 9:394f0000.gpio
pin 12 (SD_DATA6) 10:394f0000.gpio
pin 13 (SD_DATA7) 11:394f0000.gpio
pin 14 (SD_DATA_STRB) 12:394f0000.gpio
pin 15 (SD_DET_N) 13:394f0000.gpio
pin 16 (SD_WPROT) 14:394f0000.gpio
pin 17 (I2C5_SCL) 15:394f0000.gpio
pin 18 (I2C5_SDA) 16:394f0000.gpio
pin 19 (SPI0_CSN0) 17:394f0000.gpio
pin 20 (SPI0_CSN1) 18:394f0000.gpio
pin 21 (SPI0_MOSI) 19:394f0000.gpio
pin 22 (SPI0_MISO) 20:394f0000.gpio
pin 23 (SPI0_SCLK) 21:394f0000.gpio
pin 24 (SPI1_CSN0) 22:394f0000.gpio
pin 25 (SPI1_CSN1) 23:394f0000.gpio
pin 26 (SPI1_MOSI) 24:394f0000.gpio
pin 27 (SPI1_MISO) 25:394f0000.gpio
pin 28 (SPI1_SCLK) 26:394f0000.gpio
pin 29 (UART0_TXD) 27:394f0000.gpio
pin 30 (UART0_RXD) 28:394f0000.gpio
pin 31 (UART0_RTSN) 29:394f0000.gpio
pin 32 (UART0_CTSN) 30:394f0000.gpio
pin 33 (UART1_TXD) 31:394f0000.gpio
pin 34 (UART1_RXD) 0:39500000.gpio
pin 35 (PCM0_MCLK) 1:39500000.gpio
pin 36 (PCM0_BCLK) 2:39500000.gpio
pin 37 (PCM0_FSYNC) 3:39500000.gpio
pin 38 (PCM0_DATA0) 4:39500000.gpio
pin 39 (PCM0_DATA1) 5:39500000.gpio
root@ubuntu:~#
